root/radiance/ray/src/rt/pmapdata.h
Revision: 2.11
Committed: Mon Aug 14 21:12:10 2017 UTC (7 years, 9 months ago) by rschregle
Changes since 2.10: +30 -17 lines
Updated photon map code for Windows; no multproc or ooC for now
1 /* RCSid $Id: pmapdata.h,v 2.10 2016/05/17 17:39:47 rschregle Exp $ */
2
3 /*
4 =========================================================================
5 Photon map types and interface to nearest neighbour lookups in underlying
6 point cloud data structure.
7
8 The default data structure is an in-core kd-tree (see pmapkdt.{h,c}).
9 This can be overriden with the PMAP_OOC compiletime switch, which enables
10 an out-of-core octree (see oococt.{h,c}).
11
12 Defining PMAP_FLOAT_FLUX stores photon flux as floats rather than packed
13 RGBE for greater precision; this may be necessary when the flux differs
14 significantly in individual colour channels, e.g. with highly saturated
15 colours.
16
17 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
18 (c) Fraunhofer Institute for Solar Energy Systems,
19 (c) Lucerne University of Applied Sciences and Arts,
20 supported by the Swiss National Science Foundation (SNSF, #147053)
21 =========================================================================
22
23 $Id: pmapdata.h,v 2.10 2016/05/17 17:39:47 rschregle Exp $
24 */
25
26
27
28 #ifndef PMAPDATA_H
29 #define PMAPDATA_H
30
31 #ifndef NIX
32 #if defined(_WIN32) || defined(_WIN64)
33 #define NIX 0
34 #else
35 #define NIX 1
36 #endif
37 #endif
38
39 #if (defined(PMAP_OOC) && !NIX)
40 #error "OOC currently only supported on NIX -- tuff luck."
41 #endif
42
43
44 #include "ray.h"
45 #include "pmaptype.h"
46 #include "paths.h"
47 #include "lookup.h"
48 #include <stdint.h>
49
50
51
52 /* Primary photon ray for light source contributions */
53 typedef struct {
54 int16 srcIdx; /* Index of emitting light source */
55 /* !!! REDUCED FROM 32 BITS !!! */
56 int32 dir; /* Encoded ray direction */
57 #ifdef PMAP_PRIMARYPOS
58 float pos [3]; /* Hit point */
59 #endif
60 } PhotonPrimary;
61
62 #define photonSrcIdx(pm, p) ((pm)->primaries[(p)->primary].srcIdx)
63
64
65
66 /* Photon primary ray index type and limit */
67 typedef uint32 PhotonPrimaryIdx;
68 #define PMAP_MAXPRIMARY UINT32_MAX
69
70 /* Macros for photon's generating subprocess field */
71 #ifdef PMAP_OOC
72 #define PMAP_PROCBITS 7
73 #else
74 #define PMAP_PROCBITS 5
75 #endif
76 #define PMAP_MAXPROC (1 << PMAP_PROCBITS)
77 #define PMAP_GETRAYPROC(r) ((r) -> crtype >> 8)
78 #define PMAP_SETRAYPROC(r,p) ((r) -> crtype |= p << 8)
79
80 /* Tolerance for photon normal check during lookups */
81 #define PMAP_NORM_TOL 0.02
82
83
84
85 typedef struct {
86 float pos [3]; /* Photon position */
87 signed char norm [3]; /* Surface normal at pos (incident
88 direction for volume photons) */
89 union {
90 struct {
91 #ifndef PMAP_OOC
92 unsigned char discr : 2; /* kd-tree discriminator axis */
93 #endif
94 unsigned char caustic : 1; /* Specularly scattered (=caustic) */
95
96 /* Photon's generating subprocess index, used for primary ray
97 * index linearisation when building contrib pmaps; note this is
98 * reduced for kd-tree to accommodate the discriminator field */
99 unsigned char proc : PMAP_PROCBITS;
100 };
101
102 unsigned char flags;
103 };
104
105 #ifdef PMAP_FLOAT_FLUX
106 COLOR flux;
107 #else
108 COLR flux;
109 #endif
110 PhotonPrimaryIdx primary; /* Index to primary ray */
111 } Photon;
112
113
114
115 /* Define PMAP_FLOAT_FLUX to store photon flux as floats instead of
116 * compact RGBE, which was found to improve accuracy in analytical
117 * validation. */
118 #ifdef PMAP_FLOAT_FLUX
119 #define setPhotonFlux(p,f) copycolor((p) -> flux, f)
120 #define getPhotonFlux(p,f) copycolor(f, (p) -> flux)
121 #else
122 #define setPhotonFlux(p,f) setcolr((p)->flux, (f)[0], (f)[1], (f)[2])
123 #define getPhotonFlux(p,f) colr_color(f, (p) -> flux)
124 #endif
125
126
127 /* Bias compensation history node */
128 typedef struct {
129 COLOR irrad;
130 float weight;
