| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: pmapdump.c,v 2.16 2020/07/21 16:10:42 rschregle Exp $";
| 3 |
#endif
| 4 |
| 5 |
| 6 |
| 7 |
Dump photon maps as RADIANCE scene description or ASCII point list
| 8 |
to stdout
| 9 |
| 10 |
Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
| 11 |
(c) Fraunhofer Institute for Solar Energy Systems,
| 12 |
supported by the German Research Foundation (DFG)
| 13 |
under the FARESYS project.
| 14 |
(c) Lucerne University of Applied Sciences and Arts,
| 15 |
supported by the Swiss National Science Foundation (SNSF #147053).
| 16 |
(c) Tokyo University of Science,
| 17 |
supported by the JSPS KAKENHI Grant Number JP19KK0115.
| 18 |
| 19 |
| 20 |
| 21 |
| 22 |
| 23 |
| 24 |
| 25 |
#include "pmap.h"
| 26 |
#include "pmapio.h"
| 27 |
#include "rtio.h"
| 28 |
#include "resolu.h"
| 29 |
#include "random.h"
| 30 |
#include "math.h"
| 31 |
| 32 |
| 33 |
/* Defaults */
| 34 |
/* Sphere radius as fraction of avg. intersphere dist */
| 35 |
/* Relative scale for sphere radius (fudge factor) */
| 36 |
/* Number of spheres */
| 37 |
#define RADCOEFF 0.05
| 38 |
#define RADSCALE 1.0
| 39 |
#define NSPHERES 10000
| 40 |
| 41 |
/* Format for optional ASCII output as XYZ RGB points */
| 42 |
#define POINTFMT "%g\t%g\t%g\t%g\t%g\t%g\n"
| 43 |
| 44 |
/* RADIANCE material and object defs for each photon type */
| 45 |
typedef struct {
| 46 |
char *mat, *obj;
| 47 |
} RadianceDef;
| 48 |
| 49 |
const RadianceDef radDefs [] = {
| 50 |
{ "void glow mat.global\n0\n0\n4 %g %g %g 0\n",
| 51 |
"mat.global sphere obj.global\n0\n0\n4 %g %g %g %g\n"
| 52 |
| 53 |
{ "void glow mat.pglobal\n0\n0\n4 %g %g %g 0\n",
| 54 |
"mat.pglobal sphere obj.pglobal\n0\n0\n4 %g %g %g %g\n"
| 55 |
| 56 |
{ "void glow mat.caustic\n0\n0\n4 %g %g %g 0\n",
| 57 |
"mat.caustic sphere obj.caustic\n0\n0\n4 %g %g %g %g\n"
| 58 |
| 59 |
{ "void glow mat.volume\n0\n0\n4 %g %g %g 0\n",
| 60 |
"mat.volume sphere obj.volume\n0\n0\n4 %g %g %g %g\n"
| 61 |
| 62 |
{ "void glow mat.direct\n0\n0\n4 %g %g %g 0\n",
| 63 |
"mat.direct sphere obj.direct\n0\n0\n4 %g %g %g %g\n"
| 64 |
| 65 |
{ "void glow mat.contrib\n0\n0\n4 %g %g %g 0\n",
| 66 |
"mat.contrib sphere obj.contrib\n0\n0\n4 %g %g %g %g\n"
| 67 |
| 68 |
| 69 |
| 70 |
| 71 |
/* Default colour codes are as follows: global = blue
| 72 |
precomp global = cyan
| 73 |
caustic = red
| 74 |
volume = green
| 75 |
direct = magenta
| 76 |
contrib = yellow */
| 77 |
const COLOR colDefs [] = {
| 78 |
{0.25, 0.25, 2}, {0.1, 1, 1}, {1, 0.1, 0.1},
| 79 |
{0.1, 1, 0.1}, {1, 0.1, 1}, {1, 1, 0.1}
| 80 |
| 81 |
| 82 |
| 83 |
static int setBool(char *str, unsigned pos, unsigned *var)
| 84 |
| 85 |
