1 |
2 |
3 |
Photon map support for light source contributions |
4 |
5 |
Roland Schregle (roland.schregle@{hslu.ch, gmail.com}) |
6 |
(c) Fraunhofer Institute for Solar Energy Systems, |
7 |
Lucerne University of Applied Sciences & Arts |
8 |
9 |
10 |
$Id: pmapcontrib.c,v 4.27 2015/02/12 09:57:21 taschreg Exp taschreg $ |
11 |
12 |
13 |
14 |
#include "pmapcontrib.h" |
15 |
#include "pmap.h" |
16 |
#include "pmapmat.h" |
17 |
#include "pmapsrc.h" |
18 |
#include "pmaprand.h" |
19 |
#include "pmapio.h" |
20 |
#include "pmapdiag.h" |
21 |
#include "rcontrib.h" |
22 |
#include "otypes.h" |
23 |
#include <signal.h> |
24 |
25 |
26 |
27 |
extern int contrib; /* coeff/contrib flag */ |
28 |
29 |
30 |
31 |
static void setPmapContribParams (PhotonMap *pmap, LUTAB *srcContrib) |
32 |
/* Set parameters for light source contributions */ |
33 |
34 |
/* Set light source modifier list and appropriate callback to extract |
35 |
* their contributions from the photon map */ |
36 |
if (pmap) { |
37 |
pmap -> srcContrib = srcContrib; |
38 |
pmap -> lookup = photonContrib; |
39 |
/* Ensure we get all requested photon contribs during lookups */ |
40 |
pmap -> gatherTolerance = 1.0; |
41 |
42 |
43 |
44 |
45 |
46 |
static void checkPmapContribs (const PhotonMap *pmap, LUTAB *srcContrib) |
47 |
/* Check modifiers for light source contributions */ |
48 |
49 |
const PhotonPrimary *primary = pmap -> primary; |
50 |
OBJREC *srcMod; |
51 |
unsigned long i, found = 0; |
52 |
53 |
/* Make sure at least one of the modifiers is actually in the pmap, |
54 |
* otherwise findPhotons() winds up in an infinite loop! */ |
55 |
for (i = pmap -> primarySize; i; --i, ++primary) { |
56 |
if (primary -> srcIdx < 0 || primary -> srcIdx >= nsources) |
57 |
error(INTERNAL, "invalid light source index in photon map"); |
58 |
59 |
srcMod = objptr(source [primary -> srcIdx].so -> omod); |
60 |
if ((MODCONT*)lu_find(srcContrib, srcMod -> oname) -> data) |
61 |
++found; |
62 |
63 |
64 |
if (!found) |
65 |
error(USER, "modifiers not in photon map"); |
66 |
67 |
68 |
69 |
70 |
void initPmapContrib (LUTAB *srcContrib, unsigned numSrcContrib) |
71 |
72 |
unsigned t; |
73 |
74 |
for (t = 0; t < NUM_PMAP_TYPES; t++) |
75 |
if (photonMaps [t] && t != PMAP_TYPE_CONTRIB) { |
76 |
sprintf(errmsg, "%s photon map does not support contributions", |
77 |
pmapName [t]); |
78 |
error(USER, errmsg); |
79 |
80 |
81 |
/* Get params */ |
82 |
setPmapContribParams(contribPmap, srcContrib); |
83 |
84 |
if (contribPhotonMapping) { |
85 |
if (contribPmap -> maxGather < numSrcContrib) { |
86 |
/* Adjust density estimate bandwidth if lower than modifier |
87 |
* count, otherwise contributions are missing */ |
88 |
error(WARNING, "contrib density estimate bandwidth too low, " |
89 |
"adjusting to modifier count"); |
90 |
contribPmap -> maxGather = numSrcContrib; |
91 |
92 |
93 |
/* Sanity check */ |
94 |
checkPmapContribs(contribPmap, srcContrib); |
95 |
96 |
97 |
98 |
99 |
100 |
void photonContrib (PhotonMap *pmap, RAY *ray, COLOR irrad) |
101 |
