root/Development/ray/src/rt/pmapdata.h
Revision: 2.10
Committed: Tue May 17 17:39:47 2016 UTC (9 years, 5 months ago) by rschregle
Changes since 2.9: +253 -140 lines
1 /* RCSid $Id: pmapdata.h,v 4.22.2.7 2016/02/04 20:21:28 taschreg Exp taschreg $ */
2
3 /*
4 =========================================================================
5 Photon map types and interface to nearest neighbour lookups in underlying
6 point cloud data structure.
7
8 The default data structure is an in-core kd-tree (see pmapkdt.{h,c}).
9 This can be overriden with the PMAP_OOC compiletime switch, which enables
10 an out-of-core octree (see oococt.{h,c}).
11
12 Defining PMAP_FLOAT_FLUX stores photon flux as floats rather than packed
13 RGBE for greater precision; this may be necessary when the flux differs
14 significantly in individual colour channels, e.g. with highly saturated
15 colours.
16
17 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
18 (c) Fraunhofer Institute for Solar Energy Systems,
19 (c) Lucerne University of Applied Sciences and Arts,
20 supported by the Swiss National Science Foundation (SNSF, #147053)
21 =========================================================================
22
23 $Id: pmapdata.h,v 4.22.2.7 2016/02/04 20:21:28 taschreg Exp taschreg $
24 */
25
26
27
28 #ifndef PMAPDATA_H
29 #define PMAPDATA_H
30
31 #include "ray.h"
32 #include "pmaptype.h"
33 #include "lookup.h"
34 #include <stdint.h>
35
36
37
38 /* Primary photon ray for light source contributions */
39 typedef struct {
40 int16 srcIdx; /* Index of emitting light source */
41 /* !!! REDUCED FROM 32 BITS !!! */
42 int32 dir; /* Encoded ray direction */
43 #ifdef PMAP_PRIMARYPOS
44 float pos [3]; /* Hit point */
45 #endif
46 } PhotonPrimary;
47
48 #define photonSrcIdx(pm, p) ((pm)->primaries[(p)->primary].srcIdx)
49
50
51
52 /* Photon primary ray index type and limit */
53 typedef uint32 PhotonPrimaryIdx;
54 #define PMAP_MAXPRIMARY UINT32_MAX
55
56 /* Macros for photon's generating subprocess field */
57 #ifdef PMAP_OOC
58 #define PMAP_PROCBITS 7
59 #else
60 #define PMAP_PROCBITS 5
61 #endif
62 #define PMAP_MAXPROC (1 << PMAP_PROCBITS)
63 #define PMAP_GETRAYPROC(r) ((r) -> crtype >> 8)
64 #define PMAP_SETRAYPROC(r,p) ((r) -> crtype |= p << 8)
65
66 /* Tolerance for photon normal check during lookups */
67 #define PMAP_NORM_TOL 0.02
68
69
70
71 typedef struct {
72 float pos [3]; /* Photon position */
73 signed char norm [3]; /* Surface normal at pos (incident
74 direction for volume photons) */
75 union {
76 struct {
77 #ifndef PMAP_OOC
78 unsigned char discr : 2; /* kd-tree discriminator axis */
79 #endif
80 unsigned char caustic : 1; /* Specularly scattered (=caustic) */
81
82 /* Photon's generating subprocess index, used for primary ray
83 * index linearisation when building contrib pmaps; note this is
84 * reduced for kd-tree to accommodate the discriminator field */
85 unsigned char proc : PMAP_PROCBITS;
86 };
87
88 unsigned char flags;
89 };
90
91 #ifdef PMAP_FLOAT_FLUX
92 COLOR flux;
93 #else
94 COLR flux;
95 #endif
96 PhotonPrimaryIdx primary; /* Index to primary ray */
97 } Photon;
98
99
100
101 /* Define PMAP_FLOAT_FLUX to store photon flux as floats instead of
102 * compact RGBE, which was found to improve accuracy in analytical
103 * validation. */
104 #ifdef PMAP_FLOAT_FLUX
105 #define setPhotonFlux(p,f) copycolor((p) -> flux, f)
106 #define getPhotonFlux(p,f) copycolor(f, (p) -> flux)
107 #else
108 #define setPhotonFlux(p,f) setcolr((p)->flux, (f)[0], (f)[1], (f)[2])
109 #define getPhotonFlux(p,f) colr_color(f, (p) -> flux)
110 #endif
111
112
113
114 /* Bias compensation history node */
115 typedef struct {
116 COLOR irrad;
117 float weight;
118 } PhotonBiasCompNode;
119
120
121 /* Forward declaration */
122 struct PhotonMap;
123
124
125 /* Define search queue and underlying data struct types */
126 #ifdef PMAP_OOC
127 #include "pmapooc.h"
128 #else
