root/radiance/ray/src/rt/pmapdata.c
Revision: 2.14
Committed: Thu Feb 4 11:36:59 2016 UTC (9 years, 3 months ago) by rschregle
Changes since 2.13: +9 -5 lines
Minor pmapcontrib cleanup, revised photon normal test in pmapdata
2 static const char RCSid[] = "$Id: pmapdata.c,v 4.35 2016/01/20 16:05:16 taschreg Exp taschreg $";
5 ==================================================================
6 Photon map data structures and kd-tree handling
7
8 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
9 (c) Fraunhofer Institute for Solar Energy Systems,
10 (c) Lucerne University of Applied Sciences and Arts,
11 supported by the Swiss National Science Foundation (SNSF, #147053)
12 ==================================================================
13
14 */
15
16
17
18 #include "pmap.h"
19 #include "pmaprand.h"
20 #include "pmapmat.h"
21 #include "otypes.h"
22 #include "source.h"
23 #include "rcontrib.h"
24 #include "random.h"
25
26
27
28 PhotonMap *photonMaps [NUM_PMAP_TYPES] = {
29 NULL, NULL, NULL, NULL, NULL, NULL
30 };
31
32
33
34 void initPhotonMap (PhotonMap *pmap, PhotonMapType t)
35 /* Init photon map 'n' stuff... */
36 {
37 if (!pmap)
38 return;
39
40 pmap -> heapSize = pmap -> heapEnd = 0;
41 pmap -> heap = NULL;
42 pmap -> squeue = NULL;
43 pmap -> biasCompHist = NULL;
44 pmap -> maxPos [0] = pmap -> maxPos [1] = pmap -> maxPos [2] = -FHUGE;
45 pmap -> minPos [0] = pmap -> minPos [1] = pmap -> minPos [2] = FHUGE;
46 pmap -> minGathered = pmap -> maxGathered = pmap -> totalGathered = 0;
47 pmap -> gatherTolerance = gatherTolerance;
48 pmap -> minError = pmap -> maxError = pmap -> rmsError = 0;
49 pmap -> numDensity = 0;
50 pmap -> distribRatio = 1;
51 pmap -> type = t;
52
53 /* Init local RNG state */
54 pmap -> randState [0] = 10243;
55 pmap -> randState [1] = 39829;
56 pmap -> randState [2] = 9433;
57 /* pmapSeed(25999, pmap -> randState); */
58 pmapSeed(randSeed, pmap -> randState);
59
60 /* Set up type-specific photon lookup callback */
61 pmap -> lookup = pmapLookup [t];
62
63 pmap -> primary = NULL;
64 pmap -> primarySize = pmap -> primaryEnd = 0;
65 }
66
67
68
69 const PhotonPrimary* addPhotonPrimary (PhotonMap *pmap, const RAY *ray)
70 {
71 PhotonPrimary *prim = NULL;
72 FVECT dvec;
73
74 if (!pmap || !ray)
75 return NULL;
76
77 /* Check if last primary ray has spawned photons (srcIdx >= 0, see
78 * addPhoton()), in which case we keep it and allocate a new one;
79 * otherwise we overwrite the unused entry */
80 if (pmap -> primary && pmap -> primary [pmap -> primaryEnd].srcIdx >= 0)
81 pmap -> primaryEnd++;
82
83 if (!pmap -> primarySize || pmap -> primaryEnd >= pmap -> primarySize) {
84 /* Allocate/enlarge array */
85 pmap -> primarySize += pmap -> heapSizeInc;
86
87 /* Counter wraparound? */
88 if (pmap -> primarySize < pmap -> heapSizeInc)
89 error(INTERNAL, "photon primary overflow");
90
91 pmap -> primary = (PhotonPrimary *)realloc(pmap -> primary,
92 sizeof(PhotonPrimary) *
93 pmap -> primarySize);
94 if (!pmap -> primary)
95 error(USER, "can't allocate photon primaries");
96 }
97
98 prim = pmap -> primary + pmap -> primaryEnd;
99
100 /* Mark unused with negative source index until path spawns a photon (see
101 * addPhoton()) */
102 prim -> srcIdx = -1;
103
