1 |
/* RCSid $Id: pmapdata.h,v 2.13 2018/12/07 20:02:40 rschregle Exp $ */ |
2 |
3 |
4 |
5 |
Photon map types and interface to nearest neighbour lookups in underlying |
6 |
point cloud data structure. |
7 |
8 |
The default data structure is an in-core kd-tree (see pmapkdt.{h,c}). |
9 |
This can be overriden with the PMAP_OOC compiletime switch, which enables |
10 |
an out-of-core octree (see oococt.{h,c}). |
11 |
12 |
Defining PMAP_FLOAT_FLUX stores photon flux as floats rather than packed |
13 |
RGBE for greater precision; this may be necessary when the flux differs |
14 |
significantly in individual colour channels, e.g. with highly saturated |
15 |
colours. |
16 |
17 |
Roland Schregle (roland.schregle@{hslu.ch, gmail.com}) |
18 |
(c) Fraunhofer Institute for Solar Energy Systems, |
19 |
(c) Lucerne University of Applied Sciences and Arts, |
20 |
supported by the Swiss National Science Foundation (SNSF, #147053) |
21 |
22 |
23 |
$Id: pmapdata.h,v 2.13 2018/12/07 20:02:40 rschregle Exp $ |
24 |
25 |
26 |
27 |
28 |
#ifndef PMAPDATA_H |
29 |
#define PMAPDATA_H |
30 |
31 |
#ifndef NIX |
32 |
#if defined(_WIN32) || defined(_WIN64) |
33 |
#define NIX 0 |
34 |
#else |
35 |
#define NIX 1 |
36 |
#endif |
37 |
#endif |
38 |
39 |
#if (defined(PMAP_OOC) && !NIX) |
40 |
#error "OOC currently only supported on NIX -- tuff luck." |
41 |
#endif |
42 |
43 |
#ifdef PMAP_CBDM |
44 |
/* Enable photon primary hitpoints and incident directions (see struct |
45 |
* PhotonPrimary below). Note this will increase the size of photon |
46 |
* primaries 9-fold (10-fold after alignment)!!! */ |
47 |
#define PMAP_PRIMARYPOS |
48 |
#define PMAP_PRIMARYDIR |
49 |
#endif |
50 |
51 |
#include "ray.h" |
52 |
#include "pmaptype.h" |
53 |
#include "paths.h" |
54 |
#include "lookup.h" |
55 |
#include <stdint.h> |
56 |
57 |
58 |
59 |
/* Primary photon ray for light source contributions */ |
60 |
typedef struct { |
61 |
int16 srcIdx; /* Index of emitting light source */ |
62 |
/* !!! REDUCED FROM 32 BITS !!! */ |
63 |
#ifdef PMAP_PRIMARYDIR |
64 |
int32 dir; /* Encoded ray direction */ |
65 |
#endif |
66 |
#ifdef PMAP_PRIMARYPOS |
67 |
float pos [3]; /* Hit point */ |
68 |
#endif |
69 |
} PhotonPrimary; |
70 |
71 |
#define photonSrcIdx(pm, p) ((pm)->primaries[(p)->primary].srcIdx) |
72 |
73 |
74 |
75 |
/* Photon primary ray index type and limit */ |
76 |
typedef uint32 PhotonPrimaryIdx; |
77 |
#define PMAP_MAXPRIMARY UINT32_MAX |
78 |
79 |
/* Macros for photon's generating subprocess field */ |
80 |
#ifdef PMAP_OOC |
81 |
#define PMAP_PROCBITS 7 |
82 |
#else |
83 |
#define PMAP_PROCBITS 5 |
84 |
#endif |
85 |
#define PMAP_MAXPROC (1 << PMAP_PROCBITS) |
86 |
#define PMAP_GETRAYPROC(r) ((r) -> crtype >> 8) |
87 |
#define PMAP_SETRAYPROC(r,p) ((r) -> crtype |= p << 8) |
88 |
89 |
/* Tolerance for photon normal check during lookups */ |
90 |
#define PMAP_NORM_TOL 0.02 |
91 |
92 |
93 |
94 |
typedef struct { |
95 |
float pos [3]; /* Photon position */ |
96 |
signed char norm [3]; /* Surface normal at pos (incident |
97 |
direction for volume photons) */ |
98 |
union { |
