1 |
2 |
3 |
Photon map support for light source contributions |
4 |
5 |
Roland Schregle (roland.schregle@{hslu.ch, gmail.com}) |
6 |
(c) Fraunhofer Institute for Solar Energy Systems, |
7 |
Lucerne University of Applied Sciences & Arts |
8 |
9 |
10 |
$Id: pmapcontrib.c,v 2.2 2015/04/21 19:16:51 greg Exp $ |
11 |
12 |
13 |
14 |
#include "pmapcontrib.h" |
15 |
#include "pmap.h" |
16 |
#include "pmapmat.h" |
17 |
#include "pmapsrc.h" |
18 |
#include "pmaprand.h" |
19 |
#include "pmapio.h" |
20 |
#include "pmapdiag.h" |
21 |
#include "rcontrib.h" |
22 |
#include "otypes.h" |
23 |
24 |
25 |
26 |
extern int contrib; /* coeff/contrib flag */ |
27 |
28 |
29 |
30 |
static void setPmapContribParams (PhotonMap *pmap, LUTAB *srcContrib) |
31 |
/* Set parameters for light source contributions */ |
32 |
33 |
/* Set light source modifier list and appropriate callback to extract |
34 |
* their contributions from the photon map */ |
35 |
if (pmap) { |
36 |
pmap -> srcContrib = srcContrib; |
37 |
pmap -> lookup = photonContrib; |
38 |
/* Ensure we get all requested photon contribs during lookups */ |
39 |
pmap -> gatherTolerance = 1.0; |
40 |
41 |
42 |
43 |
44 |
45 |
static void checkPmapContribs (const PhotonMap *pmap, LUTAB *srcContrib) |
46 |
/* Check modifiers for light source contributions */ |
47 |
48 |
const PhotonPrimary *primary = pmap -> primary; |
49 |
OBJREC *srcMod; |
50 |
unsigned long i, found = 0; |
51 |
52 |
/* Make sure at least one of the modifiers is actually in the pmap, |
53 |
* otherwise findPhotons() winds up in an infinite loop! */ |
54 |
for (i = pmap -> primarySize; i; --i, ++primary) { |
55 |
if (primary -> srcIdx < 0 || primary -> srcIdx >= nsources) |
56 |
error(INTERNAL, "invalid light source index in photon map"); |
57 |
58 |
srcMod = objptr(source [primary -> srcIdx].so -> omod); |
59 |
if ((MODCONT*)lu_find(srcContrib, srcMod -> oname) -> data) |
60 |
++found; |
61 |
62 |
63 |
if (!found) |
64 |
error(USER, "modifiers not in photon map"); |
65 |
66 |
67 |
68 |
69 |
void initPmapContrib (LUTAB *srcContrib, unsigned numSrcContrib) |
70 |
71 |
unsigned t; |
72 |
73 |
for (t = 0; t < NUM_PMAP_TYPES; t++) |
74 |
if (photonMaps [t] && t != PMAP_TYPE_CONTRIB) { |
75 |
sprintf(errmsg, "%s photon map does not support contributions", |
76 |
pmapName [t]); |
77 |
error(USER, errmsg); |
78 |
79 |
80 |
/* Get params */ |
81 |
setPmapContribParams(contribPmap, srcContrib); |
82 |
83 |
if (contribPhotonMapping) { |
84 |
if (contribPmap -> maxGather < numSrcContrib) { |
85 |
/* Adjust density estimate bandwidth if lower than modifier |
86 |
* count, otherwise contributions are missing */ |
87 |
error(WARNING, "contrib density estimate bandwidth too low, " |
88 |
"adjusting to modifier count"); |
89 |
contribPmap -> maxGather = numSrcContrib; |
90 |
91 |
92 |
/* Sanity check */ |
93 |
checkPmapContribs(contribPmap, srcContrib); |
94 |
95 |
96 |
97 |
98 |
99 |
void photonContrib (PhotonMap *pmap, RAY *ray, COLOR irrad) |
100 |
/* Sum up light source contributions from photons in pmap->srcContrib */ |
101 |
