root/radiance/ray/src/rt/pmapcontrib.c
Revision: 2.1
Committed: Tue Feb 24 19:39:26 2015 UTC (10 years, 5 months ago) by greg
1 /*
2 ==================================================================
3 Photon map support for light source contributions
4
5 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
6 (c) Fraunhofer Institute for Solar Energy Systems,
7 Lucerne University of Applied Sciences & Arts
8 ==================================================================
9
10 $Id: pmapcontrib.c,v 4.27 2015/02/12 09:57:21 taschreg Exp taschreg $
11 */
12
13
14 #include "pmapcontrib.h"
15 #include "pmap.h"
16 #include "pmapmat.h"
17 #include "pmapsrc.h"
18 #include "pmaprand.h"
19 #include "pmapio.h"
20 #include "pmapdiag.h"
21 #include "rcontrib.h"
22 #include "otypes.h"
23 #include <signal.h>
24
25
26
27 extern int contrib; /* coeff/contrib flag */
28
29
30
31 static void setPmapContribParams (PhotonMap *pmap, LUTAB *srcContrib)
32 /* Set parameters for light source contributions */
33 {
34 /* Set light source modifier list and appropriate callback to extract
35 * their contributions from the photon map */
36 if (pmap) {
37 pmap -> srcContrib = srcContrib;
38 pmap -> lookup = photonContrib;
39 /* Ensure we get all requested photon contribs during lookups */
40 pmap -> gatherTolerance = 1.0;
41 }
42 }
43
44
45
46 static void checkPmapContribs (const PhotonMap *pmap, LUTAB *srcContrib)
47 /* Check modifiers for light source contributions */
48 {
49 const PhotonPrimary *primary = pmap -> primary;
50 OBJREC *srcMod;
51 unsigned long i, found = 0;
52
53 /* Make sure at least one of the modifiers is actually in the pmap,
54 * otherwise findPhotons() winds up in an infinite loop! */
55 for (i = pmap -> primarySize; i; --i, ++primary) {
56 if (primary -> srcIdx < 0 || primary -> srcIdx >= nsources)
57 error(INTERNAL, "invalid light source index in photon map");
58
59 srcMod = objptr(source [primary -> srcIdx].so -> omod);
60 if ((MODCONT*)lu_find(srcContrib, srcMod -> oname) -> data)
61 ++found;
62 }
63
64 if (!found)
65 error(USER, "modifiers not in photon map");
66 }
67
68
69
70 void initPmapContrib (LUTAB *srcContrib, unsigned numSrcContrib)
71 {
72 unsigned t;
73
74 for (t = 0; t < NUM_PMAP_TYPES; t++)
75 if (photonMaps [t] && t != PMAP_TYPE_CONTRIB) {
76 sprintf(errmsg, "%s photon map does not support contributions",
77 pmapName [t]);
78 error(USER, errmsg);
79 }
80
81 /* Get params */
82 setPmapContribParams(contribPmap, srcContrib);
83
84 if (contribPhotonMapping) {
85 if (contribPmap -> maxGather < numSrcContrib) {
86 /* Adjust density estimate bandwidth if lower than modifier
87 * count, otherwise contributions are missing */
88 error(WARNING, "contrib density estimate bandwidth too low, "
89 "adjusting to modifier count");
90 contribPmap -> maxGather = numSrcContrib;
91 }
92
93 /* Sanity check */
94 checkPmapContribs(contribPmap, srcContrib);
95 }
96 }
97
98
99
100 void photonContrib (PhotonMap *pmap, RAY *ray, COLOR irrad)
101 /* Sum up light source contributions from photons in pmap->srcContrib */
102 {
103 unsigned i;
104 PhotonSQNode *sq;
105 float r, invArea;
106 RREAL rayCoeff [3];
107 FVECT rdir, rop;
108
109 setcolor(irrad, 0, 0, 0);
110
111 if (!pmap -> maxGather)
112 return;
113
114 /* Ignore sources */
115 if (ray -> ro)
116 if (islight(objptr(ray -> ro -> omod) -> otype))
117 return;
118
119 /* Set context for binning function evaluation and get cumulative path
120 * coefficient up to photon lookup point */
121 worldfunc(RCCONTEXT, ray);
122 raycontrib(rayCoeff, ray, PRIMARY);
123
124 /* Save incident ray's direction and hitpoint */
125 VCOPY(rdir, ray -> rdir);
126 VCOPY(rop, ray -> rop);
127
128 /* Lookup photons */
129 pmap -> squeueEnd = 0;
