root/radiance/ray/src/rt/pmapdata.h
Revision: 2.6
Committed: Thu May 28 12:27:22 2015 UTC (9 years, 11 months ago) by greg
Bug fix for uninitialized sources set to -1
1 /*
2 ==================================================================
3 Photon map data structures and kd-tree handling
4
5 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
6 (c) Fraunhofer Institute for Solar Energy Systems,
7 (c) Lucerne University of Applied Sciences and Arts,
8 supported by the Swiss National Science Foundation (SNSF, #147053)
9 ==================================================================
10
11 $Id: pmapdata.h,v 2.5 2015/05/20 14:44:12 greg Exp $
12 */
13
14
15 #ifndef PMAPDATA_H
16 #define PMAPDATA_H
17
18 #include "ray.h"
19 #include "pmaptype.h"
20 #include "lookup.h"
21
22
23 /* Define PMAP_FLOAT_FLUX to store photon flux as floats instead of
24 * compact RGBE, which was found to improve accuracy in analytical
25 * validation. */
26 #ifdef PMAP_FLOAT_FLUX
27 #define setPhotonFlux(p,f) copycolor((p) -> flux, f)
28 #define getPhotonFlux(p,f) copycolor(f, (p) -> flux)
29 #else
30 #define setPhotonFlux(p,f) setcolr((p)->flux, (f)[0], (f)[1], (f)[2])
31 #define getPhotonFlux(p,f) colr_color(f, (p) -> flux)
32 #endif
33
34
35 /* Primary photon ray for light source contributions */
36 typedef struct {
37 int32 srcIdx; /* Index of emitting light source */
38 int32 dir; /* Encoded ray direction */
39 float pos [3]; /* Hit point */
40 } PhotonPrimary;
41
42 #define photonSrcIdx(pm, p) ((pm) -> primary [(p) -> primary].srcIdx)
43
44
45 typedef struct {
46 float pos [3]; /* Photon position */
47 signed char norm [3]; /* Surface normal at pos (incident
48 direction for volume photons) */
49 char flags; /* Bit 0-1: kd-tree discriminator axis,
50 Bit 2: caustic photon */
51 #ifdef PMAP_FLOAT_FLUX
52 COLOR flux;
53 #else
54 COLR flux; /* Photon flux */
55 #endif
56
57 uint32 primary; /* Index to primary ray */
58 } Photon;
59
60 /* Photon flag bitmasks and manipulation macros */
61 #define PMAP_DISCR_BIT 3
62 #define PMAP_CAUST_BIT 4
63 #define photonDiscr(p) ((p).flags & PMAP_DISCR_BIT)
64 #define setPhotonDiscr(p, d) ((p).flags = ((p).flags & ~PMAP_DISCR_BIT) | \
65 ((d) & PMAP_DISCR_BIT))
66
67 /* Photon map type tests */
68 #define isGlobalPmap(p) ((p) -> type == PMAP_TYPE_GLOBAL)
69 #define isCausticPmap(p) ((p) -> type == PMAP_TYPE_CAUSTIC)
70 #define isContribPmap(p) ((p) -> type == PMAP_TYPE_CONTRIB)
71 #define isVolumePmap(p) ((p) -> type == PMAP_TYPE_VOLUME)
72
73
74 /* Queue node for photon lookups */
75 typedef struct {
76 Photon *photon;
77 float dist;
78 } PhotonSQNode;
79
80 /* Bias compensation history node */
81 typedef struct {
82 COLOR irrad;
83 float weight;
84 } PhotonBCNode;
85
86
87 struct PhotonMap; /* Forward declarations */
88
89 typedef struct PhotonMap {
90 PhotonMapType type; /* See pmaptype.h */
91 char *fileName; /* Photon map file */
92 Photon *heap; /* Photon k-d tree as linear array */
93 PhotonSQNode *squeue; /* Search queue */
94 PhotonBCNode *biasCompHist; /* Bias compensation history */
95 char lookupFlags; /* Flags passed to findPhotons() */
96
97 unsigned long distribTarget, /* Num stored specified by user */
98 heapSize,
99 heapSizeInc,
100 heapEnd, /* Num actually stored in heap */
101 numDensity, /* Num density estimates */
102 totalGathered, /* Total photons gathered */
103 numLookups, /* Counters for short photon lookups */
104 numShortLookups;
105
106 unsigned minGather, /* Specified min/max photons per */
107 maxGather, /* density estimate */
108 squeueSize,
109 squeueEnd,
110 minGathered, /* Min/max photons actually gathered */
111 maxGathered, /* per density estimate */
112 shortLookupPct; /* Percentage of short lookups (for
113 statistics output */
114
