root/radiance/ray/src/rt/pmapdata.h
Revision: 2.11
Committed: Mon Aug 14 21:12:10 2017 UTC (7 years, 9 months ago) by rschregle
Changes since 2.10: +30 -17 lines
Updated photon map code for Windows; no multproc or ooC for now
# User Rev Content
1 rschregle 2.11 /* RCSid $Id: pmapdata.h,v 2.10 2016/05/17 17:39:47 rschregle Exp $ */
2 rschregle 2.10
3 greg 2.1 /*
4 rschregle 2.10 =========================================================================
5     Photon map types and interface to nearest neighbour lookups in underlying
6     point cloud data structure.
7
8     The default data structure is an in-core kd-tree (see pmapkdt.{h,c}).
9     This can be overriden with the PMAP_OOC compiletime switch, which enables
10     an out-of-core octree (see oococt.{h,c}).
11
12     Defining PMAP_FLOAT_FLUX stores photon flux as floats rather than packed
13     RGBE for greater precision; this may be necessary when the flux differs
14     significantly in individual colour channels, e.g. with highly saturated
15     colours.
16 greg 2.1
17     Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
18     (c) Fraunhofer Institute for Solar Energy Systems,
19 rschregle 2.2 (c) Lucerne University of Applied Sciences and Arts,
20 rschregle 2.10 supported by the Swiss National Science Foundation (SNSF, #147053)
21     =========================================================================
22 greg 2.1
23 rschregle 2.11 $Id: pmapdata.h,v 2.10 2016/05/17 17:39:47 rschregle Exp $
24 greg 2.1 */
25
26
27 rschregle 2.10
28 greg 2.1 #ifndef PMAPDATA_H
29     #define PMAPDATA_H
30
31 rschregle 2.11 #ifndef NIX
32     #if defined(_WIN32) || defined(_WIN64)
33     #define NIX 0
34     #else
35     #define NIX 1
36     #endif
37     #endif
38
39     #if (defined(PMAP_OOC) && !NIX)
40     #error "OOC currently only supported on NIX -- tuff luck."
41     #endif
42
43
44 greg 2.1 #include "ray.h"
45     #include "pmaptype.h"
46 rschregle 2.11 #include "paths.h"
47 greg 2.1 #include "lookup.h"
48 rschregle 2.10 #include <stdint.h>
49 greg 2.1
50
51 rschregle 2.10
52 greg 2.1 /* Primary photon ray for light source contributions */
53     typedef struct {
54 rschregle 2.10 int16 srcIdx; /* Index of emitting light source */
55     /* !!! REDUCED FROM 32 BITS !!! */
56     int32 dir; /* Encoded ray direction */
57     #ifdef PMAP_PRIMARYPOS
58     float pos [3]; /* Hit point */
59     #endif
60 greg 2.1 } PhotonPrimary;
61
62 rschregle 2.10 #define photonSrcIdx(pm, p) ((pm)->primaries[(p)->primary].srcIdx)
63
64
65
66     /* Photon primary ray index type and limit */
67     typedef uint32 PhotonPrimaryIdx;
68     #define PMAP_MAXPRIMARY UINT32_MAX
69
70     /* Macros for photon's generating subprocess field */
71 rschregle 2.11 #ifdef PMAP_OOC
72 rschregle 2.10 #define PMAP_PROCBITS 7
73     #else
74     #define PMAP_PROCBITS 5
75     #endif
76     #define PMAP_MAXPROC (1 << PMAP_PROCBITS)
77     #define PMAP_GETRAYPROC(r) ((r) -> crtype >> 8)
78     #define PMAP_SETRAYPROC(r,p) ((r) -> crtype |= p << 8)
79
80     /* Tolerance for photon normal check during lookups */
81     #define PMAP_NORM_TOL 0.02
82
83 greg 2.1
84
85     typedef struct {
86 rschregle 2.10 float pos [3]; /* Photon position */
87     signed char norm [3]; /* Surface normal at pos (incident
88     direction for volume photons) */
89     union {
90     struct {
91     #ifndef PMAP_OOC
92     unsigned char discr : 2; /* kd-tree discriminator axis */
93     #endif
94     unsigned char caustic : 1; /* Specularly scattered (=caustic) */
95
96     /* Photon's generating subprocess index, used for primary ray
97     * index linearisation when building contrib pmaps; note this is
98     * reduced for kd-tree to accommodate the discriminator field */
99     unsigned char proc : PMAP_PROCBITS;
100     };
101
102     unsigned char flags;
103     };
104
105     #ifdef PMAP_FLOAT_FLUX
106     COLOR flux;
107     #else
108     COLR flux;
109     #endif
110     PhotonPrimaryIdx primary; /* Index to primary ray */
111     } Photon;
112
113 greg 2.1
114
115 rschregle 2.10 /* Define PMAP_FLOAT_FLUX to store photon flux as floats instead of
116     * compact RGBE, which was found to improve accuracy in analytical
117     * validation. */
118     #ifdef PMAP_FLOAT_FLUX
119     #define setPhotonFlux(p,f) copycolor((p) -> flux, f)
120     #define getPhotonFlux(p,f) copycolor(f, (p) -> flux)
121     #else
122     #define setPhotonFlux(p,f) setcolr((p)->flux, (f)[0], (f)[1], (f)[2])
