root/radiance/ray/src/rt/pmapdump.c
Thu Aug 2 18:33:49 2018 UTC (6 years, 9 months ago) by greg
Thu Feb 8 19:55:02 2018 UTC (7 years, 3 months ago) by rschregle
Changes since 2.9: +8 -4 lines
Made photon primary incident dirs optional via PMAP_PRIMARYDIR, bumped PMAP_FILEVER
Sat Dec 9 18:40:43 2017 UTC (7 years, 5 months ago) by rschregle
Changes since 2.8: +19 -10 lines
Fixed sphere radius for coplanar (and even colinear!) photon distribs
Mon Aug 14 21:12:10 2017 UTC (7 years, 8 months ago) by rschregle
Changes since 2.7: +7 -3 lines
Updated photon map code for Windows; no multproc or ooC for now
Tue May 17 17:39:47 2016 UTC (8 years, 11 months ago) by rschregle
Changes since 2.6: +69 -32 lines
Thu Feb 4 19:39:10 2016 UTC (9 years, 3 months ago) by rschregle
Fixed SEGFAULTs when pmapdump fails to identify newer pmap formats
Tue Sep 1 16:27:52 2015 UTC (9 years, 8 months ago) by greg
Tue Aug 18 18:45:55 2015 UTC (9 years, 8 months ago) by greg
Changes since 2.3: +5 -2 lines
Fri May 8 13:20:23 2015 UTC (10 years ago) by rschregle
Changes since 2.2: +5 -4 lines
Tue Apr 21 19:16:51 2015 UTC (10 years ago) by greg
Changes since 2.1: +4 -3 lines
Fixes for Windows and photon map
Tue Feb 24 19:39:27 2015 UTC (10 years, 2 months ago) by greg
Diff to selected 2.2