/* Sum up light source contributions from photons in pmap->srcContrib */ |
102 |
103 |
unsigned i; |
104 |
PhotonSQNode *sq; |
105 |
float r, invArea; |
106 |
RREAL rayCoeff [3]; |
107 |
FVECT rdir, rop; |
108 |
109 |
setcolor(irrad, 0, 0, 0); |
110 |
111 |
if (!pmap -> maxGather) |
112 |
return; |
113 |
114 |
/* Ignore sources */ |
115 |
if (ray -> ro) |
116 |
if (islight(objptr(ray -> ro -> omod) -> otype)) |
117 |
return; |
118 |
119 |
/* Set context for binning function evaluation and get cumulative path |
120 |
* coefficient up to photon lookup point */ |
121 |
worldfunc(RCCONTEXT, ray); |
122 |
raycontrib(rayCoeff, ray, PRIMARY); |
123 |
124 |
/* Save incident ray's direction and hitpoint */ |
125 |
VCOPY(rdir, ray -> rdir); |
126 |
VCOPY(rop, ray -> rop); |
127 |
128 |
/* Lookup photons */ |
129 |
pmap -> squeueEnd = 0; |
130 |
findPhotons(pmap, ray); |
131 |
132 |
/* Need at least 2 photons */ |
133 |
if (pmap -> squeueEnd < 2) { |
134 |
#ifdef PMAP_NONEFOUND |
135 |
sprintf(errmsg, "no photons found on %s at (%.3f, %.3f, %.3f)", |
136 |
ray -> ro ? ray -> ro -> oname : "<null>", |
137 |
ray -> rop [0], ray -> rop [1], ray -> rop [2]); |
138 |
error(WARNING, errmsg); |
139 |
#endif |
140 |
141 |
return; |
142 |
143 |
144 |
/* Average (squared) radius between furthest two photons to improve |
145 |
* accuracy and get inverse search area 1 / (PI * r^2), with extra |
146 |
* normalisation factor 1 / PI for ambient calculation */ |
147 |
sq = pmap -> squeue + 1; |
148 |
r = max(sq -> dist, (sq + 1) -> dist); |
149 |
r = 0.25 * (pmap -> maxDist + r + 2 * sqrt(pmap -> maxDist * r)); |
150 |
invArea = 1 / (PI * PI * r); |
151 |
152 |
/* Skip the extra photon */ |
153 |
for (i = 1 ; i < pmap -> squeueEnd; i++, sq++) { |
154 |
COLOR flux; |
155 |
156 |
/* Get photon's contribution to density estimate */ |
157 |
getPhotonFlux(sq -> photon, flux); |
158 |
scalecolor(flux, invArea); |
159 |
#ifdef PMAP_EPANECHNIKOV |
160 |
/* Apply Epanechnikov kernel to photon flux (dists are squared) */ |
161 |
scalecolor(flux, 2 * (1 - sq -> dist / r)); |
162 |
#endif |
163 |
addcolor(irrad, flux); |
164 |
165 |
if (pmap -> srcContrib) { |
166 |
const PhotonPrimary *primary = pmap -> primary + |
167 |
sq -> photon -> primary; |
168 |
OBJREC *srcMod = objptr(source [primary -> srcIdx].so -> omod); |
169 |
MODCONT *srcContrib = (MODCONT*)lu_find(pmap -> srcContrib, |
170 |
srcMod -> oname) -> data; |
171 |
172 |
if (srcContrib) { |
173 |
/* Photon's emitting light source has modifier whose |
174 |
* contributions are sought */ |
175 |
int srcBin; |
176 |
177 |
/* Set incident dir and origin of photon's primary ray on |
178 |
* light source for dummy shadow ray, and evaluate binning |
179 |
* function */ |
180 |
VCOPY(ray -> rdir, primary -> dir); |
181 |
VCOPY(ray -> rop, primary -> org); |
182 |
srcBin = evalue(srcContrib -> binv) + .5; |
183 |
184 |
if (srcBin < 0 || srcBin >= srcContrib -> nbins) { |
185 |
error(WARNING, "bad bin number (ignored)"); |
186 |
continue; |
187 |
188 |
189 |
if (!contrib) { |
190 |
/* Ray coefficient mode; normalise by light source radiance |
