root/radiance/ray/src/rt/pmapdata.h
Revision: 2.15
Committed: Tue Sep 17 16:36:05 2024 UTC (7 months, 3 weeks ago) by greg
Changes since 2.14: +15 -13 lines
chore: Added extern "C" to headers to avoid C++ name mangling
1 /* RCSid $Id: pmapdata.h,v 2.14 2020/04/08 15:14:21 rschregle Exp $ */
2
3 /*
4 =========================================================================
5 Photon map types and interface to nearest neighbour lookups in underlying
6 point cloud data structure.
7
8 The default data structure is an in-core kd-tree (see pmapkdt.{h,c}).
9 This can be overriden with the PMAP_OOC compiletime switch, which enables
10 an out-of-core octree (see oococt.{h,c}).
11
12 Defining PMAP_FLOAT_FLUX stores photon flux as floats rather than packed
13 RGBE for greater precision; this may be necessary when the flux differs
14 significantly in individual colour channels, e.g. with highly saturated
15 colours.
16
17 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
18 (c) Fraunhofer Institute for Solar Energy Systems,
19 (c) Lucerne University of Applied Sciences and Arts,
20 supported by the Swiss National Science Foundation (SNSF, #147053)
21 =========================================================================
22
23 $Id: pmapdata.h,v 2.14 2020/04/08 15:14:21 rschregle Exp $
24 */
25
26
27
28 #ifndef PMAPDATA_H
29 #define PMAPDATA_H
30
31 #ifndef NIX
32 #if defined(_WIN32) || defined(_WIN64)
33 #define NIX 0
34 #else
35 #define NIX 1
36 #endif
37 #endif
38
39 #if (defined(PMAP_OOC) && !NIX)
40 #error "OOC currently only supported on NIX -- tuff luck."
41 #endif
42
43 #ifdef PMAP_CBDM
44 /* Enable photon primary hitpoints and incident directions (see struct
45 * PhotonPrimary below). Note this will increase the size of photon
46 * primaries 9-fold (10-fold after alignment)!!! */
47 #define PMAP_PRIMARYPOS
48 #define PMAP_PRIMARYDIR
49 #endif
50
51 #include "ray.h"
52 #include "pmaptype.h"
53 #include "paths.h"
54 #include "lookup.h"
55 #include <stdint.h>
56
57 /* Primary photon ray for light source contributions */
58 typedef struct {
59 int16 srcIdx; /* Index of emitting light source */
60 /* !!! REDUCED FROM 32 BITS !!! */
61 #ifdef PMAP_PRIMARYDIR
62 int32 dir; /* Encoded ray direction */
63 #endif
64 #ifdef PMAP_PRIMARYPOS
65 float pos [3]; /* Hit point */
66 #endif
67 } PhotonPrimary;
68
69 #define photonSrcIdx(pm, p) ((pm)->primaries[(p)->primary].srcIdx)
70
71
72
73 /* Photon primary ray index type and limit */
74 typedef uint32 PhotonPrimaryIdx;
75 #define PMAP_MAXPRIMARY UINT32_MAX
76
77 /* Macros for photon's generating subprocess field */
78 #ifdef PMAP_OOC
79 #define PMAP_PROCBITS 7
80 #else
81 #define PMAP_PROCBITS 5
82 #endif
83 #define PMAP_MAXPROC (1 << PMAP_PROCBITS)
84 #define PMAP_GETRAYPROC(r) ((r) -> crtype >> 8)
85 #define PMAP_SETRAYPROC(r,p) ((r) -> crtype |= p << 8)
86
87 /* Tolerance for photon normal check during lookups */
88 #define PMAP_NORM_TOL 0.02
89
90
91
92 typedef struct {
93 float pos [3]; /* Photon position */
94 signed char norm [3]; /* Surface normal at pos (incident
95 direction for volume photons) */
96 union {
97 struct {
98 #ifndef PMAP_OOC
99 unsigned char discr : 2; /* kd-tree discriminator axis */
100 #endif
101 unsigned char caustic : 1; /* Specularly scattered (=caustic) */
102
103 /* Photon's generating subprocess index, used for primary ray
104 * index linearisation when building contrib pmaps; note this is
105 * reduced for kd-tree to accommodate the discriminator field */
106 unsigned char proc : PMAP_PROCBITS;
107 };
108
109 unsigned char flags;
110 };
111
112 #ifdef PMAP_FLOAT_FLUX
113 COLOR flux;
114 #else
115 COLR flux;
116 #endif
117 PhotonPrimaryIdx primary; /* Index to primary ray */
118 } Photon;
119
120 /* Define search queue and underlying data struct types */
121 #ifdef PMAP_OOC
122 #include "pmapooc.h"
123 #else
124 #include "pmapkdt.h"
125 #endif
126
127
128 /* Define PMAP_FLOAT_FLUX to store photon flux as floats instead of
129 * compact RGBE, which was found to improve accuracy in analytical
130 * validation. */
131 #ifdef PMAP_FLOAT_FLUX
132 #define setPhotonFlux(p,f) copycolor((p) -> flux, f)