102 |
unsigned i; |
103 |
PhotonSQNode *sq; |
104 |
float r, invArea; |
105 |
RREAL rayCoeff [3]; |
106 |
FVECT rdir, rop; |
107 |
108 |
setcolor(irrad, 0, 0, 0); |
109 |
110 |
if (!pmap -> maxGather) |
111 |
return; |
112 |
113 |
/* Ignore sources */ |
114 |
if (ray -> ro) |
115 |
if (islight(objptr(ray -> ro -> omod) -> otype)) |
116 |
return; |
117 |
118 |
/* Set context for binning function evaluation and get cumulative path |
119 |
* coefficient up to photon lookup point */ |
120 |
worldfunc(RCCONTEXT, ray); |
121 |
raycontrib(rayCoeff, ray, PRIMARY); |
122 |
123 |
/* Save incident ray's direction and hitpoint */ |
124 |
VCOPY(rdir, ray -> rdir); |
125 |
VCOPY(rop, ray -> rop); |
126 |
127 |
/* Lookup photons */ |
128 |
pmap -> squeueEnd = 0; |
129 |
findPhotons(pmap, ray); |
130 |
131 |
/* Need at least 2 photons */ |
132 |
if (pmap -> squeueEnd < 2) { |
133 |
#ifdef PMAP_NONEFOUND |
134 |
sprintf(errmsg, "no photons found on %s at (%.3f, %.3f, %.3f)", |
135 |
ray -> ro ? ray -> ro -> oname : "<null>", |
136 |
ray -> rop [0], ray -> rop [1], ray -> rop [2]); |
137 |
error(WARNING, errmsg); |
138 |
#endif |
139 |
140 |
return; |
141 |
142 |
143 |
/* Average (squared) radius between furthest two photons to improve |
144 |
* accuracy and get inverse search area 1 / (PI * r^2), with extra |
145 |
* normalisation factor 1 / PI for ambient calculation */ |
146 |
sq = pmap -> squeue + 1; |
147 |
r = max(sq -> dist, (sq + 1) -> dist); |
148 |
r = 0.25 * (pmap -> maxDist + r + 2 * sqrt(pmap -> maxDist * r)); |
149 |
invArea = 1 / (PI * PI * r); |
150 |
151 |
/* Skip the extra photon */ |
152 |
for (i = 1 ; i < pmap -> squeueEnd; i++, sq++) { |
153 |
COLOR flux; |
154 |
155 |
/* Get photon's contribution to density estimate */ |
156 |
getPhotonFlux(sq -> photon, flux); |
157 |
scalecolor(flux, invArea); |
158 |
#ifdef PMAP_EPANECHNIKOV |
159 |
/* Apply Epanechnikov kernel to photon flux (dists are squared) */ |
160 |
scalecolor(flux, 2 * (1 - sq -> dist / r)); |
161 |
#endif |
162 |
addcolor(irrad, flux); |
163 |
164 |
if (pmap -> srcContrib) { |
165 |
const PhotonPrimary *primary = pmap -> primary + |
166 |
sq -> photon -> primary; |
167 |
OBJREC *srcMod = objptr(source [primary -> srcIdx].so -> omod); |
168 |
MODCONT *srcContrib = (MODCONT*)lu_find(pmap -> srcContrib, |
169 |
srcMod -> oname) -> data; |
170 |
171 |
if (srcContrib) { |
172 |
/* Photon's emitting light source has modifier whose |
173 |
* contributions are sought */ |
174 |
int srcBin; |
175 |
176 |
/* Set incident dir and origin of photon's primary ray on |
177 |
* light source for dummy shadow ray, and evaluate binning |
178 |
* function */ |
179 |
VCOPY(ray -> rdir, primary -> dir); |
180 |
VCOPY(ray -> rop, primary -> org); |
181 |
srcBin = evalue(srcContrib -> binv) + .5; |
182 |
183 |
if (srcBin < 0 || srcBin >= srcContrib -> nbins) { |
184 |
error(WARNING, "bad bin number (ignored)"); |
185 |
continue; |
186 |
187 |
188 |
if (!contrib) { |
189 |
/* Ray coefficient mode; normalise by light source radiance |
190 |
* after applying distrib pattern */ |
