root/radiance/ray/src/rt/pmapdata.h
Revision: 2.12
Committed: Thu Feb 8 19:55:02 2018 UTC (7 years, 6 months ago) by rschregle
Made photon primary incident dirs optional via PMAP_PRIMARYDIR, bumped PMAP_FILEVER
1 /* RCSid $Id: pmapdata.h,v 2.11 2017/08/14 21:12:10 rschregle Exp $ */
2
3 /*
4 =========================================================================
5 Photon map types and interface to nearest neighbour lookups in underlying
6 point cloud data structure.
7
8 The default data structure is an in-core kd-tree (see pmapkdt.{h,c}).
9 This can be overriden with the PMAP_OOC compiletime switch, which enables
10 an out-of-core octree (see oococt.{h,c}).
11
12 Defining PMAP_FLOAT_FLUX stores photon flux as floats rather than packed
13 RGBE for greater precision; this may be necessary when the flux differs
14 significantly in individual colour channels, e.g. with highly saturated
15 colours.
16
17 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
18 (c) Fraunhofer Institute for Solar Energy Systems,
19 (c) Lucerne University of Applied Sciences and Arts,
20 supported by the Swiss National Science Foundation (SNSF, #147053)
21 =========================================================================
22
23 $Id: pmapdata.h,v 2.11 2017/08/14 21:12:10 rschregle Exp $
24 */
25
26
27
28 #ifndef PMAPDATA_H
29 #define PMAPDATA_H
30
31 #ifndef NIX
32 #if defined(_WIN32) || defined(_WIN64)
33 #define NIX 0
34 #else
35 #define NIX 1
36 #endif
37 #endif
38
39 #if (defined(PMAP_OOC) && !NIX)
40 #error "OOC currently only supported on NIX -- tuff luck."
41 #endif
42
43
44 #include "ray.h"
45 #include "pmaptype.h"
46 #include "paths.h"
47 #include "lookup.h"
48 #include <stdint.h>
49
50
51
52 /* Primary photon ray for light source contributions */
53 typedef struct {
54 int16 srcIdx; /* Index of emitting light source */
55 /* !!! REDUCED FROM 32 BITS !!! */
56 #ifdef PMAP_PRIMARYDIR
57 int32 dir; /* Encoded ray direction */
58 #endif
59 #ifdef PMAP_PRIMARYPOS
60 float pos [3]; /* Hit point */
61 #endif
62 } PhotonPrimary;
63
64 #define photonSrcIdx(pm, p) ((pm)->primaries[(p)->primary].srcIdx)
65
66
67
68 /* Photon primary ray index type and limit */
69 typedef uint32 PhotonPrimaryIdx;
70 #define PMAP_MAXPRIMARY UINT32_MAX
71
72 /* Macros for photon's generating subprocess field */
73 #ifdef PMAP_OOC
74 #define PMAP_PROCBITS 7
75 #else
76 #define PMAP_PROCBITS 5
77 #endif
78 #define PMAP_MAXPROC (1 << PMAP_PROCBITS)
79 #define PMAP_GETRAYPROC(r) ((r) -> crtype >> 8)
80 #define PMAP_SETRAYPROC(r,p) ((r) -> crtype |= p << 8)
81
82 /* Tolerance for photon normal check during lookups */
83 #define PMAP_NORM_TOL 0.02
84
85
86
87 typedef struct {
88 float pos [3]; /* Photon position */
89 signed char norm [3]; /* Surface normal at pos (incident
90 direction for volume photons) */
91 union {
92 struct {
93 #ifndef PMAP_OOC
94 unsigned char discr : 2; /* kd-tree discriminator axis */
95 #endif
96 unsigned char caustic : 1; /* Specularly scattered (=caustic) */
97
98 /* Photon's generating subprocess index, used for primary ray
99 * index linearisation when building contrib pmaps; note this is
100 * reduced for kd-tree to accommodate the discriminator field */
101 unsigned char proc : PMAP_PROCBITS;
102 };
103
104 unsigned char flags;
105 };
106
107 #ifdef PMAP_FLOAT_FLUX
108 COLOR flux;
109 #else
110 COLR flux;
111 #endif
112 PhotonPrimaryIdx primary; /* Index to primary ray */
113 } Photon;
114
115
116
117 /* Define PMAP_FLOAT_FLUX to store photon flux as floats instead of
118 * compact RGBE, which was found to improve accuracy in analytical
119 * validation. */
120 #ifdef PMAP_FLOAT_FLUX
121 #define setPhotonFlux(p,f) copycolor((p) -> flux, f)
122 #define getPhotonFlux(p,f) copycolor(f, (p) -> flux)
123 #else
124 #define setPhotonFlux(p,f) setcolr((p)->flux, (f)[0], (f)[1], (f)[2])
125 #define getPhotonFlux(p,f) colr_color(f, (p) -> flux)
126 #endif
127
128
129 /* Bias compensation history node */
130 typedef struct {
131 COLOR irrad;
132 float weight;