switch ((str) [pos]) {
| 86 |
case '\0':
| 87 |
*var = !*var;
| 88 |
break;
| 89 |
case 'y': case 'Y': case 't': case 'T': case '+': case '1':
| 90 |
*var = 1;
| 91 |
break;
| 92 |
case 'n': case 'N': case 'f': case 'F': case '-': case '0':
| 93 |
*var = 0;
| 94 |
break;
| 95 |
default:
| 96 |
return 0;
| 97 |
| 98 |
| 99 |
return 1;
| 100 |
| 101 |
| 102 |
| 103 |
int main (int argc, char** argv)
| 104 |
| 105 |
char format [MAXFMTLEN];
| 106 |
RREAL rad, radScale = RADSCALE, extent, dumpRatio;
| 107 |
unsigned arg, j, ptype, dim, fluxCol = 0, points = 0;
| 108 |
long numSpheres = NSPHERES;
| 109 |
COLOR col = {0, 0, 0};
| 110 |
FILE *pmapFile;
| 111 |
PhotonMap pm;
| 112 |
PhotonPrimary pri;
| 113 |
Photon p;
| 114 |
#ifdef PMAP_OOC
| 115 |
char leafFname [1024];
| 116 |
#endif
| 117 |
| 118 |
if (argc < 2) {
| 119 |
puts("Dump photon maps as RADIANCE scene description "
| 120 |
"or ASCII point list\n");
| 121 |
printf("Usage: %s "
| 122 |
"[-a] [-r radscale1] [-n num1] "
| 123 |
"[-f | -c rcol1 gcol1 bcol1] pmap1 "
| 124 |
"[-a] [-r radscale2] [-n num2] "
| 125 |
"[-f | -c rcol2 gcol2 bcol2] pmap2 "
| 126 |
"...\n", argv [0]);
| 127 |
return 1;
| 128 |
| 129 |
| 130 |
for (arg = 1; arg < argc; arg++) {
| 131 |
/* Parse options */
| 132 |
if (argv [arg][0] == '-') {
| 133 |
switch (argv [arg][1]) {
| 134 |
case 'a':
| 135 |
if (!setBool(argv [arg], 2, &points))
| 136 |
error(USER, "invalid option syntax at -a");
| 137 |
break;
| 138 |
case 'r':
| 139 |
if ((radScale = atof(argv [++arg])) <= 0)
| 140 |
error(USER, "invalid radius scale");
| 141 |
break;
| 142 |
| 143 |
case 'n':
| 144 |
if ((numSpheres = parseMultiplier(argv [++arg])) <= 0)
| 145 |
error(USER, "invalid number of points/spheres");
| 146 |
break;
| 147 |
| 148 |
case 'c':
| 149 |
if (fluxCol)
| 150 |
error(USER, "-f and -c are mutually exclusive");
| 151 |
| 152 |
if (badarg(argc - arg - 1, &argv [arg + 1], "fff"))
| 153 |
error(USER, "invalid RGB colour");
| 154 |
| 155 |
for (j = 0; j < 3; j++)
| 156 |
col [j] = atof(argv [++arg]);
| 157 |
break;
| 158 |
| 159 |
case 'f':
| 160 |
if (intens(col) > 0)
| 161 |
| 162 |
| 163 |
if (!setBool(argv [arg], 2, &fluxCol))
| 164 |
error(USER, "invalid option syntax at -f");
| 165 |
break;
| 166 |
| 167 |
default:
| 168 |
sprintf(errmsg, "unknown option %s", argv [arg]);
| 169 |
error(USER, errmsg);
| 170 |
return -1;
| 171 |
| 172 |
| 173 |
continue;
| 174 |
| 175 |
| 176 |
/* Open next photon map file */
| 177 |
if (!(pmapFile = fopen(argv [arg], "rb"))) {
| 178 |
sprintf(errmsg, "can't open %s", argv [arg]);
| 179 |
error(SYSTEM, errmsg);
| 180 |
| 181 |
| 182 |
/* Get format string */
| 183 |
strcpy(format, PMAP_FORMAT_GLOB);
| 184 |
