root/radiance/ray/src/rt/pmapio.c
Thu Aug 2 18:33:49 2018 UTC (6 years, 9 months ago) by greg
CVS Tags: rad5R2, rad5R3
Thu Feb 8 19:55:02 2018 UTC (7 years, 3 months ago) by rschregle
Changes since 2.10: +6 -3 lines
Made photon primary incident dirs optional via PMAP_PRIMARYDIR, bumped PMAP_FILEVER
Mon Aug 14 21:12:10 2017 UTC (7 years, 9 months ago) by rschregle
Changes since 2.9: +5 -5 lines
Updated photon map code for Windows; no multproc or ooC for now
Tue May 17 17:39:47 2016 UTC (9 years ago) by rschregle
Changes since 2.8: +73 -106 lines
Tue Oct 20 15:51:54 2015 UTC (9 years, 7 months ago) by rschregle
Fixed format string check during photon map load
Tue Sep 1 16:27:52 2015 UTC (9 years, 8 months ago) by greg
Changes since 2.6: +1 -2 lines
Tue Aug 18 18:45:55 2015 UTC (9 years, 9 months ago) by greg
Fri May 22 14:09:01 2015 UTC (10 years ago) by greg
Changes since 2.4: +4 -4 lines
Removed redundant photon map type parameter
Wed May 20 14:44:12 2015 UTC (10 years ago) by greg
Changes since 2.3: +3 -5 lines
Reduced primary photon struct size using encoded direction
Wed May 20 12:58:31 2015 UTC (10 years ago) by greg
Added appropriate setting of ray parameters for bin rcontrib evaluation
Fri May 8 13:20:23 2015 UTC (10 years ago) by rschregle
Tue Feb 24 19:39:27 2015 UTC (10 years, 3 months ago) by greg
