root/radiance/ray/src/rt/pmapdump.c
Revision: 2.2
Committed: Tue Apr 21 19:16:51 2015 UTC (10 years ago) by greg
Changes since 2.1: +4 -3 lines
Fixes for Windows and photon map
1 /*
2 ===============================================================
3 Dump photon maps as RADIANCE scene description to stdout
4
5 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
6 (c) Fraunhofer Institute for Solar Energy Systems,
7 Lucerne University of Applied Sciences & Arts
8 ==================================================================
9
10 $Id: pmapdump.c,v 4.13 2015/04/21 09:29:28 taschreg Exp taschreg $
11 */
12
13
14
15 #include "pmapio.h"
16 #include "pmapparm.h"
17 #include "pmaptype.h"
18 #include "rtio.h"
19 #include "resolu.h"
20 #include "random.h"
21 #include "math.h"
22
23
24 /* Defaults */
25 /* Sphere radius as fraction of avg. intersphere dist */
26 /* Relative scale for sphere radius (fudge factor) */
27 /* Number of spheres */
28 #define RADCOEFF 0.05
29 #define RADSCALE 1.0
30 #define NSPHERES 10000
31
32
33 /* RADIANCE material and object defs for each photon type */
34 typedef struct {
35 char *mat, *obj;
36 } RadianceDef;
37
38
39 static char header [] = "$Revision: 4.13 $";
40
41
42 /* Colour code is as follows: global = blue
43 precomp global = cyan
44 caustic = red
45 volume = green
46 direct = magenta
47 contrib = yellow */
48 const RadianceDef radDefs [] = {
49 { "void plastic mat.global\n0\n0\n5 0 0 1 0 0\n",
50 "mat.global sphere obj.global\n0\n0\n4 %g %g %g %g\n"
51 },
52 { "void plastic mat.pglobal\n0\n0\n5 0 1 1 0 0\n",
53 "mat.pglobal sphere obj.global\n0\n0\n4 %g %g %g %g\n"
54 },
55 { "void plastic mat.caustic\n0\n0\n5 1 0 0 0 0\n",
56 "mat.caustic sphere obj.caustic\n0\n0\n4 %g %g %g %g\n"
57 },
58 { "void plastic mat.volume\n0\n0\n5 0 1 0 0 0\n",
59 "mat.volume sphere obj.volume\n0\n0\n4 %g %g %g %g\n"
60 },
61 { "void plastic mat.direct\n0\n0\n5 1 0 1 0 0\n",
62 "mat.direct sphere obj.direct\n0\n0\n4 %g %g %g %g\n"
63 },
64 { "void plastic mat.contrib\n0\n0\n5 1 1 0 0 0\n",
65 "mat.contrib sphere obj.contrib\n0\n0\n4 %g %g %g %g\n"
66 }
67 };
68
69
70
71 int main (int argc, char** argv)
72 {
73 char format [128];
74 RREAL rad, radScale = RADSCALE, vol, dumpRatio;
75 FVECT minPos, maxPos;
76 unsigned arg, j, ptype;
77 long numPhotons, numSpheres = NSPHERES;
78 FILE *pmapFile;
79 Photon p;
80
81 if (argc < 2) {
82 puts("Dump photon maps as RADIANCE scene description\n");
83 printf("Usage: %s [-r radscale1] [-n nspheres1] pmap1 "
84 "[-r radscale2] [-n nspheres2] pmap2 ...\n", argv [0]);
85 return 1;
86 }
87
88 for (arg = 1; arg < argc; arg++) {
89 /* Parse options */
90 if (argv [arg][0] == '-') {
91 switch (argv [arg][1]) {
92 case 'r':
93 if ((radScale = atof(argv [++arg])) <= 0)
94 error(USER, "invalid radius scale");
95 break;
96
97 case 'n':
98 if ((numSpheres = parseMultiplier(argv [++arg])) <= 0)
99 error(USER, "invalid number of spheres");
100 break;
101
102 default:
103 sprintf(errmsg, "unknown option %s", argv [arg]);
104 error(USER, errmsg);
105 return -1;
106 }
107
108 continue;
