root/radiance/ray/src/rt/pmapcontrib.c
Revision: 2.19
Committed: Thu Nov 8 00:54:07 2018 UTC (6 years, 6 months ago) by greg
2 static const char RCSid[] = "$Id: pmapcontrib.c,v 2.18 2018/06/07 19:26:04 rschregle Exp $";
4
5 /*
6 ======================================================================
7 Photon map for light source contributions
8
9 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
10 (c) Lucerne University of Applied Sciences and Arts,
11 supported by the Swiss National Science Foundation (SNSF, #147053)
12 ======================================================================
13
14 $Id: pmapcontrib.c,v 2.18 2018/06/07 19:26:04 rschregle Exp $
15 */
16
17
18 #include "pmapcontrib.h"
19 #include "pmapmat.h"
20 #include "pmapsrc.h"
21 #include "pmaprand.h"
22 #include "pmapio.h"
23 #include "pmapdiag.h"
24 #include "rcontrib.h"
25 #include "otypes.h"
26 #include "otspecial.h"
27 #if NIX
28 #include <sys/mman.h>
29 #include <sys/wait.h>
30 #endif
31
32
33 static PhotonPrimaryIdx newPhotonPrimary (PhotonMap *pmap,
34 const RAY *primRay,
35 FILE *primHeap)
36 /* Add primary ray for emitted photon and save light source index, origin on
37 * source, and emitted direction; used by contrib photons. The current
38 * primary is stored in pmap -> lastPrimary. If the previous primary
39 * contributed photons (has srcIdx >= 0), it's appended to primHeap. If
40 * primRay == NULL, the current primary is still flushed, but no new primary
41 * is set. Returns updated primary counter pmap -> numPrimary. */
42 {
43 if (!pmap || !primHeap)
44 return 0;
45
46 /* Check if last primary ray has spawned photons (srcIdx >= 0, see
47 * newPhoton()), in which case we save it to the primary heap file
48 * before clobbering it */
49 if (pmap -> lastPrimary.srcIdx >= 0) {
50 if (!fwrite(&pmap -> lastPrimary, sizeof(PhotonPrimary), 1, primHeap))
51 error(SYSTEM, "failed writing photon primary in newPhotonPrimary");
52
53 pmap -> numPrimary++;
54 if (pmap -> numPrimary > PMAP_MAXPRIMARY)
55 error(INTERNAL, "photon primary overflow in newPhotonPrimary");
56 }
57
58 /* Mark unused with negative source index until path spawns a photon (see
59 * newPhoton()) */
60 pmap -> lastPrimary.srcIdx = -1;
61
62 if (primRay) {
63 FVECT dvec;
64
65 #ifdef PMAP_PRIMARYDIR
66 /* Reverse incident direction to point to light source */
67 dvec [0] = -primRay -> rdir [0];
68 dvec [1] = -primRay -> rdir [1];
69 dvec [2] = -primRay -> rdir [2];
70 pmap -> lastPrimary.dir = encodedir(dvec);
71 #endif
72 #ifdef PMAP_PRIMARYPOS
73 VCOPY(pmap -> lastPrimary.pos, primRay -> rop);
74 #endif
75 }
76
77 return pmap -> numPrimary;
78 }
79
80
81
82 #ifdef DEBUG_PMAP
83 static int checkPrimaryHeap (FILE *file)
84 /* Check heap for ordered primaries */
85 {
86 Photon p, lastp;
87 int i, dup;
88
89 rewind(file);
90 memset(&lastp, 0, sizeof(lastp));
91
92 while (fread(&p, sizeof(p), 1, file)) {
93 dup = 1;
94
95 for (i = 0; i <= 2; i++) {
96 if (p.pos [i] < thescene.cuorg [i] ||
97 p.pos [i] > thescene.cuorg [i] + thescene.cusize) {
98
99 sprintf(errmsg, "corrupt photon in heap at [%f, %f, %f]\n",
100 p.pos [0], p.pos [1], p.pos [2]);
101 error(WARNING, errmsg);
102 }
103
104 dup &= p.pos [i] == lastp.pos [i];
105 }
106
107 if (dup) {
108 sprintf(errmsg,
109 "consecutive duplicate photon in heap at [%f, %f, %f]\n",