191 |
int j; |
192 |
raytexture(ray, srcMod -> omod); |
193 |
setcolor(ray -> rcol, srcMod -> oargs.farg [0], |
194 |
srcMod -> oargs.farg [1], srcMod -> oargs.farg [2]); |
195 |
multcolor(ray -> rcol, ray -> pcol); |
196 |
for (j = 0; j < 3; j++) |
197 |
flux [j] = ray -> rcol [j] ? flux [j] / ray -> rcol [j] |
198 |
: 0; |
199 |
200 |
201 |
multcolor(flux, rayCoeff); |
202 |
addcolor(srcContrib -> cbin [srcBin], flux); |
203 |
204 |
else fprintf(stderr, "Skipped contrib from %s\n", srcMod -> oname); |
205 |
206 |
207 |
208 |
/* Restore incident ray's direction and hitpoint */ |
209 |
VCOPY(ray -> rdir, rdir); |
210 |
VCOPY(ray -> rop, rop); |
211 |
212 |
return; |
213 |
214 |
215 |
216 |
217 |
void distribPhotonContrib (PhotonMap* pm) |
218 |
219 |
EmissionMap emap; |
220 |
char errmsg2 [128]; |
221 |
unsigned srcIdx; |
222 |
double *srcFlux; /* Emitted flux per light source */ |
223 |
const double srcDistribTarget = /* Target photon count per source */ |
224 |
nsources ? (double)pm -> distribTarget / nsources : 0; |
225 |
226 |
if (!pm) |
227 |
error(USER, "no photon map defined"); |
228 |
229 |
if (!nsources) |
230 |
error(USER, "no light sources"); |
231 |
232 |
/* Allocate photon flux per light source; this differs for every |
233 |
* source as all sources contribute the same number of distributed |
234 |
* photons (srcDistribTarget), hence the number of photons emitted per |
235 |
* source does not correlate with its emitted flux. The resulting flux |
236 |
* per photon is therefore adjusted individually for each source. */ |
237 |
if (!(srcFlux = calloc(nsources, sizeof(double)))) |
238 |
error(SYSTEM, "cannot allocate source flux"); |
239 |
240 |
241 |
* INITIALISASHUNN - Set up emisshunn and scattering funcs |
242 |
243 |
emap.samples = NULL; |
244 |
emap.src = NULL; |
245 |
emap.maxPartitions = MAXSPART; |
246 |
emap.partitions = (unsigned char*)malloc(emap.maxPartitions >> 1); |
247 |
if (!emap.partitions) |
248 |
error(USER, "can't allocate source partitions"); |
249 |
250 |
initPhotonMap(pm, PMAP_TYPE_CONTRIB); |
251 |
initPhotonEmissionFuncs(); |
252 |
initPhotonScatterFuncs(); |
253 |
254 |
/* Get photon ports if specified */ |
255 |
if (ambincl == 1) |
256 |
getPhotonPorts(); |
257 |
258 |
/* Get photon sensor modifiers */ |
259 |
getPhotonSensors(photonSensorList); |
260 |
261 |
/* Seed RNGs for photon distribution */ |
262 |
pmapSeed(randSeed, partState); |
263 |
pmapSeed(randSeed, emitState); |
264 |
pmapSeed(randSeed, cntState); |
265 |
pmapSeed(randSeed, mediumState); |
266 |
pmapSeed(randSeed, scatterState); |
267 |
pmapSeed(randSeed, rouletteState); |
268 |
269 |
/* Record start time and enable progress report signal handler */ |
270 |
repStartTime = time(NULL); |
271 |
#ifdef SIGCONT |
272 |
signal(SIGCONT, pmapDistribReport); |
273 |
#endif |
274 |
275 |
for (srcIdx = 0; srcIdx < nsources; srcIdx++) { |
276 |
unsigned portCnt = 0, passCnt = 0, prePassCnt = 0; |
277 |
double srcNumEmit = 0; /* # photons to emit from source */ |
278 |
