1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: pmapcontrib.c,v 2.13 2016/09/29 21:51:58 greg Exp $"; |
3 |
#endif |
4 |
5 |
6 |
7 |
Photon map for light source contributions |
8 |
9 |
Roland Schregle (roland.schregle@{hslu.ch, gmail.com}) |
10 |
(c) Lucerne University of Applied Sciences and Arts, |
11 |
supported by the Swiss National Science Foundation (SNSF, #147053) |
12 |
13 |
14 |
$Id: pmapcontrib.c,v 2.13 2016/09/29 21:51:58 greg Exp $ |
15 |
16 |
17 |
18 |
#include "pmapcontrib.h" |
19 |
#include "pmapmat.h" |
20 |
#include "pmapsrc.h" |
21 |
#include "pmaprand.h" |
22 |
#include "pmapio.h" |
23 |
#include "pmapdiag.h" |
24 |
#include "rcontrib.h" |
25 |
#include "otypes.h" |
26 |
#if NIX |
27 |
#include <sys/mman.h> |
28 |
#include <sys/wait.h> |
29 |
#endif |
30 |
31 |
32 |
static PhotonPrimaryIdx newPhotonPrimary (PhotonMap *pmap, |
33 |
const RAY *primRay, |
34 |
FILE *primHeap) |
35 |
/* Add primary ray for emitted photon and save light source index, origin on |
36 |
* source, and emitted direction; used by contrib photons. The current |
37 |
* primary is stored in pmap -> lastPrimary. If the previous primary |
38 |
* contributed photons (has srcIdx >= 0), it's appended to primHeap. If |
39 |
* primRay == NULL, the current primary is still flushed, but no new primary |
40 |
* is set. Returns updated primary counter pmap -> numPrimary. */ |
41 |
42 |
if (!pmap || !primHeap) |
43 |
return 0; |
44 |
45 |
/* Check if last primary ray has spawned photons (srcIdx >= 0, see |
46 |
* newPhoton()), in which case we save it to the primary heap file |
47 |
* before clobbering it */ |
48 |
if (pmap -> lastPrimary.srcIdx >= 0) { |
49 |
if (!fwrite(&pmap -> lastPrimary, sizeof(PhotonPrimary), 1, primHeap)) |
50 |
error(SYSTEM, "failed writing photon primary in newPhotonPrimary"); |
51 |
52 |
pmap -> numPrimary++; |
53 |
if (pmap -> numPrimary > PMAP_MAXPRIMARY) |
54 |
error(INTERNAL, "photon primary overflow in newPhotonPrimary"); |
55 |
56 |
57 |
/* Mark unused with negative source index until path spawns a photon (see |
58 |
* newPhoton()) */ |
59 |
pmap -> lastPrimary.srcIdx = -1; |
60 |
61 |
if (primRay) { |
62 |
FVECT dvec; |
63 |
64 |
/* Reverse incident direction to point to light source */ |
65 |
dvec [0] = -primRay -> rdir [0]; |
66 |
dvec [1] = -primRay -> rdir [1]; |
67 |
dvec [2] = -primRay -> rdir [2]; |
68 |
pmap -> lastPrimary.dir = encodedir(dvec); |
69 |
#ifdef PMAP_PRIMARYPOS |
70 |
VCOPY(pmap -> lastPrimary.pos, primRay -> rop); |
71 |
#endif |
72 |
73 |
74 |
return pmap -> numPrimary; |
75 |
76 |
77 |
78 |
79 |
#ifdef DEBUG_PMAP |
80 |
static int checkPrimaryHeap (FILE *file) |
81 |
/* Check heap for ordered primaries */ |
82 |
83 |
Photon p, lastp; |
84 |
int i, dup; |
85 |
86 |
rewind(file); |
87 |
memset(&lastp, 0, sizeof(lastp)); |
88 |
89 |
while (fread(&p, sizeof(p), 1, file)) { |
90 |
dup = 1; |
91 |
92 |
for (i = 0; i <= 2; i++) { |
93 |
if (p.pos [i] < thescene.cuorg [i] || |
94 |
p.pos [i] > thescene.cuorg [i] + thescene.cusize) { |
95 |
96 |
sprintf(errmsg, "corrupt photon in heap at [%f, %f, %f]\n", |
97 |
p.pos [0], p.pos [1], p.pos [2]); |
