root/radiance/ray/src/rt/pmapdump.c
Revision: 2.18
Committed: Thu Feb 18 17:08:50 2021 UTC (4 years, 5 months ago) by rschregle
CVS Tags: rad5R4, rad6R0, HEAD
Changes since 2.17: +14 -9 lines
fix(mkpmap,pmapdump): Made pmap files (hopefully) more portable by
forcing numPhotons to fixed size irrespective of platform (possibly with 0-padding)
# User Rev Content
1 greg 2.4 #ifndef lint
2 rschregle 2.18 static const char RCSid[] = "$Id: pmapdump.c,v 2.17 2020/08/07 01:21:13 rschregle Exp $";
3 greg 2.4 #endif
4 rschregle 2.7
5 greg 2.1 /*
6 rschregle 2.7 ======================================================================
7 rschregle 2.14 Dump photon maps as RADIANCE scene description or ASCII point list
8     to stdout
9 greg 2.1
10     Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
11     (c) Fraunhofer Institute for Solar Energy Systems,
12 rschregle 2.18 supported by the German Research Foundation
13     (DFG LU-204/10-2, "Fassadenintegrierte Regelsysteme FARESYS")
14 rschregle 2.3 (c) Lucerne University of Applied Sciences and Arts,
15 rschregle 2.18 supported by the Swiss National Science Foundation
16     (SNSF #147053, "Daylight Redirecting Components")
17 rschregle 2.16 (c) Tokyo University of Science,
18 rschregle 2.18 supported by the JSPS Grants-in-Aid for Scientific Research
19     (KAKENHI JP19KK0115, "Three-Dimensional Light Flow")
20 rschregle 2.7 ======================================================================
21 greg 2.1
22 rschregle 2.18 $Id: pmapdump.c,v 2.17 2020/08/07 01:21:13 rschregle Exp $
23 greg 2.1 */
24
25
26
27 rschregle 2.14 #include "pmap.h"
28 greg 2.1 #include "pmapio.h"
29     #include "rtio.h"
30     #include "resolu.h"
31     #include "random.h"
32 greg 2.2 #include "math.h"
33 greg 2.1
34
35     /* Defaults */
36     /* Sphere radius as fraction of avg. intersphere dist */
37     /* Relative scale for sphere radius (fudge factor) */
38     /* Number of spheres */
39     #define RADCOEFF 0.05
40     #define RADSCALE 1.0
41     #define NSPHERES 10000
42
43 rschregle 2.14 /* Format for optional ASCII output as XYZ RGB points */
44     #define POINTFMT "%g\t%g\t%g\t%g\t%g\t%g\n"
45 greg 2.1
46     /* RADIANCE material and object defs for each photon type */
47     typedef struct {
48     char *mat, *obj;
49     } RadianceDef;
50
51     const RadianceDef radDefs [] = {
52 rschregle 2.14 { "void glow mat.global\n0\n0\n4 %g %g %g 0\n",
53 greg 2.1 "mat.global sphere obj.global\n0\n0\n4 %g %g %g %g\n"
54     },
55 rschregle 2.14 { "void glow mat.pglobal\n0\n0\n4 %g %g %g 0\n",
56 rschregle 2.13 "mat.pglobal sphere obj.pglobal\n0\n0\n4 %g %g %g %g\n"
57 greg 2.1 },
58 rschregle 2.14 { "void glow mat.caustic\n0\n0\n4 %g %g %g 0\n",
59 greg 2.1 "mat.caustic sphere obj.caustic\n0\n0\n4 %g %g %g %g\n"
60     },
61 rschregle 2.14 { "void glow mat.volume\n0\n0\n4 %g %g %g 0\n",
62 greg 2.1 "mat.volume sphere obj.volume\n0\n0\n4 %g %g %g %g\n"
63     },
64 rschregle 2.14 { "void glow mat.direct\n0\n0\n4 %g %g %g 0\n",
65 greg 2.1 "mat.direct sphere obj.direct\n0\n0\n4 %g %g %g %g\n"
66     },
67 rschregle 2.14 { "void glow mat.contrib\n0\n0\n4 %g %g %g 0\n",
68 greg 2.1 "mat.contrib sphere obj.contrib\n0\n0\n4 %g %g %g %g\n"
69     }
70     };
71
72 rschregle 2.14
73 rschregle 2.12 /* Default colour codes are as follows: global = blue
