root/radiance/ray/src/rt/pmapcontrib.c
Revision: 2.3
Committed: Wed Apr 22 20:28:16 2015 UTC (10 years, 1 month ago) by rschregle
Changes since 2.2: +8 -4 lines
Disabled use of SIGCONT if undefined (e.g. on WIN32), removed extra space in
rpict reports after biascomp stats
1 /*
2 ==================================================================
3 Photon map support for light source contributions
4
5 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
6 (c) Fraunhofer Institute for Solar Energy Systems,
7 Lucerne University of Applied Sciences & Arts
8 ==================================================================
9
10 $Id: pmapcontrib.c,v 2.2 2015/04/21 19:16:51 greg Exp $
11 */
12
13
14 #include "pmapcontrib.h"
15 #include "pmap.h"
16 #include "pmapmat.h"
17 #include "pmapsrc.h"
18 #include "pmaprand.h"
19 #include "pmapio.h"
20 #include "pmapdiag.h"
21 #include "rcontrib.h"
22 #include "otypes.h"
23
24
25
26 extern int contrib; /* coeff/contrib flag */
27
28
29
30 static void setPmapContribParams (PhotonMap *pmap, LUTAB *srcContrib)
31 /* Set parameters for light source contributions */
32 {
33 /* Set light source modifier list and appropriate callback to extract
34 * their contributions from the photon map */
35 if (pmap) {
36 pmap -> srcContrib = srcContrib;
37 pmap -> lookup = photonContrib;
38 /* Ensure we get all requested photon contribs during lookups */
39 pmap -> gatherTolerance = 1.0;
40 }
41 }
42
43
44
45 static void checkPmapContribs (const PhotonMap *pmap, LUTAB *srcContrib)
46 /* Check modifiers for light source contributions */
47 {
48 const PhotonPrimary *primary = pmap -> primary;
49 OBJREC *srcMod;
50 unsigned long i, found = 0;
51
52 /* Make sure at least one of the modifiers is actually in the pmap,
53 * otherwise findPhotons() winds up in an infinite loop! */
54 for (i = pmap -> primarySize; i; --i, ++primary) {
55 if (primary -> srcIdx < 0 || primary -> srcIdx >= nsources)
56 error(INTERNAL, "invalid light source index in photon map");
57
58 srcMod = objptr(source [primary -> srcIdx].so -> omod);
59 if ((MODCONT*)lu_find(srcContrib, srcMod -> oname) -> data)
60 ++found;
61 }
62
63 if (!found)
64 error(USER, "modifiers not in photon map");
65 }
66
67
68
69 void initPmapContrib (LUTAB *srcContrib, unsigned numSrcContrib)
70 {
71 unsigned t;
72
73 for (t = 0; t < NUM_PMAP_TYPES; t++)
74 if (photonMaps [t] && t != PMAP_TYPE_CONTRIB) {
75 sprintf(errmsg, "%s photon map does not support contributions",
76 pmapName [t]);
77 error(USER, errmsg);
78 }
79
80 /* Get params */
81 setPmapContribParams(contribPmap, srcContrib);
82
83 if (contribPhotonMapping) {
84 if (contribPmap -> maxGather < numSrcContrib) {
85 /* Adjust density estimate bandwidth if lower than modifier
86 * count, otherwise contributions are missing */
87 error(WARNING, "contrib density estimate bandwidth too low, "
88 "adjusting to modifier count");
89 contribPmap -> maxGather = numSrcContrib;
90 }
91
92 /* Sanity check */
93 checkPmapContribs(contribPmap, srcContrib);
94 }
95 }
96
97
98
99 void photonContrib (PhotonMap *pmap, RAY *ray, COLOR irrad)
100 /* Sum up light source contributions from photons in pmap->srcContrib */
101 {
102 unsigned i;
103 PhotonSQNode *sq;
104 float r, invArea;
105 RREAL rayCoeff [3];
106 FVECT rdir, rop;
107
108 setcolor(irrad, 0, 0, 0);
109
110 if (!pmap -> maxGather)
111 return;
112
113 /* Ignore sources */
114 if (ray -> ro)
115 if (islight(objptr(ray -> ro -> omod) -> otype))
116 return;
117
118 /* Set context for binning function evaluation and get cumulative path
119 * coefficient up to photon lookup point */
120 worldfunc(RCCONTEXT, ray);
121 raycontrib(rayCoeff, ray, PRIMARY);
122
123 /* Save incident ray's direction and hitpoint */
124 VCOPY(rdir, ray -> rdir);
125 VCOPY(rop, ray -> rop);