98 |
error(WARNING, errmsg); |
99 |
100 |
101 |
dup &= p.pos [i] == lastp.pos [i]; |
102 |
103 |
104 |
if (dup) { |
105 |
sprintf(errmsg, |
106 |
"consecutive duplicate photon in heap at [%f, %f, %f]\n", |
107 |
108 |
109 |
110 |
111 |
112 |
return 0; |
113 |
114 |
#endif |
115 |
116 |
117 |
118 |
static PhotonPrimaryIdx buildPrimaries (PhotonMap *pmap, FILE **primaryHeap, |
119 |
char **primaryHeapFname, |
120 |
PhotonPrimaryIdx *primaryOfs, |
121 |
unsigned numHeaps) |
122 |
/* Consolidate per-subprocess photon primary heaps into the primary array |
123 |
* pmap -> primaries. Returns offset for primary index linearisation in |
124 |
* numPrimary. The heap files in primaryHeap are closed on return. */ |
125 |
126 |
PhotonPrimaryIdx heapLen; |
127 |
unsigned heap; |
128 |
129 |
if (!pmap || !primaryHeap || !primaryOfs || !numHeaps) |
130 |
return 0; |
131 |
132 |
pmap -> numPrimary = 0; |
133 |
134 |
for (heap = 0; heap < numHeaps; heap++) { |
135 |
primaryOfs [heap] = pmap -> numPrimary; |
136 |
137 |
if (fseek(primaryHeap [heap], 0, SEEK_END) < 0) |
138 |
error(SYSTEM, "failed photon primary seek in buildPrimaries"); |
139 |
pmap -> numPrimary += heapLen = ftell(primaryHeap [heap]) / |
140 |
sizeof(PhotonPrimary); |
141 |
142 |
pmap -> primaries = realloc(pmap -> primaries, |
143 |
pmap -> numPrimary * |
144 |
sizeof(PhotonPrimary)); |
145 |
if (!pmap -> primaries) |
146 |
error(SYSTEM, "failed photon primary alloc in buildPrimaries"); |
147 |
148 |
rewind(primaryHeap [heap]); |
149 |
if (fread(pmap -> primaries + primaryOfs [heap], sizeof(PhotonPrimary), |
150 |
heapLen, primaryHeap [heap]) != heapLen) |
151 |
error(SYSTEM, "failed reading photon primaries in buildPrimaries"); |
152 |
153 |
fclose(primaryHeap [heap]); |
154 |
unlink(primaryHeapFname [heap]); |
155 |
156 |
157 |
158 |
159 |
160 |
161 |
162 |
/* Defs for photon emission counter array passed by sub-processes to parent |
163 |
* via shared memory */ |
164 |
typedef unsigned long PhotonContribCnt; |
165 |
166 |
/* Indices for photon emission counter array: num photons stored and num |
167 |
* emitted per source */ |
168 |
#define PHOTONCNT_NUMPHOT 0 |
169 |
#define PHOTONCNT_NUMEMIT(n) (1 + n) |
170 |
171 |
172 |
173 |
void distribPhotonContrib (PhotonMap* pm, unsigned numProc) |
174 |
175 |
EmissionMap emap; |
176 |
char errmsg2 [128], shmFname [PMAP_TMPFNLEN]; |
177 |
unsigned srcIdx, proc; |
178 |
int shmFile, stat, pid; |
179 |
double *srcFlux, /* Emitted flux per light source */ |
180 |
srcDistribTarget; /* Target photon count per source */ |
181 |
PhotonContribCnt *photonCnt; /* Photon emission counter array */ |
182 |
unsigned photonCntSize = sizeof(PhotonContribCnt) * |
183 |
PHOTONCNT_NUMEMIT(nsources); |
184 |
FILE **primaryHeap = NULL; |
185 |
char **primaryHeapFname = NULL; |
186 |
PhotonPrimaryIdx *primaryOfs = NULL; |
187 |
188 |
if (!pm) |
189 |
error(USER, "no photon map defined in distribPhotonContrib"); |
190 |
191 |
if (!nsources) |
192 |
error(USER, "no light sources in distribPhotonContrib"); |
193 |
194 |
if (nsources > MAXMODLIST) |
195 |
