--- ray/src/rt/pmapdata.c 2015/05/26 11:26:27 2.7 +++ ray/src/rt/pmapdata.c 2017/08/14 21:12:10 2.18 @@ -1,19 +1,28 @@ +#ifndef lint +static const char RCSid[] = "$Id: pmapdata.c,v 2.18 2017/08/14 21:12:10 rschregle Exp $"; +#endif + /* - ================================================================== - Photon map data structures and kd-tree handling + ========================================================================= + Photon map types and interface to nearest neighbour lookups in underlying + point cloud data structure. + + The default data structure is an in-core kd-tree (see pmapkdt.{h,c}). + This can be overriden with the PMAP_OOC compiletime switch, which enables + an out-of-core octree (see oococt.{h,c}). Roland Schregle (roland.schregle@{hslu.ch, gmail.com}) (c) Fraunhofer Institute for Solar Energy Systems, (c) Lucerne University of Applied Sciences and Arts, - supported by the Swiss National Science Foundation (SNSF, #147053) - ================================================================== + supported by the Swiss National Science Foundation (SNSF, #147053) + ========================================================================== - $Id: pmapdata.c,v 2.7 2015/05/26 11:26:27 rschregle Exp $ + $Id: pmapdata.c,v 2.18 2017/08/14 21:12:10 rschregle Exp $ */ -#include "pmap.h" +#include "pmapdata.h" #include "pmaprand.h" #include "pmapmat.h" #include "otypes.h" @@ -29,15 +38,22 @@ PhotonMap *photonMaps [NUM_PMAP_TYPES] = { +/* Include routines to handle underlying point cloud data structure */ +#ifdef PMAP_OOC + #include "pmapooc.c" +#else + #include "pmapkdt.c" +#endif + + + void initPhotonMap (PhotonMap *pmap, PhotonMapType t) /* Init photon map 'n' stuff... */ { if (!pmap) return; - pmap -> heapSize = pmap -> heapEnd = 0; - pmap -> heap = NULL; - pmap -> squeue = NULL; + pmap -> numPhotons = 0; pmap -> biasCompHist = NULL; pmap -> maxPos [0] = pmap -> maxPos [1] = pmap -> maxPos [2] = -FHUGE; pmap -> minPos [0] = pmap -> minPos [1] = pmap -> minPos [2] = FHUGE; @@ -47,257 +63,383 @@ void initPhotonMap (PhotonMap *pmap, PhotonMapType t) pmap -> numDensity = 0; pmap -> distribRatio = 1; pmap -> type = t; + pmap -> squeue.node = NULL; + pmap -> squeue.len = 0; /* Init local RNG state */ pmap -> randState [0] = 10243; pmap -> randState [1] = 39829; pmap -> randState [2] = 9433; - /* pmapSeed(25999, pmap -> randState); */ pmapSeed(randSeed, pmap -> randState); /* Set up type-specific photon lookup callback */ pmap -> lookup = pmapLookup [t]; - pmap -> primary = NULL; - pmap -> primarySize = pmap -> primaryEnd = 0; + /* Mark primary photon ray as unused */ + pmap -> lastPrimary.srcIdx = -1; + pmap -> numPrimary = 0; + pmap -> primaries = NULL; + + /* Init storage */ + pmap -> heap = NULL; + pmap -> heapBuf = NULL; + pmap -> heapBufLen = 0; +#ifdef PMAP_OOC + OOC_Null(&pmap -> store); +#else + kdT_Null(&pmap -> store); +#endif } -const PhotonPrimary* addPhotonPrimary (PhotonMap *pmap, const RAY *ray) +void initPhotonHeap (PhotonMap *pmap) { - PhotonPrimary *prim = NULL; - FVECT dvec; + int fdFlags; - if (!pmap || !ray) - return NULL; + if (!pmap) + error(INTERNAL, "undefined photon map in initPhotonHeap"); - /* Check if last primary ray has spawned photons (srcIdx >= 0, see - * addPhoton()), in which case we keep it and allocate a new one; - * otherwise we overwrite the unused entry */ - if (pmap -> primary && pmap -> primary [pmap -> primaryEnd].srcIdx >= 0) - pmap -> primaryEnd++; - - if (!pmap -> primarySize || pmap -> primaryEnd >= pmap -> primarySize) { - /* Allocate/enlarge array */ - pmap -> primarySize += pmap -> heapSizeInc; - - /* Counter wraparound? */ - if (pmap -> primarySize < pmap -> heapSizeInc) - error(INTERNAL, "photon primary overflow"); - - pmap -> primary = (PhotonPrimary *)realloc(pmap -> primary, - sizeof(PhotonPrimary) * - pmap -> primarySize); - if (!pmap -> primary) - error(USER, "can't allocate photon primaries"); + if (!pmap -> heap) { + /* Open heap file */ + mktemp(strcpy(pmap -> heapFname, PMAP_TMPFNAME)); + if (!