110 p.pos [0], p.pos [1], p.pos [2]);
111 error(WARNING, errmsg);
112 }
113 }
114
115 return 0;
116 }
117 #endif
118
119
120
121 static PhotonPrimaryIdx buildPrimaries (PhotonMap *pmap, FILE **primaryHeap,
122 char **primaryHeapFname,
123 PhotonPrimaryIdx *primaryOfs,
124 unsigned numHeaps)
125 /* Consolidate per-subprocess photon primary heaps into the primary array
126 * pmap -> primaries. Returns offset for primary index linearisation in
127 * numPrimary. The heap files in primaryHeap are closed on return. */
128 {
129 PhotonPrimaryIdx heapLen;
130 unsigned heap;
131
132 if (!pmap || !primaryHeap || !primaryOfs || !numHeaps)
133 return 0;
134
135 pmap -> numPrimary = 0;
136
137 for (heap = 0; heap < numHeaps; heap++) {
138 primaryOfs [heap] = pmap -> numPrimary;
139
140 if (fseek(primaryHeap [heap], 0, SEEK_END) < 0)
141 error(SYSTEM, "failed photon primary seek in buildPrimaries");
142 pmap -> numPrimary += heapLen = ftell(primaryHeap [heap]) /
143 sizeof(PhotonPrimary);
144
145 pmap -> primaries = realloc(pmap -> primaries,
146 pmap -> numPrimary *
147 sizeof(PhotonPrimary));
148 if (!pmap -> primaries)
149 error(SYSTEM, "failed photon primary alloc in buildPrimaries");
150
151 rewind(primaryHeap [heap]);
152 if (fread(pmap -> primaries + primaryOfs [heap], sizeof(PhotonPrimary),
153 heapLen, primaryHeap [heap]) != heapLen)
154 error(SYSTEM, "failed reading photon primaries in buildPrimaries");
155
156 fclose(primaryHeap [heap]);
157 unlink(primaryHeapFname [heap]);
158 }
159
160 return pmap -> numPrimary;
161 }
162
163
164
165 /* Defs for photon emission counter array passed by sub-processes to parent
166 * via shared memory */
167 typedef unsigned long PhotonContribCnt;
168
169 /* Indices for photon emission counter array: num photons stored and num
170 * emitted per source */
171 #define PHOTONCNT_NUMPHOT 0
172 #define PHOTONCNT_NUMEMIT(n) (1 + n)
173
174
175
176
177
178
179 void distribPhotonContrib (PhotonMap* pm, unsigned numProc)
180 {
181 EmissionMap emap;
182 char errmsg2 [128], shmFname [PMAP_TMPFNLEN];
183 unsigned srcIdx, proc;
184 int shmFile, stat, pid;
185 double *srcFlux, /* Emitted flux per light source */
186 srcDistribTarget; /* Target photon count per source */
187 PhotonContribCnt *photonCnt; /* Photon emission counter array */
188 unsigned photonCntSize = sizeof(PhotonContribCnt) *
189 PHOTONCNT_NUMEMIT(nsources);
190 FILE **primaryHeap = NULL;
191 char **primaryHeapFname = NULL;
192 PhotonPrimaryIdx *primaryOfs = NULL;
193
194 if (!pm)
195 error(USER, "no photon map defined in distribPhotonContrib");
196
197 if (!nsources)
198 error(USER, "no light sources in distribPhotonContrib");
199
200 if (nsources > MAXMODLIST)
201 error(USER, "too many light sources in distribPhotonContrib");
202
203 /* Allocate photon flux per light source; this differs for every
204 * source as all sources contribute the same number of distributed
205 * photons (srcDistribTarget), hence the number of photons emitted per
206 * source does not correlate with its emitted flux. The resulting flux
207 * per photon is therefore adjusted individually for each source. */
208 if (!(srcFlux = calloc(nsources, sizeof(double))))
209 error(SYSTEM, "can't allocate source flux in distribPhotonContrib");
210
211 /* ===================================================================
212 * INITIALISATION - Set up emission and scattering funcs