error(USER, "too many light sources in distribPhotonContrib"); |
196 |
197 |
/* Allocate photon flux per light source; this differs for every |
198 |
* source as all sources contribute the same number of distributed |
199 |
* photons (srcDistribTarget), hence the number of photons emitted per |
200 |
* source does not correlate with its emitted flux. The resulting flux |
201 |
* per photon is therefore adjusted individually for each source. */ |
202 |
if (!(srcFlux = calloc(nsources, sizeof(double)))) |
203 |
error(SYSTEM, "can't allocate source flux in distribPhotonContrib"); |
204 |
205 |
206 |
* INITIALISATION - Set up emission and scattering funcs |
207 |
208 |
emap.samples = NULL; |
209 |
emap.src = NULL; |
210 |
emap.maxPartitions = MAXSPART; |
211 |
emap.partitions = (unsigned char*)malloc(emap.maxPartitions >> 1); |
212 |
if (!emap.partitions) |
213 |
error(USER, "can't allocate source partitions in distribPhotonContrib"); |
214 |
215 |
/* Initialise contrib photon map */ |
216 |
initPhotonMap(pm, PMAP_TYPE_CONTRIB); |
217 |
initPhotonHeap(pm); |
218 |
initPhotonEmissionFuncs(); |
219 |
initPhotonScatterFuncs(); |
220 |
221 |
/* Per-subprocess / per-source target counts */ |
222 |
pm -> distribTarget /= numProc; |
223 |
srcDistribTarget = nsources ? (double)pm -> distribTarget / nsources : 0; |
224 |
225 |
if (!pm -> distribTarget) |
226 |
error(INTERNAL, "no photons to distribute in distribPhotonContrib"); |
227 |
228 |
/* Get photon ports if specified */ |
229 |
if (ambincl == 1) |
230 |
getPhotonPorts(); |
231 |
232 |
/* Get photon sensor modifiers */ |
233 |
getPhotonSensors(photonSensorList); |
234 |
235 |
#if NIX |
236 |
/* Set up shared mem for photon counters (zeroed by ftruncate) */ |
237 |
strcpy(shmFname, PMAP_TMPFNAME); |
238 |
shmFile = mkstemp(shmFname); |
239 |
240 |
if (shmFile < 0 || ftruncate(shmFile, photonCntSize) < 0) |
241 |
error(SYSTEM, "failed shared mem init in distribPhotonContrib"); |
242 |
243 |
photonCnt = mmap(NULL, photonCntSize, PROT_READ | PROT_WRITE, |
244 |
MAP_SHARED, shmFile, 0); |
245 |
246 |
if (photonCnt == MAP_FAILED) |
247 |
error(SYSTEM, "failed shared mem mapping in distribPhotonContrib"); |
248 |
#else |
249 |
/* Allocate photon counters statically on Windoze */ |
250 |
if (!(photonCnt = malloc(photonCntSize))) |
251 |
error(SYSTEM, "failed trivial malloc in distribPhotonContrib"); |
252 |
253 |
for (srcIdx = 0; srcIdx < PHOTONCNT_NUMEMIT(nsources); srcIdx++) |
254 |
photonCnt [srcIdx] = 0; |
255 |
#endif /* NIX */ |
256 |
257 |
if (verbose) { |
258 |
sprintf(errmsg, "\nIntegrating flux from %d sources", nsources); |
259 |
260 |
if (photonPorts) { |
261 |
sprintf(errmsg2, " via %d ports", numPhotonPorts); |
262 |
strcat(errmsg, errmsg2); |
263 |
264 |
265 |
strcat(errmsg, "\n"); |
266 |
eputs(errmsg); |
267 |
268 |
269 |
270 |
* FLUX INTEGRATION - Get total flux emitted from sources/ports |
271 |
272 |
for (srcIdx = 0; srcIdx < nsources; srcIdx++) { |
273 |
unsigned portCnt = 0; |
274 |
srcFlux [srcIdx] = 0; |
275 |
emap.src = source + srcIdx; |
276 |
277 |
do { /* Need at least one iteration if no ports! */ |
278 |
