| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: pmapcontrib.c,v 4.30.1.12 2016/05/11 12:40:00 taschreg Exp taschreg $";
| 3 |
#endif
| 4 |
| 5 |
| 6 |
| 7 |
Photon map support for light source contributions
| 8 |
| 9 |
Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
| 10 |
(c) Lucerne University of Applied Sciences and Arts,
| 11 |
supported by the Swiss National Science Foundation (SNSF, #147053)
| 12 |
| 13 |
| 14 |
| 15 |
| 16 |
| 17 |
| 18 |
#include "pmapcontrib.h"
| 19 |
#include "pmapmat.h"
| 20 |
#include "pmapsrc.h"
| 21 |
#include "pmaprand.h"
| 22 |
#include "pmapio.h"
| 23 |
#include "pmapdiag.h"
| 24 |
#include "rcontrib.h"
| 25 |
#include "otypes.h"
| 26 |
#include <sys/mman.h>
| 27 |
#include <sys/wait.h>
| 28 |
| 29 |
| 30 |
| 31 |
static void setPmapContribParams (PhotonMap *pmap, LUTAB *srcContrib)
| 32 |
/* Set parameters for light source contributions */
| 33 |
| 34 |
/* Set light source modifier list and appropriate callback to extract
| 35 |
* their contributions from the photon map */
| 36 |
if (pmap) {
| 37 |
pmap -> srcContrib = srcContrib;
| 38 |
pmap -> lookup = photonContrib;
| 39 |
/* Ensure we get all requested photon contribs during lookups */
| 40 |
pmap -> gatherTolerance = 1.0;
| 41 |
| 42 |
| 43 |
| 44 |
| 45 |
| 46 |
static void checkPmapContribs (const PhotonMap *pmap, LUTAB *srcContrib)
| 47 |
/* Check modifiers for light source contributions */
| 48 |
| 49 |
const PhotonPrimary *primary = pmap -> primaries;
| 50 |
PhotonPrimaryIdx i, found = 0;
| 51 |
OBJREC *srcMod;
| 52 |
| 53 |
/* Make sure at least one of the modifiers is actually in the pmap,
| 54 |
* otherwise findPhotons() winds up in an infinite loop! */
| 55 |
for (i = pmap -> numPrimary; i; --i, ++primary) {
| 56 |
if (primary -> srcIdx < 0 || primary -> srcIdx >= nsources)
| 57 |
error(INTERNAL, "invalid light source index in photon map");
| 58 |
| 59 |
srcMod = findmaterial(source [primary -> srcIdx].so);
| 60 |
if ((MODCONT*)lu_find(srcContrib, srcMod -> oname) -> data)
| 61 |
++found;
| 62 |
| 63 |
| 64 |
if (!found)
| 65 |
error(USER, "modifiers not in photon map");
| 66 |
| 67 |
| 68 |
| 69 |
| 70 |
void initPmapContrib (LUTAB *srcContrib, unsigned numSrcContrib)
| 71 |
| 72 |
unsigned t;
| 73 |
| 74 |
for (t = 0; t < NUM_PMAP_TYPES; t++)
| 75 |
if (photonMaps [t] && t != PMAP_TYPE_CONTRIB) {
| 76 |
sprintf(errmsg, "%s photon map does not support contributions",
| 77 |
pmapName [t]);
| 78 |
error(USER, errmsg);
| 79 |
| 80 |
| 81 |
/* Get params */
| 82 |
setPmapContribParams(contribPmap, srcContrib);
| 83 |
| 84 |
if (contribPhotonMapping) {
| 85 |
if (contribPmap -> maxGather < numSrcContrib) {
| 86 |
/* Adjust density estimate bandwidth if lower than modifier
| 87 |
* count, otherwise contributions are missing */
| 88 |
error(WARNING, "contrib density estimate bandwidth too low, "
| 89 |
"adjusting to modifier count");
| 90 |
contribPmap -> maxGather = numSrcContrib;
| 91 |
| 92 |
| 93 |
/* Sanity check */
| 94 |
checkPmapContribs(contribPmap, srcContrib);
| 95 |
| 96 |
| 97 |
| 98 |
| 99 |
| 100 |
static PhotonPrimaryIdx newPhotonPrimary (PhotonMap *pmap,
| 101 |
const RAY *primRay,
| 102 |
FILE *primHeap)
| 103 |
/* Add primary ray for emitted photon and save light source index, origin on
| 104 |
* source, and emitted direction; used by contrib photons. The current
| 105 |
* primary is stored in pmap -> lastPrimary. If the previous primary
| 106 |
