root/radiance/ray/src/rt/pmapcontrib.c
Revision: 2.14
Committed: Mon Aug 14 21:12:10 2017 UTC (6 years, 9 months ago) by rschregle
Changes since 2.13: +186 -100 lines
Updated photon map code for Windows; no multproc or ooC for now
2 static const char RCSid[] = "$Id: pmapcontrib.c,v 2.13 2016/09/29 21:51:58 greg Exp $";
4
5 /*
6 ======================================================================
7 Photon map for light source contributions
8
9 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
10 (c) Lucerne University of Applied Sciences and Arts,
11 supported by the Swiss National Science Foundation (SNSF, #147053)
12 ======================================================================
13
14 $Id: pmapcontrib.c,v 2.13 2016/09/29 21:51:58 greg Exp $
15 */
16
17
18 #include "pmapcontrib.h"
19 #include "pmapmat.h"
20 #include "pmapsrc.h"
21 #include "pmaprand.h"
22 #include "pmapio.h"
23 #include "pmapdiag.h"
24 #include "rcontrib.h"
25 #include "otypes.h"
26 #if NIX
27 #include <sys/mman.h>
28 #include <sys/wait.h>
29 #endif
30
31
32 static PhotonPrimaryIdx newPhotonPrimary (PhotonMap *pmap,
33 const RAY *primRay,
34 FILE *primHeap)
35 /* Add primary ray for emitted photon and save light source index, origin on
36 * source, and emitted direction; used by contrib photons. The current
37 * primary is stored in pmap -> lastPrimary. If the previous primary
38 * contributed photons (has srcIdx >= 0), it's appended to primHeap. If
39 * primRay == NULL, the current primary is still flushed, but no new primary
40 * is set. Returns updated primary counter pmap -> numPrimary. */
41 {
42 if (!pmap || !primHeap)
43 return 0;
44
45 /* Check if last primary ray has spawned photons (srcIdx >= 0, see
46 * newPhoton()), in which case we save it to the primary heap file
47 * before clobbering it */
48 if (pmap -> lastPrimary.srcIdx >= 0) {
49 if (!fwrite(&pmap -> lastPrimary, sizeof(PhotonPrimary), 1, primHeap))
50 error(SYSTEM, "failed writing photon primary in newPhotonPrimary");
51
52 pmap -> numPrimary++;
53 if (pmap -> numPrimary > PMAP_MAXPRIMARY)
54 error(INTERNAL, "photon primary overflow in newPhotonPrimary");
55 }
56
57 /* Mark unused with negative source index until path spawns a photon (see
58 * newPhoton()) */
59 pmap -> lastPrimary.srcIdx = -1;
60
61 if (primRay) {
62 FVECT dvec;
63
64 /* Reverse incident direction to point to light source */
65 dvec [0] = -primRay -> rdir [0];
66 dvec [1] = -primRay -> rdir [1];
67 dvec [2] = -primRay -> rdir [2];
68 pmap -> lastPrimary.dir = encodedir(dvec);
69 #ifdef PMAP_PRIMARYPOS
70 VCOPY(pmap -> lastPrimary.pos, primRay -> rop);
71 #endif
72 }
73
74 return pmap -> numPrimary;
75 }
76
77
78
79 #ifdef DEBUG_PMAP
80 static int checkPrimaryHeap (FILE *file)
81 /* Check heap for ordered primaries */
82 {
83 Photon p, lastp;
84 int i, dup;
85
86 rewind(file);
87 memset(&lastp, 0, sizeof(lastp));
88
89 while (fread(&p, sizeof(p), 1, file)) {
90 dup = 1;
91
92 for (i = 0; i <= 2; i++) {
93 if (p.pos [i] < thescene.cuorg [i] ||
94 p.pos [i] > thescene.cuorg [i] + thescene.cusize) {
95
96 sprintf(errmsg, "corrupt photon in heap at [%f, %f, %f]\n",
97 p.pos [0], p.pos [1], p.pos [2]);
98 error(WARNING, errmsg);
99 }
100
101 dup &= p.pos [i] == lastp.pos [i];
102 }
103
104 if (dup) {
105 sprintf(errmsg,
106 "consecutive duplicate photon in heap at [%f, %f, %f]\n",
