root/radiance/ray/src/rt/pmapcontrib.c
Revision: 2.8
Committed: Thu May 21 13:54:59 2015 UTC (10 years, 1 month ago) by greg
Added calls to findmaterial() and simplified photon map shadow check
1 /*
2 ==================================================================
3 Photon map support for light source contributions
4
5 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
6 (c) Lucerne University of Applied Sciences and Arts,
7 supported by the Swiss National Science Foundation (SNSF, #147053)
8 ==================================================================
9
10 $Id: pmapcontrib.c,v 2.7 2015/05/20 14:44:12 greg Exp $
11 */
12
13
14 #include "pmapcontrib.h"
15 #include "pmap.h"
16 #include "pmapmat.h"
17 #include "pmapsrc.h"
18 #include "pmaprand.h"
19 #include "pmapio.h"
20 #include "pmapdiag.h"
21 #include "rcontrib.h"
22 #include "otypes.h"
23
24
25
26 static void setPmapContribParams (PhotonMap *pmap, LUTAB *srcContrib)
27 /* Set parameters for light source contributions */
28 {
29 /* Set light source modifier list and appropriate callback to extract
30 * their contributions from the photon map */
31 if (pmap) {
32 pmap -> srcContrib = srcContrib;
33 pmap -> lookup = photonContrib;
34 /* Ensure we get all requested photon contribs during lookups */
35 pmap -> gatherTolerance = 1.0;
36 }
37 }
38
39
40
41 static void checkPmapContribs (const PhotonMap *pmap, LUTAB *srcContrib)
42 /* Check modifiers for light source contributions */
43 {
44 const PhotonPrimary *primary = pmap -> primary;
45 OBJREC *srcMod;
46 unsigned long i, found = 0;
47
48 /* Make sure at least one of the modifiers is actually in the pmap,
49 * otherwise findPhotons() winds up in an infinite loop! */
50 for (i = pmap -> primarySize; i; --i, ++primary) {
51 if (primary -> srcIdx < 0 || primary -> srcIdx >= nsources)
52 error(INTERNAL, "invalid light source index in photon map");
53
54 srcMod = findmaterial(source [primary -> srcIdx].so);
55 if ((MODCONT*)lu_find(srcContrib, srcMod -> oname) -> data)
56 ++found;
57 }
58
59 if (!found)
60 error(USER, "modifiers not in photon map");
61 }
62
63
64
65 void initPmapContrib (LUTAB *srcContrib, unsigned numSrcContrib)
66 {
67 unsigned t;
68
69 for (t = 0; t < NUM_PMAP_TYPES; t++)
70 if (photonMaps [t] && t != PMAP_TYPE_CONTRIB) {
71 sprintf(errmsg, "%s photon map does not support contributions",
72 pmapName [t]);
73 error(USER, errmsg);
74 }
75
76 /* Get params */
77 setPmapContribParams(contribPmap, srcContrib);
78
79 if (contribPhotonMapping) {
80 if (contribPmap -> maxGather < numSrcContrib) {
81 /* Adjust density estimate bandwidth if lower than modifier
82 * count, otherwise contributions are missing */
83 error(WARNING, "contrib density estimate bandwidth too low, "
84 "adjusting to modifier count");
85 contribPmap -> maxGather = numSrcContrib;
86 }
87
88 /* Sanity check */
89 checkPmapContribs(contribPmap, srcContrib);
90 }
91 }
92
93
94
95 void photonContrib (PhotonMap *pmap, RAY *ray, COLOR irrad)
96 /* Sum up light source contributions from photons in pmap->srcContrib */
97 {
98 unsigned i;
99 PhotonSQNode *sq;
100 float r, invArea;
101 RREAL rayCoeff [3];
102
103 setcolor(irrad, 0, 0, 0);
104
105 if (!pmap -> maxGather)
106 return;
107
108 /* Ignore sources */
109 if (ray -> ro)
110 if (islight(objptr(ray -> ro -> omod) -> otype))
111 return;
112
113 /* Get cumulative path
114 * coefficient up to photon lookup point */
115 raycontrib(rayCoeff, ray, PRIMARY);
116
117 /* Lookup photons */
118 pmap -> squeueEnd = 0;
119 findPhotons(pmap, ray);
120
121 /* Need at least 2 photons */
122 if (pmap -> squeueEnd < 2) {
123 #ifdef PMAP_NONEFOUND
124 sprintf(errmsg, "no photons found on %s at (%.3f, %.3f, %.3f)",
125 ray -> ro ? ray -> ro -> oname : "<null>",