133 } PhotonBiasCompNode;
134
135
136 /* Forward declaration */
137 struct PhotonMap;
138
139
140 /* Define search queue and underlying data struct types */
141 #ifdef PMAP_OOC
142 #include "pmapooc.h"
143 #else
144 #include "pmapkdt.h"
145 #endif
146
147
148 /* Mean size of heapfile write buffer, in number of photons */
149 #define PMAP_HEAPBUFSIZE 1e6
150
151 /* Mean idle time between heap locking attempts, in usec */
152 #define PMAP_HEAPBUFSLEEP 2e6
153
154 /* Temporary filename for photon heaps */
155 #define PMAP_TMPFNAME TEMPLATE
156 #define PMAP_TMPFNLEN (TEMPLEN + 1)
157
158
159 typedef struct PhotonMap {
160 PhotonMapType type; /* See pmaptype.h */
161 char *fileName; /* Photon map file */
162
163
164 /* ================================================================
165 * PRE/POST-BUILD STORAGE
166 * ================================================================ */
167 FILE *heap; /* Unsorted photon heap prior to
168 construction of store */
169 char heapFname [sizeof(PMAP_TMPFNAME)];
170 Photon *heapBuf; /* Write buffer for above */
171 unsigned long heapBufLen, /* Current & max size of heapBuf */
172 heapBufSize;
173 PhotonStorage store; /* Photon storage in space
174 subdividing data struct */
175
176 /* ================================================================
177 * PHOTON DISTRIBUTION STUFF
178 * ================================================================ */
179 unsigned long distribTarget, /* Num stored specified by user */
180 numPhotons; /* Num actually stored */
181 float distribRatio; /* Probability of photon storage */
182 COLOR photonFlux; /* Average photon flux */
183 unsigned short randState [3]; /* Local RNG state */
184
185
186 /* ================================================================
187 * PHOTON LOOKUP STUFF
188 * ================================================================ */
189 union { /* Flags passed to findPhotons() */
190 char lookupCaustic : 1;
191 char lookupFlags;
192 };
193
194 PhotonSearchQueue squeue; /* Search queue for photon lookups */
195 unsigned minGather, /* Specified min/max photons per */
196 maxGather; /* density estimate */
197
198 /* NOTE: All distances are SQUARED */
199 float maxDist2, /* Max search radius */
200 maxDist0, /* Initial value for above */
201 maxDist2Limit, /* Hard limit for above */
202 gatherTolerance; /* Fractional deviation from minGather/
203 maxGather for short lookup */
204 void (*lookup)(struct PhotonMap*,
205 RAY*, COLOR); /* Callback for type-specific photon
206 * lookup (usually density estimate) */
207
208
209 /* ================================================================
210 * BIAS COMPENSATION STUFF
211 * ================================================================ */
212 PhotonBiasCompNode *biasCompHist; /* Bias compensation history */
213
214
215 /* ================================================================
216 * STATISTIX
217 * ================================================================ */
218 unsigned long totalGathered, /* Total photons gathered */
219 numDensity, /* Num density estimates */
220 numLookups, /* Counters for short photon lookups */
221 numShortLookups;
222
223 unsigned minGathered, /* Min/max photons actually gathered */
224 maxGathered, /* per density estimate */
225 shortLookupPct; /* % of short lookups for stats */
226
227 float minError, /* Min/max/rms density estimate error */
228 maxError,
229 rmsError,
230 CoGdist, /* Avg distance to centre of gravity */
231 maxPos [3], /* Max & min photon positions */
232 minPos [3];
233
234 FVECT CoG; /* Centre of gravity (avg photon pos) */
235
236
237 /* ================================================================
238 * PHOTON CONTRIB/COEFF STUFF
239 * ================================================================ */
240 PhotonPrimary *primaries, /* Photon primary array for rendering */
241 lastPrimary; /* Current primary for photon distrib */
242 PhotonPrimaryIdx numPrimary; /* Number of primary rays */