107 p.pos [0], p.pos [1], p.pos [2]);
108 error(WARNING, errmsg);
109 }
110 }
111
112 return 0;
113 }
114 #endif
115
116
117
118 static PhotonPrimaryIdx buildPrimaries (PhotonMap *pmap, FILE **primaryHeap,
119 char **primaryHeapFname,
120 PhotonPrimaryIdx *primaryOfs,
121 unsigned numHeaps)
122 /* Consolidate per-subprocess photon primary heaps into the primary array
123 * pmap -> primaries. Returns offset for primary index linearisation in
124 * numPrimary. The heap files in primaryHeap are closed on return. */
125 {
126 PhotonPrimaryIdx heapLen;
127 unsigned heap;
128
129 if (!pmap || !primaryHeap || !primaryOfs || !numHeaps)
130 return 0;
131
132 pmap -> numPrimary = 0;
133
134 for (heap = 0; heap < numHeaps; heap++) {
135 primaryOfs [heap] = pmap -> numPrimary;
136
137 if (fseek(primaryHeap [heap], 0, SEEK_END) < 0)
138 error(SYSTEM, "failed photon primary seek in buildPrimaries");
139 pmap -> numPrimary += heapLen = ftell(primaryHeap [heap]) /
140 sizeof(PhotonPrimary);
141
142 pmap -> primaries = realloc(pmap -> primaries,
143 pmap -> numPrimary *
144 sizeof(PhotonPrimary));
145 if (!pmap -> primaries)
146 error(SYSTEM, "failed photon primary alloc in buildPrimaries");
147
148 rewind(primaryHeap [heap]);
149 if (fread(pmap -> primaries + primaryOfs [heap], sizeof(PhotonPrimary),
150 heapLen, primaryHeap [heap]) != heapLen)
151 error(SYSTEM, "failed reading photon primaries in buildPrimaries");
152
153 fclose(primaryHeap [heap]);
154 unlink(primaryHeapFname [heap]);
155 }
156
157 return pmap -> numPrimary;
158 }
159
160
161
162 /* Defs for photon emission counter array passed by sub-processes to parent
163 * via shared memory */
164 typedef unsigned long PhotonContribCnt;
165
166 /* Indices for photon emission counter array: num photons stored and num
167 * emitted per source */
168 #define PHOTONCNT_NUMPHOT 0
169 #define PHOTONCNT_NUMEMIT(n) (1 + n)
170
171
172
173 void distribPhotonContrib (PhotonMap* pm, unsigned numProc)
174 {
175 EmissionMap emap;
176 char errmsg2 [128], shmFname [PMAP_TMPFNLEN];
177 unsigned srcIdx, proc;
178 int shmFile, stat, pid;
179 double *srcFlux, /* Emitted flux per light source */
180 srcDistribTarget; /* Target photon count per source */
181 PhotonContribCnt *photonCnt; /* Photon emission counter array */
182 unsigned photonCntSize = sizeof(PhotonContribCnt) *
183 PHOTONCNT_NUMEMIT(nsources);
184 FILE **primaryHeap = NULL;
185 char **primaryHeapFname = NULL;
186 PhotonPrimaryIdx *primaryOfs = NULL;
187
188 if (!pm)
189 error(USER, "no photon map defined in distribPhotonContrib");
190
191 if (!nsources)
192 error(USER, "no light sources in distribPhotonContrib");
193
194 if (nsources > MAXMODLIST)
195 error(USER, "too many light sources in distribPhotonContrib");
196
197 /* Allocate photon flux per light source; this differs for every
198 * source as all sources contribute the same number of distributed
199 * photons (srcDistribTarget), hence the number of photons emitted per
200 * source does not correlate with its emitted flux. The resulting flux
201 * per photon is therefore adjusted individually for each source. */
202 if (!(srcFlux = calloc(nsources, sizeof(double))))
203 error(SYSTEM, "can't allocate source flux in distribPhotonContrib");
204
205 /* ===================================================================
206 * INITIALISATION - Set up emission and scattering funcs
