root/radiance/ray/src/rt/pmapdump.c
Revision: 2.4
Committed: Tue Aug 18 18:45:55 2015 UTC (9 years, 8 months ago) by greg
Changes since 2.3: +5 -2 lines
5 ==================================================================
6 Dump photon maps as RADIANCE scene description to stdout
7
8 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
9 (c) Fraunhofer Institute for Solar Energy Systems,
10 (c) Lucerne University of Applied Sciences and Arts,
11 supported by the Swiss National Science Foundation (SNSF, #147053)
12 ==================================================================
13
14 $Id: pmapdump.c,v 2.3 2015/05/08 13:20:23 rschregle Exp $
15 */
16
17
18
19 #include "pmapio.h"
20 #include "pmapparm.h"
21 #include "pmaptype.h"
22 #include "rtio.h"
23 #include "resolu.h"
24 #include "random.h"
25 #include "math.h"
26
27
28 /* Defaults */
29 /* Sphere radius as fraction of avg. intersphere dist */
30 /* Relative scale for sphere radius (fudge factor) */
31 /* Number of spheres */
32 #define RADCOEFF 0.05
33 #define RADSCALE 1.0
34 #define NSPHERES 10000
35
36
37 /* RADIANCE material and object defs for each photon type */
38 typedef struct {
39 char *mat, *obj;
40 } RadianceDef;
41
42
43 static char header [] = "$Revision: 2.3 $";
44
45
46 /* Colour code is as follows: global = blue
47 precomp global = cyan
48 caustic = red
49 volume = green
50 direct = magenta
51 contrib = yellow */
52 const RadianceDef radDefs [] = {
53 { "void plastic mat.global\n0\n0\n5 0 0 1 0 0\n",
54 "mat.global sphere obj.global\n0\n0\n4 %g %g %g %g\n"
55 },
56 { "void plastic mat.pglobal\n0\n0\n5 0 1 1 0 0\n",
57 "mat.pglobal sphere obj.global\n0\n0\n4 %g %g %g %g\n"
58 },
59 { "void plastic mat.caustic\n0\n0\n5 1 0 0 0 0\n",
60 "mat.caustic sphere obj.caustic\n0\n0\n4 %g %g %g %g\n"
61 },
62 { "void plastic mat.volume\n0\n0\n5 0 1 0 0 0\n",
63 "mat.volume sphere obj.volume\n0\n0\n4 %g %g %g %g\n"
64 },
65 { "void plastic mat.direct\n0\n0\n5 1 0 1 0 0\n",
66 "mat.direct sphere obj.direct\n0\n0\n4 %g %g %g %g\n"
67 },
68 { "void plastic mat.contrib\n0\n0\n5 1 1 0 0 0\n",
69 "mat.contrib sphere obj.contrib\n0\n0\n4 %g %g %g %g\n"
70 }
71 };
72
73
74
75 int main (int argc, char** argv)
76 {
77 char format [128];
78 RREAL rad, radScale = RADSCALE, vol, dumpRatio;
79 FVECT minPos, maxPos;
80 unsigned arg, j, ptype;
81 long numPhotons, numSpheres = NSPHERES;
82 FILE *pmapFile;
83 Photon p;
84
85 if (argc < 2) {
86 puts("Dump photon maps as RADIANCE scene description\n");
87 printf("Usage: %s [-r radscale1] [-n nspheres1] pmap1 "
88 "[-r radscale2] [-n nspheres2] pmap2 ...\n", argv [0]);
89 return 1;
90 }
91
92 for (arg = 1; arg < argc; arg++) {
93 /* Parse options */
94 if (argv [arg][0] == '-') {
95 switch (argv [arg][1]) {
96 case 'r':
97 if ((radScale = atof(argv [++arg])) <= 0)
98 error(USER, "invalid radius scale");
99 break;
100
101 case 'n':
102 if ((numSpheres = parseMultiplier(argv [++arg])) <= 0)
103 error(USER, "invalid number of spheres");
104 break;
105
106 default:
107 sprintf(errmsg, "unknown option %s", argv [arg]);
108 error(USER, errmsg);
109 return -1;