129 #include "pmapkdt.h"
130 #endif
131
132
133 typedef struct PhotonMap {
134 PhotonMapType type; /* See pmaptype.h */
135 char *fileName; /* Photon map file */
136
137
138 /* ================================================================
139 * PRE/POST-BUILD STORAGE
140 * ================================================================ */
141 FILE *heap; /* Unsorted photon heap prior to
142 construction of store */
143 Photon *heapBuf; /* Write buffer for above */
144 unsigned long heapBufLen, /* Current & max size of heapBuf */
145 heapBufSize;
146 PhotonStorage store; /* Photon storage in spacee
147 subdividing data struct */
148
149 /* ================================================================
150 * PHOTON DISTRIBUTION STUFF
151 * ================================================================ */
152 unsigned long distribTarget, /* Num stored specified by user */
153 numPhotons; /* Num actually stored */
154 float distribRatio; /* Probability of photon storage */
155 COLOR photonFlux; /* Average photon flux */
156 unsigned short randState [3]; /* Local RNG state */
157
158
159 /* ================================================================
160 * PHOTON LOOKUP STUFF
161 * ================================================================ */
162 union { /* Flags passed to findPhotons() */
163 char lookupCaustic : 1;
164 char lookupFlags;
165 };
166
167 PhotonSearchQueue squeue; /* Search queue for photon lookups */
168 unsigned minGather, /* Specified min/max photons per */
169 maxGather; /* density estimate */
170
171 /* NOTE: All distances are SQUARED */
172 float maxDist2, /* Max search radius */
173 maxDist0, /* Initial value for above */
174 maxDist2Limit, /* Hard limit for above */
175 gatherTolerance; /* Fractional deviation from minGather/
176 maxGather for short lookup */
177 void (*lookup)(struct PhotonMap*,
178 RAY*, COLOR); /* Callback for type-specific photon
179 * lookup (usually density estimate) */
180
181
182 /* ================================================================
183 * BIAS COMPENSATION STUFF
184 * ================================================================ */
185 PhotonBiasCompNode *biasCompHist; /* Bias compensation history */
186
187
188 /* ================================================================
189 * STATISTIX
190 * ================================================================ */
191 unsigned long totalGathered, /* Total photons gathered */
192 numDensity, /* Num density estimates */
193 numLookups, /* Counters for short photon lookups */
194 numShortLookups;
195
196 unsigned minGathered, /* Min/max photons actually gathered */
197 maxGathered, /* per density estimate */
198 shortLookupPct; /* % of short lookups for stats */
199
200 float minError, /* Min/max/rms density estimate error */
201 maxError,
202 rmsError,
203 CoGdist, /* Avg distance to centre of gravity */
204 maxPos [3], /* Max & min photon positions */
205 minPos [3];
206
207 FVECT CoG; /* Centre of gravity (avg photon pos) */
208
209
210 /* ================================================================
211 * PHOTON CONTRIB/COEFF STUFF
212 * ================================================================ */
213 PhotonPrimary *primaries, /* Photon primary array for rendering */
214 lastPrimary; /* Current primary for photon distrib */
215 PhotonPrimaryIdx numPrimary; /* Number of primary rays */
216 LUTAB *srcContrib; /* Lookup table for source contribs */
217 } PhotonMap;
218
219
220
221 /* Photon maps by type (see PhotonMapType) */
222 extern PhotonMap *photonMaps [];
223
224 /* Macros for specific photon map types */
225 #define globalPmap (photonMaps [PMAP_TYPE_GLOBAL])
226 #define preCompPmap (photonMaps [PMAP_TYPE_PRECOMP])
227 #define causticPmap (photonMaps [PMAP_TYPE_CAUSTIC])
228 #define volumePmap (photonMaps [PMAP_TYPE_VOLUME])
229 #define directPmap (photonMaps [PMAP_TYPE_DIRECT])