126 ray -> rop [0], ray -> rop [1], ray -> rop [2]);
127 error(WARNING, errmsg);
128 #endif
129
130 return;
131 }
132
133 /* Average (squared) radius between furthest two photons to improve
134 * accuracy and get inverse search area 1 / (PI * r^2), with extra
135 * normalisation factor 1 / PI for ambient calculation */
136 sq = pmap -> squeue + 1;
137 r = max(sq -> dist, (sq + 1) -> dist);
138 r = 0.25 * (pmap -> maxDist + r + 2 * sqrt(pmap -> maxDist * r));
139 invArea = 1 / (PI * PI * r);
140
141 /* Skip the extra photon */
142 for (i = 1 ; i < pmap -> squeueEnd; i++, sq++) {
143 COLOR flux;
144
145 /* Get photon's contribution to density estimate */
146 getPhotonFlux(sq -> photon, flux);
147 scalecolor(flux, invArea);
148 #ifdef PMAP_EPANECHNIKOV
149 /* Apply Epanechnikov kernel to photon flux (dists are squared) */
150 scalecolor(flux, 2 * (1 - sq -> dist / r));
151 #endif
152 addcolor(irrad, flux);
153
154 if (pmap -> srcContrib) {
155 const PhotonPrimary *primary = pmap -> primary +
156 sq -> photon -> primary;
157 const SRCREC *sp = &source[primary -> srcIdx];
158 OBJREC *srcMod = findmaterial(sp -> so);
159 MODCONT *srcContrib = (MODCONT*)lu_find(pmap -> srcContrib,
160 srcMod -> oname) -> data;
161 if (!srcContrib)
162 continue;
163
164 /* Photon's emitting light source has modifier whose
165 * contributions are sought */
166 double srcBinReal;
167 int srcBin;
168 RAY srcRay;
169
170 if (srcContrib -> binv -> type != NUM) {
171 /* Use intersection function to set shadow ray parameters
172 * if it's not simply a constant
173 */
174 rayorigin(&srcRay, SHADOW, NULL, NULL);
175 srcRay.rsrc = primary -> srcIdx;
176 VCOPY(srcRay.rorg, primary -> pos);
177 decodedir(srcRay.rdir, primary -> dir);
178
179 if (!(sp->sflags & SDISTANT ? sourcehit(&srcRay)
180 : (*ofun[sp -> so -> otype].funp)(sp -> so, &srcRay)))
181 continue; /* XXX shouldn't happen! */
182
183 worldfunc(RCCONTEXT, &srcRay);
184 set_eparams((char *)srcContrib -> params);
185 }
186
187 if ((srcBinReal = evalue(srcContrib -> binv)) < -.5)
188 continue; /* silently ignore negative bins */
189
190 if ((srcBin = srcBinReal + .5) >= srcContrib -> nbins) {
191 error(WARNING, "bad bin number (ignored)");
192 continue;
193 }
194
195 if (!contrib) {
196 /* Ray coefficient mode; normalise by light source radiance
197 * after applying distrib pattern */
198 int j;
199 raytexture(ray, srcMod -> omod);
200 setcolor(ray -> rcol, srcMod -> oargs.farg [0],
201 srcMod -> oargs.farg [1], srcMod -> oargs.farg [2]);
202 multcolor(ray -> rcol, ray -> pcol);
203 for (j = 0; j < 3; j++)
204 flux [j] = ray -> rcol [j] ? flux [j] / ray -> rcol [j]
205 : 0;
206 }
207
208 multcolor(flux, rayCoeff);
209 addcolor(srcContrib -> cbin [srcBin], flux);
210 }
211 }
212
213 return;
214 }
215
216
217
218 void distribPhotonContrib (PhotonMap* pm)
219 {
220 EmissionMap emap;
221 char errmsg2 [128];
222 unsigned srcIdx;
223 double *srcFlux; /* Emitted flux per light source */
224 const double srcDistribTarget = /* Target photon count per source */
225 nsources ? (double)pm -> distribTarget / nsources : 0;
226
227 if (!pm)
228 error(USER, "no photon map defined");
229
230 if (!nsources)
231 error(USER, "no light sources");
232
233 /* Allocate photon flux per light source; this differs for every
234 * source as all sources contribute the same number of distributed
235 * photons (srcDistribTarget), hence the number of photons emitted per
236 * source does not correlate with its emitted flux. The resulting flux
237 * per photon is therefore adjusted individually for each source. */
238 if (!(srcFlux = calloc(nsources, sizeof(double))))
239 error(SYSTEM, "cannot allocate source flux");
240
241 /* ================================================================
242 * INITIALISASHUNN - Set up emisshunn and scattering funcs