207 * =================================================================== */
208 emap.samples = NULL;
209 emap.src = NULL;
210 emap.maxPartitions = MAXSPART;
211 emap.partitions = (unsigned char*)malloc(emap.maxPartitions >> 1);
212 if (!emap.partitions)
213 error(USER, "can't allocate source partitions in distribPhotonContrib");
214
215 /* Initialise contrib photon map */
216 initPhotonMap(pm, PMAP_TYPE_CONTRIB);
217 initPhotonHeap(pm);
218 initPhotonEmissionFuncs();
219 initPhotonScatterFuncs();
220
221 /* Per-subprocess / per-source target counts */
222 pm -> distribTarget /= numProc;
223 srcDistribTarget = nsources ? (double)pm -> distribTarget / nsources : 0;
224
225 if (!pm -> distribTarget)
226 error(INTERNAL, "no photons to distribute in distribPhotonContrib");
227
228 /* Get photon ports if specified */
229 if (ambincl == 1)
230 getPhotonPorts();
231
232 /* Get photon sensor modifiers */
233 getPhotonSensors(photonSensorList);
234
235 #if NIX
236 /* Set up shared mem for photon counters (zeroed by ftruncate) */
237 strcpy(shmFname, PMAP_TMPFNAME);
238 shmFile = mkstemp(shmFname);
239
240 if (shmFile < 0 || ftruncate(shmFile, photonCntSize) < 0)
241 error(SYSTEM, "failed shared mem init in distribPhotonContrib");
242
243 photonCnt = mmap(NULL, photonCntSize, PROT_READ | PROT_WRITE,
244 MAP_SHARED, shmFile, 0);
245
246 if (photonCnt == MAP_FAILED)
247 error(SYSTEM, "failed shared mem mapping in distribPhotonContrib");
248 #else
249 /* Allocate photon counters statically on Windoze */
250 if (!(photonCnt = malloc(photonCntSize)))
251 error(SYSTEM, "failed trivial malloc in distribPhotonContrib");
252
253 for (srcIdx = 0; srcIdx < PHOTONCNT_NUMEMIT(nsources); srcIdx++)
254 photonCnt [srcIdx] = 0;
255 #endif /* NIX */
256
257 if (verbose) {
258 sprintf(errmsg, "\nIntegrating flux from %d sources", nsources);
259
260 if (photonPorts) {
261 sprintf(errmsg2, " via %d ports", numPhotonPorts);
262 strcat(errmsg, errmsg2);
263 }
264
265 strcat(errmsg, "\n");
266 eputs(errmsg);
267 }
268
269 /* =============================================================
270 * FLUX INTEGRATION - Get total flux emitted from sources/ports
271 * ============================================================= */
272 for (srcIdx = 0; srcIdx < nsources; srcIdx++) {
273 unsigned portCnt = 0;
274 srcFlux [srcIdx] = 0;
275 emap.src = source + srcIdx;
276
277 do { /* Need at least one iteration if no ports! */
278 emap.port = emap.src -> sflags & SDISTANT ? photonPorts + portCnt
279 : NULL;
280 photonPartition [emap.src -> so -> otype] (&emap);
281
282 if (verbose) {
283 sprintf(errmsg, "\tIntegrating flux from source %s ",
284 source [srcIdx].so -> oname);
285
286 if (emap.port) {
287 sprintf(errmsg2, "via port %s ",
288 photonPorts [portCnt].so -> oname);
289 strcat(errmsg, errmsg2);
290 }
291
292 sprintf(errmsg2, "(%lu partitions)\n", emap.numPartitions);
293 strcat(errmsg, errmsg2);
294 eputs(errmsg);
295 #if NIX
296 fflush(stderr);
297 #endif
298 }
299
300 for (emap.partitionCnt = 0; emap.partitionCnt < emap.numPartitions;
301 emap.partitionCnt++) {
302 initPhotonEmission(&emap, pdfSamples);
303 srcFlux [srcIdx] += colorAvg(emap.partFlux);
304 }
305
306 portCnt++;
307 } while (portCnt < numPhotonPorts);
308
309 if (srcFlux [srcIdx] < FTINY) {
310 sprintf(errmsg, "source %s has zero emission",
311 source [srcIdx].so -> oname);
