1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: pmapdump.c,v 2.10 2018/02/08 19:55:02 rschregle Exp $"; |
3 |
#endif |
4 |
5 |
6 |
7 |
Dump photon maps as RADIANCE scene description to stdout |
8 |
9 |
Roland Schregle (roland.schregle@{hslu.ch, gmail.com}) |
10 |
(c) Fraunhofer Institute for Solar Energy Systems, |
11 |
(c) Lucerne University of Applied Sciences and Arts, |
12 |
supported by the Swiss National Science Foundation (SNSF, #147053) |
13 |
14 |
15 |
$Id: pmapdump.c,v 2.10 2018/02/08 19:55:02 rschregle Exp $ |
16 |
17 |
18 |
19 |
20 |
#include "pmapio.h" |
21 |
#include "pmapparm.h" |
22 |
#include "pmaptype.h" |
23 |
#include "rtio.h" |
24 |
#include "resolu.h" |
25 |
#include "random.h" |
26 |
#include "math.h" |
27 |
28 |
#define PMAPDUMP_REC "$Revision: 2.10 $" |
29 |
30 |
31 |
/* Defaults */ |
32 |
/* Sphere radius as fraction of avg. intersphere dist */ |
33 |
/* Relative scale for sphere radius (fudge factor) */ |
34 |
/* Number of spheres */ |
35 |
#define RADCOEFF 0.05 |
36 |
#define RADSCALE 1.0 |
37 |
#define NSPHERES 10000 |
38 |
39 |
40 |
/* RADIANCE material and object defs for each photon type */ |
41 |
typedef struct { |
42 |
char *mat, *obj; |
43 |
} RadianceDef; |
44 |
45 |
46 |
47 |
/* Colour code is as follows: global = blue |
48 |
precomp global = cyan |
49 |
caustic = red |
50 |
volume = green |
51 |
direct = magenta |
52 |
contrib = yellow */ |
53 |
const RadianceDef radDefs [] = { |
54 |
{ "void plastic mat.global\n0\n0\n5 0 0 1 0 0\n", |
55 |
"mat.global sphere obj.global\n0\n0\n4 %g %g %g %g\n" |
56 |
57 |
{ "void plastic mat.pglobal\n0\n0\n5 0 1 1 0 0\n", |
58 |
"mat.pglobal sphere obj.global\n0\n0\n4 %g %g %g %g\n" |
59 |
60 |
{ "void plastic mat.caustic\n0\n0\n5 1 0 0 0 0\n", |
61 |
"mat.caustic sphere obj.caustic\n0\n0\n4 %g %g %g %g\n" |
62 |
63 |
{ "void plastic mat.volume\n0\n0\n5 0 1 0 0 0\n", |
64 |
"mat.volume sphere obj.volume\n0\n0\n4 %g %g %g %g\n" |
65 |
66 |
{ "void plastic mat.direct\n0\n0\n5 1 0 1 0 0\n", |
67 |
"mat.direct sphere obj.direct\n0\n0\n4 %g %g %g %g\n" |
68 |
69 |
{ "void plastic mat.contrib\n0\n0\n5 1 1 0 0 0\n", |
70 |
"mat.contrib sphere obj.contrib\n0\n0\n4 %g %g %g %g\n" |
71 |
72 |
73 |
74 |
75 |
76 |
int main (int argc, char** argv) |
77 |
78 |
char format [MAXFMTLEN]; |
79 |
RREAL rad, radScale = RADSCALE, extent, dumpRatio; |
80 |
unsigned arg, j, ptype, dim; |
81 |
long numSpheres = NSPHERES; |
82 |
FILE *pmapFile; |
83 |
PhotonMap pm; |
84 |
PhotonPrimary pri; |
85 |
Photon p; |
86 |
#ifdef PMAP_OOC |
87 |
char leafFname [1024]; |
88 |
#endif |
89 |
90 |
if (argc < 2) { |
91 |
puts("Dump photon maps as RADIANCE scene description\n"); |
92 |
printf("Usage: %s [-r radscale1] [-n nspheres1] pmap1 " |
93 |
"[-r radscale2] [-n nspheres2] pmap2 ...\n", argv [0]); |
94 |
return 1; |
95 |
96 |
97 |
for (arg = 1; arg < argc; arg++) { |
98 |
/* Parse options */ |
99 |
if (argv [arg][0] == '-') { |
100 |
switch (argv [arg][1]) { |
101 |
case 'r': |
102 |
if ((radScale = atof(argv [++arg])) <= 0) |
103 |
error(USER, "invalid radius scale"); |
104 |
break; |
105 |
106 |
case 'n': |
107 |
if ((numSpheres = parseMultiplier(argv [++arg])) <= 0) |
108 |
error(USER, "invalid number of spheres"); |
109 |
break; |
110 |
111 |
default: |
112 |
sprintf(errmsg, "unknown option %s", argv [arg]); |
113 |
error(USER, errmsg); |
114 |
return -1; |
115 |
116 |
117 |
continue; |
118 |
119 |
120 |
/* Dump photon map */ |
121 |
if (!(pmapFile = fopen(argv [arg], "rb"))) { |
122 |
sprintf(errmsg, "can't open %s", argv [arg]); |
123 |
error(SYSTEM, errmsg); |
124 |
125 |
126 |
/* Get format string */ |
127 |
strcpy(format, PMAP_FORMAT_GLOB); |
128 |
if (checkheader(pmapFile, format, NULL) != 1) { |
129 |
sprintf(errmsg, "photon map file %s has unknown format %s", |
130 |
argv [arg], format); |
131 |
132 |
133 |
134 |
/* Identify photon map type from format string */ |
135 |
for (ptype = 0; |
136 |
ptype < NUM_PMAP_TYPES && strcmp(pmapFormat [ptype], format); |
137 |
ptype++); |
138 |
139 |