126
127 /* Lookup photons */
128 pmap -> squeueEnd = 0;
129 findPhotons(pmap, ray);
130
131 /* Need at least 2 photons */
132 if (pmap -> squeueEnd < 2) {
133 #ifdef PMAP_NONEFOUND
134 sprintf(errmsg, "no photons found on %s at (%.3f, %.3f, %.3f)",
135 ray -> ro ? ray -> ro -> oname : "<null>",
136 ray -> rop [0], ray -> rop [1], ray -> rop [2]);
137 error(WARNING, errmsg);
138 #endif
139
140 return;
141 }
142
143 /* Average (squared) radius between furthest two photons to improve
144 * accuracy and get inverse search area 1 / (PI * r^2), with extra
145 * normalisation factor 1 / PI for ambient calculation */
146 sq = pmap -> squeue + 1;
147 r = max(sq -> dist, (sq + 1) -> dist);
148 r = 0.25 * (pmap -> maxDist + r + 2 * sqrt(pmap -> maxDist * r));
149 invArea = 1 / (PI * PI * r);
150
151 /* Skip the extra photon */
152 for (i = 1 ; i < pmap -> squeueEnd; i++, sq++) {
153 COLOR flux;
154
155 /* Get photon's contribution to density estimate */
156 getPhotonFlux(sq -> photon, flux);
157 scalecolor(flux, invArea);
158 #ifdef PMAP_EPANECHNIKOV
159 /* Apply Epanechnikov kernel to photon flux (dists are squared) */
160 scalecolor(flux, 2 * (1 - sq -> dist / r));
161 #endif
162 addcolor(irrad, flux);
163
164 if (pmap -> srcContrib) {
165 const PhotonPrimary *primary = pmap -> primary +
166 sq -> photon -> primary;
167 OBJREC *srcMod = objptr(source [primary -> srcIdx].so -> omod);
168 MODCONT *srcContrib = (MODCONT*)lu_find(pmap -> srcContrib,
169 srcMod -> oname) -> data;
170
171 if (srcContrib) {
172 /* Photon's emitting light source has modifier whose
173 * contributions are sought */
174 int srcBin;
175
176 /* Set incident dir and origin of photon's primary ray on
177 * light source for dummy shadow ray, and evaluate binning
178 * function */
179 VCOPY(ray -> rdir, primary -> dir);
180 VCOPY(ray -> rop, primary -> org);
181 srcBin = evalue(srcContrib -> binv) + .5;
182
183 if (srcBin < 0 || srcBin >= srcContrib -> nbins) {
184 error(WARNING, "bad bin number (ignored)");
185 continue;
186 }
187
188 if (!contrib) {
189 /* Ray coefficient mode; normalise by light source radiance
190 * after applying distrib pattern */
191 int j;
192 raytexture(ray, srcMod -> omod);
193 setcolor(ray -> rcol, srcMod -> oargs.farg [0],
194 srcMod -> oargs.farg [1], srcMod -> oargs.farg [2]);
195 multcolor(ray -> rcol, ray -> pcol);
196 for (j = 0; j < 3; j++)
197 flux [j] = ray -> rcol [j] ? flux [j] / ray -> rcol [j]
198 : 0;
199 }
200
201 multcolor(flux, rayCoeff);
202 addcolor(srcContrib -> cbin [srcBin], flux);
203 }
204 else fprintf(stderr, "Skipped contrib from %s\n", srcMod -> oname);
205 }
206 }
207
208 /* Restore incident ray's direction and hitpoint */
209 VCOPY(ray -> rdir, rdir);
210 VCOPY(ray -> rop, rop);
211
212 return;
213 }
214
215
216
217 void distribPhotonContrib (PhotonMap* pm)
218 {
219 EmissionMap emap;
220 char errmsg2 [128];
221 unsigned srcIdx;
222 double *srcFlux; /* Emitted flux per light source */
223 const double srcDistribTarget = /* Target photon count per source */
224 nsources ? (double)pm -> distribTarget / nsources : 0;
225
226 if (!pm)
227 error(USER, "no photon map defined");
228
229 if (!nsources)
230 error(USER, "no light sources");
231
232 /* Allocate photon flux per light source; this differs for every
233 * source as all sources contribute the same number of distributed
234 * photons (srcDistribTarget), hence the number of photons emitted per
235 * source does not correlate with its emitted flux. The resulting flux
236 * per photon is therefore adjusted individually for each source. */
237 if (!(srcFlux = calloc(nsources, sizeof(double))))
238 error(SYSTEM, "cannot allocate source flux");
239
240 /* ================================================================
