--- ray/src/rt/pmapdata.c 2015/05/26 11:26:27 2.7 +++ ray/src/rt/pmapdata.c 2015/05/27 19:15:27 2.9 @@ -8,7 +8,7 @@ supported by the Swiss National Science Foundation (SNSF, #147053) ================================================================== - $Id: pmapdata.c,v 2.7 2015/05/26 11:26:27 rschregle Exp $ + $Id: pmapdata.c,v 2.9 2015/05/27 19:15:27 rschregle Exp $ */ @@ -312,6 +312,10 @@ static void nearestNeighbours (PhotonMap* pmap, const /* Threshold below which we assume increasing max radius won't help */ #define PMAP_SHORT_LOOKUP_THRESH 1 +/* Coefficient for adaptive maximum search radius */ +#define PMAP_MAXDIST_COEFF 100 + + void findPhotons (PhotonMap* pmap, const RAY* ray) { float pos [3], norm [3]; @@ -333,17 +337,12 @@ void findPhotons (PhotonMap* pmap, const RAY* ray) pmap -> minError = FHUGE; pmap -> maxError = -FHUGE; pmap -> rmsError = 0; -#ifdef PMAP_MAXDIST_ABS - /* Treat maxDistCoeff as an *absolute* and *fixed* max search radius. - Primarily intended for debugging; FOR ZE ECKSPURTZ ONLY! */ - pmap -> maxDist0 = pmap -> maxDistLimit = maxDistCoeff; -#else - /* Maximum search radius limit based on avg photon distance to - * centre of gravity */ + /* SQUARED max search radius limit is based on avg photon distance to + * centre of gravity, unless fixed by user (maxDistFix > 0) */ pmap -> maxDist0 = pmap -> maxDistLimit = - maxDistCoeff * pmap -> squeueSize * pmap -> CoGdist / - pmap -> heapSize; -#endif + maxDistFix > 0 ? maxDistFix * maxDistFix + : PMAP_MAXDIST_COEFF * pmap -> squeueSize * + pmap -> CoGdist / pmap -> heapSize; } do { @@ -363,7 +362,6 @@ void findPhotons (PhotonMap* pmap, const RAY* ray) nearestNeighbours(pmap, pos, norm, 1); } -#ifndef PMAP_MAXDIST_ABS if (pmap -> squeueEnd < pmap -> squeueSize * pmap -> gatherTolerance) { /* Short lookup; too few photons found */ if (pmap -> squeueEnd > PMAP_SHORT_LOOKUP_THRESH) { @@ -371,43 +369,50 @@ void findPhotons (PhotonMap* pmap, const RAY* ray) * PMAP_SHORT_LOOKUP_THRESH photons under the assumption there * really are no photons in the vicinity, and increasing the max * search radius therefore won't help */ - #ifdef PMAP_LOOKUP_WARN +#ifdef PMAP_LOOKUP_WARN sprintf(errmsg, "%d/%d %s photons found at (%.2f,%.2f,%.2f) on %s", pmap -> squeueEnd, pmap -> squeueSize, pmapName [pmap -> type], pos [0], pos [1], pos [2], ray -> ro ? ray -> ro -> oname : ""); error(WARNING, errmsg); - #endif +#endif + /* Bail out after warning if maxDist is fixed */ + if (maxDistFix > 0) + return; + if (pmap -> maxDist0 < pmap -> maxDistLimit) { /* Increase max search radius if below limit & redo search */ pmap -> maxDist0 *= PMAP_MAXDIST_INC; - #ifdef PMAP_LOOKUP_REDO +#ifdef PMAP_LOOKUP_REDO redo = 1; - #endif - - #ifdef PMAP_LOOKUP_WARN +#endif +#ifdef PMAP_LOOKUP_WARN sprintf(errmsg, redo ? "restarting photon lookup with max radius %.1e" : "max photon lookup radius adjusted to %.1e", pmap -> maxDist0); error(WARNING, errmsg); - #endif +#endif } - #ifdef PMAP_LOOKUP_REDO +#ifdef PMAP_LOOKUP_REDO else { sprintf(errmsg, "max photon lookup radius clamped to %.1e", pmap -> maxDist0); error(WARNING, errmsg); } - #endif +#endif } /* Reset successful lookup counter */ pmap -> numLookups = 0; } else { + /* Bail out after warning if maxDist is fixed */ + if (maxDistFix > 0) + return; + /* Increment successful lookup counter and reduce max search radius if * wraparound */ pmap -> numLookups = (pmap -> numLookups + 1) % PMAP_MAXDIST_CNT; @@ -416,7 +421,7 @@ void findPhotons (PhotonMap* pmap, const RAY* ray) redo = 0; } -#endif + } while (redo); }