131 } PhotonBiasCompNode;
132
133
134 /* Forward declaration */
135 struct PhotonMap;
136
137
138 /* Define search queue and underlying data struct types */
139 #ifdef PMAP_OOC
140 #include "pmapooc.h"
141 #else
142 #include "pmapkdt.h"
143 #endif
144
145
146 /* Mean size of heapfile write buffer, in number of photons */
147 #define PMAP_HEAPBUFSIZE 1e6
148
149 /* Mean idle time between heap locking attempts, in usec */
150 #define PMAP_HEAPBUFSLEEP 2e6
151
152 /* Temporary filename for photon heaps */
153 #define PMAP_TMPFNAME TEMPLATE
154 #define PMAP_TMPFNLEN (TEMPLEN + 1)
155
156
157 typedef struct PhotonMap {
158 PhotonMapType type; /* See pmaptype.h */
159 char *fileName; /* Photon map file */
160
161
162 /* ================================================================
163 * PRE/POST-BUILD STORAGE
164 * ================================================================ */
165 FILE *heap; /* Unsorted photon heap prior to
166 construction of store */
167 char heapFname [sizeof(PMAP_TMPFNAME)];
168 Photon *heapBuf; /* Write buffer for above */
169 unsigned long heapBufLen, /* Current & max size of heapBuf */
170 heapBufSize;
171 PhotonStorage store; /* Photon storage in space
172 subdividing data struct */
173
174 /* ================================================================
175 * PHOTON DISTRIBUTION STUFF
176 * ================================================================ */
177 unsigned long distribTarget, /* Num stored specified by user */
178 numPhotons; /* Num actually stored */
179 float distribRatio; /* Probability of photon storage */
180 COLOR photonFlux; /* Average photon flux */
181 unsigned short randState [3]; /* Local RNG state */
182
183
184 /* ================================================================
185 * PHOTON LOOKUP STUFF
186 * ================================================================ */
187 union { /* Flags passed to findPhotons() */
188 char lookupCaustic : 1;
189 char lookupFlags;
190 };
191
192 PhotonSearchQueue squeue; /* Search queue for photon lookups */
193 unsigned minGather, /* Specified min/max photons per */
194 maxGather; /* density estimate */
195
196 /* NOTE: All distances are SQUARED */
197 float maxDist2, /* Max search radius */
198 maxDist0, /* Initial value for above */
199 maxDist2Limit, /* Hard limit for above */
200 gatherTolerance; /* Fractional deviation from minGather/
201 maxGather for short lookup */
202 void (*lookup)(struct PhotonMap*,
203 RAY*, COLOR); /* Callback for type-specific photon
204 * lookup (usually density estimate) */
205
206
207 /* ================================================================
208 * BIAS COMPENSATION STUFF
209 * ================================================================ */
210 PhotonBiasCompNode *biasCompHist; /* Bias compensation history */
211
212
213 /* ================================================================
214 * STATISTIX
215 * ================================================================ */
216 unsigned long totalGathered, /* Total photons gathered */
217 numDensity, /* Num density estimates */
218 numLookups, /* Counters for short photon lookups */
219 numShortLookups;
220
221 unsigned minGathered, /* Min/max photons actually gathered */
222 maxGathered, /* per density estimate */
223 shortLookupPct; /* % of short lookups for stats */
224
225 float minError, /* Min/max/rms density estimate error */
226 maxError,
227 rmsError,
228 CoGdist, /* Avg distance to centre of gravity */
229 maxPos [3], /* Max & min photon positions */
230 minPos [3];
231
232 FVECT CoG; /* Centre of gravity (avg photon pos) */
233
234
235 /* ================================================================
236 * PHOTON CONTRIB/COEFF STUFF
237 * ================================================================ */
238 PhotonPrimary *primaries, /* Photon primary array for rendering */
239 lastPrimary; /* Current primary for photon distrib */
240 PhotonPrimaryIdx numPrimary; /* Number of primary rays */