99 |
struct { |
100 |
#ifndef PMAP_OOC |
101 |
unsigned char discr : 2; /* kd-tree discriminator axis */ |
102 |
#endif |
103 |
unsigned char caustic : 1; /* Specularly scattered (=caustic) */ |
104 |
105 |
/* Photon's generating subprocess index, used for primary ray |
106 |
* index linearisation when building contrib pmaps; note this is |
107 |
* reduced for kd-tree to accommodate the discriminator field */ |
108 |
unsigned char proc : PMAP_PROCBITS; |
109 |
110 |
111 |
unsigned char flags; |
112 |
113 |
114 |
#ifdef PMAP_FLOAT_FLUX |
115 |
COLOR flux; |
116 |
#else |
117 |
COLR flux; |
118 |
#endif |
119 |
PhotonPrimaryIdx primary; /* Index to primary ray */ |
120 |
} Photon; |
121 |
122 |
123 |
124 |
/* Define PMAP_FLOAT_FLUX to store photon flux as floats instead of |
125 |
* compact RGBE, which was found to improve accuracy in analytical |
126 |
* validation. */ |
127 |
128 |
#define setPhotonFlux(p,f) copycolor((p) -> flux, f) |
129 |
#define getPhotonFlux(p,f) copycolor(f, (p) -> flux) |
130 |
#else |
131 |
#define setPhotonFlux(p,f) setcolr((p)->flux, (f)[0], (f)[1], (f)[2]) |
132 |
#define getPhotonFlux(p,f) colr_color(f, (p) -> flux) |
133 |
#endif |
134 |
135 |
136 |
/* Bias compensation history node */ |
137 |
typedef struct { |
138 |
COLOR irrad; |
139 |
float weight; |
140 |
} PhotonBiasCompNode; |
141 |
142 |
143 |
/* Forward declaration */ |
144 |
struct PhotonMap; |
145 |
146 |
147 |
/* Define search queue and underlying data struct types */ |
148 |
#ifdef PMAP_OOC |
149 |
#include "pmapooc.h" |
150 |
#else |
151 |
#include "pmapkdt.h" |
152 |
#endif |
153 |
154 |
155 |
/* Mean size of heapfile write buffer, in number of photons */ |
156 |
#define PMAP_HEAPBUFSIZE 1e6 |
157 |
158 |
/* Mean idle time between heap locking attempts, in usec */ |
159 |
#define PMAP_HEAPBUFSLEEP 2e6 |
160 |
161 |
/* Temporary filename for photon heaps */ |
162 |
#define PMAP_TMPFNAME TEMPLATE |
163 |
#define PMAP_TMPFNLEN (TEMPLEN + 1) |
164 |
165 |
166 |
typedef struct PhotonMap { |
167 |
PhotonMapType type; /* See pmaptype.h */ |
168 |
char *fileName; /* Photon map file */ |
169 |
170 |
171 |
172 |
* PRE/POST-BUILD STORAGE |
173 |
174 |
FILE *heap; /* Unsorted photon heap prior to |
175 |
construction of store */ |
176 |
char heapFname [sizeof(PMAP_TMPFNAME)]; |
177 |
Photon *heapBuf; /* Write buffer for above */ |
178 |
unsigned long heapBufLen, /* Current & max size of heapBuf */ |
179 |
heapBufSize; |
180 |
PhotonStorage store; /* Photon storage in space |
181 |
subdividing data struct */ |
182 |
183 |
184 |
* PHOTON DISTRIBUTION STUFF |
185 |
186 |
unsigned long distribTarget, /* Num stored specified by user */ |
187 |
numPhotons; /* Num actually stored */ |
188 |
float distribRatio; /* Probability of photon storage */ |
189 |
COLOR photonFlux; /* Average photon flux */ |
190 |
unsigned short randState [3]; /* Local RNG state */ |
191 |
192 |
193 |
194 |
* PHOTON LOOKUP STUFF |
195 |
196 |
union { /* Flags passed to findPhotons() */ |
197 |
char lookupCaustic : 1; |
198 |
char lookupFlags; |
199 |
200 |
201 |