243 LUTAB *srcContrib; /* Lookup table for source contribs */
244 } PhotonMap;
245
246
247
248 /* Photon maps by type (see PhotonMapType) */
249 extern PhotonMap *photonMaps [];
250
251 /* Macros for specific photon map types */
252 #define globalPmap (photonMaps [PMAP_TYPE_GLOBAL])
253 #define preCompPmap (photonMaps [PMAP_TYPE_PRECOMP])
254 #define causticPmap (photonMaps [PMAP_TYPE_CAUSTIC])
255 #define volumePmap (photonMaps [PMAP_TYPE_VOLUME])
256 #define directPmap (photonMaps [PMAP_TYPE_DIRECT])
257 #define contribPmap (photonMaps [PMAP_TYPE_CONTRIB])
258
259 /* Photon map type tests */
260 #define isGlobalPmap(p) ((p) -> type == PMAP_TYPE_GLOBAL)
261 #define isCausticPmap(p) ((p) -> type == PMAP_TYPE_CAUSTIC)
262 #define isContribPmap(p) ((p) -> type == PMAP_TYPE_CONTRIB)
263 #define isVolumePmap(p) ((p) -> type == PMAP_TYPE_VOLUME)
264
265
266
267 void initPhotonMap (PhotonMap *pmap, PhotonMapType t);
268 /* Initialise empty photon map of specified type */
269
270 int newPhoton (PhotonMap *pmap, const RAY *ray);
271 /* Create new photon with ray's direction, intersection point, and flux,
272 and append to unsorted photon heap pmap -> heap. The photon is
273 accepted with probability pmap -> distribRatio for global density
274 control; if the photon is rejected, -1 is returned, else 0. The flux
275 is scaled by ray -> rweight and 1 / pmap -> distribRatio. */
276
277 void initPhotonHeap (PhotonMap *pmap);
278 /* Open photon heap file */
279
280 void flushPhotonHeap (PhotonMap *pmap);
281 /* Flush photon heap buffa pmap -> heapBuf to heap file pmap -> heap;
282 * used by newPhoton() and to finalise heap in distribPhotons(). */
283
284 void buildPhotonMap (PhotonMap *pmap, double *photonFlux,
285 PhotonPrimaryIdx *primaryOfs, unsigned nproc);
286 /* Postpress unsorted photon heap pmap -> heap and build underlying data
287 * structure pmap -> store. This is prerequisite to photon lookups with
288 * findPhotons(). */
289
290 /* PhotonFlux is the flux per photon averaged over RGB; this is
291 * multiplied with each photon's flux during the postprocess. In the
292 * case of a contribution photon map, this is an array with a separate
293 * flux specific to each light source due to non-uniform photon emission;
294 * Otherwise it is referenced as a scalar value. Flux is not scaled if
295 * photonFlux == NULL. */
296
297 /* Photon map construction may be parallelised if nproc > 1, if
298 * supported. The heap is destroyed on return. */
299
300 /* PrimaryOfs is an array of index offsets for the primaries in pmap ->
301 * primaries generated by each of the nproc subprocesses during contrib
302 * photon distribution (see distribPhotonContrib()). These offsets are
303 * used to linearise the photon primary indices in the postprocess. This
304 * linearisation is skipped if primaryOfs == NULL. */
305
306 void findPhotons (PhotonMap* pmap, const RAY *ray);
307 /* Find pmap -> squeue.len closest photons to ray -> rop with similar
308 normal. For volume photons ray -> rorg is used and the normal is
309 ignored (being the incident direction in this case). Found photons
310 are placed search queue starting with the furthest photon at pmap ->
311 squeue.node, and pmap -> squeue.tail being the number actually found. */
312
313 void find1Photon (PhotonMap *pmap, const RAY *ray, Photon *photon);
314 /* Finds single closest photon to ray -> rop with similar normal.
315 Returns NULL if none found. */
316
317 void getPhoton (PhotonMap *pmap, PhotonIdx idx, Photon *photon);
318 /* Retrieve photon referenced by idx from pmap -> store */
319
320 Photon *getNearestPhoton (const PhotonSearchQueue *squeue, PhotonIdx idx);
321 /* Retrieve photon from NN search queue after calling findPhotons() */
322
323 PhotonIdx firstPhoton (const PhotonMap *pmap);
324 /* Index to first photon, to be passed to getPhoton(). Indices to
325 * subsequent photons can be optained via increment operator (++) */
326
327 void deletePhotons (PhotonMap*);
328 /* Free dem mammaries... */
329
330 #endif