if (checkheader(pmapFile, format, NULL) != 1) {
| 185 |
sprintf(errmsg, "photon map file %s has unknown format %s",
| 186 |
argv [arg], format);
| 187 |
| 188 |
| 189 |
| 190 |
/* Identify photon map type from format string */
| 191 |
for (ptype = 0;
| 192 |
ptype < NUM_PMAP_TYPES && strcmp(pmapFormat [ptype], format);
| 193 |
ptype++);
| 194 |
| 195 |
if (!validPmapType(ptype)) {
| 196 |
sprintf(errmsg, "file %s contains an unknown photon map type",
| 197 |
argv [arg]);
| 198 |
| 199 |
| 200 |
| 201 |
/* Get file format version and check for compatibility */
| 202 |
if (strcmp(getstr(format, pmapFile), PMAP_FILEVER))
| 203 |
error(USER, "incompatible photon map file format");
| 204 |
| 205 |
if (!points) {
| 206 |
/* Dump command line as comment */
| 207 |
fputs("# ", stdout);
| 208 |
printargs(argc, argv, stdout);
| 209 |
fputc('\n', stdout);
| 210 |
| 211 |
| 212 |
/* Set point/sphere colour if independent of photon flux,
| 213 |
output RADIANCE material def if required */
| 214 |
if (!fluxCol) {
| 215 |
if (intens(col) <= 0)
| 216 |
copycolor(col, colDefs [ptype]);
| 217 |
if (!points) {
| 218 |
printf(radDefs [ptype].mat, col [0], col [1], col [2]);
| 219 |
| 220 |
| 221 |
| 222 |
| 223 |
/* Get number of photons */
| 224 |
pm.numPhotons = getint(sizeof(pm.numPhotons), pmapFile);
| 225 |
| 226 |
/* Skip avg photon flux */
| 227 |
| 228 |
getflt(pmapFile);
| 229 |
| 230 |
/* Get distribution extent (min & max photon positions) */
| 231 |
for (j = 0; j < 3; j++) {
| 232 |
pm.minPos [j] = getflt(pmapFile);
| 233 |
pm.maxPos [j] = getflt(pmapFile);
| 234 |
| 235 |
| 236 |
/* Skip centre of gravity, and avg photon dist to it */
| 237 |
for (j = 0; j < 4; j++)
| 238 |
getflt(pmapFile);
| 239 |
| 240 |
/* Sphere radius based on avg intersphere dist depending on
| 241 |
whether the distribution occupies a 1D line (!), a 2D plane,
| 242 |
or 3D volume (= sphere distrib density ^-1/d, where d is the
| 243 |
dimensionality of the distribution) */
| 244 |
for (j = 0, extent = 1.0, dim = 0; j < 3; j++) {
| 245 |
rad = pm.maxPos [j] - pm.minPos [j];
| 246 |
| 247 |
if (rad > FTINY) {
| 248 |
dim++;
| 249 |
extent *= rad;
| 250 |
| 251 |
| 252 |
| 253 |
rad = radScale * RADCOEFF * pow(extent / numSpheres, 1./dim);
| 254 |
| 255 |
/* Photon dump probability to satisfy target sphere count */
| 256 |
dumpRatio = min(1, (float)numSpheres / pm.numPhotons);
| 257 |
| 258 |
/* Skip primary rays */
| 259 |
pm.numPrimary = getint(sizeof(pm.numPrimary), pmapFile);
| 260 |
while (pm.numPrimary-- > 0) {
| 261 |
/* Skip source index & incident dir */
| 262 |
getint(sizeof(pri.srcIdx), pmapFile);
| 263 |
#ifdef PMAP_PRIMARYDIR
| 264 |
/* Skip primary incident dir */