312 error(WARNING, errmsg);
313 }
314 }
315
316 /* Allocate & init per-subprocess primary heap files */
317 primaryHeap = calloc(numProc, sizeof(FILE*));
318 primaryHeapFname = calloc(numProc, sizeof(char*));
319 primaryOfs = calloc(numProc, sizeof(PhotonPrimaryIdx));
320 if (!primaryHeap || !primaryHeapFname || !primaryOfs)
321 error(SYSTEM, "failed primary heap allocation in "
322 "distribPhotonContrib");
323
324 for (proc = 0; proc < numProc; proc++) {
325 primaryHeapFname [proc] = malloc(PMAP_TMPFNLEN);
326 if (!primaryHeapFname [proc])
327 error(SYSTEM, "failed primary heap file allocation in "
328 "distribPhotonContrib");
329
330 mktemp(strcpy(primaryHeapFname [proc], PMAP_TMPFNAME));
331 if (!(primaryHeap [proc] = fopen(primaryHeapFname [proc], "w+b")))
332 error(SYSTEM, "failed opening primary heap file in "
333 "distribPhotonContrib");
334 }
335
336 /* Record start time for progress reports */
337 repStartTime = time(NULL);
338
339 if (verbose) {
340 sprintf(errmsg, "\nPhoton distribution @ %d procs\n", numProc);
341 eputs(errmsg);
342 }
343
344 /* MAIN LOOP */
345 for (proc = 0; proc < numProc; proc++) {
346 #if NIX
347 if (!(pid = fork())) {
348 /* SUBPROCESS ENTERS HERE; opened and mmapped files inherited */
349 #else
350 if (1) {
351 /* No subprocess under Windoze */
352 #endif
353 /* Local photon counters for this subprocess */
354 unsigned long lastNumPhotons = 0, localNumEmitted = 0;
355 double photonFluxSum = 0; /* Accum. photon flux */
356
357 /* Seed RNGs from PID for decorellated photon distribution */
358 pmapSeed(randSeed + proc, partState);
359 pmapSeed(randSeed + proc, emitState);
360 pmapSeed(randSeed + proc, cntState);
361 pmapSeed(randSeed + proc, mediumState);
362 pmapSeed(randSeed + proc, scatterState);
363 pmapSeed(randSeed + proc, rouletteState);
364
365 /* =============================================================
366 * 2-PASS PHOTON DISTRIBUTION
367 * Pass 1 (pre): emit fraction of target photon count
368 * Pass 2 (main): based on outcome of pass 1, estimate remaining
369 * number of photons to emit to approximate target
370 * count
371 * ============================================================= */
372 for (srcIdx = 0; srcIdx < nsources; srcIdx++) {
373 unsigned portCnt, passCnt = 0, prePassCnt = 0;
374 float srcPreDistrib = preDistrib;
375 double srcNumEmit = 0; /* # to emit from source */
376 unsigned long srcNumDistrib = pm -> numPhotons; /* # stored */
377
378 if (srcFlux [srcIdx] < FTINY)
379 continue;
380
381 while (passCnt < 2) {
382 if (!passCnt) {
383 /* INIT PASS 1 */
384 if (++prePassCnt > maxPreDistrib && !proc) {
385 /* Warn if no photons contributed after sufficient
386 * iterations; only output from subprocess 0 to reduce
387 * console clutter */
388 sprintf(errmsg,
389 "source %s: too many prepasses, skipped",
390 source [srcIdx].so -> oname);
391 error(WARNING, errmsg);
392 break;
393 }
394
395 /* Num to emit is fraction of target count */
396 srcNumEmit = srcPreDistrib * srcDistribTarget;
397 }
398 else {
399 /* INIT PASS 2 */
400 double srcPhotonFlux, avgPhotonFlux;
401
402 /* Based on the outcome of the predistribution we can now
403 * figure out how many more photons we have to emit from
404 * the current source to meet the target count,
405 * srcDistribTarget. This value is clamped to 0 in case
406 * the target has already been exceeded in pass 1.