* contributed photons (has srcIdx >= 0), it's appended to primHeap. If
| 107 |
* primRay == NULL, the current primary is still flushed, but no new primary
| 108 |
* is set. Returns updated primary counter pmap -> numPrimary. */
| 109 |
| 110 |
if (!pmap || !primHeap)
| 111 |
return 0;
| 112 |
| 113 |
/* Check if last primary ray has spawned photons (srcIdx >= 0, see
| 114 |
* newPhoton()), in which case we write it to the primary heap file
| 115 |
* before overwriting it */
| 116 |
if (pmap -> lastPrimary.srcIdx >= 0) {
| 117 |
if (!fwrite(&pmap -> lastPrimary, sizeof(PhotonPrimary), 1, primHeap))
| 118 |
error(SYSTEM, "failed writing photon primary in newPhotonPrimary");
| 119 |
| 120 |
pmap -> numPrimary++;
| 121 |
if (pmap -> numPrimary > PMAP_MAXPRIMARY)
| 122 |
error(INTERNAL, "photon primary overflow in newPhotonPrimary");
| 123 |
| 124 |
| 125 |
/* Mark unused with negative source index until path spawns a photon (see
| 126 |
* newPhoton()) */
| 127 |
pmap -> lastPrimary.srcIdx = -1;
| 128 |
| 129 |
if (primRay) {
| 130 |
FVECT dvec;
| 131 |
| 132 |
/* Reverse incident direction to point to light source */
| 133 |
dvec [0] = -primRay -> rdir [0];
| 134 |
dvec [1] = -primRay -> rdir [1];
| 135 |
dvec [2] = -primRay -> rdir [2];
| 136 |
pmap -> lastPrimary.dir = encodedir(dvec);
| 137 |
#ifdef PMAP_PRIMARYPOS
| 138 |
VCOPY(pmap -> lastPrimary.pos, primRay -> rop);
| 139 |
#endif
| 140 |
| 141 |
| 142 |
return pmap -> numPrimary;
| 143 |
| 144 |
| 145 |
| 146 |
| 147 |
#ifdef DEBUG_PMAP_CONTRIB
| 148 |
static int checkPrimaryHeap (FILE *file)
| 149 |
/* Check heap for ordered primaries */
| 150 |
| 151 |
Photon p, lastp;
| 152 |
int i, dup;
| 153 |
| 154 |
rewind(file);
| 155 |
memset(&lastp, 0, sizeof(lastp));
| 156 |
| 157 |
while (fread(&p, sizeof(p), 1, file)) {
| 158 |
dup = 1;
| 159 |
| 160 |
for (i = 0; i <= 2; i++) {
| 161 |
if (p.pos [i] < thescene.cuorg [i] ||
| 162 |
p.pos [i] > thescene.cuorg [i] + thescene.cusize) {
| 163 |
| 164 |
sprintf(errmsg, "corrupt photon in heap at [%f, %f, %f]\n",
| 165 |
p.pos [0], p.pos [1], p.pos [2]);
| 166 |
error(WARNING, errmsg);
| 167 |
| 168 |
| 169 |
dup &= p.pos [i] == lastp.pos [i];
| 170 |
| 171 |
| 172 |
if (dup) {
| 173 |
sprintf(errmsg,
| 174 |
"consecutive duplicate photon in heap at [%f, %f, %f]\n",
| 175 |
| 176 |
| 177 |
| 178 |
| 179 |
| 180 |
return 0;
| 181 |
| 182 |
#endif
| 183 |
| 184 |
| 185 |
| 186 |
static PhotonPrimaryIdx buildPrimaries (PhotonMap *pmap, FILE **primaryHeap,
| 187 |
PhotonPrimaryIdx *primaryOfs,
| 188 |
unsigned numHeaps)
| 189 |
/* Consolidate per-subprocess photon primary heaps into the primary array
| 190 |
* pmap -> primaries. Returns offset for primary index linearisation in
| 191 |
* numPrimary. The heap files in primaryHeap are closed on return. */
| 192 |
| 193 |
PhotonPrimaryIdx heapLen;
| 194 |
unsigned heap;
| 195 |
| 196 |
if (!pmap || !primaryHeap || !primaryOfs || !numHeaps)
| 197 |
return 0;
| 198 |
| 199 |
pmap -> numPrimary = 0;
| 200 |
| 201 |
for (heap = 0; heap < numHeaps; heap++) {
| 202 |
primaryOfs [heap] = pmap -> numPrimary;
| 203 |
| 204 |
if (fseek(primaryHeap [heap], 0, SEEK_END))
| 205 |
error(SYSTEM, "failed photon primary seek in buildPrimaries");
| 206 |
pmap -> numPrimary += heapLen = ftell(primaryHeap [heap]) /
| 207 |
sizeof(PhotonPrimary);
| 208 |
| 209 |
pmap -> primaries = realloc(pmap -> primaries,
| 210 |
pmap -> numPrimary *
| 211 |
sizeof(PhotonPrimary));
| 212 |
if (!pmap -> primaries)
