root/radiance/ray/src/rt/pmapdata.h
Revision: 2.2
Committed: Fri May 8 13:20:22 2015 UTC (10 years, 1 month ago) by rschregle
1 /*
2 ==================================================================
3 Photon map data structures and kd-tree handling
4
5 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
6 (c) Fraunhofer Institute for Solar Energy Systems,
7 (c) Lucerne University of Applied Sciences and Arts,
8 supported by the Swiss National Science Foundation (SNSF, #147053)
9 ==================================================================
10
11 $Id: pmapdata.h,v 2.1 2015/02/24 19:39:26 greg Exp $
12 */
13
14
15 #ifndef PMAPDATA_H
16 #define PMAPDATA_H
17
18 #include "ray.h"
19 #include "pmaptype.h"
20 #include "lookup.h"
21
22
23 /* Define PMAP_FLOAT_FLUX to store photon flux as floats instead of
24 * compact RGBE, which was found to improve accuracy in analytical
25 * validation. */
26 #ifdef PMAP_FLOAT_FLUX
27 #define setPhotonFlux(p,f) copycolor((p) -> flux, f)
28 #define getPhotonFlux(p,f) copycolor(f, (p) -> flux)
29 #else
30 #define setPhotonFlux(p,f) setcolr((p)->flux, (f)[0], (f)[1], (f)[2])
31 #define getPhotonFlux(p,f) colr_color(f, (p) -> flux)
32 #endif
33
34
35 /* Primary photon ray for light source contributions */
36 typedef struct {
37 short srcIdx; /* Index of emitting light source */
38 float dir [3], org [3]; /* Incident dir & origin on source */
39 } PhotonPrimary;
40
41 #define photonSrcIdx(pm, p) ((pm) -> primary [(p) -> primary].srcIdx)
42
43
44 typedef struct {
45 float pos [3]; /* Photon position */
46 signed char norm [3]; /* Surface normal at pos (incident
47 direction for volume photons) */
48 char flags; /* Bit 0-1: kd-tree discriminator axis,
49 Bit 2: caustic photon */
50 #ifdef PMAP_FLOAT_FLUX
51 COLOR flux;
52 #else
53 COLR flux; /* Photon flux */
54 #endif
55
56 unsigned primary; /* Index to primary ray */
57 } Photon;
58
59 /* Photon flag bitmasks and manipulation macros */
60 #define PMAP_DISCR_BIT 3
61 #define PMAP_CAUST_BIT 4
62 #define photonDiscr(p) ((p).flags & PMAP_DISCR_BIT)
63 #define setPhotonDiscr(p, d) ((p).flags = ((p).flags & ~PMAP_DISCR_BIT) | \
64 ((d) & PMAP_DISCR_BIT))
65
66 /* Photon map type tests */
67 #define isGlobalPmap(p) ((p) -> type == PMAP_TYPE_GLOBAL)
68 #define isCausticPmap(p) ((p) -> type == PMAP_TYPE_CAUSTIC)
69 #define isContribPmap(p) ((p) -> type == PMAP_TYPE_CONTRIB)
70 #define isVolumePmap(p) ((p) -> type == PMAP_TYPE_VOLUME)
71
72
73 /* Queue node for photon lookups */
74 typedef struct {
75 Photon *photon;
76 float dist;
77 } PhotonSQNode;
78
79 /* Bias compensation history node */
80 typedef struct {
81 COLOR irrad;
82 float weight;
83 } PhotonBCNode;
84
85
86 struct PhotonMap; /* Forward declarations */
87
88 typedef struct PhotonMap {
89 PhotonMapType type; /* See pmaptype.h */
90 char *fileName; /* Photon map file */
91 Photon *heap; /* Photon k-d tree as linear array */
92 PhotonSQNode *squeue; /* Search queue */
93 PhotonBCNode *biasCompHist; /* Bias compensation history */
94 char lookupFlags; /* Flags passed to findPhotons() */
95
96 unsigned long distribTarget, /* Num stored specified by user */
97 heapSize,
98 heapSizeInc,
99 heapEnd, /* Num actually stored in heap */
100 numDensity, /* Num density estimates */
101 totalGathered, /* Total photons gathered */
102 numLookups, /* Counters for short photon lookups */
103 numShortLookups;
104
105 unsigned minGather, /* Specified min/max photons per */
106 maxGather, /* density estimate */
107 squeueSize,
108 squeueEnd,
109 minGathered, /* Min/max photons actually gathered */
110 maxGathered, /* per density estimate */
111 shortLookupPct; /* Percentage of short lookups (for
112 statistics output */
113
114 /* NOTE: All distances are SQUARED */
