1 |
2 |
3 |
Dump photon maps as RADIANCE scene description to stdout |
4 |
5 |
Roland Schregle (roland.schregle@{hslu.ch, gmail.com}) |
6 |
(c) Fraunhofer Institute for Solar Energy Systems, |
7 |
(c) Lucerne University of Applied Sciences and Arts, |
8 |
supported by the Swiss National Science Foundation (SNSF, #147053) |
9 |
10 |
11 |
$Id: pmapdump.c,v 2.2 2015/04/21 19:16:51 greg Exp $ |
12 |
13 |
14 |
15 |
16 |
#include "pmapio.h" |
17 |
#include "pmapparm.h" |
18 |
#include "pmaptype.h" |
19 |
#include "rtio.h" |
20 |
#include "resolu.h" |
21 |
#include "random.h" |
22 |
#include "math.h" |
23 |
24 |
25 |
/* Defaults */ |
26 |
/* Sphere radius as fraction of avg. intersphere dist */ |
27 |
/* Relative scale for sphere radius (fudge factor) */ |
28 |
/* Number of spheres */ |
29 |
#define RADCOEFF 0.05 |
30 |
#define RADSCALE 1.0 |
31 |
#define NSPHERES 10000 |
32 |
33 |
34 |
/* RADIANCE material and object defs for each photon type */ |
35 |
typedef struct { |
36 |
char *mat, *obj; |
37 |
} RadianceDef; |
38 |
39 |
40 |
static char header [] = "$Revision: 2.2 $"; |
41 |
42 |
43 |
/* Colour code is as follows: global = blue |
44 |
precomp global = cyan |
45 |
caustic = red |
46 |
volume = green |
47 |
direct = magenta |
48 |
contrib = yellow */ |
49 |
const RadianceDef radDefs [] = { |
50 |
{ "void plastic mat.global\n0\n0\n5 0 0 1 0 0\n", |
51 |
"mat.global sphere obj.global\n0\n0\n4 %g %g %g %g\n" |
52 |
53 |
{ "void plastic mat.pglobal\n0\n0\n5 0 1 1 0 0\n", |
54 |
"mat.pglobal sphere obj.global\n0\n0\n4 %g %g %g %g\n" |
55 |
56 |
{ "void plastic mat.caustic\n0\n0\n5 1 0 0 0 0\n", |
57 |
"mat.caustic sphere obj.caustic\n0\n0\n4 %g %g %g %g\n" |
58 |
59 |
{ "void plastic mat.volume\n0\n0\n5 0 1 0 0 0\n", |
60 |
"mat.volume sphere obj.volume\n0\n0\n4 %g %g %g %g\n" |
61 |
62 |
{ "void plastic mat.direct\n0\n0\n5 1 0 1 0 0\n", |
63 |
"mat.direct sphere obj.direct\n0\n0\n4 %g %g %g %g\n" |
64 |
65 |
{ "void plastic mat.contrib\n0\n0\n5 1 1 0 0 0\n", |
66 |
"mat.contrib sphere obj.contrib\n0\n0\n4 %g %g %g %g\n" |
67 |
68 |
69 |
70 |
71 |
72 |
int main (int argc, char** argv) |
73 |
74 |
char format [128]; |
75 |
RREAL rad, radScale = RADSCALE, vol, dumpRatio; |
76 |
FVECT minPos, maxPos; |
77 |
unsigned arg, j, ptype; |
78 |
long numPhotons, numSpheres = NSPHERES; |
79 |
FILE *pmapFile; |
80 |
Photon p; |
81 |
82 |
if (argc < 2) { |
83 |
puts("Dump photon maps as RADIANCE scene description\n"); |
84 |
printf("Usage: %s [-r radscale1] [-n nspheres1] pmap1 " |
85 |
"[-r radscale2] [-n nspheres2] pmap2 ...\n", argv [0]); |
86 |
return 1; |
87 |
88 |
89 |
for (arg = 1; arg < argc; arg++) { |
90 |
/* Parse options */ |
91 |
if (argv [arg][0] == '-') { |
92 |
switch (argv [arg][1]) { |
93 |
case 'r': |
94 |
if ((radScale = atof(argv [++arg])) <= 0) |
95 |
error(USER, "invalid radius scale"); |
96 |
break; |
97 |
98 |
case 'n': |
99 |
if ((numSpheres = parseMultiplier(argv [++arg])) <= 0) |
100 |
error(USER, "invalid number of spheres"); |
101 |
break; |
102 |
103 |
default: |
104 |
sprintf(errmsg, "unknown option %s", argv [arg]); |
105 |
error(USER, errmsg); |
106 |
return -1; |
107 |
108 |
109 |
continue; |
110 |
