root/radiance/ray/src/rt/pmapdump.c
Revision: 2.1
Committed: Tue Feb 24 19:39:27 2015 UTC (10 years, 2 months ago) by greg
1 /*
2 ===============================================================
3 Dump photon maps as RADIANCE scene description to stdout
4
5 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
6 (c) Fraunhofer Institute for Solar Energy Systems,
7 Lucerne University of Applied Sciences & Arts
8 ==================================================================
9
10 $Id: pmapdump.c,v 4.12 2015/01/13 09:55:32 taschreg Exp taschreg $
11 */
12
13
14
15 #include "pmapio.h"
16 #include "pmapparm.h"
17 #include "pmaptype.h"
18 #include "rtio.h"
19 #include "resolu.h"
20 #include "random.h"
21
22
23 /* Defaults */
24 /* Sphere radius as fraction of avg. intersphere dist */
25 /* Relative scale for sphere radius (fudge factor) */
26 /* Number of spheres */
27 #define RADCOEFF 0.05
28 #define RADSCALE 1.0
29 #define NSPHERES 10000
30
31
32 /* RADIANCE material and object defs for each photon type */
33 typedef struct {
34 char *mat, *obj;
35 } RadianceDef;
36
37
38 static char header [] = "$Revision: 4.12 $";
39
40
41 /* Colour code is as follows: global = blue
42 precomp global = cyan
43 caustic = red
44 volume = green
45 direct = magenta
46 contrib = yellow */
47 const RadianceDef radDefs [] = {
48 { "void plastic mat.global\n0\n0\n5 0 0 1 0 0\n",
49 "mat.global sphere obj.global\n0\n0\n4 %g %g %g %g\n"
50 },
51 { "void plastic mat.pglobal\n0\n0\n5 0 1 1 0 0\n",
52 "mat.pglobal sphere obj.global\n0\n0\n4 %g %g %g %g\n"
53 },
54 { "void plastic mat.caustic\n0\n0\n5 1 0 0 0 0\n",
55 "mat.caustic sphere obj.caustic\n0\n0\n4 %g %g %g %g\n"
56 },
57 { "void plastic mat.volume\n0\n0\n5 0 1 0 0 0\n",
58 "mat.volume sphere obj.volume\n0\n0\n4 %g %g %g %g\n"
59 },
60 { "void plastic mat.direct\n0\n0\n5 1 0 1 0 0\n",
61 "mat.direct sphere obj.direct\n0\n0\n4 %g %g %g %g\n"
62 },
63 { "void plastic mat.contrib\n0\n0\n5 1 1 0 0 0\n",
64 "mat.contrib sphere obj.contrib\n0\n0\n4 %g %g %g %g\n"
65 }
66 };
67
68
69
70 int main (int argc, char** argv)
71 {
72 char format [128];
73 RREAL rad, radScale = RADSCALE, vol, dumpRatio;
74 FVECT minPos, maxPos;
75 unsigned arg, j, ptype;
76 long numPhotons, numSpheres = NSPHERES;
77 FILE *pmapFile;
78 Photon p;
79
80 if (argc < 2) {
81 puts("Dump photon maps as RADIANCE scene description\n");
82 printf("Usage: %s [-r radscale1] [-n nspheres1] pmap1 "
83 "[-r radscale2] [-n nspheres2] pmap2 ...\n", argv [0]);
84 return 1;
85 }
86
87 for (arg = 1; arg < argc; arg++) {
88 /* Parse options */
89 if (argv [arg][0] == '-') {
90 switch (argv [arg][1]) {
91 case 'r':
92 if ((radScale = atof(argv [++arg])) <= 0)
93 error(USER, "invalid radius scale");
94 break;
95
96 case 'n':
97 if ((numSpheres = parseMultiplier(argv [++arg])) <= 0)
98 error(USER, "invalid number of spheres");
99 break;
100
101 default:
102 sprintf(errmsg, "unknown option %s", argv [arg]);
103 error(USER, errmsg);
104 return -1;
105 }
106
107 continue;
108 }
109
110 /* Dump photon map */