104 /* Reverse incident direction to point to light source */
105 dvec [0] = -ray -> rdir [0];
106 dvec [1] = -ray -> rdir [1];
107 dvec [2] = -ray -> rdir [2];
108 prim -> dir = encodedir(dvec);
109
110 VCOPY(prim -> pos, ray -> rop);
111
112 return prim;
113 }
114
115
116
117 const Photon* addPhoton (PhotonMap* pmap, const RAY* ray)
118 {
119 unsigned i;
120 Photon* photon = NULL;
121 COLOR photonFlux;
122
123 /* Account for distribution ratio */
124 if (!pmap || pmapRandom(pmap -> randState) > pmap -> distribRatio)
125 return NULL;
126
127 /* Don't store on sources */
128 if (ray -> robj > -1 && islight(objptr(ray -> ro -> omod) -> otype))
129 return NULL;
130
131 #if 0
132 if (inContribPmap(pmap)) {
133 /* Adding contribution photon */
134 if (ray -> parent && ray -> parent -> rtype & PRIMARY)
135 /* Add primary photon ray if parent is primary; by putting this
136 * here and checking the ray's immediate parent, we only add
137 * primaries that actually contribute photons, and we only add them
138 * once. */
139 addPhotonPrimary(pmap, ray -> parent);
140
141 /* Save index to primary ray (remains unchanged if primary already in
142 * array) */
143 primary = pmap -> primaryEnd;
144 }
145 #endif
146
147 #ifdef PMAP_ROI
148 /* Store photon if within region of interest -- for egg-spurtz only! */
149 if (ray -> rop [0] >= pmapROI [0] && ray -> rop [0] <= pmapROI [1] &&
150 ray -> rop [1] >= pmapROI [2] && ray -> rop [1] <= pmapROI [3] &&
151 ray -> rop [2] >= pmapROI [4] && ray -> rop [2] <= pmapROI [5])
152 #endif
153 {
154 if (pmap -> heapEnd >= pmap -> heapSize) {
155 /* Enlarge heap */
156 pmap -> heapSize += pmap -> heapSizeInc;
157
158 /* Counter wraparound? */
159 if (pmap -> heapSize < pmap -> heapSizeInc)
160 error(INTERNAL, "photon heap overflow");
161
162 pmap -> heap = (Photon *)realloc(pmap -> heap,
163 sizeof(Photon) * pmap -> heapSize);
164 if (!pmap -> heap)
165 error(USER, "can't allocate photon heap");
166 }
167
168 photon = pmap -> heap + pmap -> heapEnd++;
169
170 /* Adjust flux according to distribution ratio and ray weight */
171 copycolor(photonFlux, ray -> rcol);
172 scalecolor(photonFlux,
173 ray -> rweight / (pmap -> distribRatio ? pmap -> distribRatio
174 : 1));
175 setPhotonFlux(photon, photonFlux);
176
177 /* Set photon position and flags */
178 VCOPY(photon -> pos, ray -> rop);
179 photon -> flags = PMAP_CAUSTICRAY(ray) ? PMAP_CAUST_BIT : 0;
180
181 /* Set primary ray index and mark as used for contrib photons */
182 if (isContribPmap(pmap)) {
183 photon -> primary = pmap -> primaryEnd;
184 pmap -> primary [pmap -> primaryEnd].srcIdx = ray -> rsrc;
185 }
186 else photon -> primary = 0;
187
188 /* Update min and max positions & set normal */
189 for (i = 0; i <= 2; i++) {
190 if (photon -> pos [i] < pmap -> minPos [i])
191 pmap -> minPos [i] = photon -> pos [i];
192 if (photon -> pos [i] > pmap -> maxPos [i])
193 pmap -> maxPos [i] = photon -> pos [i];
194 photon -> norm [i] = 127.0 * (isVolumePmap(pmap) ? ray -> rdir [i]
195 : ray -> ron [i]);
196 }
197 }
198
199 return photon;
200 }
201
202
203
204 static void nearestNeighbours (PhotonMap* pmap, const float pos [3],
205 const float norm [3], unsigned long node)
206 /* Recursive part of findPhotons(..).