| 213 |
error(SYSTEM, "failed photon primary alloc in buildPrimaries");
| 214 |
| 215 |
rewind(primaryHeap [heap]);
| 216 |
if (fread(pmap -> primaries + primaryOfs [heap], sizeof(PhotonPrimary),
| 217 |
heapLen, primaryHeap [heap]) != heapLen)
| 218 |
error(SYSTEM, "failed reading photon primaries in buildPrimaries");
| 219 |
| 220 |
fclose(primaryHeap [heap]);
| 221 |
| 222 |
| 223 |
| 224 |
| 225 |
| 226 |
| 227 |
| 228 |
/* Defs for photon emission counter array passed by sub-processes to parent
| 229 |
* via shared memory */
| 230 |
typedef unsigned long PhotonContribCnt;
| 231 |
| 232 |
/* Indices for photon emission counter array: num photons stored and num
| 233 |
* emitted per source */
| 234 |
#define PHOTONCNT_NUMPHOT 0
| 235 |
#define PHOTONCNT_NUMEMIT(n) (1 + n)
| 236 |
| 237 |
| 238 |
| 239 |
void distribPhotonContrib (PhotonMap* pm, unsigned numProc)
| 240 |
| 241 |
EmissionMap emap;
| 242 |
char errmsg2 [128], shmFname [255];
| 243 |
unsigned srcIdx, proc;
| 244 |
int shmFile, stat, pid;
| 245 |
double *srcFlux, /* Emitted flux per light source */
| 246 |
srcDistribTarget; /* Target photon count per source */
| 247 |
PhotonContribCnt *photonCnt; /* Photon emission counter array */
| 248 |
const unsigned photonCntSize = sizeof(PhotonContribCnt) *
| 249 |
PHOTONCNT_NUMEMIT(nsources);
| 250 |
FILE *primaryHeap [numProc];
| 251 |
PhotonPrimaryIdx primaryOfs [numProc];
| 252 |
| 253 |
if (!pm)
| 254 |
error(USER, "no photon map defined in distribPhotonContrib");
| 255 |
| 256 |
if (!nsources)
| 257 |
error(USER, "no light sources in distribPhotonContrib");
| 258 |
| 259 |
if (nsources > MAXMODLIST)
| 260 |
error(USER, "too many light sources in distribPhotonContrib");
| 261 |
| 262 |
/* Allocate photon flux per light source; this differs for every
| 263 |
* source as all sources contribute the same number of distributed
| 264 |
* photons (srcDistribTarget), hence the number of photons emitted per
| 265 |
* source does not correlate with its emitted flux. The resulting flux
| 266 |
* per photon is therefore adjusted individually for each source. */
| 267 |
if (!(srcFlux = calloc(nsources, sizeof(double))))
| 268 |
error(SYSTEM, "can't allocate source flux in distribPhotonContrib");
| 269 |
| 270 |
| 271 |
* INITIALISATION - Set up emission and scattering funcs
| 272 |
| 273 |
emap.samples = NULL;
| 274 |
emap.src = NULL;
| 275 |
emap.maxPartitions = MAXSPART;
| 276 |
emap.partitions = (unsigned char*)malloc(emap.maxPartitions >> 1);
| 277 |
if (!emap.partitions)
| 278 |
error(USER, "can't allocate source partitions in distribPhotonContrib");
| 279 |
| 280 |
/* Initialise contrib photon map */
| 281 |
initPhotonMap(pm, PMAP_TYPE_CONTRIB);
| 282 |
initPhotonHeap(pm);
| 283 |
initPhotonEmissionFuncs();
| 284 |
initPhotonScatterFuncs();
| 285 |
| 286 |
/* Per-subprocess / per-source target counts */
| 287 |
pm -> distribTarget /= numProc;
| 288 |
srcDistribTarget = nsources ? (double)pm -> distribTarget / nsources : 0;
| 289 |
| 290 |
/* Get photon ports if specified */
| 291 |
if (ambincl == 1)
| 292 |
getPhotonPorts();
| 293 |
| 294 |
/* Get photon sensor modifiers */
| 295 |
getPhotonSensors(photonSensorList);
| 296 |
| 297 |
/* Set up shared mem for photon counters (zeroed by ftruncate) */
| 298 |
#if 0
| 299 |
snprintf(shmFname, 255, PMAP_SHMFNAME, getpid());
| 300 |
shmFile = shm_open(shmFname, O_CREAT | O_RDWR, S_IRUSR | S_IWUSR);
| 301 |
#else
| 302 |
strcpy(shmFname, PMAP_SHMFNAME);
