--- ray/src/rt/pmapdata.h 2015/09/01 16:27:52 2.9 +++ ray/src/rt/pmapdata.h 2024/09/17 16:36:05 2.15 @@ -1,202 +1,340 @@ -/* RCSid $Id: pmapdata.h,v 2.9 2015/09/01 16:27:52 greg Exp $ */ +/* RCSid $Id: pmapdata.h,v 2.15 2024/09/17 16:36:05 greg Exp $ */ + /* - ================================================================== - Photon map data structures and kd-tree handling + ========================================================================= + Photon map types and interface to nearest neighbour lookups in underlying + point cloud data structure. + The default data structure is an in-core kd-tree (see pmapkdt.{h,c}). + This can be overriden with the PMAP_OOC compiletime switch, which enables + an out-of-core octree (see oococt.{h,c}). + + Defining PMAP_FLOAT_FLUX stores photon flux as floats rather than packed + RGBE for greater precision; this may be necessary when the flux differs + significantly in individual colour channels, e.g. with highly saturated + colours. + Roland Schregle (roland.schregle@{hslu.ch, gmail.com}) (c) Fraunhofer Institute for Solar Energy Systems, (c) Lucerne University of Applied Sciences and Arts, - supported by the Swiss National Science Foundation (SNSF, #147053) - ================================================================== + supported by the Swiss National Science Foundation (SNSF, #147053) + ========================================================================= + $Id: pmapdata.h,v 2.15 2024/09/17 16:36:05 greg Exp $ */ + #ifndef PMAPDATA_H #define PMAPDATA_H - #include "ray.h" - #include "pmaptype.h" - #include "lookup.h" + #ifndef NIX + #if defined(_WIN32) || defined(_WIN64) + #define NIX 0 + #else + #define NIX 1 + #endif + #endif + #if (defined(PMAP_OOC) && !NIX) + #error "OOC currently only supported on NIX -- tuff luck." + #endif - /* Define PMAP_FLOAT_FLUX to store photon flux as floats instead of - * compact RGBE, which was found to improve accuracy in analytical - * validation. */ - #ifdef PMAP_FLOAT_FLUX - #define setPhotonFlux(p,f) copycolor((p) -> flux, f) - #define getPhotonFlux(p,f) copycolor(f, (p) -> flux) - #else - #define setPhotonFlux(p,f) setcolr((p)->flux, (f)[0], (f)[1], (f)[2]) - #define getPhotonFlux(p,f) colr_color(f, (p) -> flux) + #ifdef PMAP_CBDM + /* Enable photon primary hitpoints and incident directions (see struct + * PhotonPrimary below). Note this will increase the size of photon + * primaries 9-fold (10-fold after alignment)!!! */ + #define PMAP_PRIMARYPOS + #define PMAP_PRIMARYDIR #endif + #include "ray.h" + #include "pmaptype.h" + #include "paths.h" + #include "lookup.h" + #include /* Primary photon ray for light source contributions */ typedef struct { - int32 srcIdx; /* Index of emitting light source */ - int32 dir; /* Encoded ray direction */ - float pos [3]; /* Hit point */ + int16 srcIdx; /* Index of emitting light source */ + /* !!! REDUCED FROM 32 BITS !!! */ +#ifdef PMAP_PRIMARYDIR + int32 dir; /* Encoded ray direction */ +#endif +#ifdef PMAP_PRIMARYPOS + float pos [3]; /* Hit point */ +#endif } PhotonPrimary; - #define photonSrcIdx(pm, p) ((pm) -> primary [(p) -> primary].srcIdx) + #define photonSrcIdx(pm, p) ((pm)->primaries[(p)->primary].srcIdx) + + + /* Photon primary ray index type and limit */ + typedef uint32 PhotonPrimaryIdx; + #define PMAP_MAXPRIMARY UINT32_MAX + + /* Macros for photon's generating subprocess field */ +#ifdef PMAP_OOC + #define PMAP_PROCBITS 7 +#else + #define PMAP_PROCBITS 5 +#endif + #define PMAP_MAXPROC (1 << PMAP_PROCBITS) + #define