| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: pmapdump.c,v 2.4 2015/08/18 18:45:55 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
| 6 |
Dump photon maps as RADIANCE scene description to stdout
| 7 |
| 8 |
Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
| 9 |
(c) Fraunhofer Institute for Solar Energy Systems,
| 10 |
(c) Lucerne University of Applied Sciences and Arts,
| 11 |
supported by the Swiss National Science Foundation (SNSF, #147053)
| 12 |
| 13 |
| 14 |
| 15 |
| 16 |
| 17 |
| 18 |
#include "pmapio.h"
| 19 |
#include "pmapparm.h"
| 20 |
#include "pmaptype.h"
| 21 |
#include "rtio.h"
| 22 |
#include "resolu.h"
| 23 |
#include "random.h"
| 24 |
#include "math.h"
| 25 |
| 26 |
| 27 |
/* Defaults */
| 28 |
/* Sphere radius as fraction of avg. intersphere dist */
| 29 |
/* Relative scale for sphere radius (fudge factor) */
| 30 |
/* Number of spheres */
| 31 |
#define RADCOEFF 0.05
| 32 |
#define RADSCALE 1.0
| 33 |
#define NSPHERES 10000
| 34 |
| 35 |
| 36 |
/* RADIANCE material and object defs for each photon type */
| 37 |
typedef struct {
| 38 |
char *mat, *obj;
| 39 |
} RadianceDef;
| 40 |
| 41 |
| 42 |
static char header [] = "$Revision: 2.4 $";
| 43 |
| 44 |
| 45 |
/* Colour code is as follows: global = blue
| 46 |
precomp global = cyan
| 47 |
caustic = red
| 48 |
volume = green
| 49 |
direct = magenta
| 50 |
contrib = yellow */
| 51 |
const RadianceDef radDefs [] = {
| 52 |
{ "void plastic mat.global\n0\n0\n5 0 0 1 0 0\n",
| 53 |
"mat.global sphere obj.global\n0\n0\n4 %g %g %g %g\n"
| 54 |
| 55 |
{ "void plastic mat.pglobal\n0\n0\n5 0 1 1 0 0\n",
| 56 |
"mat.pglobal sphere obj.global\n0\n0\n4 %g %g %g %g\n"
| 57 |
| 58 |
{ "void plastic mat.caustic\n0\n0\n5 1 0 0 0 0\n",
| 59 |
"mat.caustic sphere obj.caustic\n0\n0\n4 %g %g %g %g\n"
| 60 |
| 61 |
{ "void plastic mat.volume\n0\n0\n5 0 1 0 0 0\n",
| 62 |
"mat.volume sphere obj.volume\n0\n0\n4 %g %g %g %g\n"
| 63 |
| 64 |
{ "void plastic mat.direct\n0\n0\n5 1 0 1 0 0\n",
| 65 |
"mat.direct sphere obj.direct\n0\n0\n4 %g %g %g %g\n"
| 66 |
| 67 |
{ "void plastic mat.contrib\n0\n0\n5 1 1 0 0 0\n",
| 68 |
"mat.contrib sphere obj.contrib\n0\n0\n4 %g %g %g %g\n"
| 69 |
| 70 |
| 71 |
| 72 |
| 73 |
| 74 |
int main (int argc, char** argv)
| 75 |
| 76 |
char format [128];
| 77 |
RREAL rad, radScale = RADSCALE, vol, dumpRatio;
| 78 |
FVECT minPos, maxPos;
| 79 |
unsigned arg, j, ptype;
| 80 |
long numPhotons, numSpheres = NSPHERES;
| 81 |
FILE *pmapFile;
| 82 |
Photon p;
| 83 |
| 84 |
if (argc < 2) {
| 85 |
puts("Dump photon maps as RADIANCE scene description\n");
| 86 |
printf("Usage: %s [-r radscale1] [-n nspheres1] pmap1 "
| 87 |
"[-r radscale2] [-n nspheres2] pmap2 ...\n", argv [0]);
| 88 |
return 1;
| 89 |
| 90 |
| 91 |
for (arg = 1; arg < argc; arg++) {
| 92 |
/* Parse options */
| 93 |
if (argv [arg][0] == '-') {
| 94 |
switch (argv [arg][1]) {
| 95 |
case 'r':
| 96 |
if ((radScale = atof(argv [++arg])) <= 0)
| 97 |
error(USER, "invalid radius scale");
| 98 |
break;
| 99 |
| 100 |
case 'n':
| 101 |
if ((numSpheres = parseMultiplier(argv [++arg])) <= 0)
| 102 |
error(USER, "invalid number of spheres");
| 103 |
break;
| 104 |
| 105 |
default:
| 106 |
sprintf(errmsg, "unknown option %s", argv [arg]);
| 107 |
error(USER, errmsg);
| 108 |
return -1;
| 109 |
