root/radiance/ray/src/rt/pmapdiag.h
Tue Sep 17 16:36:05 2024 UTC (8 months, 2 weeks ago) by greg
Changes since 2.7: +10 -3 lines
chore: Added extern "C" to headers to avoid C++ name mangling
Tue May 17 17:39:47 2016 UTC (9 years ago) by rschregle
CVS Tags: rad5R1, rad5R2, rad5R3, rad5R4
Changes since 2.6: +10 -2 lines
Tue Sep 1 16:27:52 2015 UTC (9 years, 9 months ago) by greg
Changes since 2.5: +1 -2 lines
Tue Aug 18 18:45:55 2015 UTC (9 years, 9 months ago) by greg
Fri May 8 13:20:22 2015 UTC (10 years, 1 month ago) by rschregle
Wed Apr 22 20:28:16 2015 UTC (10 years, 1 month ago) by rschregle
Changes since 2.2: +2 -8 lines
Disabled use of SIGCONT if undefined (e.g. on WIN32), removed extra space in
rpict reports after biascomp stats
Tue Apr 21 19:16:51 2015 UTC (10 years, 1 month ago) by greg
Changes since 2.1: +8 -1 lines
Diff to previous 2.1
Fixes for Windows and photon map
Tue Feb 24 19:39:26 2015 UTC (10 years, 3 months ago) by greg