243 * ================================================================ */
244 emap.samples = NULL;
245 emap.src = NULL;
246 emap.maxPartitions = MAXSPART;
247 emap.partitions = (unsigned char*)malloc(emap.maxPartitions >> 1);
248 if (!emap.partitions)
249 error(USER, "can't allocate source partitions");
250
251 initPhotonMap(pm, PMAP_TYPE_CONTRIB);
252 initPhotonEmissionFuncs();
253 initPhotonScatterFuncs();
254
255 /* Get photon ports if specified */
256 if (ambincl == 1)
257 getPhotonPorts();
258
259 /* Get photon sensor modifiers */
260 getPhotonSensors(photonSensorList);
261
262 /* Seed RNGs for photon distribution */
263 pmapSeed(randSeed, partState);
264 pmapSeed(randSeed, emitState);
265 pmapSeed(randSeed, cntState);
266 pmapSeed(randSeed, mediumState);
267 pmapSeed(randSeed, scatterState);
268 pmapSeed(randSeed, rouletteState);
269
270 /* Record start time and enable progress report signal handler */
271 repStartTime = time(NULL);
272 #ifdef SIGCONT
273 signal(SIGCONT, pmapDistribReport);
274 #endif
275
276 for (srcIdx = 0; srcIdx < nsources; srcIdx++) {
277 unsigned portCnt = 0, passCnt = 0, prePassCnt = 0;
278 double srcNumEmit = 0; /* # photons to emit from source */
279 unsigned long srcNumDistrib = pm -> heapEnd; /* # photons stored */
280
281 srcFlux [srcIdx] = repProgress = 0;
282 emap.src = source + srcIdx;
283
284 if (photonRepTime)
285 eputs("\n");
286
287 /* =============================================================
288 * FLUX INTEGRATION - Get total flux emitted from light source
289 * ============================================================= */
290 do {
291 emap.port = emap.src -> sflags & SDISTANT
292 ? photonPorts + portCnt : NULL;
293 photonPartition [emap.src -> so -> otype] (&emap);
294
295 if (photonRepTime) {
296 sprintf(errmsg, "Integrating flux from source %s (mod %s) ",
297 source [srcIdx].so -> oname,
298 objptr(source [srcIdx].so -> omod) -> oname);
299
300 if (emap.port) {
301 sprintf(errmsg2, "via port %s ",
302 photonPorts [portCnt].so -> oname);
303 strcat(errmsg, errmsg2);
304 }
305
306 sprintf(errmsg2, "(%lu partitions)...\n",
307 emap.numPartitions);
308 strcat(errmsg, errmsg2);
309 eputs(errmsg);
310 fflush(stderr);
311 }
312
313 for (emap.partitionCnt = 0;
314 emap.partitionCnt < emap.numPartitions;
315 emap.partitionCnt++) {
316 initPhotonEmission(&emap, pdfSamples);
317 srcFlux [srcIdx] += colorAvg(emap.partFlux);
318 }
319
320 portCnt++;
321 } while (portCnt < numPhotonPorts);
322
323 if (srcFlux [srcIdx] < FTINY) {
324 sprintf(errmsg, "source %s has zero emission",
325 source [srcIdx].so -> oname);
326 error(WARNING, errmsg);
327 }
328 else {
329 /* ==========================================================
330 * 2-PASS PHOTON DISTRIBUTION
331 * Pass 1 (pre): emit fraction of target photon count
332 * Pass 2 (main): based on outcome of pass 1, estimate
333 * remaining number of photons to emit to
334 * approximate target count
335 * ========================================================== */
336 do {
337 if (!passCnt) {
338 /* INIT PASS 1 */
339 if (++prePassCnt > maxPreDistrib) {
340 /* Warn if no photons contributed after sufficient
341 * iterations */
342 sprintf(errmsg, "too many prepasses, no photons "
343 "from source %s", source [srcIdx].so -> oname);
344 error(WARNING, errmsg);
345 break;
346 }
347
348 /* Num to emit is fraction of target count */
349 srcNumEmit = preDistrib * srcDistribTarget;
350 }
351
352 else {
353 /* INIT PASS 2 */
354 /* Based on the outcome of the predistribution we can now
355 * figure out how many more photons we have to emit from
356 * the current source to meet the target count,
357 * srcDistribTarget. This value is clamped to 0 in case
358 * the target has already been exceeded in pass 1.