123     #define getPhotonFlux(p,f) colr_color(f, (p) -> flux)
124     #endif
125 greg 2.1
126
127     /* Bias compensation history node */
128     typedef struct {
129     COLOR irrad;
130     float weight;
131 rschregle 2.10 } PhotonBiasCompNode;
132
133 greg 2.1
134 rschregle 2.10 /* Forward declaration */
135     struct PhotonMap;
136
137
138     /* Define search queue and underlying data struct types */
139     #ifdef PMAP_OOC
140     #include "pmapooc.h"
141     #else
142     #include "pmapkdt.h"
143     #endif
144 greg 2.1
145
146 rschregle 2.11 /* Mean size of heapfile write buffer, in number of photons */
147     #define PMAP_HEAPBUFSIZE 1e6
148
149     /* Mean idle time between heap locking attempts, in usec */
150     #define PMAP_HEAPBUFSLEEP 2e6
151
152     /* Temporary filename for photon heaps */
153     #define PMAP_TMPFNAME TEMPLATE
154     #define PMAP_TMPFNLEN (TEMPLEN + 1)
155
156
157 greg 2.1 typedef struct PhotonMap {
158 rschregle 2.10 PhotonMapType type; /* See pmaptype.h */
159     char *fileName; /* Photon map file */
160
161
162     /* ================================================================
163     * PRE/POST-BUILD STORAGE
164     * ================================================================ */
165     FILE *heap; /* Unsorted photon heap prior to
166     construction of store */
167 rschregle 2.11 char heapFname [sizeof(PMAP_TMPFNAME)];
168 rschregle 2.10 Photon *heapBuf; /* Write buffer for above */
169     unsigned long heapBufLen, /* Current & max size of heapBuf */
170     heapBufSize;
171 rschregle 2.11 PhotonStorage store; /* Photon storage in space
172 rschregle 2.10 subdividing data struct */
173
174     /* ================================================================
175     * PHOTON DISTRIBUTION STUFF
176     * ================================================================ */
177     unsigned long distribTarget, /* Num stored specified by user */
178     numPhotons; /* Num actually stored */
179     float distribRatio; /* Probability of photon storage */
180     COLOR photonFlux; /* Average photon flux */
181     unsigned short randState [3]; /* Local RNG state */
182
183
184     /* ================================================================
185     * PHOTON LOOKUP STUFF
186     * ================================================================ */
187     union { /* Flags passed to findPhotons() */
188     char lookupCaustic : 1;
189     char lookupFlags;
190     };
191
192     PhotonSearchQueue squeue; /* Search queue for photon lookups */
193     unsigned minGather, /* Specified min/max photons per */
194     maxGather; /* density estimate */
195
196     /* NOTE: All distances are SQUARED */
197     float maxDist2, /* Max search radius */
198     maxDist0, /* Initial value for above */
199     maxDist2Limit, /* Hard limit for above */
200     gatherTolerance; /* Fractional deviation from minGather/
201     maxGather for short lookup */
202     void (*lookup)(struct PhotonMap*,
203     RAY*, COLOR); /* Callback for type-specific photon
204     * lookup (usually density estimate) */
205
206
207     /* ================================================================
208     * BIAS COMPENSATION STUFF
209     * ================================================================ */
210     PhotonBiasCompNode *biasCompHist; /* Bias compensation history */
211
212
213     /* ================================================================
214     * STATISTIX
215     * ================================================================ */
216     unsigned long totalGathered, /* Total photons gathered */
217     numDensity, /* Num density estimates */
218     numLookups, /* Counters for short photon lookups */
219     numShortLookups;
220
221     unsigned minGathered, /* Min/max photons actually gathered */
222     maxGathered, /* per density estimate */
223     shortLookupPct; /* % of short lookups for stats */
224
225     float minError, /* Min/max/rms density estimate error */
226     maxError,
227     rmsError,
228     CoGdist, /* Avg distance to centre of gravity */
229     maxPos [3], /* Max & min photon positions */
230     minPos [3];
231
232     FVECT CoG; /* Centre of gravity (avg photon pos) */
233
234
235     /* ================================================================
236     * PHOTON CONTRIB/COEFF STUFF
237     * ================================================================ */
238     PhotonPrimary *primaries, /* Photon primary array for rendering */
239     lastPrimary; /* Current primary for photon distrib */