(pmap -> heap = fopen(pmap -> heapFname, "w+b"))) + error(SYSTEM, "failed opening heap file in initPhotonHeap"); + +#ifdef F_SETFL /* XXX is there an alternate needed for Windows? */ + fdFlags = fcntl(fileno(pmap -> heap), F_GETFL); + fcntl(fileno(pmap -> heap), F_SETFL, fdFlags | O_APPEND); +#endif/* ftruncate(fileno(pmap -> heap), 0); */ } +} + + + +void flushPhotonHeap (PhotonMap *pmap) +{ + int fd; + const unsigned long len = pmap -> heapBufLen * sizeof(Photon); - prim = pmap -> primary + pmap -> primaryEnd; + if (!pmap) + error(INTERNAL, "undefined photon map in flushPhotonHeap"); + + if (!pmap -> heap || !pmap -> heapBuf) { + /* Silently ignore undefined heap + error(INTERNAL, "undefined heap in flushPhotonHeap"); */ + return; + } + + /* Atomically seek and write block to heap */ + /* !!! Unbuffered I/O via pwrite() avoids potential race conditions + * !!! and buffer corruption which can occur with lseek()/fseek() + * !!! followed by write()/fwrite(). */ + fd = fileno(pmap -> heap); - /* Mark unused with negative source index until path spawns a photon (see - * addPhoton()) */ - prim -> srcIdx = -1; - - /* Reverse incident direction to point to light source */ - dvec [0] = -ray -> rdir [0]; - dvec [1] = -ray -> rdir [1]; - dvec [2] = -ray -> rdir [2]; - prim -> dir = encodedir(dvec); +#ifdef DEBUG_PMAP + sprintf(errmsg, "Proc %d: flushing %ld photons from pos %ld\n", getpid(), + pmap -> heapBufLen, lseek(fd, 0, SEEK_END) / sizeof(Photon)); + eputs(errmsg); +#endif - VCOPY(prim -> pos, ray -> rop); + /*if (pwrite(fd, pmap -> heapBuf, len, lseek(fd, 0, SEEK_END)) != len) */ + if (write(fd, pmap -> heapBuf, len) != len) + error(SYSTEM, "failed append to heap file in flushPhotonHeap"); + +#if NIX + if (fsync(fd)) + error(SYSTEM, "failed fsync in flushPhotonHeap"); +#endif + + pmap -> heapBufLen = 0; +} + + + +#ifdef DEBUG_PMAP +static int checkPhotonHeap (FILE *file) +/* Check heap for nonsensical or duplicate photons */ +{ + Photon p, lastp; + int i, dup; - return prim; + rewind(file); + memset(&lastp, 0, sizeof(lastp)); + + while (fread(&p, sizeof(p), 1, file)) { + dup = 1; + + for (i = 0; i <= 2; i++) { + if (p.pos [i] < thescene.cuorg [i] || + p.pos [i] > thescene.cuorg [i] + thescene.cusize) { + + sprintf(errmsg, "corrupt photon in heap at [%f, %f, %f]\n", + p.pos [0], p.pos [1], p.pos [2]); + error(WARNING, errmsg); + } + + dup &= p.pos [i] == lastp.pos [i]; + } + + if (dup) { + sprintf(errmsg, + "consecutive duplicate photon in heap at [%f, %f, %f]\n", + p.pos [0], p.pos [1], p.pos [2]); + error(WARNING, errmsg); + } + } + + return 0; } +#endif -const Photon* addPhoton (PhotonMap* pmap, const RAY* ray) +int newPhoton (PhotonMap* pmap, const RAY* ray) { - unsigned i; - Photon* photon = NULL; + unsigned i, inROI = 0; + Photon photon; COLOR photonFlux; /* Account for distribution ratio */ if (!pmap || pmapRandom(pmap -> randState) > pmap -> distribRatio) - return NULL; + return -1; /* Don't store on sources */ if (ray -> robj > -1 && islight(objptr(ray -> ro -> omod) -> otype)) - return NULL; + return -1; -#if 0 - if (inContribPmap(pmap)) { - /* Adding contribution photon */ - if (ray -> parent && ray -> parent -> rtype & PRIMARY) - /* Add primary photon ray if parent is primary; by putting this - * here and checking the ray's immediate parent, we only add - * primaries that actually contribute photons, and we only add them - * once. */ - addPhotonPrimary(pmap, ray -> parent); - - /* Save index to primary ray (remains unchanged if primary already in - * array) */ - primary = pmap -> primaryEnd; + /* Store photon if within a region of interest (for ze Ecksperts!) */ + if (!pmapNumROI || !pmapROI) + inROI = 1; + else { + for (i = 0; !inROI && i < pmapNumROI; i++) + inROI = (ray -> rop [0] >= pmapROI [i].min [0] && + ray -> rop [0] <= pmapROI [i].max [0] && + ray -> rop [1] >= pmapROI [i].min [1] && + ray -> rop [1] <= pmapROI [i].max [1] && + ray -> rop [2] >= pmapROI [i].min [2] && + ray -> rop [2] <= pmapROI [i].max [2]); } -#endif - -#ifdef PMAP_ROI - /* Store photon if within region of interest -- for egg-spurtz only! */ - if (ray -> rop [0] >= pmapROI [0] && ray -> rop [0] <= pmapROI [1] && - ray -> rop [1] >= pmapROI [2] && ray -> rop [1] <= pmapROI [3] && - ray -> rop [2] >= pmapROI [4] && ray -> rop [2] <= pmapROI [5]) -#endif - { - if (pmap -> heapEnd >= pmap -> heapSize) { - /* Enlarge heap */ - pmap -> heapSize += pmap -> heapSizeInc; - - /* Counter wraparound? */ - if (pmap -> heapSize < pmap -> heapSizeInc) - error(INTERNAL, "photon heap overflow"); - - pmap -> heap = (Photon *)realloc(pmap -> heap, - sizeof(Photon) * pmap -> heapSize); - if (!pmap -> heap) - error(USER, "can't allocate photon heap"); - } - - photon = pmap -> heap + pmap -> heapEnd++; - + + if (inROI) { /* Adjust flux according to distribution ratio and ray weight */ copycolor(photonFlux, ray -> rcol); scalecolor(photonFlux, ray -> rweight / (pmap -> distribRatio ? pmap -> distribRatio : 1)); - setPhotonFlux(photon, photonFlux); + setPhotonFlux(&photon, photonFlux); /* Set photon position and flags */ - VCOPY(photon -> pos, ray -> rop); - photon -> flags = PMAP_CAUSTICRAY(ray) ? PMAP_CAUST_BIT : 0; + VCOPY(photon.pos, ray -> rop); + photon.flags = 0; + photon.caustic = PMAP_CAUSTICRAY(ray); - /* Set primary ray index and mark as used for contrib photons */ + /* Set contrib photon's primary ray and subprocess index (the latter + * to linearise the primary ray indices after photon distribution is + * complete). Also set primary ray's source index, thereby marking it + * as used. */ if (isContribPmap(pmap)) { - photon -> primary = pmap -> primaryEnd; - pmap -> primary [pmap -> primaryEnd].srcIdx = ray -> rsrc; + photon.primary = pmap -> numPrimary; + photon.proc = PMAP_GETRAYPROC(ray); + pmap -> lastPrimary.srcIdx = ray -> rsrc; } - else photon -> primary = 0; + else photon.primary = 0; - /* Update min and max positions & set normal */ - for (i = 0; i <= 2; i++) { - if (photon -> pos [i] < pmap -> minPos [i]) - pmap -> minPos [i] = photon -> pos [i]; - if (photon -> pos [i] > pmap -> maxPos [i]) - pmap -> maxPos [i] = photon -> pos [i]; - photon -> norm [i] = 127.0 * (isVolumePmap(pmap) ? ray -> rdir [i] - : ray -> ron [i]); + /* Set normal */ + for (i = 0; i <= 2; i++) + photon.norm [i] = 127.0 * (isVolumePmap(pmap) ? ray -> rdir [i] + : ray -> ron [i]); + + if (!pmap -> heapBuf) { + /* Lazily allocate heap buffa */ +#if NIX + /* Randomise buffa size to temporally decorellate flushes in + * multiprocessing mode */ + srandom(randSeed + getpid()); + pmap -> heapBufSize = PMAP_HEAPBUFSIZE * (0.5 + frandom()); +#else + /* Randomisation disabled for single processes on WIN; also useful + * for reproducability during debugging */ + pmap -> heapBufSize = PMAP_HEAPBUFSIZE; +#endif + if (!(pmap -> heapBuf = calloc(pmap -> heapBufSize, sizeof(Photon)))) + error(SYSTEM, "failed heap buffer allocation in newPhoton"); + pmap -> heapBufLen = 0; } + + /* Photon initialised; now append to heap buffa */ + memcpy(pmap -> heapBuf + pmap -> heapBufLen, &photon, sizeof(Photon)); + + if (++pmap -> heapBufLen >= pmap -> heapBufSize) + /* Heap buffa full, flush to heap file */ + flushPhotonHeap(pmap); + + pmap -> numPhotons++; } - return photon; + return 0; } -static void nearestNeighbours (PhotonMap* pmap, const float pos [3], - const float norm [3], unsigned long node) -/* Recursive part of findPhotons(..). - Note that all heap and priority queue index handling is 1-based, but - accesses to the arrays are 0-based! */ +void buildPhotonMap (PhotonMap *pmap, double *photonFlux, + PhotonPrimaryIdx *primaryOfs, unsigned nproc) { - Photon* p = &pmap -> heap [node - 1]; - unsigned i, j; - /* Signed distance to current photon's splitting plane */ - float d = pos [photonDiscr(*p)] - p -> pos [photonDiscr(*p)], - d2 = d * d; - PhotonSQNode* sq = pmap -> squeue; - const unsigned sqSize = pmap -> squeueSize; - float dv [3]; + unsigned long n, nCheck = 0; + unsigned i; + Photon *p; + COLOR flux; + char nuHeapFname [sizeof(PMAP_TMPFNAME)]; + FILE *nuHeap; + /* Need double here to reduce summation errors */ + double avgFlux [3] = {0, 0, 0}, CoG [3] = {0, 0, 0}, CoGdist = 0; + FVECT d; - /* Search subtree closer to pos first; exclude other subtree if the - distance to the splitting plane is greater than maxDist */ - if (d < 0) { - if (node << 1 <= pmap -> heapSize) - nearestNeighbours(pmap, pos, norm, node << 1); - if (d2 < pmap -> maxDist && node << 1 < pmap -> heapSize) - nearestNeighbours(pmap, pos, norm, (node << 1) + 1); - } - else { - if (node << 1 < pmap -> heapSize) - nearestNeighbours(pmap, pos, norm, (node << 1) + 1); - if (d2 < pmap -> maxDist && node << 1 <= pmap -> heapSize) - nearestNeighbours(pmap, pos, norm, node << 1); - } - - /* Reject photon if normal faces away (ignored for volume photons) */ - if (norm && DOT(norm, p -> norm) <= 0.5 * frandom()) - return; + if (!pmap) + error(INTERNAL, "undefined photon map in buildPhotonMap"); - if (isContribPmap(pmap) && pmap -> srcContrib) { - /* Lookup in contribution photon map */ - OBJREC *srcMod; - const int srcIdx = photonSrcIdx(pmap, p); - - if (srcIdx < 0 || srcIdx >= nsources) - error(INTERNAL, "invalid light source index in photon map"); - - srcMod = findmaterial(source [srcIdx].so); + /* Get number of photons from heapfile size */ + if (fseek(pmap -> heap, 0, SEEK_END) < 0) + error(SYSTEM, "failed seek to end of photon heap in buildPhotonMap"); + pmap -> numPhotons = ftell(pmap -> heap) / sizeof(Photon); + + if (!pmap -> numPhotons) + error(INTERNAL, "empty photon map in buildPhotonMap"); - /* Reject photon if contributions from light source which emitted it - * are not sought */ - if (!lu_find(pmap -> srcContrib, srcMod -> oname) -> data) - return; + if (!pmap -> heap) + error(INTERNAL, "no heap in buildPhotonMap"); - /* Reject non-caustic photon if lookup for caustic contribs */ - if (pmap -> lookupFlags & PMAP_CAUST_BIT & ~p -> flags) - return; +#ifdef DEBUG_PMAP + eputs("Checking photon heap consistency...\n"); + checkPhotonHeap(pmap -> heap); + + sprintf(errmsg, "Heap contains %ld photons\n", pmap -> numPhotons); + eputs(errmsg); +#endif + + /* Allocate heap buffa */ + if (!pmap -> heapBuf) { + pmap -> heapBufSize = PMAP_HEAPBUFSIZE; + pmap -> heapBuf = calloc(pmap -> heapBufSize, sizeof(Photon)); + if (!pmap -> heapBuf) + error(SYSTEM, "failed to allocate postprocessed photon heap in" + "buildPhotonMap"); } + + /* We REALLY don't need yet another @%&*! heap just to hold the scaled + * photons, but can't think of a quicker fix... */ + mktemp(strcpy(nuHeapFname, PMAP_TMPFNAME)); + if (!(nuHeap = fopen(nuHeapFname, "w+b"))) + error(SYSTEM, "failed to open postprocessed photon heap in " + "buildPhotonMap"); + + rewind(pmap -> heap); + +#ifdef DEBUG_PMAP + eputs("Postprocessing photons...\n"); +#endif - /* Squared distance to current photon */ - dv [0] = pos [0] - p -> pos [0]; - dv [1] = pos [1] - p -> pos [1]; - dv [2] = pos [2] - p -> pos [2]; - d2 = DOT(dv, dv); + while (!feof(pmap -> heap)) { +#ifdef DEBUG_PMAP + printf("Reading %lu at %lu... ", pmap -> heapBufSize, ftell(pmap->heap)); +#endif + pmap -> heapBufLen = fread(pmap -> heapBuf, sizeof(Photon), + pmap -> heapBufSize, pmap -> heap); +#ifdef DEBUG_PMAP + printf("Got %lu\n", pmap -> heapBufLen); +#endif - /* Accept photon if closer than current max dist & add to priority queue */ - if (d2 < pmap -> maxDist) { - if (pmap -> squeueEnd < sqSize) { - /* Priority queue not full; append photon and restore heap */ - i = ++pmap -> squeueEnd; + if (ferror(pmap -> heap)) + error(SYSTEM, "failed to read photon heap in buildPhotonMap"); + + for (n = pmap -> heapBufLen, p = pmap -> heapBuf; n; n--, p++) { + /* Update min and max pos and set photon flux */ + for (i = 0; i <= 2; i++) { + if (p -> pos [i] < pmap -> minPos [i]) + pmap -> minPos [i] = p -> pos [i]; + else if (p -> pos [i] > pmap -> maxPos [i]) + pmap -> maxPos [i] = p -> pos [i]; + + /* Update centre of gravity with photon position */ + CoG [i] += p -> pos [i]; + } - while (i > 1 && sq [(i >> 1) - 1].dist <= d2) { - sq [i - 1].photon = sq [(i >> 1) - 1].photon; - sq [i - 1].dist = sq [(i >> 1) - 1].dist; - i >>= 1; - } + if (primaryOfs) + /* Linearise photon primary index from subprocess index using the + * per-subprocess offsets in primaryOfs */ + p -> primary += primaryOfs [p -> proc]; - sq [--i].photon = p; - sq [i].dist = d2; - /* Update maxDist if we've just filled the queue */ - if (pmap -> squeueEnd >= pmap -> squeueSize) - pmap -> maxDist = sq [0].dist; - } - else { - /* Priority queue full; replace maximum, restore