111 |
112 |
/* Dump photon map */ |
113 |
if (!(pmapFile = fopen(argv [arg], "rb"))) { |
114 |
sprintf(errmsg, "can't open %s", argv [arg]); |
115 |
error(SYSTEM, errmsg); |
116 |
117 |
118 |
/* Get format string */ |
119 |
strcpy(format, PMAP_FORMAT_GLOB); |
120 |
if (checkheader(pmapFile, format, NULL) != 1) { |
121 |
sprintf(errmsg, "photon map file %s has unknown format %s", |
122 |
argv [arg], format); |
123 |
124 |
125 |
126 |
/* Identify photon map type from format string */ |
127 |
for (ptype = 0; |
128 |
strcmp(pmapFormat [ptype], format) && ptype < NUM_PMAP_TYPES; |
129 |
ptype++); |
130 |
131 |
if (!validPmapType(ptype)) { |
132 |
sprintf(errmsg, "file %s contains an unknown photon map type", |
133 |
argv [arg]); |
134 |
135 |
136 |
137 |
/* Get file format version and check for compatibility */ |
138 |
if (getint(sizeof(PMAP_FILEVER), pmapFile) != PMAP_FILEVER) |
139 |
error(USER, "incompatible photon map file format"); |
140 |
141 |
/* Dump command line as comment */ |
142 |
fputs("# ", stdout); |
143 |
printargs(argc, argv, stdout); |
144 |
fputc('\n', stdout); |
145 |
146 |
/* Dump material def */ |
147 |
fputs(radDefs [ptype].mat, stdout); |
148 |
149 |
150 |
/* Get number of photons (is this sizeof() hack portable?) */ |
151 |
numPhotons = getint(sizeof(((PhotonMap*)NULL) -> heapSize), pmapFile); |
152 |
153 |
/* Skip avg photon flux */ |
154 |
for (j = 0; j < 3; j++) |
155 |
getflt(pmapFile); |
156 |
157 |
/* Get distribution extent (min & max photon positions) */ |
158 |
for (j = 0; j < 3; j++) { |
159 |
minPos [j] = getflt(pmapFile); |
160 |
maxPos [j] = getflt(pmapFile); |
161 |
162 |
163 |
/* Skip centre of gravity, and avg photon dist to it */ |
164 |
for (j = 0; j < 4; j++) |
165 |
getflt(pmapFile); |
166 |
167 |
/* Sphere radius based on avg intersphere dist |
168 |
(= sphere distrib density ^-1/3) */ |
169 |
vol = (maxPos [0] - minPos [0]) * (maxPos [1] - minPos [1]) * |
170 |
(maxPos [2] - minPos [2]); |
171 |
rad = radScale * RADCOEFF * pow(vol / numSpheres, 1./3.); |
172 |
173 |
/* Photon dump probability to satisfy target sphere count */ |
174 |
dumpRatio = numSpheres < numPhotons ? (float)numSpheres / numPhotons |
175 |
: 1; |
176 |
177 |
while (numPhotons-- > 0) { |
178 |
/* Get photon position */ |
179 |
180 |
p.pos [j] = getflt(pmapFile); |
181 |
182 |
/* Dump photon probabilistically acc. to target sphere count */ |
183 |
if (frandom() <= dumpRatio) { |
184 |
printf(radDefs [ptype].obj, p.pos [0], p.pos [1], p.pos [2], rad); |
185 |
186 |
187 |
188 |
/* Skip photon normal and flux */ |
189 |
190 |
getint(sizeof(p.norm [j]), pmapFile); |
191 |
192 |
#ifdef PMAP_FLOAT_FLUX |
193 |
194 |
getflt(pmapFile); |
195 |
#else |
196 |
197 |
getint(1, pmapFile); |
198 |
#endif |
199 |
200 |
/* Skip primary ray index */ |
201 |
getint(sizeof(p.primary), pmapFile); |
202 |
203 |
/* Skip flags */ |
204 |
getint(sizeof(p.flags), pmapFile); |
205 |
206 |
if (feof(pmapFile)) { |
207 |
sprintf(errmsg, "error reading %s", argv [arg]); |
208 |
209 |
210 |
211 |
212 |
fclose(pmapFile); |
213 |
214 |
/* Reset defaults for next dump */ |
215 |
radScale = RADSCALE; |
216 |
217 |
218 |
219 |
return 0; |
220 |