74     precomp global = cyan
75     caustic = red
76     volume = green
77     direct = magenta
78     contrib = yellow */
79     const COLOR colDefs [] = {
80 rschregle 2.13 {0.25, 0.25, 2}, {0.1, 1, 1}, {1, 0.1, 0.1},
81     {0.1, 1, 0.1}, {1, 0.1, 1}, {1, 1, 0.1}
82 rschregle 2.12 };
83 greg 2.1
84
85 rschregle 2.14 static int setBool(char *str, unsigned pos, unsigned *var)
86     {
87     switch ((str) [pos]) {
88     case '\0':
89     *var = !*var;
90     break;
91     case 'y': case 'Y': case 't': case 'T': case '+': case '1':
92     *var = 1;
93     break;
94     case 'n': case 'N': case 'f': case 'F': case '-': case '0':
95     *var = 0;
96     break;
97     default:
98     return 0;
99     }
100
101     return 1;
102     }
103
104
105 greg 2.1 int main (int argc, char** argv)
106     {
107 greg 2.11 char format [MAXFMTLEN];
108 rschregle 2.9 RREAL rad, radScale = RADSCALE, extent, dumpRatio;
109 rschregle 2.14 unsigned arg, j, ptype, dim, fluxCol = 0, points = 0;
110 rschregle 2.7 long numSpheres = NSPHERES;
111 rschregle 2.14 COLOR col = {0, 0, 0};
112 rschregle 2.7 FILE *pmapFile;
113     PhotonMap pm;
114     PhotonPrimary pri;
115     Photon p;
116     #ifdef PMAP_OOC
117     char leafFname [1024];
118     #endif
119 rschregle 2.13
120 greg 2.1 if (argc < 2) {
121 rschregle 2.14 puts("Dump photon maps as RADIANCE scene description "
122     "or ASCII point list\n");
123 rschregle 2.12 printf("Usage: %s "
124 rschregle 2.14 "[-a] [-r radscale1] [-n num1] "
125     "[-f | -c rcol1 gcol1 bcol1] pmap1 "
126     "[-a] [-r radscale2] [-n num2] "
127     "[-f | -c rcol2 gcol2 bcol2] pmap2 "
128 rschregle 2.12 "...\n", argv [0]);
129 greg 2.1 return 1;
130     }
131
132     for (arg = 1; arg < argc; arg++) {
133     /* Parse options */
134     if (argv [arg][0] == '-') {
135     switch (argv [arg][1]) {
136 rschregle 2.14 case 'a':
137     if (!setBool(argv [arg], 2, &points))
138     error(USER, "invalid option syntax at -a");
139     break;
140 greg 2.1 case 'r':
141     if ((radScale = atof(argv [++arg])) <= 0)
142     error(USER, "invalid radius scale");
143     break;
144
145     case 'n':
146     if ((numSpheres = parseMultiplier(argv [++arg])) <= 0)
147 rschregle 2.14 error(USER, "invalid number of points/spheres");
148 greg 2.1 break;
149
150 rschregle 2.12 case 'c':
151 rschregle 2.13 if (fluxCol)
152     error(USER, "-f and -c are mutually exclusive");
153
154     if (badarg(argc - arg - 1, &argv [arg + 1], "fff"))
155     error(USER, "invalid RGB colour");
156
157 rschregle 2.12 for (j = 0; j < 3; j++)
158 rschregle 2.14 col [j] = atof(argv [++arg]);
159 rschregle 2.13 break;
160
161     case 'f':
162 rschregle 2.14 if (intens(col) > 0)
163 rschregle 2.13 error(USER, "-f and -c are mutually exclusive");
164
165     if (!setBool(argv [arg], 2, &fluxCol))
166     error(USER, "invalid option syntax at -f");
167 rschregle 2.12 break;
168
169 greg 2.1 default:
170     sprintf(errmsg, "unknown option %s", argv [arg]);
171     error(USER, errmsg);
172     return -1;
173     }
174
175     continue;
176     }
177 rschregle 2.13
178 rschregle 2.14 /* Open next photon map file */
179 greg 2.1 if (!(pmapFile = fopen(argv [arg], "rb"))) {
180     sprintf(errmsg, "can't open %s", argv [arg]);
181     error(SYSTEM, errmsg);
182     }
183 rschregle 2.13