111 if (!(pmapFile = fopen(argv [arg], "rb"))) {
112 sprintf(errmsg, "can't open %s", argv [arg]);
113 error(SYSTEM, errmsg);
114 }
115
116 /* Get format string */
117 strcpy(format, PMAP_FORMAT_GLOB);
118 if (checkheader(pmapFile, format, NULL) != 1) {
119 sprintf(errmsg, "photon map file %s has unknown format %s",
120 argv [arg], format);
121 error(USER, errmsg);
122 }
123
124 /* Identify photon map type from format string */
125 for (ptype = 0;
126 strcmp(pmapFormat [ptype], format) && ptype < NUM_PMAP_TYPES;
127 ptype++);
128
129 if (!validPmapType(ptype)) {
130 sprintf(errmsg, "file %s contains an unknown photon map type",
131 argv [arg]);
132 error(USER, errmsg);
133 }
134
135 /* Get file format version and check for compatibility */
136 if (getint(sizeof(PMAP_FILEVER), pmapFile) != PMAP_FILEVER)
137 error(USER, "incompatible photon map file format");
138
139 /* Dump command line as comment */
140 fputs("# ", stdout);
141 printargs(argc, argv, stdout);
142 fputc('\n', stdout);
143
144 /* Dump material def */
145 fputs(radDefs [ptype].mat, stdout);
146 fputc('\n', stdout);
147
148 /* Get number of photons (is this sizeof() hack portable?) */
149 numPhotons = getint(sizeof(((PhotonMap*)NULL) -> heapSize), pmapFile);
150
151 /* Skip avg photon flux */
152 for (j = 0; j < 3; j++)
153 getflt(pmapFile);
154
155 /* Get distribution extent (min & max photon positions) */
156 for (j = 0; j < 3; j++) {
157 minPos [j] = getflt(pmapFile);
158 maxPos [j] = getflt(pmapFile);
159 }
160
161 /* Skip centre of gravity, and avg photon dist to it */
162 for (j = 0; j < 4; j++)
163 getflt(pmapFile);
164
165 /* Sphere radius based on avg intersphere dist
166 (= sphere distrib density ^-1/3) */
167 vol = (maxPos [0] - minPos [0]) * (maxPos [1] - minPos [1]) *
168 (maxPos [2] - minPos [2]);
169 rad = radScale * RADCOEFF * cbrt(vol / numSpheres);
170
171 /* Photon dump probability to satisfy target sphere count */
172 dumpRatio = numSpheres < numPhotons ? (float)numSpheres / numPhotons
173 : 1;
174
175 while (numPhotons-- > 0) {
176 /* Get photon position */
177 for (j = 0; j < 3; j++)
178 p.pos [j] = getflt(pmapFile);
179
180 /* Dump photon probabilistically acc. to target sphere count */
181 if (frandom() <= dumpRatio) {
182 printf(radDefs [ptype].obj, p.pos [0], p.pos [1], p.pos [2], rad);
183 fputc('\n', stdout);
184 }
185
186 /* Skip photon normal and flux */
187 for (j = 0; j < 3; j++)
188 getint(sizeof(p.norm [j]), pmapFile);
189
190 #ifdef PMAP_FLOAT_FLUX
191 for (j = 0; j < 3; j++)
192 getflt(pmapFile);
193 #else
194 for (j = 0; j < 4; j++)
195 getint(1, pmapFile);
196 #endif
197
198 /* Skip primary ray index */
199 getint(sizeof(p.primary), pmapFile);
200
201 /* Skip flags */
202 getint(sizeof(p.flags), pmapFile);
203
204 if (feof(pmapFile)) {
205 sprintf(errmsg, "error reading %s", argv [arg]);
206 error(USER, errmsg);
207 }
208 }
209
210 fclose(pmapFile);
211
212 /* Reset defaults for next dump */
213 radScale = RADSCALE;
214 numSpheres = NSPHERES;
215 }
216
217 return 0;
218 }