207 Note that all heap and priority queue index handling is 1-based, but
208 accesses to the arrays are 0-based! */
209 {
210 Photon* p = &pmap -> heap [node - 1];
211 unsigned i, j;
212 /* Signed distance to current photon's splitting plane */
213 float d = pos [photonDiscr(*p)] - p -> pos [photonDiscr(*p)],
214 d2 = d * d;
215 PhotonSQNode* sq = pmap -> squeue;
216 const unsigned sqSize = pmap -> squeueSize;
217 float dv [3];
218
219 /* Search subtree closer to pos first; exclude other subtree if the
220 distance to the splitting plane is greater than maxDist */
221 if (d < 0) {
222 if (node << 1 <= pmap -> heapSize)
223 nearestNeighbours(pmap, pos, norm, node << 1);
224 if (d2 < pmap -> maxDist && node << 1 < pmap -> heapSize)
225 nearestNeighbours(pmap, pos, norm, (node << 1) + 1);
226 }
227 else {
228 if (node << 1 < pmap -> heapSize)
229 nearestNeighbours(pmap, pos, norm, (node << 1) + 1);
230 if (d2 < pmap -> maxDist && node << 1 <= pmap -> heapSize)
231 nearestNeighbours(pmap, pos, norm, node << 1);
232 }
233
234 /* Reject photon if normal faces away (ignored for volume photons) with
235 * 50% tolerance to account for perturbation; note photon normal is coded
236 * in range [-127,127]. */
237 if (norm && DOT(norm, p -> norm) <= 63.5 * frandom())
238 return;
239
240 if (isContribPmap(pmap) && pmap -> srcContrib) {
241 /* Lookup in contribution photon map */
242 OBJREC *srcMod;
243 const int srcIdx = photonSrcIdx(pmap, p);
244
245 if (srcIdx < 0 || srcIdx >= nsources)
246 error(INTERNAL, "invalid light source index in photon map");
247
248 srcMod = findmaterial(source [srcIdx].so);
249
250 /* Reject photon if contributions from light source which emitted it
251 * are not sought */
252 if (!lu_find(pmap -> srcContrib, srcMod -> oname) -> data)
253 return;
254
255 /* Reject non-caustic photon if lookup for caustic contribs */
256 if (pmap -> lookupFlags & PMAP_CAUST_BIT & ~p -> flags)
257 return;
258 }
259
260 /* Squared distance to current photon */
261 dv [0] = pos [0] - p -> pos [0];
262 dv [1] = pos [1] - p -> pos [1];
263 dv [2] = pos [2] - p -> pos [2];
264 d2 = DOT(dv, dv);
265
266 /* Accept photon if closer than current max dist & add to priority queue */
267 if (d2 < pmap -> maxDist) {
268 if (pmap -> squeueEnd < sqSize) {
269 /* Priority queue not full; append photon and restore heap */
270 i = ++pmap -> squeueEnd;
271
272 while (i > 1 && sq [(i >> 1) - 1].dist <= d2) {
273 sq [i - 1].photon = sq [(i >> 1) - 1].photon;
274 sq [i - 1].dist = sq [(i >> 1) - 1].dist;
275 i >>= 1;
276 }
277
278 sq [--i].photon = p;
279 sq [i].dist = d2;
280 /* Update maxDist if we've just filled the queue */
281 if (pmap -> squeueEnd >= pmap -> squeueSize)
282 pmap -> maxDist = sq [0].dist;
283 }
284 else {
285 /* Priority queue full; replace maximum, restore heap, and
286 update maxDist */
287 i = 1;
288
289 while (i <= sqSize >> 1) {
290 j = i << 1;
291 if (j < sqSize && sq [j - 1].dist < sq [j].dist)
292 j++;
293 if (d2 >= sq [j - 1].dist)
294 break;
295 sq [i - 1].photon = sq [j - 1].photon;