407 * srcNumEmit and srcNumDistrib is the number of photons
408 * emitted and distributed (stored) from the current
409 * source in pass 1, respectively. */
410 srcNumDistrib = pm -> numPhotons - srcNumDistrib;
411 srcNumEmit *= srcNumDistrib
412 ? max(srcDistribTarget/srcNumDistrib, 1) - 1
413 : 0;
414
415 if (!srcNumEmit)
416 /* No photons left to distribute in main pass */
417 break;
418
419 srcPhotonFlux = srcFlux [srcIdx] / srcNumEmit;
420 avgPhotonFlux = photonFluxSum / (srcIdx + 1);
421
422 if (avgPhotonFlux > 0 &&
423 srcPhotonFlux / avgPhotonFlux < FTINY) {
424 /* Skip source if its photon flux is grossly below the
425 * running average, indicating negligible contributions
426 * at the expense of excessive distribution time; only
427 * output from subproc 0 to reduce console clutter */
428 sprintf(errmsg,
429 "source %s: itsy bitsy photon flux, skipped",
430 source [srcIdx].so -> oname);
431 error(WARNING, errmsg);
432 srcNumEmit = 0;
433 }
434
435 /* Update sum of photon flux per light source */
436 photonFluxSum += srcPhotonFlux;
437 }
438
439 portCnt = 0;
440 do { /* Need at least one iteration if no ports! */
441 emap.src = source + srcIdx;
442 emap.port = emap.src -> sflags & SDISTANT
443 ? photonPorts + portCnt : NULL;
444 photonPartition [emap.src -> so -> otype] (&emap);
445
446 if (verbose && !proc) {
447 /* Output from subproc 0 only to avoid race condition
448 * on console I/O */
449 if (!passCnt)
450 sprintf(errmsg, "\tPREPASS %d on source %s ",
451 prePassCnt, source [srcIdx].so -> oname);
452 else
453 sprintf(errmsg, "\tMAIN PASS on source %s ",
454 source [srcIdx].so -> oname);
455
456 if (emap.port) {
457 sprintf(errmsg2, "via port %s ",
458 photonPorts [portCnt].so -> oname);
459 strcat(errmsg, errmsg2);
460 }
461
462 sprintf(errmsg2, "(%lu partitions)\n",
463 emap.numPartitions);
464 strcat(errmsg, errmsg2);
465 eputs(errmsg);
466 #if NIX
467 fflush(stderr);
468 #endif
469 }
470
471 for (emap.partitionCnt = 0; emap.partitionCnt < emap.numPartitions;
472 emap.partitionCnt++) {
473 double partNumEmit;
474 unsigned long partEmitCnt;
475
476 /* Get photon origin within current source partishunn
477 * and build emission map */
478 photonOrigin [emap.src -> so -> otype] (&emap);
479 initPhotonEmission(&emap, pdfSamples);
480
481 /* Number of photons to emit from ziss partishunn;
482 * scale according to its normalised contribushunn to
483 * the emitted source flux */
484 partNumEmit = srcNumEmit * colorAvg(emap.partFlux) /
485 srcFlux [srcIdx];
486 partEmitCnt = (unsigned long)partNumEmit;
487
488 /* Probabilistically account for fractional photons */
489 if (pmapRandom(cntState) < partNumEmit - partEmitCnt)
490 partEmitCnt++;
491
492 /* Update local and shared global emission counter */
493 photonCnt [PHOTONCNT_NUMEMIT(srcIdx)] += partEmitCnt;
494 localNumEmitted += partEmitCnt;
495
496 /* Integer counter avoids FP rounding errors during
497 * iteration */
498 while (partEmitCnt--) {
499 RAY photonRay;
500
501 /* Emit photon according to PDF (if any), allocate
502 * associated primary ray, and trace through scene
503 * until absorbed/leaked; emitPhoton() sets the
504 * emitting light source index in photonRay */
505 emitPhoton(&emap, &photonRay);
506 #if 1
507 if (emap.port)
508 /* !!! PHOTON PORT REJECTION SAMPLING HACK: set
509 * !!! photon port as fake hit object for
510 * !!! primary ray to check for intersection in
511 * !!! tracePhoton() */
512 photonRay.ro = emap.port -> so;
513 #endif
514 newPhotonPrimary(pm, &photonRay, primaryHeap[proc]);
515 /* Set subprocess index in photonRay for post-
516 * distrib primary index linearisation; this is
517 * propagated with the primary index in photonRay
518 * and set for photon hits by newPhoton() */
519 PMAP_SETRAYPROC(&photonRay, proc);
520 tracePhoton(&photonRay);
521 }
522
523 /* Update shared global photon count */
524 photonCnt [PHOTONCNT_NUMPHOT] += pm -> numPhotons -
525 lastNumPhotons;
526 lastNumPhotons = pm -> numPhotons;
527 #if !NIX
528 /* Synchronous progress report on Windoze */
529 if (!proc && photonRepTime > 0 &&
