root/radiance/ray/src/rt/pmapdump.c
Revision: 2.3
Committed: Fri May 8 13:20:23 2015 UTC (10 years, 1 month ago) by rschregle
Changes since 2.2: +5 -4 lines
1 /*
2 ==================================================================
3 Dump photon maps as RADIANCE scene description to stdout
4
5 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
6 (c) Fraunhofer Institute for Solar Energy Systems,
7 (c) Lucerne University of Applied Sciences and Arts,
8 supported by the Swiss National Science Foundation (SNSF, #147053)
9 ==================================================================
10
11 $Id: pmapdump.c,v 2.2 2015/04/21 19:16:51 greg Exp $
12 */
13
14
15
16 #include "pmapio.h"
17 #include "pmapparm.h"
18 #include "pmaptype.h"
19 #include "rtio.h"
20 #include "resolu.h"
21 #include "random.h"
22 #include "math.h"
23
24
25 /* Defaults */
26 /* Sphere radius as fraction of avg. intersphere dist */
27 /* Relative scale for sphere radius (fudge factor) */
28 /* Number of spheres */
29 #define RADCOEFF 0.05
30 #define RADSCALE 1.0
31 #define NSPHERES 10000
32
33
34 /* RADIANCE material and object defs for each photon type */
35 typedef struct {
36 char *mat, *obj;
37 } RadianceDef;
38
39
40 static char header [] = "$Revision: 2.2 $";
41
42
43 /* Colour code is as follows: global = blue
44 precomp global = cyan
45 caustic = red
46 volume = green
47 direct = magenta
48 contrib = yellow */
49 const RadianceDef radDefs [] = {
50 { "void plastic mat.global\n0\n0\n5 0 0 1 0 0\n",
51 "mat.global sphere obj.global\n0\n0\n4 %g %g %g %g\n"
52 },
53 { "void plastic mat.pglobal\n0\n0\n5 0 1 1 0 0\n",
54 "mat.pglobal sphere obj.global\n0\n0\n4 %g %g %g %g\n"
55 },
56 { "void plastic mat.caustic\n0\n0\n5 1 0 0 0 0\n",
57 "mat.caustic sphere obj.caustic\n0\n0\n4 %g %g %g %g\n"
58 },
59 { "void plastic mat.volume\n0\n0\n5 0 1 0 0 0\n",
60 "mat.volume sphere obj.volume\n0\n0\n4 %g %g %g %g\n"
61 },
62 { "void plastic mat.direct\n0\n0\n5 1 0 1 0 0\n",
63 "mat.direct sphere obj.direct\n0\n0\n4 %g %g %g %g\n"
64 },
65 { "void plastic mat.contrib\n0\n0\n5 1 1 0 0 0\n",
66 "mat.contrib sphere obj.contrib\n0\n0\n4 %g %g %g %g\n"
67 }
68 };
69
70
71
72 int main (int argc, char** argv)
73 {
74 char format [128];
75 RREAL rad, radScale = RADSCALE, vol, dumpRatio;
76 FVECT minPos, maxPos;
77 unsigned arg, j, ptype;
78 long numPhotons, numSpheres = NSPHERES;
79 FILE *pmapFile;
80 Photon p;
81
82 if (argc < 2) {
83 puts("Dump photon maps as RADIANCE scene description\n");
84 printf("Usage: %s [-r radscale1] [-n nspheres1] pmap1 "
85 "[-r radscale2] [-n nspheres2] pmap2 ...\n", argv [0]);
86 return 1;
87 }
88
89 for (arg = 1; arg < argc; arg++) {
90 /* Parse options */
91 if (argv [arg][0] == '-') {
92 switch (argv [arg][1]) {
93 case 'r':
94 if ((radScale = atof(argv [++arg])) <= 0)
95 error(USER, "invalid radius scale");
96 break;
97
98 case 'n':
99 if ((numSpheres = parseMultiplier(argv [++arg])) <= 0)
100 error(USER, "invalid number of spheres");
101 break;
102
103 default:
104 sprintf(errmsg, "unknown option %s", argv [arg]);
105 error(USER, errmsg);
106 return -1;