heap, and - update maxDist */ - i = 1; - - while (i <= sqSize >> 1) { - j = i << 1; - if (j < sqSize && sq [j - 1].dist < sq [j].dist) - j++; - if (d2 >= sq [j - 1].dist) - break; - sq [i - 1].photon = sq [j - 1].photon; - sq [i - 1].dist = sq [j - 1].dist; - i = j; + /* Scale photon's flux (hitherto normalised to 1 over RGB); in + * case of a contrib photon map, this is done per light source, + * and photonFlux is assumed to be an array */ + getPhotonFlux(p, flux); + + if (photonFlux) { + scalecolor(flux, photonFlux [isContribPmap(pmap) ? + photonSrcIdx(pmap, p) : 0]); + setPhotonFlux(p, flux); } - - sq [--i].photon = p; - sq [i].dist = d2; - pmap -> maxDist = sq [0].dist; + + /* Update average photon flux; need a double here */ + addcolor(avgFlux, flux); } + + /* Write modified photons to new heap */ + fwrite(pmap -> heapBuf, sizeof(Photon), pmap -> heapBufLen, nuHeap); + + if (ferror(nuHeap)) + error(SYSTEM, "failed postprocessing photon flux in " + "buildPhotonMap"); + + nCheck += pmap -> heapBufLen; } + +#ifdef DEBUG_PMAP + if (nCheck < pmap -> numPhotons) + error(INTERNAL, "truncated photon heap in buildPhotonMap"); +#endif + + /* Finalise average photon flux */ + scalecolor(avgFlux, 1.0 / pmap -> numPhotons); + copycolor(pmap -> photonFlux, avgFlux); + + /* Average photon positions to get centre of gravity */ + for (i = 0; i < 3; i++) + pmap -> CoG [i] = CoG [i] /= pmap -> numPhotons; + + rewind(pmap -> heap); + + /* Compute average photon distance to centre of gravity */ + while (!feof(pmap -> heap)) { + pmap -> heapBufLen = fread(pmap -> heapBuf, sizeof(Photon), + pmap -> heapBufSize, pmap -> heap); + + for (n = pmap -> heapBufLen, p = pmap -> heapBuf; n; n--, p++) { + VSUB(d, p -> pos, CoG); + CoGdist += DOT(d, d); + } + } + + pmap -> CoGdist = CoGdist /= pmap -> numPhotons; + + /* Swap heaps, discarding unscaled photons */ + fclose(pmap -> heap); + unlink(pmap -> heapFname); + pmap -> heap = nuHeap; + strcpy(pmap -> heapFname, nuHeapFname); + +#ifdef PMAP_OOC + OOC_BuildPhotonMap(pmap, nproc); +#else + kdT_BuildPhotonMap(pmap); +#endif + + /* Trash heap and its buffa */ + free(pmap -> heapBuf); + fclose(pmap -> heap); + unlink(pmap -> heapFname); + pmap -> heap = NULL; + pmap -> heapBuf = NULL; } @@ -312,19 +454,20 @@ static void nearestNeighbours (PhotonMap* pmap, const /* Threshold below which we assume increasing max radius won't help */ #define PMAP_SHORT_LOOKUP_THRESH 1 +/* Coefficient for adaptive maximum search radius */ +#define PMAP_MAXDIST_COEFF 100 + void findPhotons (PhotonMap* pmap, const RAY* ray) { - float pos [3], norm [3]; int redo = 0; - if (!pmap -> squeue) { + if (!pmap -> squeue.len) { /* Lazy init priority queue */ - pmap -> squeueSize = pmap -> maxGather + 1; - pmap -> squeue = (PhotonSQNode*)malloc(pmap -> squeueSize * - sizeof(PhotonSQNode)); - if (!pmap -> squeue) - error(USER, "can't allocate photon priority queue"); - +#ifdef PMAP_OOC + OOC_InitFindPhotons(pmap); +#else + kdT_InitFindPhotons(pmap); +#endif pmap -> minGathered = pmap -> maxGather; pmap -> maxGathered = pmap -> minGather; pmap -> totalGathered = 0; @@ -333,81 +476,96 @@ void findPhotons (PhotonMap* pmap, const RAY* ray) pmap -> minError = FHUGE; pmap -> maxError = -FHUGE; pmap -> rmsError = 0; -#ifdef PMAP_MAXDIST_ABS - /* Treat maxDistCoeff as an *absolute* and *fixed* max search radius. - Primarily intended for debugging; FOR ZE ECKSPURTZ ONLY! */ - pmap -> maxDist0 = pmap -> maxDistLimit = maxDistCoeff; -#else - /* Maximum search radius limit based on avg photon distance to - * centre of gravity */ - pmap -> maxDist0 = pmap -> maxDistLimit = - maxDistCoeff * pmap -> squeueSize * pmap -> CoGdist / - pmap -> heapSize; -#endif + /* SQUARED max search radius limit is based on avg photon distance to + * centre of gravity, unless fixed by user (maxDistFix > 0) */ + pmap -> maxDist0 = pmap -> maxDist2Limit = + maxDistFix > 0 ? maxDistFix * maxDistFix + : PMAP_MAXDIST_COEFF * pmap -> squeue.len * + pmap -> CoGdist / pmap -> numPhotons; } do { - pmap -> squeueEnd = 0; - pmap -> maxDist = pmap -> maxDist0; + pmap -> squeue.tail = 0; + pmap -> maxDist2 = pmap -> maxDist0; /* Search