241 LUTAB *srcContrib; /* Lookup table for source contribs */
242 } PhotonMap;
243
244
245
246 /* Photon maps by type (see PhotonMapType) */
247 extern PhotonMap *photonMaps [];
248
249 /* Macros for specific photon map types */
250 #define globalPmap (photonMaps [PMAP_TYPE_GLOBAL])
251 #define preCompPmap (photonMaps [PMAP_TYPE_PRECOMP])
252 #define causticPmap (photonMaps [PMAP_TYPE_CAUSTIC])
253 #define volumePmap (photonMaps [PMAP_TYPE_VOLUME])
254 #define directPmap (photonMaps [PMAP_TYPE_DIRECT])
255 #define contribPmap (photonMaps [PMAP_TYPE_CONTRIB])
256
257 /* Photon map type tests */
258 #define isGlobalPmap(p) ((p) -> type == PMAP_TYPE_GLOBAL)
259 #define isCausticPmap(p) ((p) -> type == PMAP_TYPE_CAUSTIC)
260 #define isContribPmap(p) ((p) -> type == PMAP_TYPE_CONTRIB)
261 #define isVolumePmap(p) ((p) -> type == PMAP_TYPE_VOLUME)
262
263
264
265 void initPhotonMap (PhotonMap *pmap, PhotonMapType t);
266 /* Initialise empty photon map of specified type */
267
268 int newPhoton (PhotonMap *pmap, const RAY *ray);
269 /* Create new photon with ray's direction, intersection point, and flux,
270 and append to unsorted photon heap pmap -> heap. The photon is
271 accepted with probability pmap -> distribRatio for global density
272 control; if the photon is rejected, -1 is returned, else 0. The flux
273 is scaled by ray -> rweight and 1 / pmap -> distribRatio. */
274
275 void initPhotonHeap (PhotonMap *pmap);
276 /* Open photon heap file */
277
278 void flushPhotonHeap (PhotonMap *pmap);
279 /* Flush photon heap buffa pmap -> heapBuf to heap file pmap -> heap;
280 * used by newPhoton() and to finalise heap in distribPhotons(). */
281
282 void buildPhotonMap (PhotonMap *pmap, double *photonFlux,
283 PhotonPrimaryIdx *primaryOfs, unsigned nproc);
284 /* Postpress unsorted photon heap pmap -> heap and build underlying data
285 * structure pmap -> store. This is prerequisite to photon lookups with
286 * findPhotons(). */
287
288 /* PhotonFlux is the flux per photon averaged over RGB; this is
289 * multiplied with each photon's flux during the postprocess. In the
290 * case of a contribution photon map, this is an array with a separate
291 * flux specific to each light source due to non-uniform photon emission;
292 * Otherwise it is referenced as a scalar value. Flux is not scaled if
293 * photonFlux == NULL. */
294
295 /* Photon map construction may be parallelised if nproc > 1, if
296 * supported. The heap is destroyed on return. */
297
298 /* PrimaryOfs is an array of index offsets for the primaries in pmap ->
299 * primaries generated by each of the nproc subprocesses during contrib
300 * photon distribution (see distribPhotonContrib()). These offsets are
301 * used to linearise the photon primary indices in the postprocess. This
302 * linearisation is skipped if primaryOfs == NULL. */
303
304 void findPhotons (PhotonMap* pmap, const RAY *ray);
305 /* Find pmap -> squeue.len closest photons to ray -> rop with similar
306 normal. For volume photons ray -> rorg is used and the normal is
307 ignored (being the incident direction in this case). Found photons
308 are placed search queue starting with the furthest photon at pmap ->
309 squeue.node, and pmap -> squeue.tail being the number actually found. */
310
311 void find1Photon (PhotonMap *pmap, const RAY *ray, Photon *photon);
312 /* Finds single closest photon to ray -> rop with similar normal.
313 Returns NULL if none found. */
314
315 void getPhoton (PhotonMap *pmap, PhotonIdx idx, Photon *photon);
316 /* Retrieve photon referenced by idx from pmap -> store */
317
318 Photon *getNearestPhoton (const PhotonSearchQueue *squeue, PhotonIdx idx);
319 /* Retrieve photon from NN search queue after calling findPhotons() */
320
321 PhotonIdx firstPhoton (const PhotonMap *pmap);
322 /* Index to first photon, to be passed to getPhoton(). Indices to
323 * subsequent photons can be optained via increment operator (++) */
324
325 void deletePhotons (PhotonMap*);
326 /* Free dem mammaries... */
327
328 #endif