| 303 |
shmFile = mkstemp(shmFname);
| 304 |
#endif
| 305 |
| 306 |
if (shmFile < 0 || ftruncate(shmFile, photonCntSize) < 0)
| 307 |
error(SYSTEM, "failed shared mem init in distribPhotonContrib");
| 308 |
| 309 |
photonCnt = mmap(NULL, photonCntSize, PROT_READ | PROT_WRITE,
| 310 |
MAP_SHARED, shmFile, 0);
| 311 |
| 312 |
if (photonCnt == MAP_FAILED)
| 313 |
error(SYSTEM, "failed shared mem mapping in distribPhotonContrib");
| 314 |
| 315 |
| 316 |
* FLUX INTEGRATION - Get total flux emitted from light source
| 317 |
| 318 |
for (srcIdx = 0; srcIdx < nsources; srcIdx++) {
| 319 |
unsigned portCnt = 0;
| 320 |
| 321 |
srcFlux [srcIdx] = 0;
| 322 |
emap.src = source + srcIdx;
| 323 |
| 324 |
if (photonRepTime)
| 325 |
eputs("\n");
| 326 |
| 327 |
do { /* Need at least one iteration if no ports! */
| 328 |
emap.port = emap.src -> sflags & SDISTANT ? photonPorts + portCnt
| 329 |
: NULL;
| 330 |
photonPartition [emap.src -> so -> otype] (&emap);
| 331 |
| 332 |
if (photonRepTime) {
| 333 |
sprintf(errmsg, "Integrating flux from source %s (mod %s) ",
| 334 |
source [srcIdx].so -> oname,
| 335 |
objptr(source [srcIdx].so -> omod) -> oname);
| 336 |
| 337 |
if (emap.port) {
| 338 |
sprintf(errmsg2, "via port %s ",
| 339 |
photonPorts [portCnt].so -> oname);
| 340 |
strcat(errmsg, errmsg2);
| 341 |
| 342 |
| 343 |
sprintf(errmsg2, "(%lu partitions)...\n", emap.numPartitions);
| 344 |
| 345 |
eputs(errmsg);
| 346 |
fflush(stderr);
| 347 |
| 348 |
| 349 |
for (emap.partitionCnt = 0; emap.partitionCnt < emap.numPartitions;
| 350 |
emap.partitionCnt++) {
| 351 |
initPhotonEmission(&emap, pdfSamples);
| 352 |
srcFlux [srcIdx] += colorAvg(emap.partFlux);
| 353 |
| 354 |
| 355 |
portCnt++;
| 356 |
} while (portCnt < numPhotonPorts);
| 357 |
| 358 |
if (srcFlux [srcIdx] < FTINY) {
| 359 |
sprintf(errmsg, "source %s has zero emission",
| 360 |
source [srcIdx].so -> oname);
| 361 |
| 362 |
| 363 |
| 364 |
| 365 |
if (photonRepTime)
| 366 |
eputs("\n");
| 367 |
| 368 |
/* Init per-subprocess primary heap files */
| 369 |
for (proc = 0; proc < numProc; proc++)
| 370 |
if (!(primaryHeap [proc] = tmpfile()))
| 371 |
error(SYSTEM, "failed opening primary heap file in "
| 372 |
"distribPhotonContrib");
| 373 |
| 374 |
/* MAIN LOOP */
| 375 |
for (proc = 0; proc < numProc; proc++) {
| 376 |
if (!(pid = fork())) {
| 377 |
/* SUBPROCESS ENTERS HERE;
| 378 |
* all opened and memory mapped files are inherited */
| 379 |
| 380 |
/* Local photon counters for this subprocess */
| 381 |
unsigned long lastNumPhotons = 0, localNumEmitted = 0;
| 382 |
double photonFluxSum = 0; /* Running photon flux sum */
| 383 |
| 384 |
/* Seed RNGs from PID for decorellated photon distribution */
| 385 |
pmapSeed(randSeed + proc, partState);
| 386 |
pmapSeed(randSeed + proc, emitState);
| 387 |
pmapSeed(randSeed + proc, cntState);
| 388 |
pmapSeed(randSeed + proc, mediumState);
| 389 |
pmapSeed(randSeed + proc, scatterState);
| 390 |
pmapSeed(randSeed + proc, rouletteState);
| 391 |
| 392 |
| 393 |
* 2-PASS PHOTON DISTRIBUTION
| 394 |
* Pass 1 (pre): emit fraction of target photon count
| 395 |
* Pass 2 (main): based on outcome of pass 1, estimate remaining
| 396 |
* number of photons to emit to approximate target
| 397 |
* count
| 398 |
| 399 |
| 400 |
unsigned portCnt, passCnt = 0, prePassCnt = 0;
| 401 |
float srcPreDistrib = preDistrib;
| 402 |
double srcNumEmit = 0; /* # to emit from source */
| 403 |
