root/Development/ray/src/rt/pmapdata.h
Revision: 2.8
Committed: Tue Aug 18 18:45:55 2015 UTC (10 years, 2 months ago) by greg
1 /* RCSid $Id$ */
2 /*
3 ==================================================================
4 Photon map data structures and kd-tree handling
5
6 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
7 (c) Fraunhofer Institute for Solar Energy Systems,
8 (c) Lucerne University of Applied Sciences and Arts,
9 supported by the Swiss National Science Foundation (SNSF, #147053)
10 ==================================================================
11
12 $Id: pmapdata.h,v 2.7 2015/07/29 18:54:20 rschregle Exp $
13 */
14
15
16 #ifndef PMAPDATA_H
17 #define PMAPDATA_H
18
19 #include "ray.h"
20 #include "pmaptype.h"
21 #include "lookup.h"
22
23
24 /* Define PMAP_FLOAT_FLUX to store photon flux as floats instead of
25 * compact RGBE, which was found to improve accuracy in analytical
26 * validation. */
27 #ifdef PMAP_FLOAT_FLUX
28 #define setPhotonFlux(p,f) copycolor((p) -> flux, f)
29 #define getPhotonFlux(p,f) copycolor(f, (p) -> flux)
30 #else
31 #define setPhotonFlux(p,f) setcolr((p)->flux, (f)[0], (f)[1], (f)[2])
32 #define getPhotonFlux(p,f) colr_color(f, (p) -> flux)
33 #endif
34
35
36 /* Primary photon ray for light source contributions */
37 typedef struct {
38 int32 srcIdx; /* Index of emitting light source */
39 int32 dir; /* Encoded ray direction */
40 float pos [3]; /* Hit point */
41 } PhotonPrimary;
42
43 #define photonSrcIdx(pm, p) ((pm) -> primary [(p) -> primary].srcIdx)
44
45
46 typedef struct {
47 float pos [3]; /* Photon position */
48 signed char norm [3]; /* Surface normal at pos (incident
49 direction for volume photons) */
50 char flags; /* Bit 0-1: kd-tree discriminator axis,
51 Bit 2: caustic photon */
52 #ifdef PMAP_FLOAT_FLUX
53 COLOR flux;
54 #else
55 COLR flux; /* Photon flux */
56 #endif
57
58 uint32 primary; /* Index to primary ray */
59 } Photon;
60
61 /* Photon flag bitmasks and manipulation macros */
62 #define PMAP_DISCR_BIT 3
63 #define PMAP_CAUST_BIT 4
64 #define photonDiscr(p) ((p).flags & PMAP_DISCR_BIT)
65 #define setPhotonDiscr(p, d) ((p).flags = ((p).flags & ~PMAP_DISCR_BIT) | \
66 ((d) & PMAP_DISCR_BIT))
67
68 /* Photon map type tests */
69 #define isGlobalPmap(p) ((p) -> type == PMAP_TYPE_GLOBAL)
70 #define isCausticPmap(p) ((p) -> type == PMAP_TYPE_CAUSTIC)
71 #define isContribPmap(p) ((p) -> type == PMAP_TYPE_CONTRIB)
72 #define isVolumePmap(p) ((p) -> type == PMAP_TYPE_VOLUME)
73
74
75 /* Queue node for photon lookups */
76 typedef struct {
77 Photon *photon;
78 float dist;
79 } PhotonSQNode;
80
81 /* Bias compensation history node */
82 typedef struct {
83 COLOR irrad;
84 float weight;
85 } PhotonBCNode;
86
87
88 struct PhotonMap; /* Forward declarations */
89
90 typedef struct PhotonMap {
91 PhotonMapType type; /* See pmaptype.h */
92 char *fileName; /* Photon map file */
93 Photon *heap; /* Photon k-d tree as linear array */
94 PhotonSQNode *squeue; /* Search queue */
95 PhotonBCNode *biasCompHist; /* Bias compensation history */
96 char lookupFlags; /* Flags passed to findPhotons() */
97
98 unsigned long distribTarget, /* Num stored specified by user */
99 heapSize,
100 heapSizeInc,
101 heapEnd, /* Num actually stored in heap */
102 numDensity, /* Num density estimates */
103 totalGathered, /* Total photons gathered */
104 numLookups, /* Counters for short photon lookups */
105 numShortLookups;
106
107 unsigned minGather, /* Specified min/max photons per */
108 maxGather, /* density estimate */
109 squeueSize,
110 squeueEnd,
111 minGathered, /* Min/max photons actually gathered */
112 maxGathered, /* per density estimate */
113 shortLookupPct; /* Percentage of short lookups (for
114 statistics output */
115