emap.port = emap.src -> sflags & SDISTANT ? photonPorts + portCnt |
279 |
: NULL; |
280 |
photonPartition [emap.src -> so -> otype] (&emap); |
281 |
282 |
if (verbose) { |
283 |
sprintf(errmsg, "\tIntegrating flux from source %s ", |
284 |
source [srcIdx].so -> oname); |
285 |
286 |
if (emap.port) { |
287 |
sprintf(errmsg2, "via port %s ", |
288 |
photonPorts [portCnt].so -> oname); |
289 |
290 |
291 |
292 |
sprintf(errmsg2, "(%lu partitions)\n", emap.numPartitions); |
293 |
294 |
eputs(errmsg); |
295 |
#if NIX |
296 |
fflush(stderr); |
297 |
#endif |
298 |
299 |
300 |
for (emap.partitionCnt = 0; emap.partitionCnt < emap.numPartitions; |
301 |
emap.partitionCnt++) { |
302 |
initPhotonEmission(&emap, pdfSamples); |
303 |
srcFlux [srcIdx] += colorAvg(emap.partFlux); |
304 |
305 |
306 |
portCnt++; |
307 |
} while (portCnt < numPhotonPorts); |
308 |
309 |
if (srcFlux [srcIdx] < FTINY) { |
310 |
sprintf(errmsg, "source %s has zero emission", |
311 |
312 |
313 |
314 |
315 |
316 |
/* Allocate & init per-subprocess primary heap files */ |
317 |
primaryHeap = calloc(numProc, sizeof(FILE*)); |
318 |
primaryHeapFname = calloc(numProc, sizeof(char*)); |
319 |
primaryOfs = calloc(numProc, sizeof(PhotonPrimaryIdx)); |
320 |
if (!primaryHeap || !primaryHeapFname || !primaryOfs) |
321 |
error(SYSTEM, "failed primary heap allocation in " |
322 |
"distribPhotonContrib"); |
323 |
324 |
for (proc = 0; proc < numProc; proc++) { |
325 |
primaryHeapFname [proc] = malloc(PMAP_TMPFNLEN); |
326 |
if (!primaryHeapFname [proc]) |
327 |
error(SYSTEM, "failed primary heap file allocation in " |
328 |
329 |
330 |
mktemp(strcpy(primaryHeapFname [proc], PMAP_TMPFNAME)); |
331 |
if (!(primaryHeap [proc] = fopen(primaryHeapFname [proc], "w+b"))) |
332 |
error(SYSTEM, "failed opening primary heap file in " |
333 |
334 |
335 |
336 |
/* Record start time for progress reports */ |
337 |
repStartTime = time(NULL); |
338 |
339 |
if (verbose) { |
340 |
sprintf(errmsg, "\nPhoton distribution @ %d procs\n", numProc); |
341 |
eputs(errmsg); |
342 |
343 |
344 |
/* MAIN LOOP */ |
345 |
346 |
#if NIX |
347 |
if (!(pid = fork())) { |
348 |
/* SUBPROCESS ENTERS HERE; opened and mmapped files inherited */ |
349 |
#else |
350 |
if (1) { |
351 |
/* No subprocess under Windoze */ |
352 |
#endif |
353 |
/* Local photon counters for this subprocess */ |
354 |
unsigned long lastNumPhotons = 0, localNumEmitted = 0; |
355 |
double photonFluxSum = 0; /* Accum. photon flux */ |
356 |
357 |
/* Seed RNGs from PID for decorellated photon distribution */ |
358 |
pmapSeed(randSeed + proc, partState); |
359 |
pmapSeed(randSeed + proc, emitState); |
360 |
pmapSeed(randSeed + proc, cntState); |
361 |
pmapSeed(randSeed + proc, mediumState); |
362 |
pmapSeed(randSeed + proc, scatterState); |
363 |
pmapSeed(randSeed + proc, rouletteState); |
364 |
365 |
366 |
* 2-PASS PHOTON DISTRIBUTION |
367 |
* Pass 1 (pre): emit fraction of target photon count |
368 |
* Pass 2 (main): based on outcome of pass 1, estimate remaining |
369 |
* number of photons to emit to approximate target |
370 |
* count |
371 |
372 |
373 |
unsigned portCnt, passCnt = 0, prePassCnt = 0; |
374 |
