root/Development/ray/src/rt/pmapdump.c
Revision: 2.18
Committed: Thu Feb 18 17:08:50 2021 UTC (4 years, 10 months ago) by rschregle
CVS Tags: rad6R0, rad5R4, HEAD
Changes since 2.17: +14 -9 lines
fix(mkpmap,pmapdump): Made pmap files (hopefully) more portable by
forcing numPhotons to fixed size irrespective of platform (possibly with 0-padding)
2 static const char RCSid[] = "$Id: pmapdump.c,v 2.17 2020/08/07 01:21:13 rschregle Exp $";
4
5 /*
6 ======================================================================
7 Dump photon maps as RADIANCE scene description or ASCII point list
8 to stdout
9
10 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
11 (c) Fraunhofer Institute for Solar Energy Systems,
12 supported by the German Research Foundation
13 (DFG LU-204/10-2, "Fassadenintegrierte Regelsysteme FARESYS")
14 (c) Lucerne University of Applied Sciences and Arts,
15 supported by the Swiss National Science Foundation
16 (SNSF #147053, "Daylight Redirecting Components")
17 (c) Tokyo University of Science,
18 supported by the JSPS Grants-in-Aid for Scientific Research
19 (KAKENHI JP19KK0115, "Three-Dimensional Light Flow")
20 ======================================================================
21
22 $Id: pmapdump.c,v 2.17 2020/08/07 01:21:13 rschregle Exp $
23 */
24
25
26
27 #include "pmap.h"
28 #include "pmapio.h"
29 #include "rtio.h"
30 #include "resolu.h"
31 #include "random.h"
32 #include "math.h"
33
34
35 /* Defaults */
36 /* Sphere radius as fraction of avg. intersphere dist */
37 /* Relative scale for sphere radius (fudge factor) */
38 /* Number of spheres */
39 #define RADCOEFF 0.05
40 #define RADSCALE 1.0
41 #define NSPHERES 10000
42
43 /* Format for optional ASCII output as XYZ RGB points */
44 #define POINTFMT "%g\t%g\t%g\t%g\t%g\t%g\n"
45
46 /* RADIANCE material and object defs for each photon type */
47 typedef struct {
48 char *mat, *obj;
49 } RadianceDef;
50
51 const RadianceDef radDefs [] = {
52 { "void glow mat.global\n0\n0\n4 %g %g %g 0\n",
53 "mat.global sphere obj.global\n0\n0\n4 %g %g %g %g\n"
54 },
55 { "void glow mat.pglobal\n0\n0\n4 %g %g %g 0\n",
56 "mat.pglobal sphere obj.pglobal\n0\n0\n4 %g %g %g %g\n"
57 },
58 { "void glow mat.caustic\n0\n0\n4 %g %g %g 0\n",
59 "mat.caustic sphere obj.caustic\n0\n0\n4 %g %g %g %g\n"
60 },
61 { "void glow mat.volume\n0\n0\n4 %g %g %g 0\n",
62 "mat.volume sphere obj.volume\n0\n0\n4 %g %g %g %g\n"
63 },
64 { "void glow mat.direct\n0\n0\n4 %g %g %g 0\n",
65 "mat.direct sphere obj.direct\n0\n0\n4 %g %g %g %g\n"
66 },
67 { "void glow mat.contrib\n0\n0\n4 %g %g %g 0\n",
68 "mat.contrib sphere obj.contrib\n0\n0\n4 %g %g %g %g\n"
69 }
70 };
71
72
73 /* Default colour codes are as follows: global = blue
74 precomp global = cyan
75 caustic = red
76 volume = green
77 direct = magenta
78 contrib = yellow */
79 const COLOR colDefs [] = {
80 {0.25, 0.25, 2}, {0.1, 1, 1}, {1, 0.1, 0.1},
81 {0.1, 1, 0.1}, {1, 0.1, 1}, {1, 1, 0.1}
82 };
83
84
85 static int setBool(char *str, unsigned pos, unsigned *var)
86 {
87 switch ((str) [pos]) {
88 case '\0':
89 *var = !*var;
90 break;
91 case 'y': case 'Y': case 't': case 'T': case '+': case '1':
92 *var = 1;
93 break;
94 case 'n': case 'N': case 'f': case 'F': case '-': case '0':
95 *var = 0;
96 break;
97 default:
98 return 0;
99 }
100
101 return 1;
102 }
103
104
105 int main (int argc, char** argv)
106 {
107 char format [MAXFMTLEN];
108 RREAL rad, radScale = RADSCALE, extent, dumpRatio;
109 unsigned arg, j, ptype, dim, fluxCol = 0, points = 0;
110 long numSpheres = NSPHERES;
111 COLOR col = {0, 0, 0};
