root/Development/ray/src/rt/pmapdata.h
Wed Apr 8 15:14:21 2020 UTC (5 years, 8 months ago) by rschregle
CVS Tags: rad5R3, rad5R4
Changes since 2.13: +6 -5 lines
Diff to previous 2.13
Fixed est00pid bug in single photon lookups that returned junk when none found, added code to detect and handle (ignore).
Fri Dec 7 20:02:40 2018 UTC (7 years ago) by rschregle
Changes since 2.12: +30 -23 lines
Diff to previous 2.12
Minor cleanup, added PMAP_CBDM convenience macro for combined PMAP_PRIMARYPOS &
PMAP_PRIMARYDIR
Thu Feb 8 19:55:02 2018 UTC (7 years, 10 months ago) by rschregle
Made photon primary incident dirs optional via PMAP_PRIMARYDIR, bumped PMAP_FILEVER
Mon Aug 14 21:12:10 2017 UTC (8 years, 4 months ago) by rschregle
Changes since 2.10: +30 -17 lines
Updated photon map code for Windows; no multproc or ooC for now
Tue May 17 17:39:47 2016 UTC (9 years, 7 months ago) by rschregle
Changes since 2.9: +253 -140 lines
Tue Sep 1 16:27:52 2015 UTC (10 years, 4 months ago) by greg
Changes since 2.8: +1 -2 lines
Tue Aug 18 18:45:55 2015 UTC (10 years, 4 months ago) by greg
Wed Jul 29 18:54:20 2015 UTC (10 years, 5 months ago) by rschregle
Fixed bug with handling of -am rendering option, removed redundant code
Thu May 28 12:27:22 2015 UTC (10 years, 7 months ago) by greg
Bug fix for uninitialized sources set to -1
Wed May 20 14:44:12 2015 UTC (10 years, 7 months ago) by greg
Reduced primary photon struct size using encoded direction
Wed May 20 14:15:26 2015 UTC (10 years, 7 months ago) by greg
Fixed primary photon index at 32 bits
Wed May 20 12:58:31 2015 UTC (10 years, 7 months ago) by greg
Added appropriate setting of ray parameters for bin rcontrib evaluation
Fri May 8 13:20:22 2015 UTC (10 years, 7 months ago) by rschregle
Tue Feb 24 19:39:26 2015 UTC (10 years, 10 months ago) by greg