unsigned long srcNumDistrib = pm -> numPhotons; /* # stored */
| 404 |
| 405 |
| 406 |
continue;
| 407 |
| 408 |
while (passCnt < 2) {
| 409 |
if (!passCnt) {
| 410 |
/* INIT PASS 1 */
| 411 |
if (++prePassCnt > maxPreDistrib) {
| 412 |
/* Warn if no photons contributed after sufficient
| 413 |
* iterations */
| 414 |
sprintf(errmsg, "proc %d, source %s: "
| 415 |
"too many prepasses, skipped",
| 416 |
proc, source [srcIdx].so -> oname);
| 417 |
| 418 |
break;
| 419 |
| 420 |
| 421 |
/* Num to emit is fraction of target count */
| 422 |
srcNumEmit = srcPreDistrib * srcDistribTarget;
| 423 |
| 424 |
else {
| 425 |
/* INIT PASS 2 */
| 426 |
double srcPhotonFlux, avgPhotonFlux;
| 427 |
| 428 |
/* Based on the outcome of the predistribution we can now
| 429 |
* figure out how many more photons we have to emit from
| 430 |
* the current source to meet the target count,
| 431 |
* srcDistribTarget. This value is clamped to 0 in case
| 432 |
* the target has already been exceeded in pass 1.
| 433 |
* srcNumEmit and srcNumDistrib is the number of photons
| 434 |
* emitted and distributed (stored) from the current
| 435 |
* source in pass 1, respectively. */
| 436 |
srcNumDistrib = pm -> numPhotons - srcNumDistrib;
| 437 |
srcNumEmit *= srcNumDistrib
| 438 |
? max(srcDistribTarget/srcNumDistrib, 1) - 1
| 439 |
: 0;
| 440 |
| 441 |
if (!srcNumEmit)
| 442 |
/* No photons left to distribute in main pass */
| 443 |
break;
| 444 |
| 445 |
srcPhotonFlux = srcFlux [srcIdx] / srcNumEmit;
| 446 |
avgPhotonFlux = photonFluxSum / (srcIdx + 1);
| 447 |
| 448 |
if (avgPhotonFlux > 0 &&
| 449 |
srcPhotonFlux / avgPhotonFlux < FTINY) {
| 450 |
/* Skip source if its photon flux is grossly below the
| 451 |
* running average, indicating negligible contribs at
| 452 |
* the expense of excessive distribution time */
| 453 |
| 454 |
"itsy bitsy photon flux, skipped",
| 455 |
| 456 |
| 457 |
srcNumEmit = 0;
| 458 |
| 459 |
| 460 |
/* Update sum of photon flux per light source */
| 461 |
photonFluxSum += srcPhotonFlux;
| 462 |
| 463 |
| 464 |
portCnt = 0;
| 465 |
| 466 |
| 467 |
| 468 |
? photonPorts + portCnt : NULL;
| 469 |
| 470 |
| 471 |
if (photonRepTime && !proc) {
| 472 |
if (!passCnt)
| 473 |
sprintf(errmsg, "PREPASS %d on source %s (mod %s) ",
| 474 |
prePassCnt, source [srcIdx].so -> oname,
| 475 |
objptr(source[srcIdx].so->omod) -> oname);
| 476 |
else
| 477 |
sprintf(errmsg, "MAIN PASS on source %s (mod %s) ",
| 478 |
| 479 |
| 480 |
| 481 |
if (emap.port) {
| 482 |
| 483 |
| 484 |
| 485 |
| 486 |
| 487 |
sprintf(errmsg2, "(%lu partitions)\n",
| 488 |
| 489 |
| 490 |
eputs(errmsg);
| 491 |
fflush(stderr);
| 492 |
| 493 |
| 494 |
| 495 |
| 496 |
double partNumEmit;
| 497 |
unsigned long partEmitCnt;
| 498 |
| 499 |
/* Get photon origin within current source partishunn
| 500 |
* and build emission map */
| 501 |
photonOrigin [emap.src -> so -> otype] (&emap);
| 502 |
| 503 |
| 504 |
/* Number of photons to emit from ziss partishunn;
| 505 |
* scale according to its normalised contribushunn to
| 506 |
* the emitted source flux */
| 507 |
partNumEmit = srcNumEmit * colorAvg(emap.partFlux) /
| 508 |
srcFlux [srcIdx];
| 509 |
partEmitCnt = (unsigned long)partNumEmit;
| 510 |
| 511 |
/* Probabilistically account for fractional photons */
| 512 |
if (pmapRandom(cntState) < partNumEmit - partEmitCnt)
| 513 |
partEmitCnt++;
| 514 |
| 515 |
/* Update local and shared global emission counter */
| 516 |
localNumEmitted += partEmitCnt;
| 517 |