| 110 |
| 111 |
continue;
| 112 |
| 113 |
| 114 |
/* Dump photon map */
| 115 |
if (!(pmapFile = fopen(argv [arg], "rb"))) {
| 116 |
sprintf(errmsg, "can't open %s", argv [arg]);
| 117 |
error(SYSTEM, errmsg);
| 118 |
| 119 |
| 120 |
/* Get format string */
| 121 |
strcpy(format, PMAP_FORMAT_GLOB);
| 122 |
if (checkheader(pmapFile, format, NULL) != 1) {
| 123 |
sprintf(errmsg, "photon map file %s has unknown format %s",
| 124 |
argv [arg], format);
| 125 |
| 126 |
| 127 |
| 128 |
/* Identify photon map type from format string */
| 129 |
for (ptype = 0;
| 130 |
strcmp(pmapFormat [ptype], format) && ptype < NUM_PMAP_TYPES;
| 131 |
ptype++);
| 132 |
| 133 |
if (!validPmapType(ptype)) {
| 134 |
sprintf(errmsg, "file %s contains an unknown photon map type",
| 135 |
argv [arg]);
| 136 |
| 137 |
| 138 |
| 139 |
/* Get file format version and check for compatibility */
| 140 |
if (getint(sizeof(PMAP_FILEVER), pmapFile) != PMAP_FILEVER)
| 141 |
error(USER, "incompatible photon map file format");
| 142 |
| 143 |
/* Dump command line as comment */
| 144 |
fputs("# ", stdout);
| 145 |
printargs(argc, argv, stdout);
| 146 |
fputc('\n', stdout);
| 147 |
| 148 |
/* Dump material def */
| 149 |
fputs(radDefs [ptype].mat, stdout);
| 150 |
| 151 |
| 152 |
/* Get number of photons (is this sizeof() hack portable?) */
| 153 |
numPhotons = getint(sizeof(((PhotonMap*)NULL) -> heapSize), pmapFile);
| 154 |
| 155 |
/* Skip avg photon flux */
| 156 |
for (j = 0; j < 3; j++)
| 157 |
getflt(pmapFile);
| 158 |
| 159 |
/* Get distribution extent (min & max photon positions) */
| 160 |
for (j = 0; j < 3; j++) {
| 161 |
minPos [j] = getflt(pmapFile);
| 162 |
maxPos [j] = getflt(pmapFile);
| 163 |
| 164 |
| 165 |
/* Skip centre of gravity, and avg photon dist to it */
| 166 |
for (j = 0; j < 4; j++)
| 167 |
getflt(pmapFile);
| 168 |
| 169 |
/* Sphere radius based on avg intersphere dist
| 170 |
(= sphere distrib density ^-1/3) */
| 171 |
vol = (maxPos [0] - minPos [0]) * (maxPos [1] - minPos [1]) *
| 172 |
(maxPos [2] - minPos [2]);
| 173 |
rad = radScale * RADCOEFF * pow(vol / numSpheres, 1./3.);
| 174 |
| 175 |
/* Photon dump probability to satisfy target sphere count */
| 176 |
dumpRatio = numSpheres < numPhotons ? (float)numSpheres / numPhotons
| 177 |
: 1;
| 178 |
| 179 |
while (numPhotons-- > 0) {
| 180 |
/* Get photon position */
| 181 |
| 182 |
p.pos [j] = getflt(pmapFile);
| 183 |
| 184 |
/* Dump photon probabilistically acc. to target sphere count */
| 185 |
if (frandom() <= dumpRatio) {
| 186 |
printf(radDefs [ptype].obj, p.pos [0], p.pos [1], p.pos [2], rad);
| 187 |
| 188 |
| 189 |
| 190 |
/* Skip photon normal and flux */
| 191 |
| 192 |
getint(sizeof(p.norm [j]), pmapFile);
| 193 |
| 194 |
#ifdef PMAP_FLOAT_FLUX
| 195 |
| 196 |
getflt(pmapFile);
| 197 |
#else
| 198 |
| 199 |
getint(1, pmapFile);
| 200 |
#endif
| 201 |
| 202 |
/* Skip primary ray index */
| 203 |
getint(sizeof(p.primary), pmapFile);
| 204 |
| 205 |
/* Skip flags */
| 206 |
getint(sizeof(p.flags), pmapFile);
| 207 |
| 208 |
if (feof(pmapFile)) {
| 209 |
sprintf(errmsg, "error reading %s", argv [arg]);
| 210 |
| 211 |
| 212 |
| 213 |
| 214 |
fclose(pmapFile);
| 215 |
| 216 |
/* Reset defaults for next dump */
| 217 |
radScale = RADSCALE;
| 218 |
| 219 |
| 220 |
| 221 |
return 0;
| 222 |