position is ray -> rorg for volume photons, since we have no intersection point. Normals are ignored -- these are incident directions). */ if (isVolumePmap(pmap)) { - VCOPY(pos, ray -> rorg); - nearestNeighbours(pmap, pos, NULL, 1); +#ifdef PMAP_OOC + OOC_FindPhotons(pmap, ray -> rorg, NULL); +#else + kdT_FindPhotons(pmap, ray -> rorg, NULL); +#endif } else { - VCOPY(pos, ray -> rop); - VCOPY(norm, ray -> ron); - nearestNeighbours(pmap, pos, norm, 1); +#ifdef PMAP_OOC + OOC_FindPhotons(pmap, ray -> rop, ray -> ron); +#else + kdT_FindPhotons(pmap, ray -> rop, ray -> ron); +#endif } -#ifndef PMAP_MAXDIST_ABS - if (pmap -> squeueEnd < pmap -> squeueSize * pmap -> gatherTolerance) { +#ifdef PMAP_LOOKUP_INFO + fprintf(stderr, "%d/%d %s photons found within radius %.3f " + "at (%.2f,%.2f,%.2f) on %s\n", pmap -> squeue.tail, + pmap -> squeue.len, pmapName [pmap -> type], sqrt(pmap -> maxDist2), + ray -> rop [0], ray -> rop [1], ray -> rop [2], + ray -> ro ? ray -> ro -> oname : ""); +#endif + + if (pmap -> squeue.tail < pmap -> squeue.len * pmap -> gatherTolerance) { /* Short lookup; too few photons found */ - if (pmap -> squeueEnd > PMAP_SHORT_LOOKUP_THRESH) { + if (pmap -> squeue.tail > PMAP_SHORT_LOOKUP_THRESH) { /* Ignore short lookups which return fewer than * PMAP_SHORT_LOOKUP_THRESH photons under the assumption there * really are no photons in the vicinity, and increasing the max * search radius therefore won't help */ - #ifdef PMAP_LOOKUP_WARN +#ifdef PMAP_LOOKUP_WARN sprintf(errmsg, "%d/%d %s photons found at (%.2f,%.2f,%.2f) on %s", - pmap -> squeueEnd, pmap -> squeueSize, - pmapName [pmap -> type], pos [0], pos [1], pos [2], + pmap -> squeue.tail, pmap -> squeue.len, + pmapName [pmap -> type], + ray -> rop [0], ray -> rop [1], ray -> rop [2], ray -> ro ? ray -> ro -> oname : ""); error(WARNING, errmsg); - #endif +#endif - if (pmap -> maxDist0 < pmap -> maxDistLimit) { + /* Bail out after warning if maxDist is fixed */ + if (maxDistFix > 0) + return; + + if (pmap -> maxDist0 < pmap -> maxDist2Limit) { /* Increase max search radius if below limit & redo search */ pmap -> maxDist0 *= PMAP_MAXDIST_INC; - #ifdef PMAP_LOOKUP_REDO +#ifdef PMAP_LOOKUP_REDO redo = 1; - #endif - - #ifdef PMAP_LOOKUP_WARN +#endif +#ifdef PMAP_LOOKUP_WARN sprintf(errmsg, redo ? "restarting photon lookup with max radius %.1e" : "max photon lookup radius adjusted to %.1e", pmap -> maxDist0); error(WARNING, errmsg); - #endif +#endif } - #ifdef PMAP_LOOKUP_REDO +#ifdef PMAP_LOOKUP_REDO else { sprintf(errmsg, "max photon lookup radius clamped to %.1e", pmap -> maxDist0); error(WARNING, errmsg); } - #endif +#endif } /* Reset successful lookup counter */ pmap -> numLookups = 0; } else { + /* Bail out after warning if maxDist is fixed */ + if (maxDistFix > 0) + return; + /* Increment successful lookup counter and reduce max search radius if * wraparound */ pmap -> numLookups = (pmap -> numLookups + 1) % PMAP_MAXDIST_CNT; @@ -416,304 +574,70 @@ void findPhotons (PhotonMap* pmap, const RAY* ray) redo = 0; } -#endif + } while (redo); } -static void nearest1Neighbour (PhotonMap *pmap, const float pos [3], - const float norm [3], Photon **photon, - unsigned long node) -/* Recursive part of find1Photon(..). - Note that all heap index handling is 1-based, but accesses to the - arrays are 0-based! */ +void find1Photon (PhotonMap *pmap, const RAY* ray, Photon *photon) { - Photon *p = pmap -> heap + node - 1; - /* Signed distance to current photon's splitting plane */ - float d = pos [photonDiscr(*p)] - p -> pos [photonDiscr(*p)], - d2 = d * d; - float dv [3]; + pmap -> maxDist2 = thescene.cusize; /* ? */ - /* Search subtree closer to pos first; exclude other subtree if the - distance to the splitting plane is greater than maxDist */ - if (d < 0) { - if (node << 1 <= pmap -> heapSize) - nearest1Neighbour(pmap, pos, norm, photon, node << 1); - if (d2 < pmap -> maxDist && node << 1 < pmap -> heapSize) - nearest1Neighbour(pmap, pos, norm, photon, (node << 1) + 1); - } - else { - if (node << 1 < pmap -> heapSize) - nearest1Neighbour(pmap, pos, norm, photon, (node << 1) + 1); - if (d2 < pmap -> maxDist && node << 1 <= pmap -> heapSize) - nearest1Neighbour(pmap, pos, norm, photon, node << 1); - } - - /* Squared distance to current photon */ - dv [0] = pos [0] - p -> pos [0]; - dv [1] = pos [1] - p -> pos [1]; - dv [2] = pos [2] - p -> pos [2]; - d2 = DOT(dv, dv); - - if (d2 < pmap -> maxDist && DOT(norm, p -> norm) > 0.5 * frandom()) { - /* Closest photon so far with similar normal */ - pmap -> maxDist = d2; - *photon = p; - } +#ifdef PMAP_OOC + OOC_Find1Photon(pmap, ray -> rop, ray -> ron, photon); +#else + kdT_Find1Photon(pmap, ray -> rop, ray -> ron, photon); +#endif } -Photon* find1Photon (PhotonMap *pmap, const RAY* ray) +void getPhoton (PhotonMap *pmap, PhotonIdx idx, Photon *photon) { - float fpos [3], norm [3]; - Photon* photon = NULL; - - VCOPY(fpos, ray -> rop); - VCOPY(norm, ray -> ron); - pmap -> maxDist = thescene.cusize; - nearest1Neighbour(pmap, fpos, norm, &photon, 1); - - return photon; +#ifdef PMAP_OOC + if (OOC_GetPhoton(pmap, idx, photon)) +#else + if (kdT_GetPhoton(pmap, idx, photon)) +#endif + error(INTERNAL, "failed photon lookup"); } -static unsigned long medianPartition (const Photon* heap, - unsigned long* heapIdx, - unsigned long* heapXdi, - unsigned long left, - unsigned long right, unsigned dim) -/* Returns index to median in heap from indices left to right - (inclusive) in dimension dim. The heap is partitioned relative to - median using a quicksort algorithm. The heap indices in heapIdx are - sorted rather than the heap itself. */ +Photon *getNearestPhoton (const PhotonSearchQueue *squeue, PhotonIdx idx) { - register const float* p; - const unsigned long n = right - left + 1; - register unsigned long l, r, lg2, n2, m; - register unsigned d; - - /* Round down n to nearest power of 2 */ - for (lg2 = 0, n2 = n; n2 > 1; n2 >>= 1, ++lg2); - n2 = 1 << lg2; - - /* Determine median position; this takes into account the fact that - only the last level in the heap can be partially empty, and that - it fills from left to right */ - m = left + ((n - n2) > (n2 >> 1) - 1 ? n2 - 1 : n - (n2 >> 1)); - - while (right > left) { - /* Pivot node */ - p = heap [heapIdx [right]].pos; - l = left; - r = right - 1; - - /* l & r converge, swapping elements out of order with respect to - pivot node. Identical keys are resolved by cycling through - dim. The convergence point is then the pivot's position. */ - do { - while (l <= r) { - d = dim; - - while (heap [heapIdx [l]].pos [d] == p [d]) { - d = (d + 1) % 3; - - if (d == dim) { - /* Ignore dupes? */ - error(WARNING, "duplicate keys in photon heap"); - l++; - break; - } - } - - if (heap [heapIdx [l]].pos [d] < p [d]) - l++; - else break; - } - - while (r > l) { - d = dim; - - while (heap [heapIdx [r]].pos [d] == p [d]) { - d = (d + 1) % 3; - - if (d == dim) { - /* Ignore dupes? */ - error(WARNING, "duplicate keys in photon heap"); - r--; - break; - } - } - - if (heap [heapIdx [r]].pos [d] > p [d]) - r--; - else break; - } - - /* Swap indices (not the nodes they point to) */ - n2 = heapIdx [l]; - heapIdx [l] = heapIdx [r]; - heapIdx [r] = n2; - /* Update reverse indices */ - heapXdi [heapIdx [l]] = l; - heapXdi [n2] = r; - } while (l < r); - - /* Swap indices of convergence and pivot nodes */ - heapIdx [r] = heapIdx [l]; - heapIdx [l] = heapIdx [right]; - heapIdx [right] = n2; - /* Update reverse indices */ - heapXdi [heapIdx [r]] = r; - heapXdi [heapIdx [l]] = l; - heapXdi [n2] = right; - if (l >= m) right = l - 1; - if (l <= m) left = l + 1; - } - - /* Once left & right have converged at m, we have found the median */ - return m; +#ifdef PMAP_OOC + return OOC_GetNearestPhoton(squeue, idx); +#else + return kdT_GetNearestPhoton(squeue, idx); +#endif } -void buildHeap (Photon* heap, unsigned long* heapIdx, - unsigned long* heapXdi, const float min [3], - const float max [3], unsigned long left, - unsigned long right, unsigned long root) -/* Recursive part of balancePhotons(..). Builds heap from subarray - defined by indices left and right. min and max are the minimum resp. - maximum photon positions in the array. root is the index of the - current subtree's root, which corresponds to the median's 1-based - index in the heap. heapIdx are the balanced heap indices. The heap - is accessed indirectly through these. heapXdi are the reverse indices - from the heap to heapIdx so that heapXdi [heapIdx [i]] = i. */ +PhotonIdx firstPhoton (const PhotonMap *pmap) { - float maxLeft [3], minRight [3]; - Photon rootNode; - unsigned d; - - /* Choose median for dimension with largest spread and partition - accordingly */ - const float d0 = max [0] - min [0], - d1 = max [1] - min [1], - d2 = max [2] - min [2]; - const unsigned char dim = d0 > d1 ? d0 > d2 ? 