1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: pmapdump.c,v 2.14 2019/01/22 18:28:23 rschregle Exp $"; |
3 |
#endif |
4 |
5 |
6 |
7 |
Dump photon maps as RADIANCE scene description or ASCII point list |
8 |
to stdout |
9 |
10 |
Roland Schregle (roland.schregle@{hslu.ch, gmail.com}) |
11 |
(c) Fraunhofer Institute for Solar Energy Systems, |
12 |
(c) Lucerne University of Applied Sciences and Arts, |
13 |
supported by the Swiss National Science Foundation (SNSF, #147053) |
14 |
15 |
16 |
$Id: pmapdump.c,v 2.14 2019/01/22 18:28:23 rschregle Exp $ |
17 |
18 |
19 |
20 |
21 |
#include "pmap.h" |
22 |
#include "pmapio.h" |
23 |
#include "rtio.h" |
24 |
#include "resolu.h" |
25 |
#include "random.h" |
26 |
#include "math.h" |
27 |
28 |
29 |
/* Defaults */ |
30 |
/* Sphere radius as fraction of avg. intersphere dist */ |
31 |
/* Relative scale for sphere radius (fudge factor) */ |
32 |
/* Number of spheres */ |
33 |
#define RADCOEFF 0.05 |
34 |
#define RADSCALE 1.0 |
35 |
#define NSPHERES 10000 |
36 |
37 |
/* Format for optional ASCII output as XYZ RGB points */ |
38 |
#define POINTFMT "%g\t%g\t%g\t%g\t%g\t%g\n" |
39 |
40 |
/* RADIANCE material and object defs for each photon type */ |
41 |
typedef struct { |
42 |
char *mat, *obj; |
43 |
} RadianceDef; |
44 |
45 |
const RadianceDef radDefs [] = { |
46 |
{ "void glow mat.global\n0\n0\n4 %g %g %g 0\n", |
47 |
"mat.global sphere obj.global\n0\n0\n4 %g %g %g %g\n" |
48 |
49 |
{ "void glow mat.pglobal\n0\n0\n4 %g %g %g 0\n", |
50 |
"mat.pglobal sphere obj.pglobal\n0\n0\n4 %g %g %g %g\n" |
51 |
52 |
{ "void glow mat.caustic\n0\n0\n4 %g %g %g 0\n", |
53 |
"mat.caustic sphere obj.caustic\n0\n0\n4 %g %g %g %g\n" |
54 |
55 |
{ "void glow mat.volume\n0\n0\n4 %g %g %g 0\n", |
56 |
"mat.volume sphere obj.volume\n0\n0\n4 %g %g %g %g\n" |
57 |
58 |
{ "void glow mat.direct\n0\n0\n4 %g %g %g 0\n", |
59 |
"mat.direct sphere obj.direct\n0\n0\n4 %g %g %g %g\n" |
60 |
61 |
{ "void glow mat.contrib\n0\n0\n4 %g %g %g 0\n", |
62 |
"mat.contrib sphere obj.contrib\n0\n0\n4 %g %g %g %g\n" |
63 |
64 |
65 |
66 |
67 |
/* Default colour codes are as follows: global = blue |
68 |
precomp global = cyan |
69 |
caustic = red |
70 |
volume = green |
71 |
direct = magenta |
72 |
contrib = yellow */ |
73 |
const COLOR colDefs [] = { |
74 |
{0.25, 0.25, 2}, {0.1, 1, 1}, {1, 0.1, 0.1}, |
75 |
{0.1, 1, 0.1}, {1, 0.1, 1}, {1, 1, 0.1} |
76 |
77 |
78 |
79 |
static int setBool(char *str, unsigned pos, unsigned *var) |
80 |
81 |
switch ((str) [pos]) { |
82 |
case '\0': |
83 |
*var = !*var; |
84 |
break; |
85 |
case 'y': case 'Y': case 't': case 'T': case '+': case '1': |
86 |
*var = 1; |
87 |
break; |
88 |
case 'n': case 'N': case 'f': case 'F': case '-': case '0': |
89 |
*var = 0; |
90 |
break; |
91 |
default: |
92 |
return 0; |
93 |
94 |
95 |
return 1; |
96 |
97 |
98 |
99 |
int main (int argc, char** argv) |
100 |
101 |
char format [MAXFMTLEN]; |
102 |
RREAL rad, radScale = RADSCALE, extent, dumpRatio; |
103 |
unsigned arg, j, ptype, dim, fluxCol = 0, points = 0; |
104 |
long numSpheres = NSPHERES; |
105 |
COLOR col = {0, 0, 0}; |
106 |
FILE *pmapFile; |
107 |
PhotonMap pm; |
108 |
PhotonPrimary pri; |
109 |
Photon p; |
110 |
#ifdef PMAP_OOC |
111 |
char leafFname [1024]; |
112 |
#endif |
113 |
114 |
if (argc < 2) { |
115 |
puts("Dump photon maps as RADIANCE scene description " |
116 |
"or ASCII point list\n"); |
117 |
printf("Usage: %s " |
118 |
"[-a] [-r radscale1] [-n num1] " |
