root/radiance/ray/src/rt/pmapcontrib.c
Tue Feb 16 20:06:06 2021 UTC (4 years, 3 months ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 2.19: +2 -5 lines
Diff to previous 2.19
feat: removed upper limit on number of modifiers in rcontrib
Revision 2.19 - (view) (download) (annotate) - [selected]
Thu Nov 8 00:54:07 2018 UTC (6 years, 6 months ago) by greg
Diff to previous 2.18
Thu Jun 7 19:26:04 2018 UTC (6 years, 11 months ago) by rschregle
Changes since 2.17: +10 -6 lines
Diff to previous 2.17 , to selected 2.19
Added photon distrib PID output to attach debugger
Tue Mar 20 19:55:33 2018 UTC (7 years, 2 months ago) by rschregle
Changes since 2.16: +4 -5 lines
Diff to previous 2.16 , to selected 2.19
Added -ae/-ai ambient exclude options to mkpmap, cleaned up opt parsing.
Fri Mar 16 21:00:09 2018 UTC (7 years, 2 months ago) by rschregle
Changes since 2.15: +79 -18 lines
Diff to previous 2.15 , to selected 2.19
Fixed serious endless predistrib loop bug in distribPhotonContrib(), added
on-demand debugging info via SIGUSR1 from child processes.
Thu Feb 8 19:55:02 2018 UTC (7 years, 3 months ago) by rschregle
Changes since 2.14: +6 -4 lines
Diff to previous 2.14 , to selected 2.19
Made photon primary incident dirs optional via PMAP_PRIMARYDIR, bumped PMAP_FILEVER
Mon Aug 14 21:12:10 2017 UTC (7 years, 9 months ago) by rschregle
Changes since 2.13: +186 -100 lines
Diff to previous 2.13 , to selected 2.19
Updated photon map code for Windows; no multproc or ooC for now
Thu Sep 29 21:51:58 2016 UTC (8 years, 8 months ago) by greg
Changes since 2.12: +3 -206 lines
Diff to previous 2.12 , to selected 2.19
Separated creation from use of contribution photon maps
Tue May 17 17:39:47 2016 UTC (9 years ago) by rschregle
Changes since 2.11: +587 -296 lines
Diff to previous 2.11 , to selected 2.19
Thu Feb 4 11:37:00 2016 UTC (9 years, 3 months ago) by rschregle
Changes since 2.10: +16 -16 lines
Diff to previous 2.10 , to selected 2.19
Minor pmapcontrib cleanup, revised photon normal test in pmapdata
Tue Sep 1 16:27:52 2015 UTC (9 years, 8 months ago) by greg
Diff to previous 2.9 , to selected 2.19
Tue Aug 18 18:45:55 2015 UTC (9 years, 9 months ago) by greg
Diff to previous 2.8 , to selected 2.19
Thu May 21 13:54:59 2015 UTC (10 years ago) by greg
Diff to previous 2.7 , to selected 2.19
Added calls to findmaterial() and simplified photon map shadow check
Wed May 20 14:44:12 2015 UTC (10 years ago) by greg
Changes since 2.6: +7 -6 lines
Diff to previous 2.6 , to selected 2.19
Reduced primary photon struct size using encoded direction
Wed May 20 13:43:28 2015 UTC (10 years ago) by greg
Changes since 2.5: +42 -41 lines
Diff to previous 2.5 , to selected 2.19
Eliminated debug message
Wed May 20 12:58:31 2015 UTC (10 years ago) by greg
Changes since 2.4: +26 -27 lines
Diff to previous 2.4 , to selected 2.19
Added appropriate setting of ray parameters for bin rcontrib evaluation
Fri May 8 13:20:23 2015 UTC (10 years ago) by rschregle
Diff to previous 2.3 , to selected 2.19
Wed Apr 22 20:28:16 2015 UTC (10 years, 1 month ago) by rschregle
Changes since 2.2: +8 -4 lines
Diff to previous 2.2 , to selected 2.19
Disabled use of SIGCONT if undefined (e.g. on WIN32), removed extra space in
rpict reports after biascomp stats
Tue Apr 21 19:16:51 2015 UTC (10 years, 1 month ago) by greg
Changes since 2.1: +1 -2 lines
Diff to previous 2.1 , to selected 2.19
Fixes for Windows and photon map
Tue Feb 24 19:39:26 2015 UTC (10 years, 3 months ago) by greg
Diff to selected 2.19