241 * INITIALISASHUNN - Set up emisshunn and scattering funcs
242 * ================================================================ */
243 emap.samples = NULL;
244 emap.src = NULL;
245 emap.maxPartitions = MAXSPART;
246 emap.partitions = (unsigned char*)malloc(emap.maxPartitions >> 1);
247 if (!emap.partitions)
248 error(USER, "can't allocate source partitions");
249
250 initPhotonMap(pm, PMAP_TYPE_CONTRIB);
251 initPhotonEmissionFuncs();
252 initPhotonScatterFuncs();
253
254 /* Get photon ports if specified */
255 if (ambincl == 1)
256 getPhotonPorts();
257
258 /* Get photon sensor modifiers */
259 getPhotonSensors(photonSensorList);
260
261 /* Seed RNGs for photon distribution */
262 pmapSeed(randSeed, partState);
263 pmapSeed(randSeed, emitState);
264 pmapSeed(randSeed, cntState);
265 pmapSeed(randSeed, mediumState);
266 pmapSeed(randSeed, scatterState);
267 pmapSeed(randSeed, rouletteState);
268
269 /* Record start time and enable progress report signal handler */
270 repStartTime = time(NULL);
271 #ifdef SIGCONT
272 signal(SIGCONT, pmapDistribReport);
273 #endif
274
275 for (srcIdx = 0; srcIdx < nsources; srcIdx++) {
276 unsigned portCnt = 0, passCnt = 0, prePassCnt = 0;
277 double srcNumEmit = 0; /* # photons to emit from source */
278 unsigned long srcNumDistrib = pm -> heapEnd; /* # photons stored */
279
280 srcFlux [srcIdx] = repProgress = 0;
281 emap.src = source + srcIdx;
282
283 if (photonRepTime)
284 eputs("\n");
285
286 /* =============================================================
287 * FLUX INTEGRATION - Get total flux emitted from light source
288 * ============================================================= */
289 do {
290 emap.port = emap.src -> sflags & SDISTANT
291 ? photonPorts + portCnt : NULL;
292 photonPartition [emap.src -> so -> otype] (&emap);
293
294 if (photonRepTime) {
295 sprintf(errmsg, "Integrating flux from source %s (mod %s) ",
296 source [srcIdx].so -> oname,
297 objptr(source [srcIdx].so -> omod) -> oname);
298
299 if (emap.port) {
300 sprintf(errmsg2, "via port %s ",
301 photonPorts [portCnt].so -> oname);
302 strcat(errmsg, errmsg2);
303 }
304
305 sprintf(errmsg2, "(%lu partitions)...\n",
306 emap.numPartitions);
307 strcat(errmsg, errmsg2);
308 eputs(errmsg);
309 fflush(stderr);
310 }
311
312 for (emap.partitionCnt = 0;
313 emap.partitionCnt < emap.numPartitions;
314 emap.partitionCnt++) {
315 initPhotonEmission(&emap, pdfSamples);
316 srcFlux [srcIdx] += colorAvg(emap.partFlux);
317 }
318
319 portCnt++;
320 } while (portCnt < numPhotonPorts);
321
322 if (srcFlux [srcIdx] < FTINY) {
323 sprintf(errmsg, "source %s has zero emission",
324 source [srcIdx].so -> oname);
325 error(WARNING, errmsg);
326 }
327 else {
328 /* ==========================================================
329 * 2-PASS PHOTON DISTRIBUTION
330 * Pass 1 (pre): emit fraction of target photon count
331 * Pass 2 (main): based on outcome of pass 1, estimate
332 * remaining number of photons to emit to
333 * approximate target count
334 * ========================================================== */
335 do {
336 if (!passCnt) {
337 /* INIT PASS 1 */
338 if (++prePassCnt > maxPreDistrib) {
339 /* Warn if no photons contributed after sufficient
340 * iterations */
341 sprintf(errmsg, "too many prepasses, no photons "
342 "from source %s", source [srcIdx].so -> oname);
343 error(WARNING, errmsg);
344 break;
345 }
346
347 /* Num to emit is fraction of target count */
348 srcNumEmit = preDistrib * srcDistribTarget;
349 }
350
351 else {
352 /* INIT PASS 2 */
353 /* Based on the outcome of the predistribution we can now
354 * figure out how many more photons we have to emit from
355 * the current source to meet the target count,
356 * srcDistribTarget. This value is clamped to 0 in case
357 * the target has already been exceeded in pass 1.