photonCnt [PHOTONCNT_NUMEMIT(srcIdx)] += partEmitCnt;
| 518 |
| 519 |
/* Integer counter avoids FP rounding errors */
| 520 |
while (partEmitCnt--) {
| 521 |
RAY photonRay;
| 522 |
| 523 |
/* Emit photon according to PDF (if any), allocate
| 524 |
* associated primary ray, and trace through scene
| 525 |
* until absorbed/leaked; emitPhoton() sets the
| 526 |
* emitting light source index in photonRay */
| 527 |
emitPhoton(&emap, &photonRay);
| 528 |
newPhotonPrimary(pm, &photonRay, primaryHeap[proc]);
| 529 |
/* Set subprocess index in photonRay for post-
| 530 |
* distrib primary index linearisation; this is
| 531 |
* propagated with the primary index in photonRay
| 532 |
* and set for photon hits by newPhoton() */
| 533 |
PMAP_SETRAYPROC(&photonRay, proc);
| 534 |
tracePhoton(&photonRay);
| 535 |
| 536 |
| 537 |
/* Update shared global photon count */
| 538 |
photonCnt [PHOTONCNT_NUMPHOT] += pm -> numPhotons -
| 539 |
lastNumPhotons;
| 540 |
lastNumPhotons = pm -> numPhotons;
| 541 |
| 542 |
| 543 |
portCnt++;
| 544 |
| 545 |
| 546 |
if (pm -> numPhotons == srcNumDistrib)
| 547 |
/* Double predistrib factor in case no photons were stored
| 548 |
* for this source and redo pass 1 */
| 549 |
srcPreDistrib *= 2;
| 550 |
else {
| 551 |
/* Now do pass 2 */
| 552 |
passCnt++;
| 553 |
/* if (photonRepTime)
| 554 |
eputs("\n"); */
| 555 |
| 556 |
| 557 |
| 558 |
| 559 |
/* Flush heap buffa one final time to prevent data corruption */
| 560 |
flushPhotonHeap(pm);
| 561 |
fclose(pm -> heap);
| 562 |
| 563 |
/* Flush final photon primary to primary heap file */
| 564 |
newPhotonPrimary(pm, NULL, primaryHeap [proc]);
| 565 |
fclose(primaryHeap [proc]);
| 566 |
| 567 |
#ifdef DEBUG_PMAP
| 568 |
sprintf(errmsg, "Proc %d exited with total %ld photons\n", proc,
| 569 |
pm -> numPhotons);
| 570 |
eputs(errmsg);
| 571 |
#endif
| 572 |
| 573 |
exit(0);
| 574 |
| 575 |
else if (pid < 0)
| 576 |
error(SYSTEM, "failed to fork subprocess in distribPhotonContrib");
| 577 |
| 578 |
| 579 |
/* PARENT PROCESS CONTINUES HERE */
| 580 |
/* Record start time and enable progress report signal handler */
| 581 |
repStartTime = time(NULL);
| 582 |
#ifdef SIGCONT
| 583 |
signal(SIGCONT, pmapDistribReport);
| 584 |
#endif
| 585 |
| 586 |
if (photonRepTime)
| 587 |
eputs("\n"); */
| 588 |
| 589 |
/* Wait for subprocesses to complete while reporting progress */
| 590 |
proc = numProc;
| 591 |
while (proc) {
| 592 |
while (waitpid(-1, &stat, WNOHANG) > 0) {
| 593 |
/* Subprocess exited; check status */
| 594 |
if (!WIFEXITED(stat) || WEXITSTATUS(stat))
| 595 |
error(USER, "failed photon distribution");
| 596 |
| 597 |
--proc;
| 598 |
| 599 |
| 600 |
/* Nod off for a bit and update progress */
| 601 |
sleep(1);
| 602 |
| 603 |
/* Update progress report from shared subprocess counters */
| 604 |
repComplete = pm -> distribTarget * numProc;
| 605 |
repProgress = photonCnt [PHOTONCNT_NUMPHOT];
| 606 |
for (repEmitted = 0, srcIdx = 0; srcIdx < nsources; srcIdx++)
| 607 |
repEmitted += photonCnt [PHOTONCNT_NUMEMIT(srcIdx)];
| 608 |
| 609 |
/* Get global photon count from shmem updated by subprocs */
| 610 |
pm -> numPhotons = photonCnt [PHOTONCNT_NUMPHOT];
| 611 |
| 612 |
if (photonRepTime > 0 && time(NULL) >= repLastTime + photonRepTime)
| 613 |
pmapDistribReport();
| 614 |
#ifdef SIGCONT
| 615 |
else signal(SIGCONT, pmapDistribReport);
| 616 |
#endif
| 617 |
| 618 |
| 619 |
| 620 |
* POST-DISTRIBUTION - Set photon flux and build kd-tree, etc.