213 * =================================================================== */
214 emap.samples = NULL;
215 emap.src = NULL;
216 emap.maxPartitions = MAXSPART;
217 emap.partitions = (unsigned char*)malloc(emap.maxPartitions >> 1);
218 if (!emap.partitions)
219 error(USER, "can't allocate source partitions in distribPhotonContrib");
220
221 /* Initialise contrib photon map */
222 initPhotonMap(pm, PMAP_TYPE_CONTRIB);
223 initPhotonHeap(pm);
224 initPhotonEmissionFuncs();
225 initPhotonScatterFuncs();
226
227 /* Per-subprocess / per-source target counts */
228 pm -> distribTarget /= numProc;
229 srcDistribTarget = nsources ? (double)pm -> distribTarget / nsources : 0;
230
231 if (!pm -> distribTarget)
232 error(INTERNAL, "no photons to distribute in distribPhotonContrib");
233
234 /* Get photon ports from modifier list */
235 getPhotonPorts(photonPortList);
236
237 /* Get photon sensor modifiers */
238 getPhotonSensors(photonSensorList);
239
240 #if NIX
241 /* Set up shared mem for photon counters (zeroed by ftruncate) */
242 strcpy(shmFname, PMAP_TMPFNAME);
243 shmFile = mkstemp(shmFname);
244
245 if (shmFile < 0 || ftruncate(shmFile, photonCntSize) < 0)
246 error(SYSTEM, "failed shared mem init in distribPhotonContrib");
247
248 photonCnt = mmap(NULL, photonCntSize, PROT_READ | PROT_WRITE,
249 MAP_SHARED, shmFile, 0);
250
251 if (photonCnt == MAP_FAILED)
252 error(SYSTEM, "failed shared mem mapping in distribPhotonContrib");
253 #else
254 /* Allocate photon counters statically on Windoze */
255 if (!(photonCnt = malloc(photonCntSize)))
256 error(SYSTEM, "failed trivial malloc in distribPhotonContrib");
257
258 for (srcIdx = 0; srcIdx < PHOTONCNT_NUMEMIT(nsources); srcIdx++)
259 photonCnt [srcIdx] = 0;
260 #endif /* NIX */
261
262 if (verbose) {
263 sprintf(errmsg, "\nIntegrating flux from %d sources", nsources);
264
265 if (photonPorts) {
266 sprintf(errmsg2, " via %d ports", numPhotonPorts);
267 strcat(errmsg, errmsg2);
268 }
269
270 strcat(errmsg, "\n");
271 eputs(errmsg);
272 }
273
274 /* =============================================================
275 * FLUX INTEGRATION - Get total flux emitted from sources/ports
276 * ============================================================= */
277 for (srcIdx = 0; srcIdx < nsources; srcIdx++) {
278 unsigned portCnt = 0;
279 srcFlux [srcIdx] = 0;
280 emap.src = source + srcIdx;
281
282 do { /* Need at least one iteration if no ports! */
283 emap.port = emap.src -> sflags & SDISTANT ? photonPorts + portCnt
284 : NULL;
285 photonPartition [emap.src -> so -> otype] (&emap);
286
287 if (verbose) {
288 sprintf(errmsg, "\tIntegrating flux from source %s ",
289 source [srcIdx].so -> oname);
290
291 if (emap.port) {
292 sprintf(errmsg2, "via port %s ",
293 photonPorts [portCnt].so -> oname);
294 strcat(errmsg, errmsg2);
295 }
296
297 sprintf(errmsg2, "(%lu partitions)\n", emap.numPartitions);
298 strcat(errmsg, errmsg2);
299 eputs(errmsg);
300 #if NIX
301 fflush(stderr);
302 #endif
303 }
304
305 for (emap.partitionCnt = 0; emap.partitionCnt < emap.numPartitions;
306 emap.partitionCnt++) {
307 initPhotonEmission(&emap, pdfSamples);
308 srcFlux [srcIdx] += colorAvg(emap.partFlux);
309 }
310
311 portCnt++;
312 } while (portCnt < numPhotonPorts);
313
314 if (srcFlux [srcIdx] < FTINY) {
315 sprintf(errmsg, "source %s has zero emission",