115 /* NOTE: All distances are SQUARED */
116 float maxDist, /* Max search radius during NN search */
117 maxDist0, /* Initial value for above */
118 maxDistLimit, /* Hard limit for above */
119 CoGdist, /* Avg distance to centre of gravity */
120 maxPos [3], minPos [3], /* Max & min photon positions */
121 distribRatio, /* Probability of photon storage */
122 gatherTolerance, /* Fractional deviation from minGather/
123 maxGather for short lookup */
124 minError, maxError, /* Min/max/rms density estimate error */
125 rmsError;
126
127 FVECT CoG; /* Centre of gravity (avg photon pos) */
128 COLOR photonFlux; /* Average photon flux */
129 unsigned short randState [3]; /* Local RNG state */
130
131 void (*lookup)(struct PhotonMap*, RAY*, COLOR);
132 /* Callback for type-specific photon
133 * lookup (usually density estimate) */
134
135 PhotonPrimary *primary; /* Primary photon rays & associated
136 counters */
137 unsigned primarySize, primaryEnd;
138
139 LUTAB *srcContrib; /* lookup table for source contribs */
140 } PhotonMap;
141
142
143
144 /* Photon maps by type (see PhotonMapType) */
145 extern PhotonMap *photonMaps [];
146
147 /* Macros for specific photon map types */
148 #define globalPmap (photonMaps [PMAP_TYPE_GLOBAL])
149 #define preCompPmap (photonMaps [PMAP_TYPE_PRECOMP])
150 #define causticPmap (photonMaps [PMAP_TYPE_CAUSTIC])
151 #define volumePmap (photonMaps [PMAP_TYPE_VOLUME])
152 #define directPmap (photonMaps [PMAP_TYPE_DIRECT])
153 #define contribPmap (photonMaps [PMAP_TYPE_CONTRIB])
154
155
156
157 void initPhotonMap (PhotonMap *pmap, PhotonMapType t);
158 /* Initialise empty photon map of specified type */
159
160 const PhotonPrimary* addPhotonPrimary (PhotonMap *pmap, const RAY *ray);
161 /* Add primary ray for emitted photon and save light source index, origin
162 * on source, and emitted direction; used by contrib photons */
163
164 const Photon* addPhoton (PhotonMap *pmap, const RAY *ray);
165 /* Create new photon with ray's direction, intersection point, and flux,
166 and add to photon map subject to acceptance probability pmap ->
167 distribRatio for global density control; if the photon is rejected,
168 NULL is returned. The flux is scaled by ray -> rweight and
169 1 / pmap -> distribRatio. */
170
171 void balancePhotons (PhotonMap *pmap, double *photonFlux);
172 /* Build a balanced kd-tree as heap to guarantee logarithmic search
173 * times. This must be called prior to performing photon search with
174 * findPhotons().
175 * PhotonFlux is the flux scaling factor per photon averaged over RGB. In
176 * the case of a contribution photon map, this is an array with a
177 * separate factor specific to each light source due to non-uniform
178 * photon emission; Otherwise it is referenced as a scalar value. Flux is
179 * not scaled if photonFlux == NULL. */
180
181 void buildHeap (Photon *heap, unsigned long *heapIdx,
182 unsigned long *heapXdi, const float min [3],
183 const float max [3], unsigned long left,
184 unsigned long right, unsigned long root);
185 /* Recursive part of balancePhotons(..); builds heap from subarray
186 * defined by indices left and right. */
187
188 void findPhotons (PhotonMap* pmap, const RAY *ray);
189 /* Find pmap -> squeueSize closest photons to ray -> rop with similar
190 normal. For volume photons ray -> rorg is used and the normal is
191 ignored (being the incident direction in this case). Found photons
192 are placed in pmap -> squeue, with pmap -> squeueEnd being the number
193 actually found. */
194
195 Photon *find1Photon (PhotonMap *pmap, const RAY *ray);
196 /* Finds single closest photon to ray -> rop with similar normal.
197 Returns NULL if none found. */
198
199 void deletePhotons (PhotonMap*);
200 /* Free dem mammaries... */
201
202 #endif