240     PhotonPrimaryIdx numPrimary; /* Number of primary rays */
241     LUTAB *srcContrib; /* Lookup table for source contribs */
242 greg 2.1 } PhotonMap;
243
244
245
246     /* Photon maps by type (see PhotonMapType) */
247 rschregle 2.10 extern PhotonMap *photonMaps [];
248 greg 2.1
249     /* Macros for specific photon map types */
250 rschregle 2.10 #define globalPmap (photonMaps [PMAP_TYPE_GLOBAL])
251     #define preCompPmap (photonMaps [PMAP_TYPE_PRECOMP])
252     #define causticPmap (photonMaps [PMAP_TYPE_CAUSTIC])
253     #define volumePmap (photonMaps [PMAP_TYPE_VOLUME])
254     #define directPmap (photonMaps [PMAP_TYPE_DIRECT])
255     #define contribPmap (photonMaps [PMAP_TYPE_CONTRIB])
256
257     /* Photon map type tests */
258     #define isGlobalPmap(p) ((p) -> type == PMAP_TYPE_GLOBAL)
259     #define isCausticPmap(p) ((p) -> type == PMAP_TYPE_CAUSTIC)
260     #define isContribPmap(p) ((p) -> type == PMAP_TYPE_CONTRIB)
261     #define isVolumePmap(p) ((p) -> type == PMAP_TYPE_VOLUME)
262 greg 2.1
263
264
265     void initPhotonMap (PhotonMap *pmap, PhotonMapType t);
266     /* Initialise empty photon map of specified type */
267
268 rschregle 2.10 int newPhoton (PhotonMap *pmap, const RAY *ray);
269     /* Create new photon with ray's direction, intersection point, and flux,
270     and append to unsorted photon heap pmap -> heap. The photon is
271     accepted with probability pmap -> distribRatio for global density
272     control; if the photon is rejected, -1 is returned, else 0. The flux
273     is scaled by ray -> rweight and 1 / pmap -> distribRatio. */
274
275     void initPhotonHeap (PhotonMap *pmap);
276     /* Open photon heap file */
277
278     void flushPhotonHeap (PhotonMap *pmap);
279     /* Flush photon heap buffa pmap -> heapBuf to heap file pmap -> heap;
280     * used by newPhoton() and to finalise heap in distribPhotons(). */
281
282     void buildPhotonMap (PhotonMap *pmap, double *photonFlux,
283     PhotonPrimaryIdx *primaryOfs, unsigned nproc);
284     /* Postpress unsorted photon heap pmap -> heap and build underlying data
285     * structure pmap -> store. This is prerequisite to photon lookups with
286     * findPhotons(). */
287
288     /* PhotonFlux is the flux per photon averaged over RGB; this is
289     * multiplied with each photon's flux during the postprocess. In the
290     * case of a contribution photon map, this is an array with a separate
291     * flux specific to each light source due to non-uniform photon emission;
292     * Otherwise it is referenced as a scalar value. Flux is not scaled if
293     * photonFlux == NULL. */
294
295     /* Photon map construction may be parallelised if nproc > 1, if
296     * supported. The heap is destroyed on return. */
297
298     /* PrimaryOfs is an array of index offsets for the primaries in pmap ->
299     * primaries generated by each of the nproc subprocesses during contrib
300     * photon distribution (see distribPhotonContrib()). These offsets are
301     * used to linearise the photon primary indices in the postprocess. This
302     * linearisation is skipped if primaryOfs == NULL. */
303 greg 2.1
304     void findPhotons (PhotonMap* pmap, const RAY *ray);
305 rschregle 2.10 /* Find pmap -> squeue.len closest photons to ray -> rop with similar
306 greg 2.1 normal. For volume photons ray -> rorg is used and the normal is
307     ignored (being the incident direction in this case). Found photons
308 rschregle 2.10 are placed search queue starting with the furthest photon at pmap ->
309     squeue.node, and pmap -> squeue.tail being the number actually found. */
310 greg 2.1
311 rschregle 2.10 void find1Photon (PhotonMap *pmap, const RAY *ray, Photon *photon);
312 greg 2.1 /* Finds single closest photon to ray -> rop with similar normal.
313     Returns NULL if none found. */
314
315 rschregle 2.10 void getPhoton (PhotonMap *pmap, PhotonIdx idx, Photon *photon);
316     /* Retrieve photon referenced by idx from pmap -> store */
317
318     Photon *getNearestPhoton (const PhotonSearchQueue *squeue, PhotonIdx idx);
319     /* Retrieve photon from NN search queue after calling findPhotons() */
320
321     PhotonIdx firstPhoton (const PhotonMap *pmap);
322     /* Index to first photon, to be passed to getPhoton(). Indices to
323     * subsequent photons can be optained via increment operator (++) */
324
325 greg 2.1 void deletePhotons (PhotonMap*);
326     /* Free dem mammaries... */
327
328     #endif