107 }
108
109 continue;
110 }
111
112 /* Dump photon map */
113 if (!(pmapFile = fopen(argv [arg], "rb"))) {
114 sprintf(errmsg, "can't open %s", argv [arg]);
115 error(SYSTEM, errmsg);
116 }
117
118 /* Get format string */
119 strcpy(format, PMAP_FORMAT_GLOB);
120 if (checkheader(pmapFile, format, NULL) != 1) {
121 sprintf(errmsg, "photon map file %s has unknown format %s",
122 argv [arg], format);
123 error(USER, errmsg);
124 }
125
126 /* Identify photon map type from format string */
127 for (ptype = 0;
128 strcmp(pmapFormat [ptype], format) && ptype < NUM_PMAP_TYPES;
129 ptype++);
130
131 if (!validPmapType(ptype)) {
132 sprintf(errmsg, "file %s contains an unknown photon map type",
133 argv [arg]);
134 error(USER, errmsg);
135 }
136
137 /* Get file format version and check for compatibility */
138 if (getint(sizeof(PMAP_FILEVER), pmapFile) != PMAP_FILEVER)
139 error(USER, "incompatible photon map file format");
140
141 /* Dump command line as comment */
142 fputs("# ", stdout);
143 printargs(argc, argv, stdout);
144 fputc('\n', stdout);
145
146 /* Dump material def */
147 fputs(radDefs [ptype].mat, stdout);
148 fputc('\n', stdout);
149
150 /* Get number of photons (is this sizeof() hack portable?) */
151 numPhotons = getint(sizeof(((PhotonMap*)NULL) -> heapSize), pmapFile);
152
153 /* Skip avg photon flux */
154 for (j = 0; j < 3; j++)
155 getflt(pmapFile);
156
157 /* Get distribution extent (min & max photon positions) */
158 for (j = 0; j < 3; j++) {
159 minPos [j] = getflt(pmapFile);
160 maxPos [j] = getflt(pmapFile);
161 }
162
163 /* Skip centre of gravity, and avg photon dist to it */
164 for (j = 0; j < 4; j++)
165 getflt(pmapFile);
166
167 /* Sphere radius based on avg intersphere dist
168 (= sphere distrib density ^-1/3) */
169 vol = (maxPos [0] - minPos [0]) * (maxPos [1] - minPos [1]) *
170 (maxPos [2] - minPos [2]);
171 rad = radScale * RADCOEFF * pow(vol / numSpheres, 1./3.);
172
173 /* Photon dump probability to satisfy target sphere count */
174 dumpRatio = numSpheres < numPhotons ? (float)numSpheres / numPhotons
175 : 1;
176
177 while (numPhotons-- > 0) {
178 /* Get photon position */
179 for (j = 0; j < 3; j++)
180 p.pos [j] = getflt(pmapFile);
181
182 /* Dump photon probabilistically acc. to target sphere count */
183 if (frandom() <= dumpRatio) {
184 printf(radDefs [ptype].obj, p.pos [0], p.pos [1], p.pos [2], rad);
185 fputc('\n', stdout);
186 }
187
188 /* Skip photon normal and flux */
189 for (j = 0; j < 3; j++)
190 getint(sizeof(p.norm [j]), pmapFile);
191
192 #ifdef PMAP_FLOAT_FLUX
193 for (j = 0; j < 3; j++)
194 getflt(pmapFile);
195 #else
196 for (j = 0; j < 4; j++)
197 getint(1, pmapFile);
198 #endif
199
200 /* Skip primary ray index */
201 getint(sizeof(p.primary), pmapFile);
202
203 /* Skip flags */
204 getint(sizeof(p.flags), pmapFile);
205
206 if (feof(pmapFile)) {
207 sprintf(errmsg, "error reading %s", argv [arg]);
208 error(USER, errmsg);
209 }
210 }
211
212 fclose(pmapFile);
213
214 /* Reset defaults for next dump */
215 radScale = RADSCALE;
216 numSpheres = NSPHERES;
217 }
218
219 return 0;
220 }