191 |
* after applying distrib pattern */ |
192 |
int j; |
193 |
raytexture(ray, srcMod -> omod); |
194 |
setcolor(ray -> rcol, srcMod -> oargs.farg [0], |
195 |
srcMod -> oargs.farg [1], srcMod -> oargs.farg [2]); |
196 |
multcolor(ray -> rcol, ray -> pcol); |
197 |
for (j = 0; j < 3; j++) |
198 |
flux [j] = ray -> rcol [j] ? flux [j] / ray -> rcol [j] |
199 |
: 0; |
200 |
201 |
202 |
multcolor(flux, rayCoeff); |
203 |
addcolor(srcContrib -> cbin [srcBin], flux); |
204 |
205 |
else fprintf(stderr, "Skipped contrib from %s\n", srcMod -> oname); |
206 |
207 |
208 |
209 |
/* Restore incident ray's direction and hitpoint */ |
210 |
VCOPY(ray -> rdir, rdir); |
211 |
VCOPY(ray -> rop, rop); |
212 |
213 |
return; |
214 |
215 |
216 |
217 |
218 |
void distribPhotonContrib (PhotonMap* pm) |
219 |
220 |
EmissionMap emap; |
221 |
char errmsg2 [128]; |
222 |
unsigned srcIdx; |
223 |
double *srcFlux; /* Emitted flux per light source */ |
224 |
const double srcDistribTarget = /* Target photon count per source */ |
225 |
nsources ? (double)pm -> distribTarget / nsources : 0; |
226 |
227 |
if (!pm) |
228 |
error(USER, "no photon map defined"); |
229 |
230 |
if (!nsources) |
231 |
error(USER, "no light sources"); |
232 |
233 |
/* Allocate photon flux per light source; this differs for every |
234 |
* source as all sources contribute the same number of distributed |
235 |
* photons (srcDistribTarget), hence the number of photons emitted per |
236 |
* source does not correlate with its emitted flux. The resulting flux |
237 |
* per photon is therefore adjusted individually for each source. */ |
238 |
if (!(srcFlux = calloc(nsources, sizeof(double)))) |
239 |
error(SYSTEM, "cannot allocate source flux"); |
240 |
241 |
242 |
* INITIALISASHUNN - Set up emisshunn and scattering funcs |
243 |
244 |
emap.samples = NULL; |
245 |
emap.src = NULL; |
246 |
emap.maxPartitions = MAXSPART; |
247 |
emap.partitions = (unsigned char*)malloc(emap.maxPartitions >> 1); |
248 |
if (!emap.partitions) |
249 |
error(USER, "can't allocate source partitions"); |
250 |
251 |
initPhotonMap(pm, PMAP_TYPE_CONTRIB); |
252 |
initPhotonEmissionFuncs(); |
253 |
initPhotonScatterFuncs(); |
254 |
255 |
/* Get photon ports if specified */ |
256 |
if (ambincl == 1) |
257 |
getPhotonPorts(); |
258 |
259 |
/* Get photon sensor modifiers */ |
260 |
getPhotonSensors(photonSensorList); |
261 |
262 |
/* Seed RNGs for photon distribution */ |
263 |
pmapSeed(randSeed, partState); |
264 |
pmapSeed(randSeed, emitState); |
265 |
pmapSeed(randSeed, cntState); |
266 |
pmapSeed(randSeed, mediumState); |
267 |
pmapSeed(randSeed, scatterState); |
268 |
pmapSeed(randSeed, rouletteState); |
269 |
270 |
/* Record start time and enable progress report signal handler */ |
271 |
repStartTime = time(NULL); |
272 |
signal(SIGCONT, pmapDistribReport); |
273 |
274 |
for (srcIdx = 0; srcIdx < nsources; srcIdx++) { |
275 |
unsigned portCnt = 0, passCnt = 0, prePassCnt = 0; |
276 |
double srcNumEmit = 0; /* # photons to emit from source */ |
277 |