296 sq [i - 1].dist = sq [j - 1].dist;
297 i = j;
298 }
299
300 sq [--i].photon = p;
301 sq [i].dist = d2;
302 pmap -> maxDist = sq [0].dist;
303 }
304 }
305 }
306
307
308
309 /* Dynamic max photon search radius increase and reduction factors */
310 #define PMAP_MAXDIST_INC 4
311 #define PMAP_MAXDIST_DEC 0.9
312
313 /* Num successful lookups before reducing in max search radius */
314 #define PMAP_MAXDIST_CNT 1000
315
316 /* Threshold below which we assume increasing max radius won't help */
317 #define PMAP_SHORT_LOOKUP_THRESH 1
318
319 /* Coefficient for adaptive maximum search radius */
320 #define PMAP_MAXDIST_COEFF 100
321
322
323 void findPhotons (PhotonMap* pmap, const RAY* ray)
324 {
325 float pos [3], norm [3];
326 int redo = 0;
327
328 if (!pmap -> squeue) {
329 /* Lazy init priority queue */
330 pmap -> squeueSize = pmap -> maxGather + 1;
331 pmap -> squeue = (PhotonSQNode*)malloc(pmap -> squeueSize *
332 sizeof(PhotonSQNode));
333 if (!pmap -> squeue)
334 error(USER, "can't allocate photon priority queue");
335
336 pmap -> minGathered = pmap -> maxGather;
337 pmap -> maxGathered = pmap -> minGather;
338 pmap -> totalGathered = 0;
339 pmap -> numLookups = pmap -> numShortLookups = 0;
340 pmap -> shortLookupPct = 0;
341 pmap -> minError = FHUGE;
342 pmap -> maxError = -FHUGE;
343 pmap -> rmsError = 0;
344 /* SQUARED max search radius limit is based on avg photon distance to
345 * centre of gravity, unless fixed by user (maxDistFix > 0) */
346 pmap -> maxDist0 = pmap -> maxDistLimit =
347 maxDistFix > 0 ? maxDistFix * maxDistFix
348 : PMAP_MAXDIST_COEFF * pmap -> squeueSize *
349 pmap -> CoGdist / pmap -> heapSize;
350 }
351
352 do {
353 pmap -> squeueEnd = 0;
354 pmap -> maxDist = pmap -> maxDist0;
355
356 /* Search position is ray -> rorg for volume photons, since we have no
357 intersection point. Normals are ignored -- these are incident
358 directions). */
359 if (isVolumePmap(pmap)) {
360 VCOPY(pos, ray -> rorg);
361 nearestNeighbours(pmap, pos, NULL, 1);
362 }
363 else {
364 VCOPY(pos, ray -> rop);
365 VCOPY(norm, ray -> ron);
366 nearestNeighbours(pmap, pos, norm, 1);
367 }
368
369 #ifdef PMAP_ITSYBITSY
370 if (pmap -> maxDist < FTINY) {
371 sprintf(errmsg, "itsy bitsy teeny weeny photon search radius %e",
372 sqrt(pmap -> maxDist));
373 error(WARNING, errmsg);
374 }
375 #endif
376
377 if (pmap -> squeueEnd < pmap -> squeueSize * pmap -> gatherTolerance) {
378 /* Short lookup; too few photons found */
379 if (pmap -> squeueEnd > PMAP_SHORT_LOOKUP_THRESH) {
380 /* Ignore short lookups which return fewer than
381 * PMAP_SHORT_LOOKUP_THRESH photons under the assumption there
382 * really are no photons in the vicinity, and increasing the max
383 * search radius therefore won't help */
384 #ifdef PMAP_LOOKUP_WARN
385 sprintf(errmsg,
386 "%d/%d %s photons found at (%.2f,%.2f,%.2f) on %s",
387 pmap -> squeueEnd, pmap -> squeueSize,
388 pmapName [pmap -> type], pos [0], pos [1], pos [2],
389 ray -> ro ? ray -> ro -> oname : "<null>");
390 error(WARNING, errmsg);
391 #endif
392