133 #define getPhotonFlux(p,f) copycolor(f, (p) -> flux)
134 #else
135 #define setPhotonFlux(p,f) setcolr((p)->flux, (f)[0], (f)[1], (f)[2])
136 #define getPhotonFlux(p,f) colr_color(f, (p) -> flux)
137 #endif
138
139
140 /* Bias compensation history node */
141 typedef struct {
142 COLOR irrad;
143 float weight;
144 } PhotonBiasCompNode;
145
146
147 /* Forward declaration */
148 struct PhotonMap;
149
150
151 /* Mean size of heapfile write buffer, in number of photons */
152 #define PMAP_HEAPBUFSIZE 1e6
153
154 /* Mean idle time between heap locking attempts, in usec */
155 #define PMAP_HEAPBUFSLEEP 2e6
156
157 /* Temporary filename for photon heaps */
158 #define PMAP_TMPFNAME TEMPLATE
159 #define PMAP_TMPFNLEN (TEMPLEN + 1)
160
161
162 typedef struct PhotonMap {
163 PhotonMapType type; /* See pmaptype.h */
164 char *fileName; /* Photon map file */
165
166
167 /* ================================================================
168 * PRE/POST-BUILD STORAGE
169 * ================================================================ */
170 FILE *heap; /* Unsorted photon heap prior to
171 construction of store */
172 char heapFname [sizeof(PMAP_TMPFNAME)];
173 Photon *heapBuf; /* Write buffer for above */
174 unsigned long heapBufLen, /* Current & max size of heapBuf */
175 heapBufSize;
176 PhotonStorage store; /* Photon storage in space
177 subdividing data struct */
178
179 /* ================================================================
180 * PHOTON DISTRIBUTION STUFF
181 * ================================================================ */
182 unsigned long distribTarget, /* Num stored specified by user */
183 numPhotons; /* Num actually stored */
184 float distribRatio; /* Probability of photon storage */
185 COLOR photonFlux; /* Average photon flux */
186 unsigned short randState [3]; /* Local RNG state */
187
188
189 /* ================================================================
190 * PHOTON LOOKUP STUFF
191 * ================================================================ */
192 union { /* Flags passed to findPhotons() */
193 char lookupCaustic : 1;
194 char lookupFlags;
195 };
196
197 PhotonSearchQueue squeue; /* Search queue for photon lookups */
198 unsigned minGather, /* Specified min/max photons per */
199 maxGather; /* density estimate */
200
201 /* NOTE: All distances are SQUARED */
202 float maxDist2, /* Max search radius */
203 maxDist0, /* Initial value for above */
204 maxDist2Limit, /* Hard limit for above */
205 gatherTolerance; /* Fractional deviation from minGather/
206 maxGather for short lookup */
207 void (*lookup)(struct PhotonMap*,
208 RAY*, COLOR); /* Callback for type-specific photon
209 * lookup (usually density estimate) */
210
211
212 /* ================================================================
213 * BIAS COMPENSATION STUFF
214 * ================================================================ */
215 PhotonBiasCompNode *biasCompHist; /* Bias compensation history */
216
217
218 /* ================================================================
219 * STATISTIX
220 * ================================================================ */
221 unsigned long totalGathered, /* Total photons gathered */
222 numDensity, /* Num density estimates */
223 numLookups, /* Counters for short photon lookups */
224 numShortLookups;
225
226 unsigned minGathered, /* Min/max photons actually gathered */
227 maxGathered, /* per density estimate */
228 shortLookupPct; /* % of short lookups for stats */
229
230 float minError, /* Min/max/rms density estimate error */
231 maxError,
232 rmsError,
233 CoGdist, /* Avg distance to centre of gravity */
234 maxPos [3], /* Max & min photon positions */
235 minPos [3];
236
237 FVECT CoG; /* Centre of gravity (avg photon pos) */
238
239
240 /* ================================================================
241 * PHOTON CONTRIB/COEFF STUFF
242 * ================================================================ */
243 PhotonPrimary *primaries, /* Photon primary array for rendering */
244 lastPrimary; /* Current primary for photon distrib */
245 PhotonPrimaryIdx numPrimary; /* Number of primary rays */
246 LUTAB *srcContrib; /* Lookup table for source contribs */