unsigned long srcNumDistrib = pm -> heapEnd; /* # photons stored */ |
278 |
279 |
srcFlux [srcIdx] = repProgress = 0; |
280 |
emap.src = source + srcIdx; |
281 |
282 |
if (photonRepTime) |
283 |
eputs("\n"); |
284 |
285 |
286 |
* FLUX INTEGRATION - Get total flux emitted from light source |
287 |
288 |
do { |
289 |
emap.port = emap.src -> sflags & SDISTANT |
290 |
? photonPorts + portCnt : NULL; |
291 |
photonPartition [emap.src -> so -> otype] (&emap); |
292 |
293 |
if (photonRepTime) { |
294 |
sprintf(errmsg, "Integrating flux from source %s (mod %s) ", |
295 |
source [srcIdx].so -> oname, |
296 |
objptr(source [srcIdx].so -> omod) -> oname); |
297 |
298 |
if (emap.port) { |
299 |
sprintf(errmsg2, "via port %s ", |
300 |
photonPorts [portCnt].so -> oname); |
301 |
strcat(errmsg, errmsg2); |
302 |
303 |
304 |
sprintf(errmsg2, "(%lu partitions)...\n", |
305 |
emap.numPartitions); |
306 |
307 |
eputs(errmsg); |
308 |
fflush(stderr); |
309 |
310 |
311 |
for (emap.partitionCnt = 0; |
312 |
emap.partitionCnt < emap.numPartitions; |
313 |
emap.partitionCnt++) { |
314 |
initPhotonEmission(&emap, pdfSamples); |
315 |
srcFlux [srcIdx] += colorAvg(emap.partFlux); |
316 |
317 |
318 |
portCnt++; |
319 |
} while (portCnt < numPhotonPorts); |
320 |
321 |
if (srcFlux [srcIdx] < FTINY) { |
322 |
sprintf(errmsg, "source %s has zero emission", |
323 |
source [srcIdx].so -> oname); |
324 |
325 |
326 |
else { |
327 |
328 |
* 2-PASS PHOTON DISTRIBUTION |
329 |
* Pass 1 (pre): emit fraction of target photon count |
330 |
* Pass 2 (main): based on outcome of pass 1, estimate |
331 |
* remaining number of photons to emit to |
332 |
* approximate target count |
333 |
334 |
do { |
335 |
if (!passCnt) { |
336 |
/* INIT PASS 1 */ |
337 |
if (++prePassCnt > maxPreDistrib) { |
338 |
/* Warn if no photons contributed after sufficient |
339 |
* iterations */ |
340 |
sprintf(errmsg, "too many prepasses, no photons " |
341 |
"from source %s", source [srcIdx].so -> oname); |
342 |
343 |
break; |
344 |
345 |
346 |
/* Num to emit is fraction of target count */ |
347 |
srcNumEmit = preDistrib * srcDistribTarget; |
348 |
349 |
350 |
else { |
351 |
/* INIT PASS 2 */ |
352 |
/* Based on the outcome of the predistribution we can now |
353 |
* figure out how many more photons we have to emit from |
354 |
* the current source to meet the target count, |
355 |
* srcDistribTarget. This value is clamped to 0 in case |
356 |
* the target has already been exceeded in pass 1. |
357 |
* srcNumEmit and srcNumDistrib is the number of photons |
358 |
* emitted and distributed (stored) from the current |
359 |
* source in pass 1, respectively. */ |
360 |
srcNumDistrib = pm -> heapEnd - srcNumDistrib; |
361 |
srcNumEmit *= srcNumDistrib |
362 |
? max(srcDistribTarget/srcNumDistrib, 1) - 1 |
363 |
: 0; |
364 |
365 |
if (!srcNumEmit) |
366 |
/* No photons left to distribute in main pass */ |
367 |
break; |
368 |
369 |
370 |
/* Set completion count for progress report */ |
371 |
repComplete = srcNumEmit + repProgress; |
372 |
portCnt = 0; |
373 |
374 |
do { |