393 /* Bail out after warning if maxDist is fixed */
394 if (maxDistFix > 0)
395 return;
396
397 if (pmap -> maxDist0 < pmap -> maxDistLimit) {
398 /* Increase max search radius if below limit & redo search */
399 pmap -> maxDist0 *= PMAP_MAXDIST_INC;
400 #ifdef PMAP_LOOKUP_REDO
401 redo = 1;
402 #endif
403 #ifdef PMAP_LOOKUP_WARN
404 sprintf(errmsg,
405 redo ? "restarting photon lookup with max radius %.1e"
406 : "max photon lookup radius adjusted to %.1e",
407 sqrt(pmap -> maxDist0));
408 error(WARNING, errmsg);
409 #endif
410 }
411 #ifdef PMAP_LOOKUP_REDO
412 else {
413 sprintf(errmsg, "max photon lookup radius clamped to %.1e",
414 sqrt(pmap -> maxDist0));
415 error(WARNING, errmsg);
416 }
417 #endif
418 }
419
420 /* Reset successful lookup counter */
421 pmap -> numLookups = 0;
422 }
423 else {
424 /* Bail out after warning if maxDist is fixed */
425 if (maxDistFix > 0)
426 return;
427
428 /* Increment successful lookup counter and reduce max search radius if
429 * wraparound */
430 pmap -> numLookups = (pmap -> numLookups + 1) % PMAP_MAXDIST_CNT;
431 if (!pmap -> numLookups)
432 pmap -> maxDist0 *= PMAP_MAXDIST_DEC;
433
434 redo = 0;
435 }
436
437 } while (redo);
438 }
439
440
441
442 static void nearest1Neighbour (PhotonMap *pmap, const float pos [3],
443 const float norm [3], Photon **photon,
444 unsigned long node)
445 /* Recursive part of find1Photon(..).
446 Note that all heap index handling is 1-based, but accesses to the
447 arrays are 0-based! */
448 {
449 Photon *p = pmap -> heap + node - 1;
450 /* Signed distance to current photon's splitting plane */
451 float d = pos [photonDiscr(*p)] - p -> pos [photonDiscr(*p)],
452 d2 = d * d;
453 float dv [3];
454
455 /* Search subtree closer to pos first; exclude other subtree if the
456 distance to the splitting plane is greater than maxDist */
457 if (d < 0) {
458 if (node << 1 <= pmap -> heapSize)
459 nearest1Neighbour(pmap, pos, norm, photon, node << 1);
460 if (d2 < pmap -> maxDist && node << 1 < pmap -> heapSize)
461 nearest1Neighbour(pmap, pos, norm, photon, (node << 1) + 1);
462 }
463 else {
464 if (node << 1 < pmap -> heapSize)
465 nearest1Neighbour(pmap, pos, norm, photon, (node << 1) + 1);
466 if (d2 < pmap -> maxDist && node << 1 <= pmap -> heapSize)
467 nearest1Neighbour(pmap, pos, norm, photon, node << 1);
468 }
469
470 /* Squared distance to current photon */
471 dv [0] = pos [0] - p -> pos [0];
472 dv [1] = pos [1] - p -> pos [1];
473 dv [2] = pos [2] - p -> pos [2];
474 d2 = DOT(dv, dv);
475
476 if (d2 < pmap -> maxDist && DOT(norm, p -> norm) > 63.5 * frandom()) {
477 /* Closest photon so far with similar normal. We allow a 50% tolerance
478 * to account for perturbation in the latter; note the photon normal
479 * is coded in the range [-127,127]. */
480 pmap -> maxDist = d2;
481 *photon = p;
482 }
483 }
484
485
486
487 Photon* find1Photon (PhotonMap *pmap, const RAY* ray)
488 {
489 float fpos [3], norm [3];
490 Photon* photon = NULL;
491
492 VCOPY(fpos, ray -> rop);
493 VCOPY(norm, ray -> ron);
494 pmap -> maxDist = thescene.cusize;