unsigned long srcNumDistrib = pm -> heapEnd; /* # photons stored */ |
279 |
280 |
srcFlux [srcIdx] = repProgress = 0; |
281 |
emap.src = source + srcIdx; |
282 |
283 |
if (photonRepTime) |
284 |
eputs("\n"); |
285 |
286 |
287 |
* FLUX INTEGRATION - Get total flux emitted from light source |
288 |
289 |
do { |
290 |
emap.port = emap.src -> sflags & SDISTANT |
291 |
? photonPorts + portCnt : NULL; |
292 |
photonPartition [emap.src -> so -> otype] (&emap); |
293 |
294 |
if (photonRepTime) { |
295 |
sprintf(errmsg, "Integrating flux from source %s (mod %s) ", |
296 |
source [srcIdx].so -> oname, |
297 |
objptr(source [srcIdx].so -> omod) -> oname); |
298 |
299 |
if (emap.port) { |
300 |
sprintf(errmsg2, "via port %s ", |
301 |
photonPorts [portCnt].so -> oname); |
302 |
strcat(errmsg, errmsg2); |
303 |
304 |
305 |
sprintf(errmsg2, "(%lu partitions)...\n", |
306 |
emap.numPartitions); |
307 |
308 |
eputs(errmsg); |
309 |
fflush(stderr); |
310 |
311 |
312 |
for (emap.partitionCnt = 0; |
313 |
emap.partitionCnt < emap.numPartitions; |
314 |
emap.partitionCnt++) { |
315 |
initPhotonEmission(&emap, pdfSamples); |
316 |
srcFlux [srcIdx] += colorAvg(emap.partFlux); |
317 |
318 |
319 |
portCnt++; |
320 |
} while (portCnt < numPhotonPorts); |
321 |
322 |
if (srcFlux [srcIdx] < FTINY) { |
323 |
sprintf(errmsg, "source %s has zero emission", |
324 |
source [srcIdx].so -> oname); |
325 |
326 |
327 |
else { |
328 |
329 |
* 2-PASS PHOTON DISTRIBUTION |
330 |
* Pass 1 (pre): emit fraction of target photon count |
331 |
* Pass 2 (main): based on outcome of pass 1, estimate |
332 |
* remaining number of photons to emit to |
333 |
* approximate target count |
334 |
335 |
do { |
336 |
if (!passCnt) { |
337 |
/* INIT PASS 1 */ |
338 |
if (++prePassCnt > maxPreDistrib) { |
339 |
/* Warn if no photons contributed after sufficient |
340 |
* iterations */ |
341 |
sprintf(errmsg, "too many prepasses, no photons " |
342 |
"from source %s", source [srcIdx].so -> oname); |
343 |
344 |
break; |
345 |
346 |
347 |
/* Num to emit is fraction of target count */ |
348 |
srcNumEmit = preDistrib * srcDistribTarget; |
349 |
350 |
351 |
else { |
352 |
/* INIT PASS 2 */ |
353 |
/* Based on the outcome of the predistribution we can now |
354 |
* figure out how many more photons we have to emit from |
355 |
* the current source to meet the target count, |
356 |
* srcDistribTarget. This value is clamped to 0 in case |
357 |
* the target has already been exceeded in pass 1. |
358 |
* srcNumEmit and srcNumDistrib is the number of photons |
359 |
* emitted and distributed (stored) from the current |
360 |
* source in pass 1, respectively. */ |
361 |
srcNumDistrib = pm -> heapEnd - srcNumDistrib; |
362 |
srcNumEmit *= srcNumDistrib |
363 |
? max(srcDistribTarget/srcNumDistrib, 1) - 1 |
364 |
: 0; |
365 |
366 |
if (!srcNumEmit) |
367 |
/* No photons left to distribute in main pass */ |
368 |
break; |
369 |
370 |
371 |
/* Set completion count for progress report */ |
372 |
repComplete = srcNumEmit + repProgress; |
373 |
portCnt = 0; |
374 |
375 |
do { |
376 |
377 |
378 |
379 |
380 |