316 source [srcIdx].so -> oname);
317 error(WARNING, errmsg);
318 }
319 }
320
321 /* Allocate & init per-subprocess primary heap files */
322 primaryHeap = calloc(numProc, sizeof(FILE*));
323 primaryHeapFname = calloc(numProc, sizeof(char*));
324 primaryOfs = calloc(numProc, sizeof(PhotonPrimaryIdx));
325 if (!primaryHeap || !primaryHeapFname || !primaryOfs)
326 error(SYSTEM, "failed primary heap allocation in "
327 "distribPhotonContrib");
328
329 for (proc = 0; proc < numProc; proc++) {
330 primaryHeapFname [proc] = malloc(PMAP_TMPFNLEN);
331 if (!primaryHeapFname [proc])
332 error(SYSTEM, "failed primary heap file allocation in "
333 "distribPhotonContrib");
334
335 mktemp(strcpy(primaryHeapFname [proc], PMAP_TMPFNAME));
336 if (!(primaryHeap [proc] = fopen(primaryHeapFname [proc], "w+b")))
337 error(SYSTEM, "failed opening primary heap file in "
338 "distribPhotonContrib");
339 }
340
341 /* Record start time for progress reports */
342 repStartTime = time(NULL);
343
344 if (verbose) {
345 sprintf(errmsg, "\nPhoton distribution @ %d procs\n", numProc);
346 eputs(errmsg);
347 }
348
349 /* MAIN LOOP */
350 for (proc = 0; proc < numProc; proc++) {
351 #if NIX
352 if (!(pid = fork())) {
353 /* SUBPROCESS ENTERS HERE; opened and mmapped files inherited */
354 #else
355 if (1) {
356 /* No subprocess under Windoze */
357 #endif
358 /* Local photon counters for this subprocess */
359 unsigned long lastNumPhotons = 0, localNumEmitted = 0;
360 double photonFluxSum = 0; /* Accum. photon flux */
361
362 /* Seed RNGs from PID for decorellated photon distribution */
363 pmapSeed(randSeed + proc, partState);
364 pmapSeed(randSeed + (proc + 1) % numProc, emitState);
365 pmapSeed(randSeed + (proc + 2) % numProc, cntState);
366 pmapSeed(randSeed + (proc + 3) % numProc, mediumState);
367 pmapSeed(randSeed + (proc + 4) % numProc, scatterState);
368 pmapSeed(randSeed + (proc + 5) % numProc, rouletteState);
369
370 #ifdef PMAP_SIGUSR
371 double partNumEmit;
372 unsigned long partEmitCnt;
373 double srcPhotonFlux, avgPhotonFlux;
374 unsigned portCnt, passCnt, prePassCnt;
375 float srcPreDistrib;
376 double srcNumEmit; /* # to emit from source */
377 unsigned long srcNumDistrib; /* # stored */
378
379 void sigUsrDiags()
380 /* Loop diags via SIGUSR1 */
381 {
382 sprintf(errmsg,
383 "********************* Proc %d Diags *********************\n"
384 "srcIdx = %d (%s)\nportCnt = %d (%s)\npassCnt = %d\n"
385 "srcFlux = %f\nsrcPhotonFlux = %f\navgPhotonFlux = %f\n"
386 "partNumEmit = %f\npartEmitCnt = %lu\n\n",
387 proc, srcIdx, findmaterial(source [srcIdx].so) -> oname,
388 portCnt, photonPorts [portCnt].so -> oname,
389 passCnt, srcFlux [srcIdx], srcPhotonFlux, avgPhotonFlux,
390 partNumEmit, partEmitCnt);
391 eputs(errmsg);
392 fflush(stderr);
393 }
394 #endif
395
396 #ifdef PMAP_SIGUSR
397 signal(SIGUSR1, sigUsrDiags);
398 #endif
399
400 #ifdef DEBUG_PMAP
401 /* Output child process PID after random delay to prevent corrupted
402 * console output due to race condition */
403 usleep(1e6 * pmapRandom(rouletteState));
404 fprintf(stderr, "Proc %d: PID = %d "
405 "(waiting 10 sec to attach debugger...)\n",
406 proc, getpid());
407 /* Allow time for debugger to attach to child process */
408 sleep(10);
409 #endif
410
411 /* =============================================================