112 FILE *pmapFile;
113 PhotonMap pm;
114 PhotonPrimary pri;
115 Photon p;
116 #ifdef PMAP_OOC
117 char leafFname [1024];
118 #endif
119
120 if (argc < 2) {
121 puts("Dump photon maps as RADIANCE scene description "
122 "or ASCII point list\n");
123 printf("Usage: %s "
124 "[-a] [-r radscale1] [-n num1] "
125 "[-f | -c rcol1 gcol1 bcol1] pmap1 "
126 "[-a] [-r radscale2] [-n num2] "
127 "[-f | -c rcol2 gcol2 bcol2] pmap2 "
128 "...\n", argv [0]);
129 return 1;
130 }
131
132 for (arg = 1; arg < argc; arg++) {
133 /* Parse options */
134 if (argv [arg][0] == '-') {
135 switch (argv [arg][1]) {
136 case 'a':
137 if (!setBool(argv [arg], 2, &points))
138 error(USER, "invalid option syntax at -a");
139 break;
140 case 'r':
141 if ((radScale = atof(argv [++arg])) <= 0)
142 error(USER, "invalid radius scale");
143 break;
144
145 case 'n':
146 if ((numSpheres = parseMultiplier(argv [++arg])) <= 0)
147 error(USER, "invalid number of points/spheres");
148 break;
149
150 case 'c':
151 if (fluxCol)
152 error(USER, "-f and -c are mutually exclusive");
153
154 if (badarg(argc - arg - 1, &argv [arg + 1], "fff"))
155 error(USER, "invalid RGB colour");
156
157 for (j = 0; j < 3; j++)
158 col [j] = atof(argv [++arg]);
159 break;
160
161 case 'f':
162 if (intens(col) > 0)
163 error(USER, "-f and -c are mutually exclusive");
164
165 if (!setBool(argv [arg], 2, &fluxCol))
166 error(USER, "invalid option syntax at -f");
167 break;
168
169 default:
170 sprintf(errmsg, "unknown option %s", argv [arg]);
171 error(USER, errmsg);
172 return -1;
173 }
174
175 continue;
176 }
177
178 /* Open next photon map file */
179 if (!(pmapFile = fopen(argv [arg], "rb"))) {
180 sprintf(errmsg, "can't open %s", argv [arg]);
181 error(SYSTEM, errmsg);
182 }
183
184 /* Get format string */
185 strcpy(format, PMAP_FORMAT_GLOB);
186 if (checkheader(pmapFile, format, NULL) != 1) {
187 sprintf(errmsg, "photon map file %s has unknown format %s",
188 argv [arg], format);
189 error(USER, errmsg);
190 }
191
192 /* Identify photon map type from format string */
193 for (ptype = 0;
194 ptype < NUM_PMAP_TYPES && strcmp(pmapFormat [ptype], format);
195 ptype++);
196
197 if (!validPmapType(ptype)) {
198 sprintf(errmsg, "file %s contains an unknown photon map type",
199 argv [arg]);
200 error(USER, errmsg);
201 }
202
203 /* Get file format version and check for compatibility */
204 if (strcmp(getstr(format, pmapFile), PMAP_FILEVER))
205 error(USER, "incompatible photon map file format");
206
207 if (!points) {
208 /* Dump command line as comment */
209 fputs("# ", stdout);
210 printargs(argc, argv, stdout);
211 fputc('\n', stdout);
212 }
213
214 /* Set point/sphere colour if independent of photon flux,
215 output RADIANCE material def if required */
216 if (!fluxCol) {
217 if (intens(col) <= 0)
218 copycolor(col, colDefs [ptype]);
219 if (!points) {
220 printf(radDefs [ptype].mat, col [0], col [1], col [2]);
221 fputc('\n', stdout);
222 }
223 }
224
225 /* Get number of photons as fixed size, which possibly results in
226 * padding of MSB with 0 on some platforms. Unlike sizeof() however,
227 * this ensures portability since this value may span 32 or 64 bits
228 * depending on platform. */
229 pm.numPhotons = getint(PMAP_LONGSIZE, pmapFile);
230
231 /* Skip avg photon flux */
232 for (j = 0; j < 3; j++)
233 getflt(pmapFile);
234
235 /* Get distribution extent (min & max photon positions) */
236 for (j = 0; j < 3; j++) {
237 pm.minPos [j] = getflt(pmapFile);
238 pm.maxPos [j] = getflt(pmapFile);
239 }
240
241 /* Skip centre of gravity, and avg photon dist to it */