130 findPhotons(pmap, ray);
131
132 /* Need at least 2 photons */
133 if (pmap -> squeueEnd < 2) {
134 #ifdef PMAP_NONEFOUND
135 sprintf(errmsg, "no photons found on %s at (%.3f, %.3f, %.3f)",
136 ray -> ro ? ray -> ro -> oname : "<null>",
137 ray -> rop [0], ray -> rop [1], ray -> rop [2]);
138 error(WARNING, errmsg);
139 #endif
140
141 return;
142 }
143
144 /* Average (squared) radius between furthest two photons to improve
145 * accuracy and get inverse search area 1 / (PI * r^2), with extra
146 * normalisation factor 1 / PI for ambient calculation */
147 sq = pmap -> squeue + 1;
148 r = max(sq -> dist, (sq + 1) -> dist);
149 r = 0.25 * (pmap -> maxDist + r + 2 * sqrt(pmap -> maxDist * r));
150 invArea = 1 / (PI * PI * r);
151
152 /* Skip the extra photon */
153 for (i = 1 ; i < pmap -> squeueEnd; i++, sq++) {
154 COLOR flux;
155
156 /* Get photon's contribution to density estimate */
157 getPhotonFlux(sq -> photon, flux);
158 scalecolor(flux, invArea);
159 #ifdef PMAP_EPANECHNIKOV
160 /* Apply Epanechnikov kernel to photon flux (dists are squared) */
161 scalecolor(flux, 2 * (1 - sq -> dist / r));
162 #endif
163 addcolor(irrad, flux);
164
165 if (pmap -> srcContrib) {
166 const PhotonPrimary *primary = pmap -> primary +
167 sq -> photon -> primary;
168 OBJREC *srcMod = objptr(source [primary -> srcIdx].so -> omod);
169 MODCONT *srcContrib = (MODCONT*)lu_find(pmap -> srcContrib,
170 srcMod -> oname) -> data;
171
172 if (srcContrib) {
173 /* Photon's emitting light source has modifier whose
174 * contributions are sought */
175 int srcBin;
176
177 /* Set incident dir and origin of photon's primary ray on
178 * light source for dummy shadow ray, and evaluate binning
179 * function */
180 VCOPY(ray -> rdir, primary -> dir);
181 VCOPY(ray -> rop, primary -> org);
182 srcBin = evalue(srcContrib -> binv) + .5;
183
184 if (srcBin < 0 || srcBin >= srcContrib -> nbins) {
185 error(WARNING, "bad bin number (ignored)");
186 continue;
187 }
188
189 if (!contrib) {
190 /* Ray coefficient mode; normalise by light source radiance
191 * after applying distrib pattern */
192 int j;
193 raytexture(ray, srcMod -> omod);
194 setcolor(ray -> rcol, srcMod -> oargs.farg [0],
195 srcMod -> oargs.farg [1], srcMod -> oargs.farg [2]);
196 multcolor(ray -> rcol, ray -> pcol);
197 for (j = 0; j < 3; j++)
198 flux [j] = ray -> rcol [j] ? flux [j] / ray -> rcol [j]
199 : 0;
200 }
201
202 multcolor(flux, rayCoeff);
203 addcolor(srcContrib -> cbin [srcBin], flux);
204 }
205 else fprintf(stderr, "Skipped contrib from %s\n", srcMod -> oname);
206 }
207 }
208
209 /* Restore incident ray's direction and hitpoint */
210 VCOPY(ray -> rdir, rdir);
211 VCOPY(ray -> rop, rop);
212
213 return;
214 }
215
216
217
218 void distribPhotonContrib (PhotonMap* pm)
219 {
220 EmissionMap emap;
221 char errmsg2 [128];
222 unsigned srcIdx;
223 double *srcFlux; /* Emitted flux per light source */
224 const double srcDistribTarget = /* Target photon count per source */
225 nsources ? (double)pm -> distribTarget / nsources : 0;
226
227 if (!pm)
228 error(USER, "no photon map defined");
229
230 if (!nsources)
231 error(USER, "no light sources");
232
233 /* Allocate photon flux per light source; this differs for every
234 * source as all sources contribute the same number of distributed
235 * photons (srcDistribTarget), hence the number of photons emitted per
236 * source does not correlate with its emitted flux. The resulting flux
237 * per photon is therefore adjusted individually for each source. */
238 if (!(srcFlux = calloc(nsources, sizeof(double))))
239 error(SYSTEM, "cannot allocate source flux");
240
241 /* ================================================================
242 * INITIALISASHUNN - Set up emisshunn and scattering funcs