119 |
"[-f | -c rcol1 gcol1 bcol1] pmap1 " |
120 |
"[-a] [-r radscale2] [-n num2] " |
121 |
"[-f | -c rcol2 gcol2 bcol2] pmap2 " |
122 |
"...\n", argv [0]); |
123 |
return 1; |
124 |
125 |
126 |
for (arg = 1; arg < argc; arg++) { |
127 |
/* Parse options */ |
128 |
if (argv [arg][0] == '-') { |
129 |
switch (argv [arg][1]) { |
130 |
case 'a': |
131 |
if (!setBool(argv [arg], 2, &points)) |
132 |
error(USER, "invalid option syntax at -a"); |
133 |
break; |
134 |
case 'r': |
135 |
if ((radScale = atof(argv [++arg])) <= 0) |
136 |
error(USER, "invalid radius scale"); |
137 |
break; |
138 |
139 |
case 'n': |
140 |
if ((numSpheres = parseMultiplier(argv [++arg])) <= 0) |
141 |
error(USER, "invalid number of points/spheres"); |
142 |
break; |
143 |
144 |
case 'c': |
145 |
if (fluxCol) |
146 |
error(USER, "-f and -c are mutually exclusive"); |
147 |
148 |
if (badarg(argc - arg - 1, &argv [arg + 1], "fff")) |
149 |
error(USER, "invalid RGB colour"); |
150 |
151 |
for (j = 0; j < 3; j++) |
152 |
col [j] = atof(argv [++arg]); |
153 |
break; |
154 |
155 |
case 'f': |
156 |
if (intens(col) > 0) |
157 |
158 |
159 |
if (!setBool(argv [arg], 2, &fluxCol)) |
160 |
error(USER, "invalid option syntax at -f"); |
161 |
break; |
162 |
163 |
default: |
164 |
sprintf(errmsg, "unknown option %s", argv [arg]); |
165 |
error(USER, errmsg); |
166 |
return -1; |
167 |
168 |
169 |
continue; |
170 |
171 |
172 |
/* Open next photon map file */ |
173 |
if (!(pmapFile = fopen(argv [arg], "rb"))) { |
174 |
sprintf(errmsg, "can't open %s", argv [arg]); |
175 |
error(SYSTEM, errmsg); |
176 |
177 |
178 |
/* Get format string */ |
179 |
strcpy(format, PMAP_FORMAT_GLOB); |
180 |
if (checkheader(pmapFile, format, NULL) != 1) { |
181 |
sprintf(errmsg, "photon map file %s has unknown format %s", |
182 |
argv [arg], format); |
183 |
184 |
185 |
186 |
/* Identify photon map type from format string */ |
187 |
for (ptype = 0; |
188 |
ptype < NUM_PMAP_TYPES && strcmp(pmapFormat [ptype], format); |
189 |
ptype++); |
190 |
191 |
if (!validPmapType(ptype)) { |
192 |
sprintf(errmsg, "file %s contains an unknown photon map type", |
193 |
argv [arg]); |
194 |
195 |
196 |
197 |
/* Get file format version and check for compatibility */ |
198 |
if (strcmp(getstr(format, pmapFile), PMAP_FILEVER)) |
199 |
error(USER, "incompatible photon map file format"); |
200 |
201 |
if (!points) { |
202 |
/* Dump command line as comment */ |
203 |
fputs("# ", stdout); |
204 |
printargs(argc, argv, stdout); |
205 |
fputc('\n', stdout); |
206 |
207 |
208 |
/* Set point/sphere colour if independent of photon flux, |
209 |
output RADIANCE material def if required */ |
210 |
if (!fluxCol) { |
211 |
if (intens(col) <= 0) |
212 |
copycolor(col, colDefs [ptype]); |
213 |
if (!points) { |
214 |
printf(radDefs [ptype].mat, col [0], col [1], col [2]); |
215 |
216 |
217 |
218 |
219 |
/* Get number of photons */ |
220 |
pm.numPhotons = getint(sizeof(pm.numPhotons), pmapFile); |
221 |
222 |
/* Skip avg photon flux */ |
223 |
224 |
getflt(pmapFile); |
225 |
226 |
/* Get distribution extent (min & max photon positions) */ |
227 |
for (j = 0; j < 3; j++) { |
228 |
pm.minPos [j] = getflt(pmapFile); |
229 |
pm.maxPos [j] = getflt(pmapFile); |
230 |
231 |
232 |
/* Skip centre of gravity, and avg photon dist to it */ |
233 |
for (j = 0; j < 4; j++) |
234 |
getflt(pmapFile); |
235 |
236 |
/* Sphere radius based on avg intersphere dist depending on |
237 |