359 * srcNumEmit and srcNumDistrib is the number of photons
360 * emitted and distributed (stored) from the current
361 * source in pass 1, respectively. */
362 srcNumDistrib = pm -> heapEnd - srcNumDistrib;
363 srcNumEmit *= srcNumDistrib
364 ? max(srcDistribTarget/srcNumDistrib, 1) - 1
365 : 0;
366
367 if (!srcNumEmit)
368 /* No photons left to distribute in main pass */
369 break;
370 }
371
372 /* Set completion count for progress report */
373 repComplete = srcNumEmit + repProgress;
374 portCnt = 0;
375
376 do {
377 emap.port = emap.src -> sflags & SDISTANT
378 ? photonPorts + portCnt : NULL;
379 photonPartition [emap.src -> so -> otype] (&emap);
380
381 if (photonRepTime) {
382 if (!passCnt)
383 sprintf(errmsg, "PREPASS %d on source %s (mod %s) ",
384 prePassCnt, source [srcIdx].so -> oname,
385 objptr(source[srcIdx].so->omod) -> oname);
386 else
387 sprintf(errmsg, "MAIN PASS on source %s (mod %s) ",
388 source [srcIdx].so -> oname,
389 objptr(source[srcIdx].so->omod) -> oname);
390
391 if (emap.port) {
392 sprintf(errmsg2, "via port %s ",
393 photonPorts [portCnt].so -> oname);
394 strcat(errmsg, errmsg2);
395 }
396
397 sprintf(errmsg2, "(%lu partitions)...\n",
398 emap.numPartitions);
399 strcat(errmsg, errmsg2);
400 eputs(errmsg);
401 fflush(stderr);
402 }
403
404 for (emap.partitionCnt = 0;
405 emap.partitionCnt < emap.numPartitions;
406 emap.partitionCnt++) {
407 double partNumEmit;
408 unsigned long partEmitCnt;
409
410 /* Get photon origin within current source partishunn
411 * and build emission map */
412 photonOrigin [emap.src -> so -> otype] (&emap);
413 initPhotonEmission(&emap, pdfSamples);
414
415 /* Number of photons to emit from ziss partishunn;
416 * scale according to its normalised contribushunn to
417 * the emitted source flux */
418 partNumEmit = srcNumEmit * colorAvg(emap.partFlux) /
419 srcFlux [srcIdx];
420 partEmitCnt = (unsigned long)partNumEmit;
421
422 /* Probabilistically account for fractional photons */
423 if (pmapRandom(cntState) < partNumEmit - partEmitCnt)
424 partEmitCnt++;
425
426 /* Integer counter avoids FP rounding errors */
427 while (partEmitCnt--) {
428 RAY photonRay;
429
430 /* Emit photon according to PDF (if any), allocate
431 * associated primary ray, and trace through scene
432 * until absorbed/leaked */
433 emitPhoton(&emap, &photonRay);
434 addPhotonPrimary(pm, &photonRay);
435 tracePhoton(&photonRay);
436
437 /* Record progress */
438 repProgress++;
439
440 if (photonRepTime > 0 &&
441 time(NULL) >= repLastTime + photonRepTime)
442 pmapDistribReport();
443 #ifdef SIGCONT
444 else signal(SIGCONT, pmapDistribReport);
445 #endif
446 }
447 }
448
449 portCnt++;
450 } while (portCnt < numPhotonPorts);
451
452 if (pm -> heapEnd == srcNumDistrib)
453 /* Double preDistrib in case no photons were stored
454 * for this source and redo pass 1 */
455 preDistrib *= 2;
456 else {
457 /* Now do pass 2 */
458 passCnt++;
459 if (photonRepTime)
460 eputs("\n");
461 }
462 } while (passCnt < 2);
463
464 /* Flux per photon emitted from this source; repProgress is the
465 * number of emitted photons after both passes */
466 srcFlux [srcIdx] = repProgress ? srcFlux [srcIdx] / repProgress
467 : 0;
468 }
469 }
470
471 /* ================================================================
472 * POST-DISTRIBUTION - Set photon flux and build kd-tree, etc.
473 * ================================================================ */
474 #ifdef SIGCONT
475 signal(SIGCONT, SIG_DFL);
476 #endif
477 free(emap.samples);
478
479 if (!pm -> heapEnd)
480 error(USER, "empty photon map");
481
482 /* Check for valid primary photon rays */
483 if (!pm -> primary)
484 error(INTERNAL, "no primary rays in contribution photon map");
485
486 if (pm -> primary [pm -> primaryEnd].srcIdx < 0)
487 /* Last primary ray is unused, so decrement counter */
488 pm -> primaryEnd--;
489
490 if (photonRepTime) {
491 eputs("\nBuilding contrib photon heap...\n");
492 fflush(stderr);
493 }
494
495 balancePhotons(pm, srcFlux);
496 }