| 621 |
| 622 |
#ifdef SIGCONT
| 623 |
signal(SIGCONT, SIG_DFL);
| 624 |
#endif
| 625 |
free(emap.samples);
| 626 |
| 627 |
if (!pm -> numPhotons)
| 628 |
error(USER, "empty photon map");
| 629 |
| 630 |
/* Load per-subprocess primary rays into pm -> primary array */
| 631 |
pm -> numPrimary = buildPrimaries(pm, primaryHeap, primaryOfs, numProc);
| 632 |
if (!pm -> numPrimary)
| 633 |
error(INTERNAL, "no primary rays in contribution photon map");
| 634 |
| 635 |
/* Set photon flux per source */
| 636 |
| 637 |
srcFlux [srcIdx] /= photonCnt [PHOTONCNT_NUMEMIT(srcIdx)];
| 638 |
| 639 |
/* Photon counters no longer needed, unmap shared memory */
| 640 |
munmap(photonCnt, sizeof(*photonCnt));
| 641 |
close(shmFile);
| 642 |
#if 0
| 643 |
shm_unlink(shmFname);
| 644 |
#else
| 645 |
unlink(shmFname);
| 646 |
#endif
| 647 |
| 648 |
| 649 |
eputs("\nBuilding contrib photon map...\n");
| 650 |
fflush(stderr);
| 651 |
| 652 |
| 653 |
/* Build underlying data structure; heap is destroyed */
| 654 |
buildPhotonMap(pm, srcFlux, primaryOfs, numProc);
| 655 |
| 656 |
| 657 |
| 658 |
| 659 |
void photonContrib (PhotonMap *pmap, RAY *ray, COLOR irrad)
| 660 |
/* Sum up light source contributions from photons in pmap->srcContrib */
| 661 |
| 662 |
unsigned i;
| 663 |
PhotonSearchQueueNode *sqn;
| 664 |
float r, invArea;
| 665 |
RREAL rayCoeff [3];
| 666 |
Photon *photon;
| 667 |
static char warn = 1;
| 668 |
| 669 |
setcolor(irrad, 0, 0, 0);
| 670 |
| 671 |
if (!pmap -> maxGather)
| 672 |
return;
| 673 |
| 674 |
/* Ignore sources */
| 675 |
if (ray -> ro && islight(objptr(ray -> ro -> omod) -> otype))
| 676 |
return;
| 677 |
| 678 |
/* Get cumulative path coefficient up to photon lookup point */
| 679 |
raycontrib(rayCoeff, ray, PRIMARY);
| 680 |
| 681 |
/* Lookup photons */
| 682 |
pmap -> squeue.tail = 0;
| 683 |
findPhotons(pmap, ray);
| 684 |
| 685 |
/* Need at least 2 photons */
| 686 |
if (pmap -> squeue.tail < 2) {
| 687 |
#ifdef PMAP_NONEFOUND
| 688 |
sprintf(errmsg, "no photons found on %s at (%.3f, %.3f, %.3f)",
| 689 |
ray -> ro ? ray -> ro -> oname : "<null>",
| 690 |
ray -> rop [0], ray -> rop [1], ray -> rop [2]);
| 691 |
| 692 |
#endif
| 693 |
| 694 |
return;
| 695 |
| 696 |
| 697 |
/* Average (squared) radius between furthest two photons to improve
| 698 |
* accuracy and get inverse search area 1 / (PI * r^2), with extra
| 699 |
* normalisation factor 1 / PI for ambient calculation */
| 700 |
sqn = pmap -> squeue.node + 1;
| 701 |
r = max(sqn -> dist2, (sqn + 1) -> dist2);
| 702 |
r = 0.25 * (pmap -> maxDist2 + r + 2 * sqrt(pmap -> maxDist2 * r));
| 703 |
invArea = 1 / (PI * PI * r);
| 704 |
| 705 |
/* Skip the extra photon */
| 706 |
for (i = 1 ; i < pmap -> squeue.tail; i++, sqn++) {
| 707 |
COLOR flux;
| 708 |
| 709 |