| 265 |
getint(sizeof(pri.dir), pmapFile);
| 266 |
#endif
| 267 |
#ifdef PMAP_PRIMARYPOS
| 268 |
/* Skip primary hitpoint */
| 269 |
| 270 |
getflt(pmapFile);
| 271 |
#endif
| 272 |
| 273 |
| 274 |
#ifdef PMAP_OOC
| 275 |
/* Open leaf file with filename derived from pmap, replace pmapFile
| 276 |
* (which is currently the node file) */
| 277 |
strncpy(leafFname, argv [arg], sizeof(leafFname) - 1);
| 278 |
strncat(leafFname, PMAP_OOC_LEAFSUFFIX, sizeof(leafFname) - 1);
| 279 |
fclose(pmapFile);
| 280 |
if (!(pmapFile = fopen(leafFname, "rb"))) {
| 281 |
sprintf(errmsg, "cannot open leaf file %s", leafFname);
| 282 |
| 283 |
| 284 |
#endif
| 285 |
| 286 |
/* Read photons */
| 287 |
while (pm.numPhotons-- > 0) {
| 288 |
#ifdef PMAP_OOC
| 289 |
/* Get entire photon record from ooC octree leaf file
| 290 |
!!! OOC PMAP FILES CURRENTLY DON'T USE PORTABLE I/O !!! */
| 291 |
if (!fread(&p, sizeof(p), 1, pmapFile)) {
| 292 |
sprintf(errmsg, "error reading OOC leaf file %s", leafFname);
| 293 |
| 294 |
| 295 |
#else /* kd-tree */
| 296 |
/* Get photon position */
| 297 |
| 298 |
p.pos [j] = getflt(pmapFile);
| 299 |
| 300 |
/* Get photon normal (currently not used) */
| 301 |
| 302 |
p.norm [j] = getint(1, pmapFile);
| 303 |
| 304 |
/* Get photon flux */
| 305 |
#ifdef PMAP_FLOAT_FLUX
| 306 |
| 307 |
p.flux [j] = getflt(pmapFile);
| 308 |
#else
| 309 |
| 310 |
p.flux [j] = getint(1, pmapFile);
| 311 |
#endif
| 312 |
| 313 |
| 314 |
| 315 |
/* Skip primary ray index */
| 316 |
getint(sizeof(p.primary), pmapFile);
| 317 |
| 318 |
/* Skip flags */
| 319 |
getint(sizeof(p.flags), pmapFile);
| 320 |
#endif
| 321 |
| 322 |
/* Dump photon probabilistically acc. to target sphere count */
| 323 |
if (frandom() <= dumpRatio) {
| 324 |
if (fluxCol) {
| 325 |
| 326 |
getPhotonFlux(&p, col);
| 327 |
/* Scale by dumpRatio for energy conservation */
| 328 |
scalecolor(col, 1.0 / dumpRatio);
| 329 |
| 330 |
| 331 |
if (!points) {
| 332 |
if (fluxCol) {
| 333 |
/* Dump material def if variable (depends on flux) */
| 334 |
| 335 |
| 336 |
| 337 |
printf(radDefs [ptype].obj, p.pos [0], p.pos [1], p.pos [2],
| 338 |
rad);
| 339 |
| 340 |
| 341 |
else /* Dump as XYZ RGB point */
| 342 |
printf(POINTFMT, p.pos [0], p.pos [1], p.pos [2],
| 343 |
col [0], col [1] ,col [2]);
| 344 |
| 345 |
| 346 |
if (ferror(pmapFile) || feof(pmapFile)) {
| 347 |
sprintf(errmsg, "error reading %s", argv [arg]);
| 348 |
| 349 |
| 350 |
| 351 |
| 352 |
fclose(pmapFile);
| 353 |
| 354 |
/* Reset defaults for next dump */
| 355 |
radScale = RADSCALE;
| 356 |
| 357 |
col [0] = col [1] = col [2] = 0;
| 358 |
fluxCol = points = 0;
| 359 |
| 360 |
| 361 |
return 0;
| 362 |