whether the distribution occupies a 1D line (!), a 2D plane, |
238 |
or 3D volume (= sphere distrib density ^-1/d, where d is the |
239 |
dimensionality of the distribution) */ |
240 |
for (j = 0, extent = 1.0, dim = 0; j < 3; j++) { |
241 |
rad = pm.maxPos [j] - pm.minPos [j]; |
242 |
243 |
if (rad > FTINY) { |
244 |
dim++; |
245 |
extent *= rad; |
246 |
247 |
248 |
249 |
rad = radScale * RADCOEFF * pow(extent / numSpheres, 1./dim); |
250 |
251 |
/* Photon dump probability to satisfy target sphere count */ |
252 |
dumpRatio = min(1, (float)numSpheres / pm.numPhotons); |
253 |
254 |
/* Skip primary rays */ |
255 |
pm.numPrimary = getint(sizeof(pm.numPrimary), pmapFile); |
256 |
while (pm.numPrimary-- > 0) { |
257 |
/* Skip source index & incident dir */ |
258 |
getint(sizeof(pri.srcIdx), pmapFile); |
259 |
#ifdef PMAP_PRIMARYDIR |
260 |
/* Skip primary incident dir */ |
261 |
getint(sizeof(pri.dir), pmapFile); |
262 |
#endif |
263 |
#ifdef PMAP_PRIMARYPOS |
264 |
/* Skip primary hitpoint */ |
265 |
266 |
getflt(pmapFile); |
267 |
#endif |
268 |
269 |
270 |
#ifdef PMAP_OOC |
271 |
/* Open leaf file with filename derived from pmap, replace pmapFile |
272 |
* (which is currently the node file) */ |
273 |
strncpy(leafFname, argv [arg], 1024); |
274 |
strncat(leafFname, PMAP_OOC_LEAFSUFFIX, 1024); |
275 |
fclose(pmapFile); |
276 |
if (!(pmapFile = fopen(leafFname, "rb"))) { |
277 |
sprintf(errmsg, "cannot open leaf file %s", leafFname); |
278 |
279 |
280 |
#endif |
281 |
282 |
/* Read photons */ |
283 |
while (pm.numPhotons-- > 0) { |
284 |
#ifdef PMAP_OOC |
285 |
/* Get entire photon record from ooC octree leaf file |
286 |
!!! OOC PMAP FILES CURRENTLY DON'T USE PORTABLE I/O !!! */ |
287 |
if (!fread(&p, sizeof(p), 1, pmapFile)) { |
288 |
sprintf(errmsg, "error reading OOC leaf file %s", leafFname); |
289 |
290 |
291 |
#else /* kd-tree */ |
292 |
/* Get photon position */ |
293 |
294 |
p.pos [j] = getflt(pmapFile); |
295 |
296 |
/* Get photon normal (currently not used) */ |
297 |
298 |
p.norm [j] = getint(1, pmapFile); |
299 |
300 |
/* Get photon flux */ |
301 |
#ifdef PMAP_FLOAT_FLUX |
302 |
303 |
p.flux [j] = getflt(pmapFile); |
304 |
#else |
305 |
306 |
p.flux [j] = getint(1, pmapFile); |
307 |
#endif |
308 |
309 |
310 |
311 |
/* Skip primary ray index */ |
312 |
getint(sizeof(p.primary), pmapFile); |
313 |
314 |
/* Skip flags */ |
315 |
getint(sizeof(p.flags), pmapFile); |
316 |
#endif |
317 |
318 |
/* Dump photon probabilistically acc. to target sphere count */ |
319 |
if (frandom() <= dumpRatio) { |
320 |
if (fluxCol) { |
321 |
322 |
getPhotonFlux(&p, col); |
323 |
/* Scale by dumpRatio for energy conservation */ |
324 |
scalecolor(col, 1.0 / dumpRatio); |
325 |
326 |
327 |
if (!points) { |
328 |
if (fluxCol) { |
329 |
/* Dump material def if variable (depends on flux) */ |
330 |
331 |
332 |
333 |
printf(radDefs [ptype].obj, p.pos [0], p.pos [1], p.pos [2], |
334 |
rad); |
335 |
336 |
337 |
else /* Dump as XYZ RGB point */ |
338 |
printf(POINTFMT, p.pos [0], p.pos [1], p.pos [2], |
339 |
col [0], col [1] ,col [2]); |
340 |
341 |
342 |
if (ferror(pmapFile) || feof(pmapFile)) { |
343 |
sprintf(errmsg, "error reading %s", argv [arg]); |
344 |
345 |
346 |
347 |
348 |
fclose(pmapFile); |
349 |
350 |
/* Reset defaults for next dump */ |
351 |
radScale = RADSCALE; |
352 |
353 |
col [0] = col [1] = col [2] = 0; |
354 |
fluxCol = points = 0; |
355 |
356 |
357 |
return 0; |
358 |