115 float maxDist, /* Max search radius during NN search */
116 maxDist0, /* Initial value for above */
117 maxDistLimit, /* Hard limit for above */
118 CoGdist, /* Avg distance to centre of gravity */
119 maxPos [3], minPos [3], /* Max & min photon positions */
120 distribRatio, /* Probability of photon storage */
121 gatherTolerance, /* Fractional deviation from minGather/
122 maxGather for short lookup */
123 minError, maxError, /* Min/max/rms density estimate error */
124 rmsError;
125
126 FVECT CoG; /* Centre of gravity (avg photon pos) */
127 COLOR photonFlux; /* Average photon flux */
128 unsigned short randState [3]; /* Local RNG state */
129
130 void (*lookup)(struct PhotonMap*, RAY*, COLOR);
131 /* Callback for type-specific photon
132 * lookup (usually density estimate) */
133
134 PhotonPrimary *primary; /* Primary photon rays & associated
135 counters */
136 unsigned primarySize, primaryEnd;
137
138 LUTAB *srcContrib; /* lookup table for source contribs */
139 } PhotonMap;
140
141
142
143 /* Photon maps by type (see PhotonMapType) */
144 extern PhotonMap *photonMaps [];
145
146 /* Macros for specific photon map types */
147 #define globalPmap (photonMaps [PMAP_TYPE_GLOBAL])
148 #define preCompPmap (photonMaps [PMAP_TYPE_PRECOMP])
149 #define causticPmap (photonMaps [PMAP_TYPE_CAUSTIC])
150 #define volumePmap (photonMaps [PMAP_TYPE_VOLUME])
151 #define directPmap (photonMaps [PMAP_TYPE_DIRECT])
152 #define contribPmap (photonMaps [PMAP_TYPE_CONTRIB])
153
154
155
156 void initPhotonMap (PhotonMap *pmap, PhotonMapType t);
157 /* Initialise empty photon map of specified type */
158
159 const PhotonPrimary* addPhotonPrimary (PhotonMap *pmap, const RAY *ray);
160 /* Add primary ray for emitted photon and save light source index, origin
161 * on source, and emitted direction; used by contrib photons */
162
163 const Photon* addPhoton (PhotonMap *pmap, const RAY *ray);
164 /* Create new photon with ray's direction, intersection point, and flux,
165 and add to photon map subject to acceptance probability pmap ->
166 distribRatio for global density control; if the photon is rejected,
167 NULL is returned. The flux is scaled by ray -> rweight and
168 1 / pmap -> distribRatio. */
169
170 void balancePhotons (PhotonMap *pmap, double *photonFlux);
171 /* Build a balanced kd-tree as heap to guarantee logarithmic search
172 * times. This must be called prior to performing photon search with
173 * findPhotons().
174 * PhotonFlux is the flux scaling factor per photon averaged over RGB. In
175 * the case of a contribution photon map, this is an array with a
176 * separate factor specific to each light source due to non-uniform
177 * photon emission; Otherwise it is referenced as a scalar value. Flux is
178 * not scaled if photonFlux == NULL. */
179
180 void buildHeap (Photon *heap, unsigned long *heapIdx,
181 unsigned long *heapXdi, const float min [3],
182 const float max [3], unsigned long left,
183 unsigned long right, unsigned long root);
184 /* Recursive part of balancePhotons(..); builds heap from subarray
185 * defined by indices left and right. */
186
187 void findPhotons (PhotonMap* pmap, const RAY *ray);
188 /* Find pmap -> squeueSize closest photons to ray -> rop with similar
189 normal. For volume photons ray -> rorg is used and the normal is
190 ignored (being the incident direction in this case). Found photons
191 are placed in pmap -> squeue, with pmap -> squeueEnd being the number
192 actually found. */
193
194 Photon *find1Photon (PhotonMap *pmap, const RAY *ray);
195 /* Finds single closest photon to ray -> rop with similar normal.
196 Returns NULL if none found. */
197
198 void deletePhotons (PhotonMap*);
199 /* Free dem mammaries... */
200
201 #endif