PhotonSearchQueue squeue; /* Search queue for photon lookups */ |
202 |
unsigned minGather, /* Specified min/max photons per */ |
203 |
maxGather; /* density estimate */ |
204 |
205 |
/* NOTE: All distances are SQUARED */ |
206 |
float maxDist2, /* Max search radius */ |
207 |
maxDist0, /* Initial value for above */ |
208 |
maxDist2Limit, /* Hard limit for above */ |
209 |
gatherTolerance; /* Fractional deviation from minGather/ |
210 |
maxGather for short lookup */ |
211 |
void (*lookup)(struct PhotonMap*, |
212 |
RAY*, COLOR); /* Callback for type-specific photon |
213 |
* lookup (usually density estimate) */ |
214 |
215 |
216 |
217 |
* BIAS COMPENSATION STUFF |
218 |
219 |
PhotonBiasCompNode *biasCompHist; /* Bias compensation history */ |
220 |
221 |
222 |
223 |
* STATISTIX |
224 |
225 |
unsigned long totalGathered, /* Total photons gathered */ |
226 |
numDensity, /* Num density estimates */ |
227 |
numLookups, /* Counters for short photon lookups */ |
228 |
numShortLookups; |
229 |
230 |
unsigned minGathered, /* Min/max photons actually gathered */ |
231 |
maxGathered, /* per density estimate */ |
232 |
shortLookupPct; /* % of short lookups for stats */ |
233 |
234 |
float minError, /* Min/max/rms density estimate error */ |
235 |
maxError, |
236 |
rmsError, |
237 |
CoGdist, /* Avg distance to centre of gravity */ |
238 |
maxPos [3], /* Max & min photon positions */ |
239 |
minPos [3]; |
240 |
241 |
FVECT CoG; /* Centre of gravity (avg photon pos) */ |
242 |
243 |
244 |
245 |
* PHOTON CONTRIB/COEFF STUFF |
246 |
247 |
PhotonPrimary *primaries, /* Photon primary array for rendering */ |
248 |
lastPrimary; /* Current primary for photon distrib */ |
249 |
PhotonPrimaryIdx numPrimary; /* Number of primary rays */ |
250 |
LUTAB *srcContrib; /* Lookup table for source contribs */ |
251 |
} PhotonMap; |
252 |
253 |
254 |
255 |
/* Photon maps by type (see PhotonMapType) */ |
256 |
extern PhotonMap *photonMaps []; |
257 |
258 |
/* Macros for specific photon map types */ |
259 |
#define globalPmap (photonMaps [PMAP_TYPE_GLOBAL]) |
260 |
#define preCompPmap (photonMaps [PMAP_TYPE_PRECOMP]) |
261 |
#define causticPmap (photonMaps [PMAP_TYPE_CAUSTIC]) |
262 |
#define volumePmap (photonMaps [PMAP_TYPE_VOLUME]) |
263 |
#define directPmap (photonMaps [PMAP_TYPE_DIRECT]) |
264 |
#define contribPmap (photonMaps [PMAP_TYPE_CONTRIB]) |
265 |
266 |
/* Photon map type tests */ |
267 |
#define isGlobalPmap(p) ((p) -> type == PMAP_TYPE_GLOBAL) |
268 |
#define isCausticPmap(p) ((p) -> type == PMAP_TYPE_CAUSTIC) |
269 |
#define isContribPmap(p) ((p) -> type == PMAP_TYPE_CONTRIB) |
270 |
#define isVolumePmap(p) ((p) -> type == PMAP_TYPE_VOLUME) |
271 |
272 |
273 |
274 |
void initPhotonMap (PhotonMap *pmap, PhotonMapType t); |
275 |
/* Initialise empty photon map of specified type */ |
276 |
277 |
int newPhoton (PhotonMap *pmap, const RAY *ray); |
278 |
/* Create new photon with ray's direction, intersection point, and flux, |
279 |
and append to unsorted photon heap pmap -> heap. The photon is |
280 |
accepted with probability pmap -> distribRatio for global density |