530 time(NULL) >= repLastTime + photonRepTime) {
531 unsigned s;
532 repComplete = pm -> distribTarget * numProc;
533 repProgress = photonCnt [PHOTONCNT_NUMPHOT];
534
535 for (repEmitted = 0, s = 0; s < nsources; s++)
536 repEmitted += photonCnt [PHOTONCNT_NUMEMIT(s)];
537
538 pmapDistribReport();
539 }
540 #endif
541 }
542
543 portCnt++;
544 } while (portCnt < numPhotonPorts);
545
546 if (pm -> numPhotons == srcNumDistrib) {
547 /* Double predistrib factor in case no photons were stored
548 * for this source and redo pass 1 */
549 srcPreDistrib *= 2;
550 }
551 else {
552 /* Now do pass 2 */
553 passCnt++;
554 }
555 }
556 }
557
558 /* Flush heap buffa one final time to prevent data corruption */
559 flushPhotonHeap(pm);
560 /* Flush final photon primary to primary heap file */
561 newPhotonPrimary(pm, NULL, primaryHeap [proc]);
562 /* Heap files closed automatically on exit
563 fclose(pm -> heap);
564 fclose(primaryHeap [proc]); */
565
566 #ifdef DEBUG_PMAP
567 sprintf(errmsg, "Proc %d total %ld photons\n", proc,
568 pm -> numPhotons);
569 eputs(errmsg);
570 fflush(stderr);
571 #endif
572
573 #if NIX
574 /* Terminate subprocess */
575 exit(0);
576 #endif
577 }
578 else if (pid < 0)
579 error(SYSTEM, "failed to fork subprocess in distribPhotonContrib");
580 }
581
582 #if NIX
583 /* PARENT PROCESS CONTINUES HERE */
584 #ifdef SIGCONT
585 /* Enable progress report signal handler */
586 signal(SIGCONT, pmapDistribReport);
587 #endif
588 /* Wait for subprocesses to complete while reporting progress */
589 proc = numProc;
590 while (proc) {
591 while (waitpid(-1, &stat, WNOHANG) > 0) {
592 /* Subprocess exited; check status */
593 if (!WIFEXITED(stat) || WEXITSTATUS(stat))
594 error(USER, "failed photon distribution");
595
596 --proc;
597 }
598
599 /* Nod off for a bit and update progress */
600 sleep(1);
601
602 /* Asynchronous progress report from shared subprocess counters */
603 repComplete = pm -> distribTarget * numProc;
604 repProgress = photonCnt [PHOTONCNT_NUMPHOT];
605
606 for (repEmitted = 0, srcIdx = 0; srcIdx < nsources; srcIdx++)
607 repEmitted += photonCnt [PHOTONCNT_NUMEMIT(srcIdx)];
608
609 /* Get global photon count from shmem updated by subprocs */
610 pm -> numPhotons = photonCnt [PHOTONCNT_NUMPHOT];
611
612 if (photonRepTime > 0 && time(NULL) >= repLastTime + photonRepTime)
613 pmapDistribReport();
614 #ifdef SIGCONT
615 else signal(SIGCONT, pmapDistribReport);
616 #endif
617 }
618 #endif /* NIX */
619
620 /* ================================================================
621 * POST-DISTRIBUTION - Set photon flux and build kd-tree, etc.
622 * ================================================================ */
623 #ifdef SIGCONT
624 /* Reset signal handler */
625 signal(SIGCONT, SIG_DFL);
626 #endif
627 free(emap.samples);
628
629 if (!pm -> numPhotons)
630 error(USER, "empty contribution photon map");
631
632 /* Load per-subprocess primary rays into pm -> primary array */
633 /* Dumb compilers apparently need the char** cast */
634 pm -> numPrimary = buildPrimaries(pm, primaryHeap,
635 (char**)primaryHeapFname,
636 primaryOfs, numProc);
637 if (!pm -> numPrimary)
638 error(INTERNAL, "no primary rays in contribution photon map");
639
640 /* Set photon flux per source */
641 for (srcIdx = 0; srcIdx < nsources; srcIdx++)
642 srcFlux [srcIdx] /= photonCnt [PHOTONCNT_NUMEMIT(srcIdx)];
643 #if NIX
644 /* Photon counters no longer needed, unmap shared memory */
645 munmap(photonCnt, sizeof(*photonCnt));
646 close(shmFile);
647 unlink(shmFname);
648 #else
649 free(photonCnt);
650 #endif
651
652 if (verbose) {
653 eputs("\nBuilding contribution photon map...\n");
654 #if NIX
655 fflush(stderr);
656 #endif
657 }
658
659 /* Build underlying data structure; heap is destroyed */
660 buildPhotonMap(pm, srcFlux, primaryOfs, numProc);
661
662 /* Free per-subprocess primary heap files */
663 for (proc = 0; proc < numProc; proc++)
664 free(primaryHeapFname [proc]);
665
666 free(primaryHeapFname);
667 free(primaryHeap);
668 free(primaryOfs);
669
670 if (verbose)
671 eputs("\n");
672 }