float srcPreDistrib = preDistrib; |
375 |
double srcNumEmit = 0; /* # to emit from source */ |
376 |
unsigned long srcNumDistrib = pm -> numPhotons; /* # stored */ |
377 |
378 |
if (srcFlux [srcIdx] < FTINY) |
379 |
continue; |
380 |
381 |
while (passCnt < 2) { |
382 |
if (!passCnt) { |
383 |
/* INIT PASS 1 */ |
384 |
if (++prePassCnt > maxPreDistrib && !proc) { |
385 |
/* Warn if no photons contributed after sufficient |
386 |
* iterations; only output from subprocess 0 to reduce |
387 |
* console clutter */ |
388 |
sprintf(errmsg, |
389 |
"source %s: too many prepasses, skipped", |
390 |
391 |
392 |
break; |
393 |
394 |
395 |
/* Num to emit is fraction of target count */ |
396 |
srcNumEmit = srcPreDistrib * srcDistribTarget; |
397 |
398 |
else { |
399 |
/* INIT PASS 2 */ |
400 |
double srcPhotonFlux, avgPhotonFlux; |
401 |
402 |
/* Based on the outcome of the predistribution we can now |
403 |
* figure out how many more photons we have to emit from |
404 |
* the current source to meet the target count, |
405 |
* srcDistribTarget. This value is clamped to 0 in case |
406 |
* the target has already been exceeded in pass 1. |
407 |
* srcNumEmit and srcNumDistrib is the number of photons |
408 |
* emitted and distributed (stored) from the current |
409 |
* source in pass 1, respectively. */ |
410 |
srcNumDistrib = pm -> numPhotons - srcNumDistrib; |
411 |
srcNumEmit *= srcNumDistrib |
412 |
? max(srcDistribTarget/srcNumDistrib, 1) - 1 |
413 |
: 0; |
414 |
415 |
if (!srcNumEmit) |
416 |
/* No photons left to distribute in main pass */ |
417 |
break; |
418 |
419 |
srcPhotonFlux = srcFlux [srcIdx] / srcNumEmit; |
420 |
avgPhotonFlux = photonFluxSum / (srcIdx + 1); |
421 |
422 |
if (avgPhotonFlux > 0 && |
423 |
srcPhotonFlux / avgPhotonFlux < FTINY) { |
424 |
/* Skip source if its photon flux is grossly below the |
425 |
* running average, indicating negligible contributions |
426 |
* at the expense of excessive distribution time; only |
427 |
* output from subproc 0 to reduce console clutter */ |
428 |
sprintf(errmsg, |
429 |
"source %s: itsy bitsy photon flux, skipped", |
430 |
431 |
432 |
srcNumEmit = 0; |
433 |
434 |
435 |
/* Update sum of photon flux per light source */ |
436 |
photonFluxSum += srcPhotonFlux; |
437 |
438 |
439 |
portCnt = 0; |
440 |
441 |
442 |
emap.port = emap.src -> sflags & SDISTANT |
443 |
? photonPorts + portCnt : NULL; |
444 |
445 |
446 |
if (verbose && !proc) { |
447 |
/* Output from subproc 0 only to avoid race condition |
448 |
* on console I/O */ |
449 |
if (!passCnt) |
450 |
sprintf(errmsg, "\tPREPASS %d on source %s ", |
451 |
prePassCnt, source [srcIdx].so -> oname); |
452 |
else |
453 |
sprintf(errmsg, "\tMAIN PASS on source %s ", |
454 |
455 |
456 |
if (emap.port) { |
457 |
458 |
459 |
460 |
461 |
462 |
sprintf(errmsg2, "(%lu partitions)\n", |
463 |
464 |
465 |
eputs(errmsg); |
466 |
#if NIX |
467 |
fflush(stderr); |
468 |
#endif |
469 |
470 |
471 |
472 |
473 |
double partNumEmit; |
474 |
unsigned long partEmitCnt; |
475 |
476 |
/* Get photon origin within current source partishunn |
477 |
* and build emission map */ |
478 |