243 * ================================================================ */
244 emap.samples = NULL;
245 emap.src = NULL;
246 emap.maxPartitions = MAXSPART;
247 emap.partitions = (unsigned char*)malloc(emap.maxPartitions >> 1);
248 if (!emap.partitions)
249 error(USER, "can't allocate source partitions");
250
251 initPhotonMap(pm, PMAP_TYPE_CONTRIB);
252 initPhotonEmissionFuncs();
253 initPhotonScatterFuncs();
254
255 /* Get photon ports if specified */
256 if (ambincl == 1)
257 getPhotonPorts();
258
259 /* Get photon sensor modifiers */
260 getPhotonSensors(photonSensorList);
261
262 /* Seed RNGs for photon distribution */
263 pmapSeed(randSeed, partState);
264 pmapSeed(randSeed, emitState);
265 pmapSeed(randSeed, cntState);
266 pmapSeed(randSeed, mediumState);
267 pmapSeed(randSeed, scatterState);
268 pmapSeed(randSeed, rouletteState);
269
270 /* Record start time and enable progress report signal handler */
271 repStartTime = time(NULL);
272 signal(SIGCONT, pmapDistribReport);
273
274 for (srcIdx = 0; srcIdx < nsources; srcIdx++) {
275 unsigned portCnt = 0, passCnt = 0, prePassCnt = 0;
276 double srcNumEmit = 0; /* # photons to emit from source */
277 unsigned long srcNumDistrib = pm -> heapEnd; /* # photons stored */
278
279 srcFlux [srcIdx] = repProgress = 0;
280 emap.src = source + srcIdx;
281
282 if (photonRepTime)
283 eputs("\n");
284
285 /* =============================================================
286 * FLUX INTEGRATION - Get total flux emitted from light source
287 * ============================================================= */
288 do {
289 emap.port = emap.src -> sflags & SDISTANT
290 ? photonPorts + portCnt : NULL;
291 photonPartition [emap.src -> so -> otype] (&emap);
292
293 if (photonRepTime) {
294 sprintf(errmsg, "Integrating flux from source %s (mod %s) ",
295 source [srcIdx].so -> oname,
296 objptr(source [srcIdx].so -> omod) -> oname);
297
298 if (emap.port) {
299 sprintf(errmsg2, "via port %s ",
300 photonPorts [portCnt].so -> oname);
301 strcat(errmsg, errmsg2);
302 }
303
304 sprintf(errmsg2, "(%lu partitions)...\n",
305 emap.numPartitions);
306 strcat(errmsg, errmsg2);
307 eputs(errmsg);
308 fflush(stderr);
309 }
310
311 for (emap.partitionCnt = 0;
312 emap.partitionCnt < emap.numPartitions;
313 emap.partitionCnt++) {
314 initPhotonEmission(&emap, pdfSamples);
315 srcFlux [srcIdx] += colorAvg(emap.partFlux);
316 }
317
318 portCnt++;
319 } while (portCnt < numPhotonPorts);
320
321 if (srcFlux [srcIdx] < FTINY) {
322 sprintf(errmsg, "source %s has zero emission",
323 source [srcIdx].so -> oname);
324 error(WARNING, errmsg);
325 }
326 else {
327 /* ==========================================================
328 * 2-PASS PHOTON DISTRIBUTION
329 * Pass 1 (pre): emit fraction of target photon count
330 * Pass 2 (main): based on outcome of pass 1, estimate
331 * remaining number of photons to emit to
332 * approximate target count
333 * ========================================================== */
334 do {
335 if (!passCnt) {
336 /* INIT PASS 1 */
337 if (++prePassCnt > maxPreDistrib) {
338 /* Warn if no photons contributed after sufficient
339 * iterations */
340 sprintf(errmsg, "too many prepasses, no photons "
341 "from source %s", source [srcIdx].so -> oname);
342 error(WARNING, errmsg);
343 break;
344 }
345
346 /* Num to emit is fraction of target count */
347 srcNumEmit = preDistrib * srcDistribTarget;
348 }
349
350 else {
351 /* INIT PASS 2 */
352 /* Based on the outcome of the predistribution we can now
353 * figure out how many more photons we have to emit from
354 * the current source to meet the target count,
355 * srcDistribTarget. This value is clamped to 0 in case
356 * the target has already been exceeded in pass 1.