242 for (j = 0; j < 4; j++)
243 getflt(pmapFile);
244
245 /* Sphere radius based on avg intersphere dist depending on
246 whether the distribution occupies a 1D line (!), a 2D plane,
247 or 3D volume (= sphere distrib density ^-1/d, where d is the
248 dimensionality of the distribution) */
249 for (j = 0, extent = 1.0, dim = 0; j < 3; j++) {
250 rad = pm.maxPos [j] - pm.minPos [j];
251
252 if (rad > FTINY) {
253 dim++;
254 extent *= rad;
255 }
256 }
257
258 rad = radScale * RADCOEFF * pow(extent / numSpheres, 1./dim);
259
260 /* Photon dump probability to satisfy target sphere count */
261 dumpRatio = min(1, (float)numSpheres / pm.numPhotons);
262
263 /* Skip primary rays */
264 pm.numPrimary = getint(sizeof(pm.numPrimary), pmapFile);
265 while (pm.numPrimary-- > 0) {
266 /* Skip source index & incident dir */
267 getint(sizeof(pri.srcIdx), pmapFile);
268 #ifdef PMAP_PRIMARYDIR
269 /* Skip primary incident dir */
270 getint(sizeof(pri.dir), pmapFile);
271 #endif
272 #ifdef PMAP_PRIMARYPOS
273 /* Skip primary hitpoint */
274 for (j = 0; j < 3; j++)
275 getflt(pmapFile);
276 #endif
277 }
278
279 #ifdef PMAP_OOC
280 /* Open leaf file with filename derived from pmap, replace pmapFile
281 * (which is currently the node file) */
282 strncpy(leafFname, argv [arg], sizeof(leafFname) - 1);
283 strncat(leafFname, PMAP_OOC_LEAFSUFFIX, sizeof(leafFname) - 1);
284 fclose(pmapFile);
285 if (!(pmapFile = fopen(leafFname, "rb"))) {
286 sprintf(errmsg, "cannot open leaf file %s", leafFname);
287 error(SYSTEM, errmsg);
288 }
289 #endif
290
291 /* Read photons */
292 while (pm.numPhotons-- > 0) {
293 #ifdef PMAP_OOC
294 /* Get entire photon record from ooC octree leaf file
295 !!! OOC PMAP FILES CURRENTLY DON'T USE PORTABLE I/O !!! */
296 if (!fread(&p, sizeof(p), 1, pmapFile)) {
297 sprintf(errmsg, "error reading OOC leaf file %s", leafFname);
298 error(SYSTEM, errmsg);
299 }
300 #else /* kd-tree */
301 /* Get photon position */
302 for (j = 0; j < 3; j++)
303 p.pos [j] = getflt(pmapFile);
304
305 /* Get photon normal (currently not used) */
306 for (j = 0; j < 3; j++)
307 p.norm [j] = getint(1, pmapFile);
308
309 /* Get photon flux */
310 #ifdef PMAP_FLOAT_FLUX
311 for (j = 0; j < 3; j++)
312 p.flux [j] = getflt(pmapFile);
313 #else
314 for (j = 0; j < 4; j++)
315 p.flux [j] = getint(1, pmapFile);
316 #endif
317
318
319
320 /* Skip primary ray index */
321 getint(sizeof(p.primary), pmapFile);
322
323 /* Skip flags */
324 getint(sizeof(p.flags), pmapFile);
325 #endif
326
327 /* Dump photon probabilistically acc. to target sphere count */
328 if (frandom() <= dumpRatio) {
329 if (fluxCol) {
330 /* Get photon flux */
331 getPhotonFlux(&p, col);
332 /* Scale by dumpRatio for energy conservation */
333 scalecolor(col, 1.0 / dumpRatio);
334 }
335
336 if (!points) {
337 if (fluxCol) {
338 /* Dump material def if variable (depends on flux) */
339 printf(radDefs [ptype].mat, col [0], col [1], col [2]);
340 fputc('\n', stdout);
341 }
342 printf(radDefs [ptype].obj, p.pos [0], p.pos [1], p.pos [2],
343 rad);
344 fputc('\n', stdout);
345 }
346 else /* Dump as XYZ RGB point */
347 printf(POINTFMT, p.pos [0], p.pos [1], p.pos [2],
348 col [0], col [1] ,col [2]);
349 }
350
351 if (ferror(pmapFile) || feof(pmapFile)) {
352 sprintf(errmsg, "error reading %s", argv [arg]);
353 error(USER, errmsg);
354 }
355 }
356
357 fclose(pmapFile);
358
359 /* Reset defaults for next dump */
360 radScale = RADSCALE;
361 numSpheres = NSPHERES;
362 col [0] = col [1] = col [2] = 0;
363 fluxCol = points = 0;
364 }
365
366 return 0;
367 }