230 #define contribPmap (photonMaps [PMAP_TYPE_CONTRIB])
231
232 /* Photon map type tests */
233 #define isGlobalPmap(p) ((p) -> type == PMAP_TYPE_GLOBAL)
234 #define isCausticPmap(p) ((p) -> type == PMAP_TYPE_CAUSTIC)
235 #define isContribPmap(p) ((p) -> type == PMAP_TYPE_CONTRIB)
236 #define isVolumePmap(p) ((p) -> type == PMAP_TYPE_VOLUME)
237
238 /* Mean size of heapfile write buffer, in number of photons */
239 #define PMAP_HEAPBUFSIZE 1e6
240
241 /* Mean idle time between heap locking attempts, in usec */
242 #define PMAP_HEAPBUFSLEEP 2e6
243
244 /* Shared memory file for parallelised photon distribution */
245 #if 0
246 #define PMAP_SHMFNAME "/mkpmap-%d"
247 #else
248 #define PMAP_SHMFNAME "mkpmapXXXXXX"
249 #endif
250
251
252 void initPhotonMap (PhotonMap *pmap, PhotonMapType t);
253 /* Initialise empty photon map of specified type */
254
255 int newPhoton (PhotonMap *pmap, const RAY *ray);
256 /* Create new photon with ray's direction, intersection point, and flux,
257 and append to unsorted photon heap pmap -> heap. The photon is
258 accepted with probability pmap -> distribRatio for global density
259 control; if the photon is rejected, -1 is returned, else 0. The flux
260 is scaled by ray -> rweight and 1 / pmap -> distribRatio. */
261
262 void initPhotonHeap (PhotonMap *pmap);
263 /* Open photon heap file */
264
265 void flushPhotonHeap (PhotonMap *pmap);
266 /* Flush photon heap buffa pmap -> heapBuf to heap file pmap -> heap;
267 * used by newPhoton() and to finalise heap in distribPhotons(). */
268
269 void buildPhotonMap (PhotonMap *pmap, double *photonFlux,
270 PhotonPrimaryIdx *primaryOfs, unsigned nproc);
271 /* Postpress unsorted photon heap pmap -> heap and build underlying data
272 * structure pmap -> store. This is prerequisite to photon lookups with
273 * findPhotons(). */
274
275 /* PhotonFlux is the flux per photon averaged over RGB; this is
276 * multiplied with each photon's flux during the postprocess. In the
277 * case of a contribution photon map, this is an array with a separate
278 * flux specific to each light source due to non-uniform photon emission;
279 * Otherwise it is referenced as a scalar value. Flux is not scaled if
280 * photonFlux == NULL. */
281
282 /* Photon map construction may be parallelised if nproc > 1, if
283 * supported. The heap is destroyed on return. */
284
285 /* PrimaryOfs is an array of index offsets for the primaries in pmap ->
286 * primaries generated by each of the nproc subprocesses during contrib
287 * photon distribution (see distribPhotonContrib()). These offsets are
288 * used to linearise the photon primary indices in the postprocess. This
289 * linearisation is skipped if primaryOfs == NULL. */
290
291 void findPhotons (PhotonMap* pmap, const RAY *ray);
292 /* Find pmap -> squeue.len closest photons to ray -> rop with similar
293 normal. For volume photons ray -> rorg is used and the normal is
294 ignored (being the incident direction in this case). Found photons
295 are placed search queue starting with the furthest photon at pmap ->
296 squeue.node, and pmap -> squeue.tail being the number actually found. */
297
298 void find1Photon (PhotonMap *pmap, const RAY *ray, Photon *photon);
299 /* Finds single closest photon to ray -> rop with similar normal.
300 Returns NULL if none found. */
301
302 void getPhoton (PhotonMap *pmap, PhotonIdx idx, Photon *photon);
303 /* Retrieve photon referenced by idx from pmap -> store */
304
305 Photon *getNearestPhoton (const PhotonSearchQueue *squeue, PhotonIdx idx);
306 /* Retrieve photon from NN search queue after calling findPhotons() */
307
308 PhotonIdx firstPhoton (const PhotonMap *pmap);
309 /* Index to first photon, to be passed to getPhoton(). Indices to
310 * subsequent photons can be optained via increment operator (++) */
311
312 void deletePhotons (PhotonMap*);
313 /* Free dem mammaries... */
314
315 #endif