357 * srcNumEmit and srcNumDistrib is the number of photons
358 * emitted and distributed (stored) from the current
359 * source in pass 1, respectively. */
360 srcNumDistrib = pm -> heapEnd - srcNumDistrib;
361 srcNumEmit *= srcNumDistrib
362 ? max(srcDistribTarget/srcNumDistrib, 1) - 1
363 : 0;
364
365 if (!srcNumEmit)
366 /* No photons left to distribute in main pass */
367 break;
368 }
369
370 /* Set completion count for progress report */
371 repComplete = srcNumEmit + repProgress;
372 portCnt = 0;
373
374 do {
375 emap.port = emap.src -> sflags & SDISTANT
376 ? photonPorts + portCnt : NULL;
377 photonPartition [emap.src -> so -> otype] (&emap);
378
379 if (photonRepTime) {
380 if (!passCnt)
381 sprintf(errmsg, "PREPASS %d on source %s (mod %s) ",
382 prePassCnt, source [srcIdx].so -> oname,
383 objptr(source[srcIdx].so->omod) -> oname);
384 else
385 sprintf(errmsg, "MAIN PASS on source %s (mod %s) ",
386 source [srcIdx].so -> oname,
387 objptr(source[srcIdx].so->omod) -> oname);
388
389 if (emap.port) {
390 sprintf(errmsg2, "via port %s ",
391 photonPorts [portCnt].so -> oname);
392 strcat(errmsg, errmsg2);
393 }
394
395 sprintf(errmsg2, "(%lu partitions)...\n",
396 emap.numPartitions);
397 strcat(errmsg, errmsg2);
398 eputs(errmsg);
399 fflush(stderr);
400 }
401
402 for (emap.partitionCnt = 0;
403 emap.partitionCnt < emap.numPartitions;
404 emap.partitionCnt++) {
405 double partNumEmit;
406 unsigned long partEmitCnt;
407
408 /* Get photon origin within current source partishunn
409 * and build emission map */
410 photonOrigin [emap.src -> so -> otype] (&emap);
411 initPhotonEmission(&emap, pdfSamples);
412
413 /* Number of photons to emit from ziss partishunn;
414 * scale according to its normalised contribushunn to
415 * the emitted source flux */
416 partNumEmit = srcNumEmit * colorAvg(emap.partFlux) /
417 srcFlux [srcIdx];
418 partEmitCnt = (unsigned long)partNumEmit;
419
420 /* Probabilistically account for fractional photons */
421 if (pmapRandom(cntState) < partNumEmit - partEmitCnt)
422 partEmitCnt++;
423
424 /* Integer counter avoids FP rounding errors */
425 while (partEmitCnt--) {
426 RAY photonRay;
427
428 /* Emit photon according to PDF (if any), allocate
429 * associated primary ray, and trace through scene
430 * until absorbed/leaked */
431 emitPhoton(&emap, &photonRay);
432 addPhotonPrimary(pm, &photonRay);
433 tracePhoton(&photonRay);
434
435 /* Record progress */
436 repProgress++;
437
438 if (photonRepTime > 0 &&
439 time(NULL) >= repLastTime + photonRepTime)
440 pmapDistribReport();
441 #ifndef BSD
442 else signal(SIGCONT, pmapDistribReport);
443 #endif
444 }
445 }
446
447 portCnt++;
448 } while (portCnt < numPhotonPorts);
449
450 if (pm -> heapEnd == srcNumDistrib)
451 /* Double preDistrib in case no photons were stored
452 * for this source and redo pass 1 */
453 preDistrib *= 2;
454 else {
455 /* Now do pass 2 */
456 passCnt++;
457 if (photonRepTime)
458 eputs("\n");
459 }
460 } while (passCnt < 2);
461
462 /* Flux per photon emitted from this source; repProgress is the
463 * number of emitted photons after both passes */
464 srcFlux [srcIdx] = repProgress ? srcFlux [srcIdx] / repProgress
465 : 0;
466 }
467 }
468
469 /* ================================================================
470 * POST-DISTRIBUTION - Set photon flux and build kd-tree, etc.
471 * ================================================================ */
472 signal(SIGCONT, SIG_DFL);
473 free(emap.samples);
474
475 if (!pm -> heapEnd)
476 error(USER, "empty photon map");
477
478 /* Check for valid primary photon rays */
479 if (!pm -> primary)
480 error(INTERNAL, "no primary rays in contribution photon map");
481
482 if (pm -> primary [pm -> primaryEnd].srcIdx < 0)
483 /* Last primary ray is unused, so decrement counter */
484 pm -> primaryEnd--;
485
486 if (photonRepTime) {
487 eputs("\nBuilding contrib photon heap...\n");
488 fflush(stderr);
489 }
490
491 balancePhotons(pm, srcFlux);
492 }