/* Get photon's contribution to density estimate */
| 710 |
photon = getNearestPhoton(&pmap -> squeue, sqn -> idx);
| 711 |
getPhotonFlux(photon, flux);
| 712 |
scalecolor(flux, invArea);
| 713 |
#ifdef PMAP_EPANECHNIKOV
| 714 |
/* Apply Epanechnikov kernel to photon flux based on photon distance */
| 715 |
scalecolor(flux, 2 * (1 - sqn -> dist2 / r));
| 716 |
#endif
| 717 |
addcolor(irrad, flux);
| 718 |
| 719 |
if (pmap -> srcContrib) {
| 720 |
const PhotonPrimary *primary = pmap -> primaries +
| 721 |
photon -> primary;
| 722 |
const SRCREC *sp = &source [primary -> srcIdx];
| 723 |
OBJREC *srcMod = findmaterial(sp -> so);
| 724 |
MODCONT *srcContrib = (MODCONT*)lu_find(pmap -> srcContrib,
| 725 |
srcMod -> oname) -> data;
| 726 |
double srcBinReal;
| 727 |
int srcBin;
| 728 |
RAY srcRay;
| 729 |
| 730 |
if (!srcContrib)
| 731 |
continue;
| 732 |
| 733 |
/* Photon's emitting light source has modifier whose contributions
| 734 |
* are sought */
| 735 |
if (srcContrib -> binv -> type != NUM) {
| 736 |
/* Use intersection function to set shadow ray parameters if
| 737 |
* it's not simply a constant */
| 738 |
rayorigin(&srcRay, SHADOW, NULL, NULL);
| 739 |
srcRay.rsrc = primary -> srcIdx;
| 740 |
| 741 |
VCOPY(srcRay.rorg, primary -> pos);
| 742 |
#else
| 743 |
/* No primary hitpoints; set dummy ray origin and warn once */
| 744 |
srcRay.rorg [0] = srcRay.rorg [1] = srcRay.rorg [2] = 0;
| 745 |
if (warn) {
| 746 |
error(WARNING, "no photon primary hitpoints for bin evaluation;"
| 747 |
" using dummy (0,0,0) !");
| 748 |
warn = 0;
| 749 |
| 750 |
#endif
| 751 |
decodedir(srcRay.rdir, primary -> dir);
| 752 |
| 753 |
if (!(sp->sflags & SDISTANT
| 754 |
? sourcehit(&srcRay)
| 755 |
: (*ofun[sp -> so -> otype].funp)(sp -> so, &srcRay)))
| 756 |
continue; /* XXX shouldn't happen! */
| 757 |
| 758 |
worldfunc(RCCONTEXT, &srcRay);
| 759 |
set_eparams((char *)srcContrib -> params);
| 760 |
| 761 |
| 762 |
if ((srcBinReal = evalue(srcContrib -> binv)) < -.5)
| 763 |
continue; /* silently ignore negative bins */
| 764 |
| 765 |
if ((srcBin = srcBinReal + .5) >= srcContrib -> nbins) {
| 766 |
error(WARNING, "bad bin number (ignored)");
| 767 |
continue;
| 768 |
| 769 |
| 770 |
if (!contrib) {
| 771 |
/* Ray coefficient mode; normalise by light source radiance
| 772 |
* after applying distrib pattern */
| 773 |
int j;
| 774 |
| 775 |
raytexture(ray, srcMod -> omod);
| 776 |
setcolor(ray -> rcol, srcMod -> oargs.farg [0],
| 777 |
srcMod -> oargs.farg [1], srcMod -> oargs.farg [2]);
| 778 |
multcolor(ray -> rcol, ray -> pcol);
| 779 |
for (j = 0; j < 3; j++)
| 780 |
flux [j] = ray -> rcol [j] ? flux [j] / ray -> rcol [j] : 0;
| 781 |
| 782 |
| 783 |
multcolor(flux, rayCoeff);
| 784 |
addcolor(srcContrib -> cbin [srcBin], flux);
| 785 |
| 786 |
| 787 |
| 788 |
return;
| 789 |