PMAP_GETRAYPROC(r) ((r) -> crtype >> 8) + #define PMAP_SETRAYPROC(r,p) ((r) -> crtype |= p << 8) + + /* Tolerance for photon normal check during lookups */ + #define PMAP_NORM_TOL 0.02 - typedef struct { - float pos [3]; /* Photon position */ - signed char norm [3]; /* Surface normal at pos (incident - direction for volume photons) */ - char flags; /* Bit 0-1: kd-tree discriminator axis, - Bit 2: caustic photon */ - #ifdef PMAP_FLOAT_FLUX - COLOR flux; - #else - COLR flux; /* Photon flux */ - #endif - uint32 primary; /* Index to primary ray */ - } Photon; - /* Photon flag bitmasks and manipulation macros */ - #define PMAP_DISCR_BIT 3 - #define PMAP_CAUST_BIT 4 - #define photonDiscr(p) ((p).flags & PMAP_DISCR_BIT) - #define setPhotonDiscr(p, d) ((p).flags = ((p).flags & ~PMAP_DISCR_BIT) | \ - ((d) & PMAP_DISCR_BIT)) + typedef struct { + float pos [3]; /* Photon position */ + signed char norm [3]; /* Surface normal at pos (incident + direction for volume photons) */ + union { + struct { +#ifndef PMAP_OOC + unsigned char discr : 2; /* kd-tree discriminator axis */ +#endif + unsigned char caustic : 1; /* Specularly scattered (=caustic) */ + + /* Photon's generating subprocess index, used for primary ray + * index linearisation when building contrib pmaps; note this is + * reduced for kd-tree to accommodate the discriminator field */ + unsigned char proc : PMAP_PROCBITS; + }; + + unsigned char flags; + }; + +#ifdef PMAP_FLOAT_FLUX + COLOR flux; +#else + COLR flux; +#endif + PhotonPrimaryIdx primary; /* Index to primary ray */ + } Photon; - /* Photon map type tests */ - #define isGlobalPmap(p) ((p) -> type == PMAP_TYPE_GLOBAL) - #define isCausticPmap(p) ((p) -> type == PMAP_TYPE_CAUSTIC) - #define isContribPmap(p) ((p) -> type == PMAP_TYPE_CONTRIB) - #define isVolumePmap(p) ((p) -> type == PMAP_TYPE_VOLUME) + /* Define search queue and underlying data struct types */ +#ifdef PMAP_OOC + #include "pmapooc.h" +#else + #include "pmapkdt.h" +#endif - /* Queue node for photon lookups */ - typedef struct { - Photon *photon; - float dist; - } PhotonSQNode; + /* Define PMAP_FLOAT_FLUX to store photon flux as floats instead of + * compact RGBE, which was found to improve accuracy in analytical + * validation. */ +#ifdef PMAP_FLOAT_FLUX + #define setPhotonFlux(p,f) copycolor((p) -> flux, f) + #define getPhotonFlux(p,f) copycolor(f, (p) -> flux) +#else + #define setPhotonFlux(p,f) setcolr((p)->flux, (f)[0], (f)[1], (f)[2]) + #define getPhotonFlux(p,f) colr_color(f, (p) -> flux) +#endif + /* Bias compensation history node */ - typedef struct { + typedef struct { COLOR irrad; float weight; - } PhotonBCNode; + } PhotonBiasCompNode; - struct PhotonMap; /* Forward declarations */ + /* Forward declaration */ + struct PhotonMap; + + /* Mean size of heapfile write buffer, in number of photons */ + #define PMAP_HEAPBUFSIZE 1e6 + + /* Mean idle time between heap locking attempts, in usec */ + #define PMAP_HEAPBUFSLEEP 2e6 + + /* Temporary filename for photon heaps */ + #define PMAP_TMPFNAME TEMPLATE + #define PMAP_TMPFNLEN (TEMPLEN + 1) + + typedef struct PhotonMap { - PhotonMapType type; /* See pmaptype.h */ - char *fileName; /* Photon map file */ - Photon *heap; /* Photon k-d tree as linear array */ - PhotonSQNode *squeue; /* Search queue */ - PhotonBCNode *biasCompHist; /* Bias compensation history */ - char lookupFlags; /* Flags passed to findPhotons() */ + PhotonMapType type; /* See pmaptype.h */ + char *fileName; /* Photon map file */ - unsigned long distribTarget, /* Num stored specified by user */ - heapSize, - heapSizeInc, - heapEnd, /* Num actually stored in heap */ - numDensity, /* Num density estimates */ - totalGathered, /* Total photons gathered */ - numLookups, /* Counters for short photon lookups */ - numShortLookups; - - unsigned minGather, /* Specified min/max photons per */ - maxGather, /* density estimate */ - squeueSize, - squeueEnd, - minGathered, /* Min/max photons actually gathered */ - maxGathered, /* per density estimate */ - shortLookupPct; /* Percentage of short lookups (for - statistics output */ - - /* NOTE: All distances are SQUARED */ - float maxDist, /* Max search radius during NN search */ - maxDist0, /* Initial value for above */ - maxDistLimit, /* Hard limit for above */ - CoGdist, /* Avg distance to centre of gravity */ - maxPos [3], minPos [3], /* Max & min photon positions */ - distribRatio, /* Probability of photon storage */ - gatherTolerance, /* Fractional deviation from minGather/ - maxGather for short lookup */ - minError, maxError, /* Min/max/rms density estimate error */ - rmsError; - - FVECT CoG; /* Centre of gravity (avg photon pos) */ - COLOR photonFlux; /* Average photon flux */ - unsigned short randState [3]; /* Local RNG state */ - void (*lookup)(struct PhotonMap*, RAY*, COLOR); - /* Callback for type-specific photon - * lookup (usually density estimate) */ + /* ================================================================ + * PRE/POST-BUILD STORAGE + * ================================================================ */ + FILE *heap; /* Unsorted photon heap prior to + construction of store */ + char heapFname [sizeof(PMAP_TMPFNAME)]; + Photon *heapBuf; /* Write buffer for above */ + unsigned long heapBufLen, /* Current & max size of heapBuf */ + heapBufSize; + PhotonStorage store; /* Photon storage in space + subdividing data struct */ + + /* ================================================================ + * PHOTON DISTRIBUTION STUFF + * ================================================================ */ + unsigned long distribTarget, /* Num stored specified by user */ + numPhotons; /* Num actually stored */ + float distribRatio; /* Probability of photon storage */ + COLOR photonFlux; /* Average photon flux */ + unsigned short randState [3]; /* Local RNG state */ - PhotonPrimary *primary; /* Primary photon rays & associated - counters */ - unsigned primarySize, primaryEnd; - - LUTAB *srcContrib; /* lookup table for source contribs */ + + /* ================================================================ + * PHOTON LOOKUP STUFF + * ================================================================ */ + union { /* Flags passed to findPhotons() */ + char lookupCaustic : 1; + char lookupFlags; + }; + + PhotonSearchQueue squeue; /* Search queue for photon lookups */ + unsigned minGather, /* Specified min/max photons per */ + maxGather; /* density estimate */ + + /* NOTE: All distances are SQUARED */ + float maxDist2, /* Max search radius */ + maxDist0, /* Initial value for above */ + maxDist2Limit, /* Hard limit for above */ + gatherTolerance; /* Fractional deviation from minGather/ + maxGather for short lookup */ + void (*lookup)(struct PhotonMap*, + RAY*, COLOR); /* Callback for type-specific photon + * lookup (usually density estimate) */ + + + /* ================================================================ + * BIAS COMPENSATION STUFF + * ================================================================ */ + PhotonBiasCompNode *biasCompHist; /* Bias compensation history */ + + + /* ================================================================ + * STATISTIX + * ================================================================ */ + unsigned long totalGathered, /* Total photons gathered */ + numDensity, /* Num density estimates */ + numLookups, /* Counters for short photon lookups */ + numShortLookups; + + unsigned minGathered, /* Min/max photons actually gathered */ + maxGathered, /* per density estimate */ + shortLookupPct; /* % of short lookups for stats */ + + float minError, /* Min/max/rms density estimate error */ + maxError, + rmsError, + CoGdist, /* Avg distance to centre of gravity */ + maxPos [3], /* Max & min photon positions */ + minPos [3]; + + FVECT CoG; /* Centre of gravity (avg photon pos) */ + + + /* ================================================================ + * PHOTON CONTRIB/COEFF STUFF + * ================================================================ */ + PhotonPrimary *primaries, /* Photon primary array for rendering */ + lastPrimary; /* Current primary for photon distrib */ + PhotonPrimaryIdx numPrimary; /* Number of primary rays */ + LUTAB *srcContrib; /* Lookup table for source contribs */ } PhotonMap; /* Photon maps by type (see PhotonMapType) */ - extern PhotonMap *photonMaps []; + extern PhotonMap *photonMaps []; /* Macros for specific photon map types */ - #define globalPmap (photonMaps [PMAP_TYPE_GLOBAL]) - #define preCompPmap (photonMaps [PMAP_TYPE_PRECOMP]) - #define causticPmap (photonMaps [PMAP_TYPE_CAUSTIC]) - #define volumePmap (photonMaps [PMAP_TYPE_VOLUME]) - #define directPmap (photonMaps [PMAP_TYPE_DIRECT]) - #define contribPmap (photonMaps [PMAP_TYPE_CONTRIB]) + #define globalPmap (photonMaps [PMAP_TYPE_GLOBAL]) + #define preCompPmap (photonMaps [PMAP_TYPE_PRECOMP]) + #define causticPmap (photonMaps [PMAP_TYPE_CAUSTIC]) + #define volumePmap (photonMaps [PMAP_TYPE_VOLUME]) + #define directPmap (photonMaps [PMAP_TYPE_DIRECT]) + #define contribPmap (photonMaps [PMAP_TYPE_CONTRIB]) + /* Photon map type tests */ + #define isGlobalPmap(p) ((p) -> type == PMAP_TYPE_GLOBAL) + #define isCausticPmap(p) ((p) -> type == PMAP_TYPE_CAUSTIC) + #define isContribPmap(p) ((p) -> type == PMAP_TYPE_CONTRIB) + #define isVolumePmap(p) ((p) -> type == PMAP_TYPE_VOLUME) +#ifdef __cplusplus +extern "C" { +#endif void initPhotonMap (PhotonMap *pmap, PhotonMapType t); /* Initialise empty photon map of specified type */ - const PhotonPrimary* addPhotonPrimary (PhotonMap *pmap, const RAY *ray); - /* Add primary ray for emitted photon and save light source index, origin - * on source, and emitted direction; used by contrib photons */ - - const Photon* addPhoton (PhotonMap *pmap, const RAY *ray); + int newPhoton (PhotonMap *pmap, const RAY *ray); /* Create new photon with ray's direction, intersection point, and flux, - and add to photon map subject to acceptance probability pmap -> - distribRatio for global density control; if the photon is rejected, - NULL is returned. The flux is scaled by ray -> rweight and - 1 / pmap -> distribRatio. */ + and append to unsorted photon heap pmap -> heap. The photon is + accepted with probability pmap -> distribRatio for global density + control; if the photon is rejected, -1 is returned, else 0. The flux + is scaled by ray -> rweight and 1 / pmap -> distribRatio. */ - void balancePhotons (PhotonMap *pmap, double *photonFlux); - /* Build a balanced kd-tree as heap to guarantee logarithmic search - * times. This must be called prior to performing photon search with - * findPhotons(). - * PhotonFlux is the flux scaling