root/radiance/ray/src/rt/pmapdata.h
Mon Aug 14 21:12:10 2017 UTC (6 years, 9 months ago) by rschregle
Changes since 2.10: +30 -17 lines
Diff to previous 2.10 , to selected 2.3
Updated photon map code for Windows; no multproc or ooC for now
Tue May 17 17:39:47 2016 UTC (8 years ago) by rschregle
Changes since 2.9: +253 -140 lines
Diff to previous 2.9 , to selected 2.3
Tue Sep 1 16:27:52 2015 UTC (8 years, 8 months ago) by greg
Changes since 2.8: +1 -2 lines
Tue Aug 18 18:45:55 2015 UTC (8 years, 9 months ago) by greg
Wed Jul 29 18:54:20 2015 UTC (8 years, 9 months ago) by rschregle
Fixed bug with handling of -am rendering option, removed redundant code
Thu May 28 12:27:22 2015 UTC (8 years, 11 months ago) by greg
Bug fix for uninitialized sources set to -1
Wed May 20 14:44:12 2015 UTC (9 years ago) by greg
Reduced primary photon struct size using encoded direction
Wed May 20 14:15:26 2015 UTC (9 years ago) by greg
Fixed primary photon index at 32 bits
Wed May 20 12:58:31 2015 UTC (9 years ago) by greg
Added appropriate setting of ray parameters for bin rcontrib evaluation
Fri May 8 13:20:22 2015 UTC (9 years ago) by rschregle
Tue Feb 24 19:39:26 2015 UTC (9 years, 2 months ago) by greg
Diff to selected 2.3
