--- ray/src/rt/pmapdata.c 2019/05/10 17:43:22 2.21 +++ ray/src/rt/pmapdata.c 2020/04/08 15:14:21 2.22 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: pmapdata.c,v 2.21 2019/05/10 17:43:22 rschregle Exp $"; +static const char RCSid[] = "$Id: pmapdata.c,v 2.22 2020/04/08 15:14:21 rschregle Exp $"; #endif /* @@ -17,7 +17,7 @@ static const char RCSid[] = "$Id: pmapdata.c,v 2.21 20 supported by the Swiss National Science Foundation (SNSF, #147053) ========================================================================== - $Id: pmapdata.c,v 2.21 2019/05/10 17:43:22 rschregle Exp $ + $Id: pmapdata.c,v 2.22 2020/04/08 15:14:21 rschregle Exp $ */ @@ -517,7 +517,11 @@ void findPhotons (PhotonMap* pmap, const RAY* ray) /* Search position is ray -> rorg for volume photons, since we have no intersection point. Normals are ignored -- these are incident - directions). */ + directions). */ + /* NOTE: status returned by XXX_FindPhotons() is currently ignored; + if no photons are found, an empty queue is returned under the + assumption all photons are too distant to contribute significant + flux. */ if (isVolumePmap(pmap)) { #ifdef PMAP_OOC OOC_FindPhotons(pmap, ray -> rorg, NULL); @@ -607,15 +611,40 @@ void findPhotons (PhotonMap* pmap, const RAY* ray) -void find1Photon (PhotonMap *pmap, const RAY* ray, Photon *photon) +Photon *find1Photon (PhotonMap *pmap, const RAY* ray, Photon *photon) { - pmap -> maxDist2 = thescene.cusize; /* ? */ + /* Init (squared) search radius to avg photon dist to centre of gravity */ + float maxDist2_0 = pmap -> CoGdist; + int found = 0; +#ifdef PMAP_LOOKUP_REDO + #define REDO 1 +#else + #define REDO 0 +#endif + do { + pmap -> maxDist2 = maxDist2_0; #ifdef PMAP_OOC - OOC_Find1Photon(pmap, ray -> rop, ray -> ron, photon); + found = OOC_Find1Photon(pmap, ray -> rop, ray -> ron, photon); #else - kdT_Find1Photon(pmap, ray -> rop, ray -> ron, photon); -#endif + found = kdT_Find1Photon(pmap, ray -> rop, ray -> ron, photon); +#endif + if (found < 0) { + /* Expand search radius to retry */ + maxDist2_0 *= 2; +#ifdef PMAP_LOOKUP_WARN + sprintf(errmsg, "failed 1-NN photon lookup" +#ifdef PMAP_LOOKUP_REDO + ", retrying with search radius %.2f", maxDist2_0 +#endif + ); + error(WARNING, errmsg); +#endif + } + } while (REDO && found < 0); + + /* Return photon buffer containing valid photon, else NULL */ + return found < 0 ? NULL : photon; }