116 /* NOTE: All distances are SQUARED */
117 float maxDist, /* Max search radius during NN search */
118 maxDist0, /* Initial value for above */
119 maxDistLimit, /* Hard limit for above */
120 CoGdist, /* Avg distance to centre of gravity */
121 maxPos [3], minPos [3], /* Max & min photon positions */
122 distribRatio, /* Probability of photon storage */
123 gatherTolerance, /* Fractional deviation from minGather/
124 maxGather for short lookup */
125 minError, maxError, /* Min/max/rms density estimate error */
126 rmsError;
127
128 FVECT CoG; /* Centre of gravity (avg photon pos) */
129 COLOR photonFlux; /* Average photon flux */
130 unsigned short randState [3]; /* Local RNG state */
131
132 void (*lookup)(struct PhotonMap*, RAY*, COLOR);
133 /* Callback for type-specific photon
134 * lookup (usually density estimate) */
135
136 PhotonPrimary *primary; /* Primary photon rays & associated
137 counters */
138 unsigned primarySize, primaryEnd;
139
140 LUTAB *srcContrib; /* lookup table for source contribs */
141 } PhotonMap;
142
143
144
145 /* Photon maps by type (see PhotonMapType) */
146 extern PhotonMap *photonMaps [];
147
148 /* Macros for specific photon map types */
149 #define globalPmap (photonMaps [PMAP_TYPE_GLOBAL])
150 #define preCompPmap (photonMaps [PMAP_TYPE_PRECOMP])
151 #define causticPmap (photonMaps [PMAP_TYPE_CAUSTIC])
152 #define volumePmap (photonMaps [PMAP_TYPE_VOLUME])
153 #define directPmap (photonMaps [PMAP_TYPE_DIRECT])
154 #define contribPmap (photonMaps [PMAP_TYPE_CONTRIB])
155
156
157
158 void initPhotonMap (PhotonMap *pmap, PhotonMapType t);
159 /* Initialise empty photon map of specified type */
160
161 const PhotonPrimary* addPhotonPrimary (PhotonMap *pmap, const RAY *ray);
162 /* Add primary ray for emitted photon and save light source index, origin
163 * on source, and emitted direction; used by contrib photons */
164
165 const Photon* addPhoton (PhotonMap *pmap, const RAY *ray);
166 /* Create new photon with ray's direction, intersection point, and flux,
167 and add to photon map subject to acceptance probability pmap ->
168 distribRatio for global density control; if the photon is rejected,
169 NULL is returned. The flux is scaled by ray -> rweight and
170 1 / pmap -> distribRatio. */
171
172 void balancePhotons (PhotonMap *pmap, double *photonFlux);
173 /* Build a balanced kd-tree as heap to guarantee logarithmic search
174 * times. This must be called prior to performing photon search with
175 * findPhotons().
176 * PhotonFlux is the flux scaling factor per photon averaged over RGB. In
177 * the case of a contribution photon map, this is an array with a
178 * separate factor specific to each light source due to non-uniform
179 * photon emission; Otherwise it is referenced as a scalar value. Flux is
180 * not scaled if photonFlux == NULL. */
181
182 void buildHeap (Photon *heap, unsigned long *heapIdx,
183 unsigned long *heapXdi, const float min [3],
184 const float max [3], unsigned long left,
185 unsigned long right, unsigned long root);
186 /* Recursive part of balancePhotons(..); builds heap from subarray
187 * defined by indices left and right. */
188
189 void findPhotons (PhotonMap* pmap, const RAY *ray);
190 /* Find pmap -> squeueSize closest photons to ray -> rop with similar
191 normal. For volume photons ray -> rorg is used and the normal is
192 ignored (being the incident direction in this case). Found photons
193 are placed in pmap -> squeue, with pmap -> squeueEnd being the number
194 actually found. */
195
196 Photon *find1Photon (PhotonMap *pmap, const RAY *ray);
197 /* Finds single closest photon to ray -> rop with similar normal.
198 Returns NULL if none found. */
199
200 void deletePhotons (PhotonMap*);
201 /* Free dem mammaries... */
202
203 #endif