247 } PhotonMap;
248
249
250
251 /* Photon maps by type (see PhotonMapType) */
252 extern PhotonMap *photonMaps [];
253
254 /* Macros for specific photon map types */
255 #define globalPmap (photonMaps [PMAP_TYPE_GLOBAL])
256 #define preCompPmap (photonMaps [PMAP_TYPE_PRECOMP])
257 #define causticPmap (photonMaps [PMAP_TYPE_CAUSTIC])
258 #define volumePmap (photonMaps [PMAP_TYPE_VOLUME])
259 #define directPmap (photonMaps [PMAP_TYPE_DIRECT])
260 #define contribPmap (photonMaps [PMAP_TYPE_CONTRIB])
261
262 /* Photon map type tests */
263 #define isGlobalPmap(p) ((p) -> type == PMAP_TYPE_GLOBAL)
264 #define isCausticPmap(p) ((p) -> type == PMAP_TYPE_CAUSTIC)
265 #define isContribPmap(p) ((p) -> type == PMAP_TYPE_CONTRIB)
266 #define isVolumePmap(p) ((p) -> type == PMAP_TYPE_VOLUME)
267
268 #ifdef __cplusplus
269 extern "C" {
270 #endif
271
272 void initPhotonMap (PhotonMap *pmap, PhotonMapType t);
273 /* Initialise empty photon map of specified type */
274
275 int newPhoton (PhotonMap *pmap, const RAY *ray);
276 /* Create new photon with ray's direction, intersection point, and flux,
277 and append to unsorted photon heap pmap -> heap. The photon is
278 accepted with probability pmap -> distribRatio for global density
279 control; if the photon is rejected, -1 is returned, else 0. The flux
280 is scaled by ray -> rweight and 1 / pmap -> distribRatio. */
281
282 void initPhotonHeap (PhotonMap *pmap);
283 /* Open photon heap file */
284
285 void flushPhotonHeap (PhotonMap *pmap);
286 /* Flush photon heap buffa pmap -> heapBuf to heap file pmap -> heap;
287 * used by newPhoton() and to finalise heap in distribPhotons(). */
288
289 void buildPhotonMap (PhotonMap *pmap, double *photonFlux,
290 PhotonPrimaryIdx *primaryOfs, unsigned nproc);
291 /* Postpress unsorted photon heap pmap -> heap and build underlying data
292 * structure pmap -> store. This is prerequisite to photon lookups with
293 * findPhotons(). */
294
295 /* PhotonFlux is the flux per photon averaged over RGB; this is
296 * multiplied with each photon's flux during the postprocess. In the
297 * case of a contribution photon map, this is an array with a separate
298 * flux specific to each light source due to non-uniform photon emission;
299 * Otherwise it is referenced as a scalar value. Flux is not scaled if
300 * photonFlux == NULL. */
301
302 /* Photon map construction may be parallelised if nproc > 1, if
303 * supported. The heap is destroyed on return. */
304
305 /* PrimaryOfs is an array of index offsets for the primaries in pmap ->
306 * primaries generated by each of the nproc subprocesses during contrib
307 * photon distribution (see distribPhotonContrib()). These offsets are
308 * used to linearise the photon primary indices in the postprocess. This
309 * linearisation is skipped if primaryOfs == NULL. */
310
311 void findPhotons (PhotonMap* pmap, const RAY *ray);
312 /* Find pmap -> squeue.len closest photons to ray -> rop with similar
313 normal. For volume photons ray -> rorg is used and the normal is
314 ignored (being the incident direction in this case). Found photons
315 are placed search queue starting with the furthest photon at pmap ->
316 squeue.node, and pmap -> squeue.tail being the number actually found. */
317
318 Photon *find1Photon (PhotonMap *pmap, const RAY *ray, Photon *photon);
319 /* Find single closest photon to ray -> rop with similar normal.
320 Return NULL if none found, else the supplied Photon* buffer,
321 indicating that it contains a valid photon. */
322
323 void getPhoton (PhotonMap *pmap, PhotonIdx idx, Photon *photon);
324 /* Retrieve photon referenced by idx from pmap -> store */
325
326 Photon *getNearestPhoton (const PhotonSearchQueue *squeue, PhotonIdx idx);
327 /* Retrieve photon from NN search queue after calling findPhotons() */
328
329 PhotonIdx firstPhoton (const PhotonMap *pmap);
330 /* Index to first photon, to be passed to getPhoton(). Indices to
331 * subsequent photons can be optained via increment operator (++) */
332
333 void deletePhotons (PhotonMap*);
334 /* Free dem mammaries... */
335
336 #ifdef __cplusplus
337 }
338 #endif
339
340 #endif
