root/radiance/ray/src/rt/pmapdata.c
Wed Apr 14 11:26:25 2021 UTC (3 years, 1 month ago) by rschregle
CVS Tags: HEAD, rad5R4
Changes since 2.22: +21 -12 lines
Diff to previous 2.22
feat(mkpmap): Added -apI option for spherical ROI
Revision 2.22 - (view) (download) (annotate) - [selected]
Wed Apr 8 15:14:21 2020 UTC (4 years, 1 month ago) by rschregle
Changes since 2.21: +37 -8 lines
Diff to previous 2.21
Fixed est00pid bug in single photon lookups that returned junk when none found, added code to detect and handle (ignore).
Fri May 10 17:43:22 2019 UTC (5 years ago) by rschregle
Changes since 2.20: +19 -3 lines
Diff to previous 2.20 , to selected 2.22
Factored out ray weight when setting photon flux in newPhoton(), as it
(erroneously) attenuates volume photons in participating media.
Prehistoric artefact?
Fri Mar 8 17:25:17 2019 UTC (5 years, 2 months ago) by rschregle
Changes since 2.19: +6 -6 lines
Diff to previous 2.19 , to selected 2.22
Minor comments fix
Tue Mar 20 19:55:33 2018 UTC (6 years, 1 month ago) by rschregle
Changes since 2.18: +68 -57 lines
Diff to previous 2.18 , to selected 2.22
Added -ae/-ai ambient exclude options to mkpmap, cleaned up opt parsing.
Mon Aug 14 21:12:10 2017 UTC (6 years, 9 months ago) by rschregle
Changes since 2.17: +97 -74 lines
Diff to previous 2.17 , to selected 2.22
Updated photon map code for Windows; no multproc or ooC for now
Thu Sep 29 20:51:07 2016 UTC (7 years, 7 months ago) by greg
Changes since 2.16: +5 -4 lines
Diff to previous 2.16 , to selected 2.22
Conditional compile of fsync() call for Windows
Wed Sep 28 22:19:18 2016 UTC (7 years, 7 months ago) by greg
Changes since 2.15: +4 -2 lines
Diff to previous 2.15 , to selected 2.22
Made fcntl() call compile conditionally for Windows
Tue May 17 17:39:47 2016 UTC (8 years ago) by rschregle
Changes since 2.14: +383 -504 lines
Diff to previous 2.14 , to selected 2.22
Thu Feb 4 11:36:59 2016 UTC (8 years, 3 months ago) by rschregle
Changes since 2.13: +9 -5 lines
Diff to previous 2.13 , to selected 2.22
Minor pmapcontrib cleanup, revised photon normal test in pmapdata
Wed Sep 9 16:08:46 2015 UTC (8 years, 8 months ago) by rschregle
Diff to previous 2.12 , to selected 2.22
Disabled warnings about itsy bitsy photon search radius
Tue Sep 1 16:27:52 2015 UTC (8 years, 8 months ago) by greg
Changes since 2.11: +1 -2 lines
Diff to previous 2.11 , to selected 2.22
Tue Aug 18 18:45:55 2015 UTC (8 years, 9 months ago) by greg
Changes since 2.10: +4 -1 lines
Diff to previous 2.10 , to selected 2.22
Wed Jul 29 18:54:20 2015 UTC (8 years, 9 months ago) by rschregle
Changes since 2.9: +9 -3 lines
Diff to previous 2.9 , to selected 2.22
Fixed bug with handling of -am rendering option, removed redundant code
Wed May 27 19:15:27 2015 UTC (8 years, 11 months ago) by rschregle
Diff to previous 2.8 , to selected 2.22
maxDistFix (fixed max photon search radius) now squared in findPhotons()
Tue May 26 13:31:19 2015 UTC (8 years, 11 months ago) by rschregle
Changes since 2.7: +27 -22 lines
Diff to previous 2.7 , to selected 2.22
-am option to rpict/rvu/rtrace now sets fixed max photon search radius,
-overriding the adaptive max search radius
Tue May 26 11:26:27 2015 UTC (8 years, 11 months ago) by rschregle
Changes since 2.6: +4 -3 lines
Diff to previous 2.6 , to selected 2.22
Added stochastic photon coplanarity test in
NearestNeighbours()/Nearest1Neighbour()
Thu May 21 13:54:59 2015 UTC (8 years, 11 months ago) by greg
Diff to previous 2.5 , to selected 2.22
Added calls to findmaterial() and simplified photon map shadow check
Wed May 20 14:44:12 2015 UTC (9 years ago) by greg
Changes since 2.4: +6 -4 lines
Diff to previous 2.4 , to selected 2.22
Reduced primary photon struct size using encoded direction
Wed May 20 12:58:31 2015 UTC (9 years ago) by greg
Diff to previous 2.3 , to selected 2.22
Added appropriate setting of ray parameters for bin rcontrib evaluation
Fri May 8 13:20:23 2015 UTC (9 years ago) by rschregle
Diff to previous 2.2 , to selected 2.22
Wed Apr 22 15:44:57 2015 UTC (9 years ago) by rschregle
Diff to previous 2.1 , to selected 2.22
Conditionally disabled warning about clamped max photon lookup radius.
Tue Feb 24 19:39:26 2015 UTC (9 years, 2 months ago) by greg
Diff to selected 2.22