109 }
110
111 /* Dump photon map */
112 if (!(pmapFile = fopen(argv [arg], "rb"))) {
113 sprintf(errmsg, "can't open %s", argv [arg]);
114 error(SYSTEM, errmsg);
115 }
116
117 /* Get format string */
118 strcpy(format, PMAP_FORMAT_GLOB);
119 if (checkheader(pmapFile, format, NULL) != 1) {
120 sprintf(errmsg, "photon map file %s has unknown format %s",
121 argv [arg], format);
122 error(USER, errmsg);
123 }
124
125 /* Identify photon map type from format string */
126 for (ptype = 0;
127 strcmp(pmapFormat [ptype], format) && ptype < NUM_PMAP_TYPES;
128 ptype++);
129
130 if (!validPmapType(ptype)) {
131 sprintf(errmsg, "file %s contains an unknown photon map type",
132 argv [arg]);
133 error(USER, errmsg);
134 }
135
136 /* Get file format version and check for compatibility */
137 if (getint(sizeof(PMAP_FILEVER), pmapFile) != PMAP_FILEVER)
138 error(USER, "incompatible photon map file format");
139
140 /* Dump command line as comment */
141 fputs("# ", stdout);
142 printargs(argc, argv, stdout);
143 fputc('\n', stdout);
144
145 /* Dump material def */
146 fputs(radDefs [ptype].mat, stdout);
147 fputc('\n', stdout);
148
149 /* Get number of photons (is this sizeof() hack portable?) */
150 numPhotons = getint(sizeof(((PhotonMap*)NULL) -> heapSize), pmapFile);
151
152 /* Skip avg photon flux */
153 for (j = 0; j < 3; j++)
154 getflt(pmapFile);
155
156 /* Get distribution extent (min & max photon positions) */
157 for (j = 0; j < 3; j++) {
158 minPos [j] = getflt(pmapFile);
159 maxPos [j] = getflt(pmapFile);
160 }
161
162 /* Skip centre of gravity, and avg photon dist to it */
163 for (j = 0; j < 4; j++)
164 getflt(pmapFile);
165
166 /* Sphere radius based on avg intersphere dist
167 (= sphere distrib density ^-1/3) */
168 vol = (maxPos [0] - minPos [0]) * (maxPos [1] - minPos [1]) *
169 (maxPos [2] - minPos [2]);
170 rad = radScale * RADCOEFF * pow(vol / numSpheres, 1./3.);
171
172 /* Photon dump probability to satisfy target sphere count */
173 dumpRatio = numSpheres < numPhotons ? (float)numSpheres / numPhotons
174 : 1;
175
176 while (numPhotons-- > 0) {
177 /* Get photon position */
178 for (j = 0; j < 3; j++)
179 p.pos [j] = getflt(pmapFile);
180
181 /* Dump photon probabilistically acc. to target sphere count */
182 if (frandom() <= dumpRatio) {
183 printf(radDefs [ptype].obj, p.pos [0], p.pos [1], p.pos [2], rad);
184 fputc('\n', stdout);
185 }
186
187 /* Skip photon normal and flux */
188 for (j = 0; j < 3; j++)
189 getint(sizeof(p.norm [j]), pmapFile);
190
191 #ifdef PMAP_FLOAT_FLUX
192 for (j = 0; j < 3; j++)
193 getflt(pmapFile);
194 #else
195 for (j = 0; j < 4; j++)
196 getint(1, pmapFile);
197 #endif
198
199 /* Skip primary ray index */
200 getint(sizeof(p.primary), pmapFile);
201
202 /* Skip flags */
203 getint(sizeof(p.flags), pmapFile);
204
205 if (feof(pmapFile)) {
206 sprintf(errmsg, "error reading %s", argv [arg]);
207 error(USER, errmsg);
208 }
209 }
210
211 fclose(pmapFile);
212
213 /* Reset defaults for next dump */
214 radScale = RADSCALE;
215 numSpheres = NSPHERES;
216 }
217
218 return 0;
219 }