412 * 2-PASS PHOTON DISTRIBUTION
413 * Pass 1 (pre): emit fraction of target photon count
414 * Pass 2 (main): based on outcome of pass 1, estimate remaining
415 * number of photons to emit to approximate target
416 * count
417 * ============================================================= */
418 for (srcIdx = 0; srcIdx < nsources; srcIdx++) {
419 #ifndef PMAP_SIGUSR
420 unsigned portCnt, passCnt = 0, prePassCnt = 0;
421 float srcPreDistrib = preDistrib;
422 double srcNumEmit = 0; /* # to emit from source */
423 unsigned long srcNumDistrib = pm -> numPhotons; /* # stored */
424 #else
425 passCnt = prePassCnt = 0;
426 srcPreDistrib = preDistrib;
427 srcNumEmit = 0; /* # to emit from source */
428 srcNumDistrib = pm -> numPhotons; /* # stored */
429 #endif
430
431 if (srcFlux [srcIdx] < FTINY)
432 continue;
433
434 while (passCnt < 2) {
435 if (!passCnt) {
436 /* INIT PASS 1 */
437 if (++prePassCnt > maxPreDistrib) {
438 /* Warn if no photons contributed after sufficient
439 * iterations; only output from subprocess 0 to reduce
440 * console clutter */
441 if (!proc) {
442 sprintf(errmsg,
443 "source %s: too many prepasses, skipped",
444 source [srcIdx].so -> oname);
445 error(WARNING, errmsg);
446 }
447
448 break;
449 }
450
451 /* Num to emit is fraction of target count */
452 srcNumEmit = srcPreDistrib * srcDistribTarget;
453 }
454 else {
455 /* INIT PASS 2 */
456 #ifndef PMAP_SIGUSR
457 double srcPhotonFlux, avgPhotonFlux;
458 #endif
459
460 /* Based on the outcome of the predistribution we can now
461 * figure out how many more photons we have to emit from
462 * the current source to meet the target count,
463 * srcDistribTarget. This value is clamped to 0 in case
464 * the target has already been exceeded in pass 1.
465 * srcNumEmit and srcNumDistrib is the number of photons
466 * emitted and distributed (stored) from the current
467 * source in pass 1, respectively. */
468 srcNumDistrib = pm -> numPhotons - srcNumDistrib;
469 srcNumEmit *= srcNumDistrib
470 ? max(srcDistribTarget/srcNumDistrib, 1) - 1
471 : 0;
472
473 if (!srcNumEmit)
474 /* No photons left to distribute in main pass */
475 break;
476
477 srcPhotonFlux = srcFlux [srcIdx] / srcNumEmit;
478 avgPhotonFlux = photonFluxSum / (srcIdx + 1);
479
480 if (avgPhotonFlux > FTINY &&
481 srcPhotonFlux / avgPhotonFlux < FTINY) {
482 /* Skip source if its photon flux is grossly below the
483 * running average, indicating negligible contributions
484 * at the expense of excessive distribution time; only
485 * output from subproc 0 to reduce console clutter */
486 if (!proc) {
487 sprintf(errmsg,
488 "source %s: itsy bitsy photon flux, skipped",
489 source [srcIdx].so -> oname);
490 error(WARNING, errmsg);
491 }
492
493 srcNumEmit = 0; /* Or just break??? */
494 }
495
496 /* Update sum of photon flux per light source */
497 photonFluxSum += srcPhotonFlux;
498 }
499
500 portCnt = 0;
501 do { /* Need at least one iteration if no ports! */
502 emap.src = source + srcIdx;
503 emap.port = emap.src -> sflags & SDISTANT
504 ? photonPorts + portCnt : NULL;
505 photonPartition [emap.src -> so -> otype] (&emap);
506
507 if (verbose && !proc) {
508 /* Output from subproc 0 only to avoid race condition
509 * on console I/O */
510 if (!passCnt)
511 sprintf(errmsg, "\tPREPASS %d on source %s ",
512 prePassCnt, source [srcIdx].so -> oname);
513 else