381 |
if (!passCnt) |
382 |
sprintf(errmsg, "PREPASS %d on source %s (mod %s) ", |
383 |
prePassCnt, source [srcIdx].so -> oname, |
384 |
objptr(source[srcIdx].so->omod) -> oname); |
385 |
else |
386 |
sprintf(errmsg, "MAIN PASS on source %s (mod %s) ", |
387 |
388 |
389 |
390 |
if (emap.port) { |
391 |
392 |
393 |
394 |
395 |
396 |
397 |
398 |
399 |
eputs(errmsg); |
400 |
fflush(stderr); |
401 |
402 |
403 |
404 |
405 |
406 |
double partNumEmit; |
407 |
unsigned long partEmitCnt; |
408 |
409 |
/* Get photon origin within current source partishunn |
410 |
* and build emission map */ |
411 |
photonOrigin [emap.src -> so -> otype] (&emap); |
412 |
413 |
414 |
/* Number of photons to emit from ziss partishunn; |
415 |
* scale according to its normalised contribushunn to |
416 |
* the emitted source flux */ |
417 |
partNumEmit = srcNumEmit * colorAvg(emap.partFlux) / |
418 |
srcFlux [srcIdx]; |
419 |
partEmitCnt = (unsigned long)partNumEmit; |
420 |
421 |
/* Probabilistically account for fractional photons */ |
422 |
if (pmapRandom(cntState) < partNumEmit - partEmitCnt) |
423 |
partEmitCnt++; |
424 |
425 |
/* Integer counter avoids FP rounding errors */ |
426 |
while (partEmitCnt--) { |
427 |
RAY photonRay; |
428 |
429 |
/* Emit photon according to PDF (if any), allocate |
430 |
* associated primary ray, and trace through scene |
431 |
* until absorbed/leaked */ |
432 |
emitPhoton(&emap, &photonRay); |
433 |
addPhotonPrimary(pm, &photonRay); |
434 |
tracePhoton(&photonRay); |
435 |
436 |
/* Record progress */ |
437 |
repProgress++; |
438 |
439 |
if (photonRepTime > 0 && |
440 |
time(NULL) >= repLastTime + photonRepTime) |
441 |
pmapDistribReport(); |
442 |
#ifdef SIGCONT |
443 |
else signal(SIGCONT, pmapDistribReport); |
444 |
#endif |
445 |
446 |
447 |
448 |
portCnt++; |
449 |
450 |
451 |
if (pm -> heapEnd == srcNumDistrib) |
452 |
/* Double preDistrib in case no photons were stored |
453 |
* for this source and redo pass 1 */ |
454 |
preDistrib *= 2; |
455 |
else { |
456 |
/* Now do pass 2 */ |
457 |
passCnt++; |
458 |
459 |
eputs("\n"); |
460 |
461 |
} while (passCnt < 2); |
462 |
463 |
/* Flux per photon emitted from this source; repProgress is the |
464 |
* number of emitted photons after both passes */ |
465 |
srcFlux [srcIdx] = repProgress ? srcFlux [srcIdx] / repProgress |
466 |
: 0; |
467 |
468 |
469 |
470 |
471 |
* POST-DISTRIBUTION - Set photon flux and build kd-tree, etc. |
472 |
473 |
#ifdef SIGCONT |
474 |
signal(SIGCONT, SIG_DFL); |
475 |
#endif |
476 |
free(emap.samples); |
477 |
478 |
if (!pm -> heapEnd) |
479 |
error(USER, "empty photon map"); |
480 |
481 |
/* Check for valid primary photon rays */ |
482 |
if (!pm -> primary) |
483 |
error(INTERNAL, "no primary rays in contribution photon map"); |
484 |
485 |
if (pm -> primary [pm -> primaryEnd].srcIdx < 0) |
486 |
/* Last primary ray is unused, so decrement counter */ |
487 |
pm -> primaryEnd--; |
488 |
489 |
490 |
eputs("\nBuilding contrib photon heap...\n"); |
491 |
fflush(stderr); |
492 |
493 |
494 |
balancePhotons(pm, srcFlux); |
495 |