358 * srcNumEmit and srcNumDistrib is the number of photons
359 * emitted and distributed (stored) from the current
360 * source in pass 1, respectively. */
361 srcNumDistrib = pm -> heapEnd - srcNumDistrib;
362 srcNumEmit *= srcNumDistrib
363 ? max(srcDistribTarget/srcNumDistrib, 1) - 1
364 : 0;
365
366 if (!srcNumEmit)
367 /* No photons left to distribute in main pass */
368 break;
369 }
370
371 /* Set completion count for progress report */
372 repComplete = srcNumEmit + repProgress;
373 portCnt = 0;
374
375 do {
376 emap.port = emap.src -> sflags & SDISTANT
377 ? photonPorts + portCnt : NULL;
378 photonPartition [emap.src -> so -> otype] (&emap);
379
380 if (photonRepTime) {
381 if (!passCnt)
382 sprintf(errmsg, "PREPASS %d on source %s (mod %s) ",
383 prePassCnt, source [srcIdx].so -> oname,
384 objptr(source[srcIdx].so->omod) -> oname);
385 else
386 sprintf(errmsg, "MAIN PASS on source %s (mod %s) ",
387 source [srcIdx].so -> oname,
388 objptr(source[srcIdx].so->omod) -> oname);
389
390 if (emap.port) {
391 sprintf(errmsg2, "via port %s ",
392 photonPorts [portCnt].so -> oname);
393 strcat(errmsg, errmsg2);
394 }
395
396 sprintf(errmsg2, "(%lu partitions)...\n",
397 emap.numPartitions);
398 strcat(errmsg, errmsg2);
399 eputs(errmsg);
400 fflush(stderr);
401 }
402
403 for (emap.partitionCnt = 0;
404 emap.partitionCnt < emap.numPartitions;
405 emap.partitionCnt++) {
406 double partNumEmit;
407 unsigned long partEmitCnt;
408
409 /* Get photon origin within current source partishunn
410 * and build emission map */
411 photonOrigin [emap.src -> so -> otype] (&emap);
412 initPhotonEmission(&emap, pdfSamples);
413
414 /* Number of photons to emit from ziss partishunn;
415 * scale according to its normalised contribushunn to
416 * the emitted source flux */
417 partNumEmit = srcNumEmit * colorAvg(emap.partFlux) /
418 srcFlux [srcIdx];
419 partEmitCnt = (unsigned long)partNumEmit;
420
421 /* Probabilistically account for fractional photons */
422 if (pmapRandom(cntState) < partNumEmit - partEmitCnt)
423 partEmitCnt++;
424
425 /* Integer counter avoids FP rounding errors */
426 while (partEmitCnt--) {
427 RAY photonRay;
428
429 /* Emit photon according to PDF (if any), allocate
430 * associated primary ray, and trace through scene
431 * until absorbed/leaked */
432 emitPhoton(&emap, &photonRay);
433 addPhotonPrimary(pm, &photonRay);
434 tracePhoton(&photonRay);
435
436 /* Record progress */
437 repProgress++;
438
439 if (photonRepTime > 0 &&
440 time(NULL) >= repLastTime + photonRepTime)
441 pmapDistribReport();
442 #ifdef SIGCONT
443 else signal(SIGCONT, pmapDistribReport);
444 #endif
445 }
446 }
447
448 portCnt++;
449 } while (portCnt < numPhotonPorts);
450
451 if (pm -> heapEnd == srcNumDistrib)
452 /* Double preDistrib in case no photons were stored
453 * for this source and redo pass 1 */
454 preDistrib *= 2;
455 else {
456 /* Now do pass 2 */
457 passCnt++;
458 if (photonRepTime)
459 eputs("\n");
460 }
461 } while (passCnt < 2);
462
463 /* Flux per photon emitted from this source; repProgress is the
464 * number of emitted photons after both passes */
465 srcFlux [srcIdx] = repProgress ? srcFlux [srcIdx] / repProgress
466 : 0;
467 }
468 }
469
470 /* ================================================================
471 * POST-DISTRIBUTION - Set photon flux and build kd-tree, etc.
472 * ================================================================ */
473 #ifdef SIGCONT
474 signal(SIGCONT, SIG_DFL);
475 #endif
476 free(emap.samples);
477
478 if (!pm -> heapEnd)
479 error(USER, "empty photon map");
480
481 /* Check for valid primary photon rays */
482 if (!pm -> primary)
483 error(INTERNAL, "no primary rays in contribution photon map");
484
485 if (pm -> primary [pm -> primaryEnd].srcIdx < 0)
486 /* Last primary ray is unused, so decrement counter */
487 pm -> primaryEnd--;
488
489 if (photonRepTime) {
490 eputs("\nBuilding contrib photon heap...\n");
491 fflush(stderr);
492 }
493
494 balancePhotons(pm, srcFlux);
495 }