110 }
111
112 continue;
113 }
114
115 /* Dump photon map */
116 if (!(pmapFile = fopen(argv [arg], "rb"))) {
117 sprintf(errmsg, "can't open %s", argv [arg]);
118 error(SYSTEM, errmsg);
119 }
120
121 /* Get format string */
122 strcpy(format, PMAP_FORMAT_GLOB);
123 if (checkheader(pmapFile, format, NULL) != 1) {
124 sprintf(errmsg, "photon map file %s has unknown format %s",
125 argv [arg], format);
126 error(USER, errmsg);
127 }
128
129 /* Identify photon map type from format string */
130 for (ptype = 0;
131 strcmp(pmapFormat [ptype], format) && ptype < NUM_PMAP_TYPES;
132 ptype++);
133
134 if (!validPmapType(ptype)) {
135 sprintf(errmsg, "file %s contains an unknown photon map type",
136 argv [arg]);
137 error(USER, errmsg);
138 }
139
140 /* Get file format version and check for compatibility */
141 if (getint(sizeof(PMAP_FILEVER), pmapFile) != PMAP_FILEVER)
142 error(USER, "incompatible photon map file format");
143
144 /* Dump command line as comment */
145 fputs("# ", stdout);
146 printargs(argc, argv, stdout);
147 fputc('\n', stdout);
148
149 /* Dump material def */
150 fputs(radDefs [ptype].mat, stdout);
151 fputc('\n', stdout);
152
153 /* Get number of photons (is this sizeof() hack portable?) */
154 numPhotons = getint(sizeof(((PhotonMap*)NULL) -> heapSize), pmapFile);
155
156 /* Skip avg photon flux */
157 for (j = 0; j < 3; j++)
158 getflt(pmapFile);
159
160 /* Get distribution extent (min & max photon positions) */
161 for (j = 0; j < 3; j++) {
162 minPos [j] = getflt(pmapFile);
163 maxPos [j] = getflt(pmapFile);
164 }
165
166 /* Skip centre of gravity, and avg photon dist to it */
167 for (j = 0; j < 4; j++)
168 getflt(pmapFile);
169
170 /* Sphere radius based on avg intersphere dist
171 (= sphere distrib density ^-1/3) */
172 vol = (maxPos [0] - minPos [0]) * (maxPos [1] - minPos [1]) *
173 (maxPos [2] - minPos [2]);
174 rad = radScale * RADCOEFF * pow(vol / numSpheres, 1./3.);
175
176 /* Photon dump probability to satisfy target sphere count */
177 dumpRatio = numSpheres < numPhotons ? (float)numSpheres / numPhotons
178 : 1;
179
180 while (numPhotons-- > 0) {
181 /* Get photon position */
182 for (j = 0; j < 3; j++)
183 p.pos [j] = getflt(pmapFile);
184
185 /* Dump photon probabilistically acc. to target sphere count */
186 if (frandom() <= dumpRatio) {
187 printf(radDefs [ptype].obj, p.pos [0], p.pos [1], p.pos [2], rad);
188 fputc('\n', stdout);
189 }
190
191 /* Skip photon normal and flux */
192 for (j = 0; j < 3; j++)
193 getint(sizeof(p.norm [j]), pmapFile);
194
195 #ifdef PMAP_FLOAT_FLUX
196 for (j = 0; j < 3; j++)
197 getflt(pmapFile);
198 #else
199 for (j = 0; j < 4; j++)
200 getint(1, pmapFile);
201 #endif
202
203 /* Skip primary ray index */
204 getint(sizeof(p.primary), pmapFile);
205
206 /* Skip flags */
207 getint(sizeof(p.flags), pmapFile);
208
209 if (feof(pmapFile)) {
210 sprintf(errmsg, "error reading %s", argv [arg]);
211 error(USER, errmsg);
212 }
213 }
214
215 fclose(pmapFile);
216
217 /* Reset defaults for next dump */
218 radScale = RADSCALE;
219 numSpheres = NSPHERES;
220 }
221
222 return 0;
223 }