factor per photon averaged over RGB. In - * the case of a contribution photon map, this is an array with a - * separate factor specific to each light source due to non-uniform - * photon emission; Otherwise it is referenced as a scalar value. Flux is - * not scaled if photonFlux == NULL. */ + void initPhotonHeap (PhotonMap *pmap); + /* Open photon heap file */ - void buildHeap (Photon *heap, unsigned long *heapIdx, - unsigned long *heapXdi, const float min [3], - const float max [3], unsigned long left, - unsigned long right, unsigned long root); - /* Recursive part of balancePhotons(..); builds heap from subarray - * defined by indices left and right. */ - + void flushPhotonHeap (PhotonMap *pmap); + /* Flush photon heap buffa pmap -> heapBuf to heap file pmap -> heap; + * used by newPhoton() and to finalise heap in distribPhotons(). */ + + void buildPhotonMap (PhotonMap *pmap, double *photonFlux, + PhotonPrimaryIdx *primaryOfs, unsigned nproc); + /* Postpress unsorted photon heap pmap -> heap and build underlying data + * structure pmap -> store. This is prerequisite to photon lookups with + * findPhotons(). */ + + /* PhotonFlux is the flux per photon averaged over RGB; this is + * multiplied with each photon's flux during the postprocess. In the + * case of a contribution photon map, this is an array with a separate + * flux specific to each light source due to non-uniform photon emission; + * Otherwise it is referenced as a scalar value. Flux is not scaled if + * photonFlux == NULL. */ + + /* Photon map construction may be parallelised if nproc > 1, if + * supported. The heap is destroyed on return. */ + + /* PrimaryOfs is an array of index offsets for the primaries in pmap -> + * primaries generated by each of the nproc subprocesses during contrib + * photon distribution (see distribPhotonContrib()). These offsets are + * used to linearise the photon primary indices in the postprocess. This + * linearisation is skipped if primaryOfs == NULL. */ + void findPhotons (PhotonMap* pmap, const RAY *ray); - /* Find pmap -> squeueSize closest photons to ray -> rop with similar + /* Find pmap -> squeue.len closest photons to ray -> rop with similar normal. For volume photons ray -> rorg is used and the normal is ignored (being the incident direction in this case). Found photons - are placed in pmap -> squeue, with pmap -> squeueEnd being the number - actually found. */ + are placed search queue starting with the furthest photon at pmap -> + squeue.node, and pmap -> squeue.tail being the number actually found. */ - Photon *find1Photon (PhotonMap *pmap, const RAY *ray); - /* Finds single closest photon to ray -> rop with similar normal. - Returns NULL if none found. */ + Photon *find1Photon (PhotonMap *pmap, const RAY *ray, Photon *photon); + /* Find single closest photon to ray -> rop with similar normal. + Return NULL if none found, else the supplied Photon* buffer, + indicating that it contains a valid photon. */ + void getPhoton (PhotonMap *pmap, PhotonIdx idx, Photon *photon); + /* Retrieve photon referenced by idx from pmap -> store */ + + Photon *getNearestPhoton (const PhotonSearchQueue *squeue, PhotonIdx idx); + /* Retrieve photon from NN search queue after calling findPhotons() */ + + PhotonIdx firstPhoton (const PhotonMap *pmap); + /* Index to first photon, to be passed to getPhoton(). Indices to + * subsequent photons can be optained via increment operator (++) */ + void deletePhotons (PhotonMap*); /* Free dem mammaries... */ + +#ifdef __cplusplus +} +#endif #endif