375 |
376 |
377 |
378 |
379 |
380 |
if (!passCnt) |
381 |
sprintf(errmsg, "PREPASS %d on source %s (mod %s) ", |
382 |
prePassCnt, source [srcIdx].so -> oname, |
383 |
objptr(source[srcIdx].so->omod) -> oname); |
384 |
else |
385 |
sprintf(errmsg, "MAIN PASS on source %s (mod %s) ", |
386 |
387 |
388 |
389 |
if (emap.port) { |
390 |
391 |
392 |
393 |
394 |
395 |
396 |
397 |
398 |
eputs(errmsg); |
399 |
fflush(stderr); |
400 |
401 |
402 |
403 |
404 |
405 |
double partNumEmit; |
406 |
unsigned long partEmitCnt; |
407 |
408 |
/* Get photon origin within current source partishunn |
409 |
* and build emission map */ |
410 |
photonOrigin [emap.src -> so -> otype] (&emap); |
411 |
412 |
413 |
/* Number of photons to emit from ziss partishunn; |
414 |
* scale according to its normalised contribushunn to |
415 |
* the emitted source flux */ |
416 |
partNumEmit = srcNumEmit * colorAvg(emap.partFlux) / |
417 |
srcFlux [srcIdx]; |
418 |
partEmitCnt = (unsigned long)partNumEmit; |
419 |
420 |
/* Probabilistically account for fractional photons */ |
421 |
if (pmapRandom(cntState) < partNumEmit - partEmitCnt) |
422 |
partEmitCnt++; |
423 |
424 |
/* Integer counter avoids FP rounding errors */ |
425 |
while (partEmitCnt--) { |
426 |
RAY photonRay; |
427 |
428 |
/* Emit photon according to PDF (if any), allocate |
429 |
* associated primary ray, and trace through scene |
430 |
* until absorbed/leaked */ |
431 |
emitPhoton(&emap, &photonRay); |
432 |
addPhotonPrimary(pm, &photonRay); |
433 |
tracePhoton(&photonRay); |
434 |
435 |
/* Record progress */ |
436 |
repProgress++; |
437 |
438 |
if (photonRepTime > 0 && |
439 |
time(NULL) >= repLastTime + photonRepTime) |
440 |
pmapDistribReport(); |
441 |
#ifndef BSD |
442 |
else signal(SIGCONT, pmapDistribReport); |
443 |
#endif |
444 |
445 |
446 |
447 |
portCnt++; |
448 |
449 |
450 |
if (pm -> heapEnd == srcNumDistrib) |
451 |
/* Double preDistrib in case no photons were stored |
452 |
* for this source and redo pass 1 */ |
453 |
preDistrib *= 2; |
454 |
else { |
455 |
/* Now do pass 2 */ |
456 |
passCnt++; |
457 |
458 |
eputs("\n"); |
459 |
460 |
} while (passCnt < 2); |
461 |
462 |
/* Flux per photon emitted from this source; repProgress is the |
463 |
* number of emitted photons after both passes */ |
464 |
srcFlux [srcIdx] = repProgress ? srcFlux [srcIdx] / repProgress |
465 |
: 0; |
466 |
467 |
468 |
469 |
470 |
* POST-DISTRIBUTION - Set photon flux and build kd-tree, etc. |
471 |
472 |
signal(SIGCONT, SIG_DFL); |
473 |
free(emap.samples); |
474 |
475 |
if (!pm -> heapEnd) |
476 |
error(USER, "empty photon map"); |
477 |
478 |
/* Check for valid primary photon rays */ |
479 |
if (!pm -> primary) |
480 |
error(INTERNAL, "no primary rays in contribution photon map"); |
481 |
482 |
if (pm -> primary [pm -> primaryEnd].srcIdx < 0) |
483 |
/* Last primary ray is unused, so decrement counter */ |
484 |
pm -> primaryEnd--; |
485 |
486 |
487 |
eputs("\nBuilding contrib photon heap...\n"); |
488 |
fflush(stderr); |
489 |
490 |
491 |
balancePhotons(pm, srcFlux); |
492 |