if (!validPmapType(ptype)) { |
140 |
sprintf(errmsg, "file %s contains an unknown photon map type", |
141 |
argv [arg]); |
142 |
143 |
144 |
145 |
/* Get file format version and check for compatibility */ |
146 |
if (strcmp(getstr(format, pmapFile), PMAP_FILEVER)) |
147 |
error(USER, "incompatible photon map file format"); |
148 |
149 |
/* Dump command line as comment */ |
150 |
fputs("# ", stdout); |
151 |
printargs(argc, argv, stdout); |
152 |
fputc('\n', stdout); |
153 |
154 |
/* Dump material def */ |
155 |
fputs(radDefs [ptype].mat, stdout); |
156 |
157 |
158 |
/* Get number of photons */ |
159 |
pm.numPhotons = getint(sizeof(pm.numPhotons), pmapFile); |
160 |
161 |
/* Skip avg photon flux */ |
162 |
for (j = 0; j < 3; j++) |
163 |
getflt(pmapFile); |
164 |
165 |
/* Get distribution extent (min & max photon positions) */ |
166 |
for (j = 0; j < 3; j++) { |
167 |
pm.minPos [j] = getflt(pmapFile); |
168 |
pm.maxPos [j] = getflt(pmapFile); |
169 |
170 |
171 |
/* Skip centre of gravity, and avg photon dist to it */ |
172 |
for (j = 0; j < 4; j++) |
173 |
getflt(pmapFile); |
174 |
175 |
/* Sphere radius based on avg intersphere dist depending on |
176 |
whether the distribution occupies a 1D line (!), a 2D plane, |
177 |
or 3D volume (= sphere distrib density ^-1/d, where d is the |
178 |
dimensionality of the distribution) */ |
179 |
for (j = 0, extent = 1.0, dim = 0; j < 3; j++) { |
180 |
rad = pm.maxPos [j] - pm.minPos [j]; |
181 |
182 |
if (rad > FTINY) { |
183 |
dim++; |
184 |
extent *= rad; |
185 |
186 |
187 |
188 |
rad = radScale * RADCOEFF * pow(extent / numSpheres, 1./dim); |
189 |
190 |
/* Photon dump probability to satisfy target sphere count */ |
191 |
dumpRatio = numSpheres < pm.numPhotons |
192 |
? (float)numSpheres / pm.numPhotons : 1; |
193 |
194 |
/* Skip primary rays */ |
195 |
pm.numPrimary = getint(sizeof(pm.numPrimary), pmapFile); |
196 |
while (pm.numPrimary-- > 0) { |
197 |
/* Skip source index & incident dir */ |
198 |
getint(sizeof(pri.srcIdx), pmapFile); |
199 |
#ifdef PMAP_PRIMARYDIR |
200 |
/* Skip primary incident dir */ |
201 |
getint(sizeof(pri.dir), pmapFile); |
202 |
#endif |
203 |
#ifdef PMAP_PRIMARYPOS |
204 |
/* Skip primary hitpoint */ |
205 |
206 |
getflt(pmapFile); |
207 |
#endif |
208 |
209 |
210 |
#ifdef PMAP_OOC |
211 |
/* Open leaf file with filename derived from pmap, replace pmapFile |
212 |
* (which is currently the node file) */ |
213 |
strncpy(leafFname, argv [arg], 1024); |
214 |
strncat(leafFname, PMAP_OOC_LEAFSUFFIX, 1024); |
215 |
fclose(pmapFile); |
216 |
if (!(pmapFile = fopen(leafFname, "rb"))) { |
217 |
sprintf(errmsg, "cannot open leaf file %s", leafFname); |
218 |
219 |
220 |
#endif |
221 |
222 |
/* Load photons */ |
223 |
while (pm.numPhotons-- > 0) { |
224 |
#ifdef PMAP_OOC |
225 |
/* Get entire photon record |
226 |
!!! OOC PMAP FILES CURRENTLY DON'T USE PORTABLE I/O !!! */ |
227 |
if (!fread(&p, sizeof(p), 1, pmapFile)) { |
228 |
sprintf(errmsg, "error reading OOC leaf file %s", leafFname); |
229 |
230 |
231 |
#else |
232 |
/* Get photon position */ |
233 |
234 |
p.pos [j] = getflt(pmapFile); |
235 |
#endif |
236 |
/* Dump photon probabilistically acc. to target sphere count */ |
237 |
if (frandom() <= dumpRatio) { |
238 |
printf(radDefs [ptype].obj, p.pos [0], p.pos [1], p.pos [2], rad); |
239 |
240 |
241 |
242 |
#ifndef PMAP_OOC |
243 |
/* Skip photon normal and flux */ |
244 |
245 |
getint(sizeof(p.norm [j]), pmapFile); |
246 |
247 |
#ifdef PMAP_FLOAT_FLUX |
248 |
249 |
getflt(pmapFile); |
250 |
#else |
251 |
252 |
getint(1, pmapFile); |
253 |
#endif |
254 |
255 |
/* Skip primary ray index */ |
256 |
getint(sizeof(p.primary), pmapFile); |
257 |
258 |
/* Skip flags */ |
259 |
getint(sizeof(p.flags), pmapFile); |
260 |
#endif |
261 |
262 |
if (ferror(pmapFile) || feof(pmapFile)) { |
263 |
sprintf(errmsg, "error reading %s", argv [arg]); |
264 |
265 |
266 |
267 |
268 |
fclose(pmapFile); |
269 |
270 |
/* Reset defaults for next dump */ |
271 |
radScale = RADSCALE; |
272 |
273 |
274 |
275 |
return 0; |
276 |