photonOrigin [emap.src -> so -> otype] (&emap); |
479 |
480 |
481 |
/* Number of photons to emit from ziss partishunn; |
482 |
* scale according to its normalised contribushunn to |
483 |
* the emitted source flux */ |
484 |
partNumEmit = srcNumEmit * colorAvg(emap.partFlux) / |
485 |
srcFlux [srcIdx]; |
486 |
partEmitCnt = (unsigned long)partNumEmit; |
487 |
488 |
/* Probabilistically account for fractional photons */ |
489 |
if (pmapRandom(cntState) < partNumEmit - partEmitCnt) |
490 |
partEmitCnt++; |
491 |
492 |
/* Update local and shared global emission counter */ |
493 |
photonCnt [PHOTONCNT_NUMEMIT(srcIdx)] += partEmitCnt; |
494 |
localNumEmitted += partEmitCnt; |
495 |
496 |
/* Integer counter avoids FP rounding errors during |
497 |
* iteration */ |
498 |
while (partEmitCnt--) { |
499 |
RAY photonRay; |
500 |
501 |
/* Emit photon according to PDF (if any), allocate |
502 |
* associated primary ray, and trace through scene |
503 |
* until absorbed/leaked; emitPhoton() sets the |
504 |
* emitting light source index in photonRay */ |
505 |
emitPhoton(&emap, &photonRay); |
506 |
#if 1 |
507 |
if (emap.port) |
508 |
/* !!! PHOTON PORT REJECTION SAMPLING HACK: set |
509 |
* !!! photon port as fake hit object for |
510 |
* !!! primary ray to check for intersection in |
511 |
* !!! tracePhoton() */ |
512 |
photonRay.ro = emap.port -> so; |
513 |
#endif |
514 |
newPhotonPrimary(pm, &photonRay, primaryHeap[proc]); |
515 |
/* Set subprocess index in photonRay for post- |
516 |
* distrib primary index linearisation; this is |
517 |
* propagated with the primary index in photonRay |
518 |
* and set for photon hits by newPhoton() */ |
519 |
PMAP_SETRAYPROC(&photonRay, proc); |
520 |
tracePhoton(&photonRay); |
521 |
522 |
523 |
/* Update shared global photon count */ |
524 |
photonCnt [PHOTONCNT_NUMPHOT] += pm -> numPhotons - |
525 |
lastNumPhotons; |
526 |
lastNumPhotons = pm -> numPhotons; |
527 |
#if !NIX |
528 |
/* Synchronous progress report on Windoze */ |
529 |
if (!proc && photonRepTime > 0 && |
530 |
time(NULL) >= repLastTime + photonRepTime) { |
531 |
unsigned s; |
532 |
repComplete = pm -> distribTarget * numProc; |
533 |
repProgress = photonCnt [PHOTONCNT_NUMPHOT]; |
534 |
535 |
for (repEmitted = 0, s = 0; s < nsources; s++) |
536 |
repEmitted += photonCnt [PHOTONCNT_NUMEMIT(s)]; |
537 |
538 |
pmapDistribReport(); |
539 |
540 |
#endif |
541 |
542 |
543 |
portCnt++; |
544 |
545 |
546 |
if (pm -> numPhotons == srcNumDistrib) { |
547 |
/* Double predistrib factor in case no photons were stored |
548 |
* for this source and redo pass 1 */ |
549 |
srcPreDistrib *= 2; |
550 |
551 |
else { |
552 |
/* Now do pass 2 */ |
553 |
passCnt++; |
554 |
555 |
556 |
557 |
558 |
/* Flush heap buffa one final time to prevent data corruption */ |
559 |
flushPhotonHeap(pm); |
560 |
/* Flush final photon primary to primary heap file */ |
561 |
newPhotonPrimary(pm, NULL, primaryHeap [proc]); |
562 |
/* Heap files closed automatically on exit |
563 |
fclose(pm -> heap); |
564 |
fclose(primaryHeap [proc]); */ |
565 |
566 |
#ifdef DEBUG_PMAP |
567 |
sprintf(errmsg, "Proc %d total %ld photons\n", proc, |
568 |
