root/radiance/ray/src/rt/pmapcontrib.c
Mon Aug 14 21:12:10 2017 UTC (6 years, 9 months ago) by rschregle
Changes since 2.13: +186 -100 lines
Updated photon map code for Windows; no multproc or ooC for now
Thu Sep 29 21:51:58 2016 UTC (7 years, 8 months ago) by greg
Changes since 2.12: +3 -206 lines
Separated creation from use of contribution photon maps
Tue May 17 17:39:47 2016 UTC (8 years ago) by rschregle
Changes since 2.11: +587 -296 lines
Thu Feb 4 11:37:00 2016 UTC (8 years, 4 months ago) by rschregle
Changes since 2.10: +16 -16 lines
Minor pmapcontrib cleanup, revised photon normal test in pmapdata
Tue Sep 1 16:27:52 2015 UTC (8 years, 9 months ago) by greg
Tue Aug 18 18:45:55 2015 UTC (8 years, 9 months ago) by greg
Thu May 21 13:54:59 2015 UTC (9 years ago) by greg
Added calls to findmaterial() and simplified photon map shadow check
Wed May 20 14:44:12 2015 UTC (9 years ago) by greg
Changes since 2.6: +7 -6 lines
Reduced primary photon struct size using encoded direction
Wed May 20 13:43:28 2015 UTC (9 years ago) by greg
Changes since 2.5: +42 -41 lines
Eliminated debug message
Wed May 20 12:58:31 2015 UTC (9 years ago) by greg
Changes since 2.4: +26 -27 lines
Added appropriate setting of ray parameters for bin rcontrib evaluation
Fri May 8 13:20:23 2015 UTC (9 years, 1 month ago) by rschregle
Wed Apr 22 20:28:16 2015 UTC (9 years, 1 month ago) by rschregle
Changes since 2.2: +8 -4 lines
Disabled use of SIGCONT if undefined (e.g. on WIN32), removed extra space in
rpict reports after biascomp stats
Tue Apr 21 19:16:51 2015 UTC (9 years, 1 month ago) by greg
Changes since 2.1: +1 -2 lines
Fixes for Windows and photon map
Tue Feb 24 19:39:26 2015 UTC (9 years, 3 months ago) by greg
Diff to selected 2.11
