feat(mkpmap): Added -apI option for spherical ROI
Fixed est00pid bug in single photon lookups that returned junk when none found, added code to detect and handle (ignore).
Factored out ray weight when setting photon flux in newPhoton(), as it (erroneously) attenuates volume photons in participating media. Prehistoric artefact?
Minor comments fix
Added -ae/-ai ambient exclude options to mkpmap, cleaned up opt parsing.
Updated photon map code for Windows; no multproc or ooC for now
Conditional compile of fsync() call for Windows
Made fcntl() call compile conditionally for Windows
Minor pmapcontrib cleanup, revised photon normal test in pmapdata
Disabled warnings about itsy bitsy photon search radius
Fixed bug with handling of -am rendering option, removed redundant code
maxDistFix (fixed max photon search radius) now squared in findPhotons()
-am option to rpict/rvu/rtrace now sets fixed max photon search radius, -overriding the adaptive max search radius
Added stochastic photon coplanarity test in NearestNeighbours()/Nearest1Neighbour()
Added calls to findmaterial() and simplified photon map shadow check
Reduced primary photon struct size using encoded direction
Added appropriate setting of ray parameters for bin rcontrib evaluation
Conditionally disabled warning about clamped max photon lookup radius.