184 greg 2.1 /* Get format string */
185     strcpy(format, PMAP_FORMAT_GLOB);
186     if (checkheader(pmapFile, format, NULL) != 1) {
187     sprintf(errmsg, "photon map file %s has unknown format %s",
188     argv [arg], format);
189     error(USER, errmsg);
190     }
191 rschregle 2.13
192 greg 2.1 /* Identify photon map type from format string */
193     for (ptype = 0;
194 rschregle 2.6 ptype < NUM_PMAP_TYPES && strcmp(pmapFormat [ptype], format);
195 greg 2.1 ptype++);
196 rschregle 2.13
197 greg 2.1 if (!validPmapType(ptype)) {
198     sprintf(errmsg, "file %s contains an unknown photon map type",
199     argv [arg]);
200     error(USER, errmsg);
201     }
202
203     /* Get file format version and check for compatibility */
204 rschregle 2.7 if (strcmp(getstr(format, pmapFile), PMAP_FILEVER))
205 greg 2.1 error(USER, "incompatible photon map file format");
206 rschregle 2.13
207 rschregle 2.14 if (!points) {
208     /* Dump command line as comment */
209     fputs("# ", stdout);
210     printargs(argc, argv, stdout);
211     fputc('\n', stdout);
212     }
213
214     /* Set point/sphere colour if independent of photon flux,
215     output RADIANCE material def if required */
216 rschregle 2.13 if (!fluxCol) {
217 rschregle 2.14 if (intens(col) <= 0)
218     copycolor(col, colDefs [ptype]);
219     if (!points) {
220     printf(radDefs [ptype].mat, col [0], col [1], col [2]);
221     fputc('\n', stdout);
222     }
223 rschregle 2.13 }
224 rschregle 2.18
225     /* Get number of photons as fixed size, which possibly results in
226     * padding of MSB with 0 on some platforms. Unlike sizeof() however,
227     * this ensures portability since this value may span 32 or 64 bits
228     * depending on platform. */
229     pm.numPhotons = getint(PMAP_LONGSIZE, pmapFile);
230 rschregle 2.13
231 greg 2.1 /* Skip avg photon flux */
232     for (j = 0; j < 3; j++)
233     getflt(pmapFile);
234 rschregle 2.13
235 greg 2.1 /* Get distribution extent (min & max photon positions) */
236     for (j = 0; j < 3; j++) {
237 rschregle 2.7 pm.minPos [j] = getflt(pmapFile);
238     pm.maxPos [j] = getflt(pmapFile);
239 greg 2.1 }
240
241     /* Skip centre of gravity, and avg photon dist to it */
242     for (j = 0; j < 4; j++)
243     getflt(pmapFile);
244
245 rschregle 2.9 /* Sphere radius based on avg intersphere dist depending on
246     whether the distribution occupies a 1D line (!), a 2D plane,
247     or 3D volume (= sphere distrib density ^-1/d, where d is the
248     dimensionality of the distribution) */
249     for (j = 0, extent = 1.0, dim = 0; j < 3; j++) {
250     rad = pm.maxPos [j] - pm.minPos [j];
251
252     if (rad > FTINY) {
253     dim++;
254     extent *= rad;
255     }
256     }
257
258     rad = radScale * RADCOEFF * pow(extent / numSpheres, 1./dim);
259 greg 2.1
260     /* Photon dump probability to satisfy target sphere count */
261 rschregle 2.14 dumpRatio = min(1, (float)numSpheres / pm.numPhotons);
262 greg 2.1
263 rschregle 2.7 /* Skip primary rays */
264     pm.numPrimary = getint(sizeof(pm.numPrimary), pmapFile);
265     while (pm.numPrimary-- > 0) {
266 rschregle 2.8 /* Skip source index & incident dir */
267 rschregle 2.10 getint(sizeof(pri.srcIdx), pmapFile);
268     #ifdef PMAP_PRIMARYDIR
269     /* Skip primary incident dir */