495 nearest1Neighbour(pmap, fpos, norm, &photon, 1);
496
497 return photon;
498 }
499
500
501
502 static unsigned long medianPartition (const Photon* heap,
503 unsigned long* heapIdx,
504 unsigned long* heapXdi,
505 unsigned long left,
506 unsigned long right, unsigned dim)
507 /* Returns index to median in heap from indices left to right
508 (inclusive) in dimension dim. The heap is partitioned relative to
509 median using a quicksort algorithm. The heap indices in heapIdx are
510 sorted rather than the heap itself. */
511 {
512 register const float* p;
513 const unsigned long n = right - left + 1;
514 register unsigned long l, r, lg2, n2, m;
515 register unsigned d;
516
517 /* Round down n to nearest power of 2 */
518 for (lg2 = 0, n2 = n; n2 > 1; n2 >>= 1, ++lg2);
519 n2 = 1 << lg2;
520
521 /* Determine median position; this takes into account the fact that
522 only the last level in the heap can be partially empty, and that
523 it fills from left to right */
524 m = left + ((n - n2) > (n2 >> 1) - 1 ? n2 - 1 : n - (n2 >> 1));
525
526 while (right > left) {
527 /* Pivot node */
528 p = heap [heapIdx [right]].pos;
529 l = left;
530 r = right - 1;
531
532 /* l & r converge, swapping elements out of order with respect to
533 pivot node. Identical keys are resolved by cycling through
534 dim. The convergence point is then the pivot's position. */
535 do {
536 while (l <= r) {
537 d = dim;
538
539 while (heap [heapIdx [l]].pos [d] == p [d]) {
540 d = (d + 1) % 3;
541
542 if (d == dim) {
543 /* Ignore dupes? */
544 error(WARNING, "duplicate keys in photon heap");
545 l++;
546 break;
547 }
548 }
549
550 if (heap [heapIdx [l]].pos [d] < p [d])
551 l++;
552 else break;
553 }
554
555 while (r > l) {
556 d = dim;
557
558 while (heap [heapIdx [r]].pos [d] == p [d]) {
559 d = (d + 1) % 3;
560
561 if (d == dim) {
562 /* Ignore dupes? */
563 error(WARNING, "duplicate keys in photon heap");
564 r--;
565 break;
566 }
567 }
568
569 if (heap [heapIdx [r]].pos [d] > p [d])
570 r--;
571 else break;
572 }
573
574 /* Swap indices (not the nodes they point to) */
575 n2 = heapIdx [l];
576 heapIdx [l] = heapIdx [r];
577 heapIdx [r] = n2;
578 /* Update reverse indices */
579 heapXdi [heapIdx [l]] = l;
580 heapXdi [n2] = r;
581 } while (l < r);
582
583 /* Swap indices of convergence and pivot nodes */
584 heapIdx [r] = heapIdx [l];
585 heapIdx [l] = heapIdx [right];
586 heapIdx [right] = n2;
587 /* Update reverse indices */
588 heapXdi [heapIdx [r]] = r;
589 heapXdi [heapIdx [l]] = l;
590 heapXdi [n2] = right;
591 if (l >= m) right = l - 1;
592 if (l <= m) left = l + 1;
593 }
594
595 /* Once left & right have converged at m, we have found the median */
596 return m;
597 }
598
599
600
601 void buildHeap (Photon* heap, unsigned long* heapIdx,
602 unsigned long* heapXdi, const float min [3],
603 const float max [3], unsigned long left,
604 unsigned long right, unsigned long root)
605 /* Recursive part of balancePhotons(..). Builds heap from subarray
606 defined by indices left and right. min and max are the minimum resp.