281 |
control; if the photon is rejected, -1 is returned, else 0. The flux |
282 |
is scaled by ray -> rweight and 1 / pmap -> distribRatio. */ |
283 |
284 |
void initPhotonHeap (PhotonMap *pmap); |
285 |
/* Open photon heap file */ |
286 |
287 |
void flushPhotonHeap (PhotonMap *pmap); |
288 |
/* Flush photon heap buffa pmap -> heapBuf to heap file pmap -> heap; |
289 |
* used by newPhoton() and to finalise heap in distribPhotons(). */ |
290 |
291 |
void buildPhotonMap (PhotonMap *pmap, double *photonFlux, |
292 |
PhotonPrimaryIdx *primaryOfs, unsigned nproc); |
293 |
/* Postpress unsorted photon heap pmap -> heap and build underlying data |
294 |
* structure pmap -> store. This is prerequisite to photon lookups with |
295 |
* findPhotons(). */ |
296 |
297 |
/* PhotonFlux is the flux per photon averaged over RGB; this is |
298 |
* multiplied with each photon's flux during the postprocess. In the |
299 |
* case of a contribution photon map, this is an array with a separate |
300 |
* flux specific to each light source due to non-uniform photon emission; |
301 |
* Otherwise it is referenced as a scalar value. Flux is not scaled if |
302 |
* photonFlux == NULL. */ |
303 |
304 |
/* Photon map construction may be parallelised if nproc > 1, if |
305 |
* supported. The heap is destroyed on return. */ |
306 |
307 |
/* PrimaryOfs is an array of index offsets for the primaries in pmap -> |
308 |
* primaries generated by each of the nproc subprocesses during contrib |
309 |
* photon distribution (see distribPhotonContrib()). These offsets are |
310 |
* used to linearise the photon primary indices in the postprocess. This |
311 |
* linearisation is skipped if primaryOfs == NULL. */ |
312 |
313 |
void findPhotons (PhotonMap* pmap, const RAY *ray); |
314 |
/* Find pmap -> squeue.len closest photons to ray -> rop with similar |
315 |
normal. For volume photons ray -> rorg is used and the normal is |
316 |
ignored (being the incident direction in this case). Found photons |
317 |
are placed search queue starting with the furthest photon at pmap -> |
318 |
squeue.node, and pmap -> squeue.tail being the number actually found. */ |
319 |
320 |
Photon *find1Photon (PhotonMap *pmap, const RAY *ray, Photon *photon); |
321 |
/* Find single closest photon to ray -> rop with similar normal. |
322 |
Return NULL if none found, else the supplied Photon* buffer, |
323 |
indicating that it contains a valid photon. */ |
324 |
325 |
void getPhoton (PhotonMap *pmap, PhotonIdx idx, Photon *photon); |
326 |
/* Retrieve photon referenced by idx from pmap -> store */ |
327 |
328 |
Photon *getNearestPhoton (const PhotonSearchQueue *squeue, PhotonIdx idx); |
329 |
/* Retrieve photon from NN search queue after calling findPhotons() */ |
330 |
331 |
PhotonIdx firstPhoton (const PhotonMap *pmap); |
332 |
/* Index to first photon, to be passed to getPhoton(). Indices to |
333 |
* subsequent photons can be optained via increment operator (++) */ |
334 |
335 |
void deletePhotons (PhotonMap*); |
336 |
/* Free dem mammaries... */ |
337 |
338 |
#endif |