270     getint(sizeof(pri.dir), pmapFile);
271 rschregle 2.13 #endif
272     #ifdef PMAP_PRIMARYPOS
273 rschregle 2.8 /* Skip primary hitpoint */
274 rschregle 2.7 for (j = 0; j < 3; j++)
275     getflt(pmapFile);
276 rschregle 2.8 #endif
277 rschregle 2.7 }
278
279     #ifdef PMAP_OOC
280     /* Open leaf file with filename derived from pmap, replace pmapFile
281     * (which is currently the node file) */
282 rschregle 2.16 strncpy(leafFname, argv [arg], sizeof(leafFname) - 1);
283     strncat(leafFname, PMAP_OOC_LEAFSUFFIX, sizeof(leafFname) - 1);
284 rschregle 2.7 fclose(pmapFile);
285     if (!(pmapFile = fopen(leafFname, "rb"))) {
286     sprintf(errmsg, "cannot open leaf file %s", leafFname);
287     error(SYSTEM, errmsg);
288     }
289     #endif
290
291 rschregle 2.14 /* Read photons */
292 rschregle 2.7 while (pm.numPhotons-- > 0) {
293     #ifdef PMAP_OOC
294 rschregle 2.13 /* Get entire photon record from ooC octree leaf file
295 rschregle 2.7 !!! OOC PMAP FILES CURRENTLY DON'T USE PORTABLE I/O !!! */
296     if (!fread(&p, sizeof(p), 1, pmapFile)) {
297     sprintf(errmsg, "error reading OOC leaf file %s", leafFname);
298     error(SYSTEM, errmsg);
299     }
300 rschregle 2.13 #else /* kd-tree */
301     /* Get photon position */
302 greg 2.1 for (j = 0; j < 3; j++)
303     p.pos [j] = getflt(pmapFile);
304 rschregle 2.13
305     /* Get photon normal (currently not used) */
306 greg 2.1 for (j = 0; j < 3; j++)
307 rschregle 2.13 p.norm [j] = getint(1, pmapFile);
308
309     /* Get photon flux */
310     #ifdef PMAP_FLOAT_FLUX
311 rschregle 2.7 for (j = 0; j < 3; j++)
312 rschregle 2.13 p.flux [j] = getflt(pmapFile);
313     #else
314 rschregle 2.7 for (j = 0; j < 4; j++)
315 rschregle 2.13 p.flux [j] = getint(1, pmapFile);
316     #endif
317 rschregle 2.15
318
319 greg 2.1
320     /* Skip primary ray index */
321     getint(sizeof(p.primary), pmapFile);
322
323     /* Skip flags */
324     getint(sizeof(p.flags), pmapFile);
325 rschregle 2.7 #endif
326 rschregle 2.13
327     /* Dump photon probabilistically acc. to target sphere count */
328     if (frandom() <= dumpRatio) {
329 rschregle 2.15 if (fluxCol) {
330 rschregle 2.14 /* Get photon flux */
331     getPhotonFlux(&p, col);
332 rschregle 2.15 /* Scale by dumpRatio for energy conservation */
333     scalecolor(col, 1.0 / dumpRatio);
334     }
335 rschregle 2.14
336     if (!points) {
337     if (fluxCol) {
338     /* Dump material def if variable (depends on flux) */
339     printf(radDefs [ptype].mat, col [0], col [1], col [2]);
340     fputc('\n', stdout);
341     }
342     printf(radDefs [ptype].obj, p.pos [0], p.pos [1], p.pos [2],
343     rad);
344 rschregle 2.13 fputc('\n', stdout);
345     }
346 rschregle 2.14 else /* Dump as XYZ RGB point */
347     printf(POINTFMT, p.pos [0], p.pos [1], p.pos [2],
348     col [0], col [1] ,col [2]);
349 rschregle 2.13 }
350 rschregle 2.14
351 rschregle 2.7 if (ferror(pmapFile) || feof(pmapFile)) {
352 greg 2.1 sprintf(errmsg, "error reading %s", argv [arg]);
353     error(USER, errmsg);
354     }
355     }
356
357     fclose(pmapFile);
358
359     /* Reset defaults for next dump */
360     radScale = RADSCALE;
361     numSpheres = NSPHERES;
362 rschregle 2.14 col [0] = col [1] = col [2] = 0;
363     fluxCol = points = 0;
364 greg 2.1 }
365
366     return 0;
367     }