514 sprintf(errmsg, "\tMAIN PASS on source %s ",
515 source [srcIdx].so -> oname);
516
517 if (emap.port) {
518 sprintf(errmsg2, "via port %s ",
519 photonPorts [portCnt].so -> oname);
520 strcat(errmsg, errmsg2);
521 }
522
523 sprintf(errmsg2, "(%lu partitions)\n",
524 emap.numPartitions);
525 strcat(errmsg, errmsg2);
526 eputs(errmsg);
527 #if NIX
528 fflush(stderr);
529 #endif
530 }
531
532 for (emap.partitionCnt = 0; emap.partitionCnt < emap.numPartitions;
533 emap.partitionCnt++) {
534 #ifndef PMAP_SIGUSR
535 double partNumEmit;
536 unsigned long partEmitCnt;
537 #endif
538
539 /* Get photon origin within current source partishunn
540 * and build emission map */
541 photonOrigin [emap.src -> so -> otype] (&emap);
542 initPhotonEmission(&emap, pdfSamples);
543
544 /* Number of photons to emit from ziss partishunn;
545 * scale according to its normalised contribushunn to
546 * the emitted source flux */
547 partNumEmit = srcNumEmit * colorAvg(emap.partFlux) /
548 srcFlux [srcIdx];
549 partEmitCnt = (unsigned long)partNumEmit;
550
551 /* Probabilistically account for fractional photons */
552 if (pmapRandom(cntState) < partNumEmit - partEmitCnt)
553 partEmitCnt++;
554
555 /* Update local and shared global emission counter */
556 photonCnt [PHOTONCNT_NUMEMIT(srcIdx)] += partEmitCnt;
557 localNumEmitted += partEmitCnt;
558
559 /* Integer counter avoids FP rounding errors during
560 * iteration */
561 while (partEmitCnt--) {
562 RAY photonRay;
563
564 /* Emit photon according to PDF (if any), allocate
565 * associated primary ray, and trace through scene
566 * until absorbed/leaked; emitPhoton() sets the
567 * emitting light source index in photonRay */
568 emitPhoton(&emap, &photonRay);
569 #if 1
570 if (emap.port)
571 /* !!! PHOTON PORT REJECTION SAMPLING HACK: set
572 * !!! photon port as fake hit object for
573 * !!! primary ray to check for intersection in
574 * !!! tracePhoton() */
575 photonRay.ro = emap.port -> so;
576 #endif
577 newPhotonPrimary(pm, &photonRay, primaryHeap[proc]);
578 /* Set subprocess index in photonRay for post-
579 * distrib primary index linearisation; this is
580 * propagated with the primary index in photonRay
581 * and set for photon hits by newPhoton() */
582 PMAP_SETRAYPROC(&photonRay, proc);
583 tracePhoton(&photonRay);
584 }
585
586 /* Update shared global photon count */
587 photonCnt [PHOTONCNT_NUMPHOT] += pm -> numPhotons -
588 lastNumPhotons;
589 lastNumPhotons = pm -> numPhotons;
590 #if !NIX
591 /* Synchronous progress report on Windoze */
592 if (!proc && photonRepTime > 0 &&
593 time(NULL) >= repLastTime + photonRepTime) {
594 unsigned s;
595 repComplete = pm -> distribTarget * numProc;
596 repProgress = photonCnt [PHOTONCNT_NUMPHOT];
597
598 for (repEmitted = 0, s = 0; s < nsources; s++)
599 repEmitted += photonCnt [PHOTONCNT_NUMEMIT(s)];
600
601 pmapDistribReport();
602 }
603 #endif
604 }
605
606 portCnt++;
607 } while (portCnt < numPhotonPorts);
608
609 if (pm -> numPhotons == srcNumDistrib) {
610 /* Double predistrib factor in case no photons were stored
611 * for this source and redo pass 1 */
612 srcPreDistrib *= 2;
613 }
614 else {
615 /* Now do pass 2 */
616 passCnt++;
617 }
618 }
619 }
620
621 /* Flush heap buffa one final time to prevent data corruption */
622 flushPhotonHeap(pm);
623 /* Flush final photon primary to primary heap file */