607 maximum photon positions in the array. root is the index of the
608 current subtree's root, which corresponds to the median's 1-based
609 index in the heap. heapIdx are the balanced heap indices. The heap
610 is accessed indirectly through these. heapXdi are the reverse indices
611 from the heap to heapIdx so that heapXdi [heapIdx [i]] = i. */
612 {
613 float maxLeft [3], minRight [3];
614 Photon rootNode;
615 unsigned d;
616
617 /* Choose median for dimension with largest spread and partition
618 accordingly */
619 const float d0 = max [0] - min [0],
620 d1 = max [1] - min [1],
621 d2 = max [2] - min [2];
622 const unsigned char dim = d0 > d1 ? d0 > d2 ? 0 : 2
623 : d1 > d2 ? 1 : 2;
624 const unsigned long median =
625 left == right ? left
626 : medianPartition(heap, heapIdx, heapXdi, left, right, dim);
627
628 /* Place median at root of current subtree. This consists of swapping
629 the median and the root nodes and updating the heap indices */
630 memcpy(&rootNode, heap + heapIdx [median], sizeof(Photon));
631 memcpy(heap + heapIdx [median], heap + root - 1, sizeof(Photon));
632 setPhotonDiscr(rootNode, dim);
633 memcpy(heap + root - 1, &rootNode, sizeof(Photon));
634 heapIdx [heapXdi [root - 1]] = heapIdx [median];
635 heapXdi [heapIdx [median]] = heapXdi [root - 1];
636 heapIdx [median] = root - 1;
637 heapXdi [root - 1] = median;
638
639 /* Update bounds for left and right subtrees and recurse on them */
640 for (d = 0; d <= 2; d++)
641 if (d == dim)
642 maxLeft [d] = minRight [d] = rootNode.pos [d];
643 else {
644 maxLeft [d] = max [d];
645 minRight [d] = min [d];
646 }
647
648 if (left < median)
649 buildHeap(heap, heapIdx, heapXdi, min, maxLeft,
650 left, median - 1, root << 1);
651
652 if (right > median)
653 buildHeap(heap, heapIdx, heapXdi, minRight, max,
654 median + 1, right, (root << 1) + 1);
655 }
656
657
658
659 void balancePhotons (PhotonMap* pmap, double *photonFlux)
660 {
661 Photon *heap = pmap -> heap;
662 unsigned long i;
663 unsigned long *heapIdx; /* Photon index array */
664 unsigned long *heapXdi; /* Reverse index to heapIdx */
665 unsigned j;
666 COLOR flux;
667 /* Need doubles here to reduce errors from increment */
668 double avgFlux [3] = {0, 0, 0}, CoG [3] = {0, 0, 0}, CoGdist = 0;
669 FVECT d;
670
671 if (pmap -> heapEnd) {
672 pmap -> heapSize = pmap -> heapEnd;
673 heapIdx = (unsigned long*)malloc(pmap -> heapSize *
674 sizeof(unsigned long));
675 heapXdi = (unsigned long*)malloc(pmap -> heapSize *
676 sizeof(unsigned long));
677 if (!heapIdx || !heapXdi)
678 error(USER, "can't allocate heap index");
679
680 for (i = 0; i < pmap -> heapSize; i++) {
681 /* Initialize index arrays */
682 heapXdi [i] = heapIdx [i] = i;
683 getPhotonFlux(heap + i, flux);
684
685 /* Scale photon's flux (hitherto normalised to 1 over RGB); in case
686 * of a contrib photon map, this is done per light source, and
687 * photonFlux is assumed to be an array */
688 if (photonFlux) {
689 scalecolor(flux, photonFlux [isContribPmap(pmap) ?
690 photonSrcIdx(pmap, heap + i) : 0]);
691 setPhotonFlux(heap + i, flux);
692 }
693
694 /* Need a double here */
695 addcolor(avgFlux, flux);
696
697 /* Add photon position to centre of gravity */
698 for (j = 0; j < 3; j++)
699 CoG [j] += heap [i].pos [j];
700 }
701
702 /* Average photon positions to get centre of gravity */
703 for (j = 0; j < 3; j++)
704 pmap -> CoG [j] = CoG [j] /= pmap -> heapSize;
705
706 /* Compute average photon distance to CoG */
707 for (i = 0; i < pmap -> heapSize; i++) {
708 VSUB(d, heap [i].pos, CoG);
709 CoGdist += DOT(d, d);
710 }
711
712 pmap -> CoGdist = CoGdist /= pmap -> heapSize;
713
714 /* Average photon flux based on RGBE representation */
715 scalecolor(avgFlux, 1.0 / pmap -> heapSize);
716 copycolor(pmap -> photonFlux, avgFlux);
717
718 /* Build kd-tree */
719 buildHeap(pmap -> heap, heapIdx, heapXdi, pmap -> minPos,
720 pmap -> maxPos, 0, pmap -> heapSize - 1, 1);
721
722 free(heapIdx);
723 free(heapXdi);
724 }
725 }
726
727
728
729 void deletePhotons (PhotonMap* pmap)
730 {
731 free(pmap -> heap);
732 free(pmap -> squeue);
733 free(pmap -> biasCompHist);
734
735 pmap -> heapSize = 0;
736 pmap -> minGather = pmap -> maxGather =
737 pmap -> squeueSize = pmap -> squeueEnd = 0;
738 }