0 : 2 - : d1 > d2 ? 1 : 2; - const unsigned long median = - left == right ? left - : medianPartition(heap, heapIdx, heapXdi, left, right, dim); - - /* Place median at root of current subtree. This consists of swapping - the median and the root nodes and updating the heap indices */ - memcpy(&rootNode, heap + heapIdx [median], sizeof(Photon)); - memcpy(heap + heapIdx [median], heap + root - 1, sizeof(Photon)); - setPhotonDiscr(rootNode, dim); - memcpy(heap + root - 1, &rootNode, sizeof(Photon)); - heapIdx [heapXdi [root - 1]] = heapIdx [median]; - heapXdi [heapIdx [median]] = heapXdi [root - 1]; - heapIdx [median] = root - 1; - heapXdi [root - 1] = median; - - /* Update bounds for left and right subtrees and recurse on them */ - for (d = 0; d <= 2; d++) - if (d == dim) - maxLeft [d] = minRight [d] = rootNode.pos [d]; - else { - maxLeft [d] = max [d]; - minRight [d] = min [d]; - } - - if (left < median) - buildHeap(heap, heapIdx, heapXdi, min, maxLeft, - left, median - 1, root << 1); - - if (right > median) - buildHeap(heap, heapIdx, heapXdi, minRight, max, - median + 1, right, (root << 1) + 1); +#ifdef PMAP_OOC + return OOC_FirstPhoton(pmap); +#else + return kdT_FirstPhoton(pmap); +#endif } -void balancePhotons (PhotonMap* pmap, double *photonFlux) -{ - Photon *heap = pmap -> heap; - unsigned long i; - unsigned long *heapIdx; /* Photon index array */ - unsigned long *heapXdi; /* Reverse index to heapIdx */ - unsigned j; - COLOR flux; - /* Need doubles here to reduce errors from increment */ - double avgFlux [3] = {0, 0, 0}, CoG [3] = {0, 0, 0}, CoGdist = 0; - FVECT d; - - if (pmap -> heapEnd) { - pmap -> heapSize = pmap -> heapEnd; - heapIdx = (unsigned long*)malloc(pmap -> heapSize * - sizeof(unsigned long)); - heapXdi = (unsigned long*)malloc(pmap -> heapSize * - sizeof(unsigned long)); - if (!heapIdx || !heapXdi) - error(USER, "can't allocate heap index"); - - for (i = 0; i < pmap -> heapSize; i++) { - /* Initialize index arrays */ - heapXdi [i] = heapIdx [i] = i; - getPhotonFlux(heap + i, flux); - - /* Scale photon's flux (hitherto normalised to 1 over RGB); in case - * of a contrib photon map, this is done per light source, and - * photonFlux is assumed to be an array */ - if (photonFlux) { - scalecolor(flux, photonFlux [isContribPmap(pmap) ? - photonSrcIdx(pmap, heap + i) : 0]); - setPhotonFlux(heap + i, flux); - } - - /* Need a double here */ - addcolor(avgFlux, flux); - - /* Add photon position to centre of gravity */ - for (j = 0; j < 3; j++) - CoG [j] += heap [i].pos [j]; - } - - /* Average photon positions to get centre of gravity */ - for (j = 0; j < 3; j++) - pmap -> CoG [j] = CoG [j] /= pmap -> heapSize; - - /* Compute average photon distance to CoG */ - for (i = 0; i < pmap -> heapSize; i++) { - VSUB(d, heap [i].pos, CoG); - CoGdist += DOT(d, d); - } - - pmap -> CoGdist = CoGdist /= pmap -> heapSize; - - /* Average photon flux based on RGBE representation */ - scalecolor(avgFlux, 1.0 / pmap -> heapSize); - copycolor(pmap -> photonFlux, avgFlux); - - /* Build kd-tree */ - buildHeap(pmap -> heap, heapIdx, heapXdi, pmap -> minPos, - pmap -> maxPos, 0, pmap -> heapSize - 1, 1); - - free(heapIdx); - free(heapXdi); - } -} - - - void deletePhotons (PhotonMap* pmap) { - free(pmap -> heap); - free(pmap -> squeue); +#ifdef PMAP_OOC + OOC_Delete(&pmap -> store); +#else + kdT_Delete(&pmap -> store); +#endif + + free(pmap -> squeue.node); free(pmap -> biasCompHist); - pmap -> heapSize = 0; - pmap -> minGather = pmap -> maxGather = - pmap -> squeueSize = pmap -> squeueEnd = 0; + pmap -> numPhotons = pmap -> minGather = pmap -> maxGather = + pmap -> squeue.len = pmap -> squeue.tail = 0; }