624 newPhotonPrimary(pm, NULL, primaryHeap [proc]);
625 /* Heap files closed automatically on exit
626 fclose(pm -> heap);
627 fclose(primaryHeap [proc]); */
628
629 #ifdef DEBUG_PMAP
630 sprintf(errmsg, "Proc %d total %ld photons\n", proc,
631 pm -> numPhotons);
632 eputs(errmsg);
633 fflush(stderr);
634 #endif
635
636 #ifdef PMAP_SIGUSR
637 signal(SIGUSR1, SIG_DFL);
638 #endif
639
640 #if NIX
641 /* Terminate subprocess */
642 exit(0);
643 #endif
644 }
645 else if (pid < 0)
646 error(SYSTEM, "failed to fork subprocess in distribPhotonContrib");
647 }
648
649 #if NIX
650 /* PARENT PROCESS CONTINUES HERE */
651 #ifdef SIGCONT
652 /* Enable progress report signal handler */
653 signal(SIGCONT, pmapDistribReport);
654 #endif
655 /* Wait for subprocesses to complete while reporting progress */
656 proc = numProc;
657 while (proc) {
658 while (waitpid(-1, &stat, WNOHANG) > 0) {
659 /* Subprocess exited; check status */
660 if (!WIFEXITED(stat) || WEXITSTATUS(stat))
661 error(USER, "failed photon distribution");
662
663 --proc;
664 }
665
666 /* Nod off for a bit and update progress */
667 sleep(1);
668
669 /* Asynchronous progress report from shared subprocess counters */
670 repComplete = pm -> distribTarget * numProc;
671 repProgress = photonCnt [PHOTONCNT_NUMPHOT];
672
673 for (repEmitted = 0, srcIdx = 0; srcIdx < nsources; srcIdx++)
674 repEmitted += photonCnt [PHOTONCNT_NUMEMIT(srcIdx)];
675
676 /* Get global photon count from shmem updated by subprocs */
677 pm -> numPhotons = photonCnt [PHOTONCNT_NUMPHOT];
678
679 if (photonRepTime > 0 && time(NULL) >= repLastTime + photonRepTime)
680 pmapDistribReport();
681 #ifdef SIGCONT
682 else signal(SIGCONT, pmapDistribReport);
683 #endif
684 }
685 #endif /* NIX */
686
687 /* ================================================================
688 * POST-DISTRIBUTION - Set photon flux and build kd-tree, etc.
689 * ================================================================ */
690 #ifdef SIGCONT
691 /* Reset signal handler */
692 signal(SIGCONT, SIG_DFL);
693 #endif
694 free(emap.samples);
695
696 if (!pm -> numPhotons)
697 error(USER, "empty contribution photon map");
698
699 /* Load per-subprocess primary rays into pm -> primary array */
700 /* Dumb compilers apparently need the char** cast */
701 pm -> numPrimary = buildPrimaries(pm, primaryHeap,
702 (char**)primaryHeapFname,
703 primaryOfs, numProc);
704 if (!pm -> numPrimary)
705 error(INTERNAL, "no primary rays in contribution photon map");
706
707 /* Set photon flux per source */
708 for (srcIdx = 0; srcIdx < nsources; srcIdx++)
709 srcFlux [srcIdx] /= photonCnt [PHOTONCNT_NUMEMIT(srcIdx)];
710 #if NIX
711 /* Photon counters no longer needed, unmap shared memory */
712 munmap(photonCnt, sizeof(*photonCnt));
713 close(shmFile);
714 unlink(shmFname);
715 #else
716 free(photonCnt);
717 #endif
718
719 if (verbose) {
720 eputs("\nBuilding contribution photon map...\n");
721 #if NIX
722 fflush(stderr);
723 #endif
724 }
725
726 /* Build underlying data structure; heap is destroyed */
727 buildPhotonMap(pm, srcFlux, primaryOfs, numProc);
728
729 /* Free per-subprocess primary heap files */
730 for (proc = 0; proc < numProc; proc++)
731 free(primaryHeapFname [proc]);
732
733 free(primaryHeapFname);
734 free(primaryHeap);
735 free(primaryOfs);
736
737 if (verbose)
738 eputs("\n");
739 }