pm -> numPhotons); |
569 |
eputs(errmsg); |
570 |
fflush(stderr); |
571 |
#endif |
572 |
573 |
#if NIX |
574 |
/* Terminate subprocess */ |
575 |
exit(0); |
576 |
#endif |
577 |
578 |
else if (pid < 0) |
579 |
error(SYSTEM, "failed to fork subprocess in distribPhotonContrib"); |
580 |
581 |
582 |
#if NIX |
583 |
/* PARENT PROCESS CONTINUES HERE */ |
584 |
#ifdef SIGCONT |
585 |
/* Enable progress report signal handler */ |
586 |
signal(SIGCONT, pmapDistribReport); |
587 |
#endif |
588 |
/* Wait for subprocesses to complete while reporting progress */ |
589 |
proc = numProc; |
590 |
while (proc) { |
591 |
while (waitpid(-1, &stat, WNOHANG) > 0) { |
592 |
/* Subprocess exited; check status */ |
593 |
if (!WIFEXITED(stat) || WEXITSTATUS(stat)) |
594 |
error(USER, "failed photon distribution"); |
595 |
596 |
--proc; |
597 |
598 |
599 |
/* Nod off for a bit and update progress */ |
600 |
sleep(1); |
601 |
602 |
/* Asynchronous progress report from shared subprocess counters */ |
603 |
604 |
605 |
606 |
for (repEmitted = 0, srcIdx = 0; srcIdx < nsources; srcIdx++) |
607 |
repEmitted += photonCnt [PHOTONCNT_NUMEMIT(srcIdx)]; |
608 |
609 |
/* Get global photon count from shmem updated by subprocs */ |
610 |
pm -> numPhotons = photonCnt [PHOTONCNT_NUMPHOT]; |
611 |
612 |
if (photonRepTime > 0 && time(NULL) >= repLastTime + photonRepTime) |
613 |
614 |
#ifdef SIGCONT |
615 |
else signal(SIGCONT, pmapDistribReport); |
616 |
#endif |
617 |
618 |
#endif /* NIX */ |
619 |
620 |
621 |
* POST-DISTRIBUTION - Set photon flux and build kd-tree, etc. |
622 |
623 |
#ifdef SIGCONT |
624 |
/* Reset signal handler */ |
625 |
signal(SIGCONT, SIG_DFL); |
626 |
#endif |
627 |
free(emap.samples); |
628 |
629 |
if (!pm -> numPhotons) |
630 |
error(USER, "empty contribution photon map"); |
631 |
632 |
/* Load per-subprocess primary rays into pm -> primary array */ |
633 |
/* Dumb compilers apparently need the char** cast */ |
634 |
pm -> numPrimary = buildPrimaries(pm, primaryHeap, |
635 |
(char**)primaryHeapFname, |
636 |
primaryOfs, numProc); |
637 |
if (!pm -> numPrimary) |
638 |
error(INTERNAL, "no primary rays in contribution photon map"); |
639 |
640 |
/* Set photon flux per source */ |
641 |
for (srcIdx = 0; srcIdx < nsources; srcIdx++) |
642 |
srcFlux [srcIdx] /= photonCnt [PHOTONCNT_NUMEMIT(srcIdx)]; |
643 |
#if NIX |
644 |
/* Photon counters no longer needed, unmap shared memory */ |
645 |
munmap(photonCnt, sizeof(*photonCnt)); |
646 |
close(shmFile); |
647 |
unlink(shmFname); |
648 |
#else |
649 |
free(photonCnt); |
650 |
#endif |
651 |
652 |
if (verbose) { |
653 |
eputs("\nBuilding contribution photon map...\n"); |
654 |
#if NIX |
655 |
fflush(stderr); |
656 |
#endif |
657 |
658 |
659 |
/* Build underlying data structure; heap is destroyed */ |
660 |
buildPhotonMap(pm, srcFlux, primaryOfs, numProc); |
661 |
662 |
/* Free per-subprocess primary heap files */ |
663 |
for (proc = 0; proc < numProc; proc++) |
664 |
free(primaryHeapFname [proc]); |
665 |
666 |
free(primaryHeapFname); |
667 |
free(primaryHeap); |
668 |
free(primaryOfs); |
669 |
670 |
if (verbose) |
671 |
eputs("\n"); |
672 |
