root/radiance/ray/src/rt/pmapcontrib.c
Revision: 2.16
Committed: Fri Mar 16 21:00:09 2018 UTC (7 years, 1 month ago) by rschregle
Changes since 2.15: +79 -18 lines
Fixed serious endless predistrib loop bug in distribPhotonContrib(), added
on-demand debugging info via SIGUSR1 from child processes.
2 static const char RCSid[] = "$Id: pmapcontrib.c,v 2.15 2018/02/08 19:55:02 rschregle Exp $";
4
5 /*
6 ======================================================================
7 Photon map for light source contributions
8
9 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
10 (c) Lucerne University of Applied Sciences and Arts,
11 supported by the Swiss National Science Foundation (SNSF, #147053)
12 ======================================================================
13
14 $Id: pmapcontrib.c,v 2.15 2018/02/08 19:55:02 rschregle Exp $
15 */
16
17
18 #include "pmapcontrib.h"
19 #include "pmapmat.h"
20 #include "pmapsrc.h"
21 #include "pmaprand.h"
22 #include "pmapio.h"
23 #include "pmapdiag.h"
24 #include "rcontrib.h"
25 #include "otypes.h"
26 #if NIX
27 #include <sys/mman.h>
28 #include <sys/wait.h>
29 #endif
30
31
32 static PhotonPrimaryIdx newPhotonPrimary (PhotonMap *pmap,
33 const RAY *primRay,
34 FILE *primHeap)
35 /* Add primary ray for emitted photon and save light source index, origin on
36 * source, and emitted direction; used by contrib photons. The current
37 * primary is stored in pmap -> lastPrimary. If the previous primary
38 * contributed photons (has srcIdx >= 0), it's appended to primHeap. If
39 * primRay == NULL, the current primary is still flushed, but no new primary
40 * is set. Returns updated primary counter pmap -> numPrimary. */
41 {
42 if (!pmap || !primHeap)
43 return 0;
44
45 /* Check if last primary ray has spawned photons (srcIdx >= 0, see
46 * newPhoton()), in which case we save it to the primary heap file
47 * before clobbering it */
48 if (pmap -> lastPrimary.srcIdx >= 0) {
49 if (!fwrite(&pmap -> lastPrimary, sizeof(PhotonPrimary), 1, primHeap))
50 error(SYSTEM, "failed writing photon primary in newPhotonPrimary");
51
52 pmap -> numPrimary++;
53 if (pmap -> numPrimary > PMAP_MAXPRIMARY)
54 error(INTERNAL, "photon primary overflow in newPhotonPrimary");
55 }
56
57 /* Mark unused with negative source index until path spawns a photon (see
58 * newPhoton()) */
59 pmap -> lastPrimary.srcIdx = -1;
60
61 if (primRay) {
62 FVECT dvec;
63
64 #ifdef PMAP_PRIMARYDIR
65 /* Reverse incident direction to point to light source */
66 dvec [0] = -primRay -> rdir [0];
67 dvec [1] = -primRay -> rdir [1];
68 dvec [2] = -primRay -> rdir [2];
69 pmap -> lastPrimary.dir = encodedir(dvec);
70 #endif
71 #ifdef PMAP_PRIMARYPOS
72 VCOPY(pmap -> lastPrimary.pos, primRay -> rop);
73 #endif
74 }
75
76 return pmap -> numPrimary;
77 }
78
79
80
81 #ifdef DEBUG_PMAP
82 static int checkPrimaryHeap (FILE *file)
83 /* Check heap for ordered primaries */
84 {
85 Photon p, lastp;
86 int i, dup;
87
88 rewind(file);
89 memset(&lastp, 0, sizeof(lastp));
90
91 while (fread(&p, sizeof(p), 1, file)) {
92 dup = 1;
93
94 for (i = 0; i <= 2; i++) {
95 if (p.pos [i] < thescene.cuorg [i] ||
96 p.pos [i] > thescene.cuorg [i] + thescene.cusize) {
97
98 sprintf(errmsg, "corrupt photon in heap at [%f, %f, %f]\n",
99 p.pos [0], p.pos [1], p.pos [2]);
100 error(WARNING, errmsg);
101 }
102
103 dup &= p.pos [i] == lastp.pos [i];
104 }
105
106 if (dup) {
107 sprintf(errmsg,
108 "consecutive duplicate photon in heap at [%f, %f, %f]\n",
109 p.pos [0], p.pos [1], p.pos [2]);
110 error(WARNING, errmsg);
111 }
112 }
113
114 return 0;
115 }
116 #endif
117
118
119
120 static PhotonPrimaryIdx buildPrimaries (PhotonMap *pmap, FILE **primaryHeap,
121 char **primaryHeapFname,
122 PhotonPrimaryIdx *primaryOfs,
123 unsigned numHeaps)
124 /* Consolidate per-subprocess photon primary heaps into the primary array
125 * pmap -> primaries. Returns offset for primary index linearisation in
126 * numPrimary. The heap files in primaryHeap are closed on return. */
127 {
128 PhotonPrimaryIdx heapLen;
129 unsigned heap;
130
131 if (!pmap || !primaryHeap || !primaryOfs || !numHeaps)
132 return 0;
133
134 pmap -> numPrimary = 0;
135
136 for (heap = 0; heap < numHeaps; heap++) {
137 primaryOfs [heap] = pmap -> numPrimary;
138
139 if (fseek(primaryHeap [heap], 0, SEEK_END) < 0)
140 error(SYSTEM, "failed photon primary seek in buildPrimaries");
141 pmap -> numPrimary += heapLen = ftell(primaryHeap [heap]) /
142 sizeof(PhotonPrimary);
143
144 pmap -> primaries = realloc(pmap -> primaries,
145 pmap -> numPrimary *
146 sizeof(PhotonPrimary));
147 if (!pmap -> primaries)
148 error(SYSTEM, "failed photon primary alloc in buildPrimaries");
149
150 rewind(primaryHeap [heap]);
151 if (fread(pmap -> primaries + primaryOfs [heap], sizeof(PhotonPrimary),
152 heapLen, primaryHeap [heap]) != heapLen)
153 error(SYSTEM, "failed reading photon primaries in buildPrimaries");
154
155 fclose(primaryHeap [heap]);
156 unlink(primaryHeapFname [heap]);
157 }
158
159 return pmap -> numPrimary;
160 }
161
162
163
164 /* Defs for photon emission counter array passed by sub-processes to parent
165 * via shared memory */
166 typedef unsigned long PhotonContribCnt;
167
168 /* Indices for photon emission counter array: num photons stored and num
169 * emitted per source */
170 #define PHOTONCNT_NUMPHOT 0
171 #define PHOTONCNT_NUMEMIT(n) (1 + n)
172
173
174
175
176
177
178 void distribPhotonContrib (PhotonMap* pm, unsigned numProc)
179 {
180 EmissionMap emap;
181 char errmsg2 [128], shmFname [PMAP_TMPFNLEN];
182 unsigned srcIdx, proc;
183 int shmFile, stat, pid;
184 double *srcFlux, /* Emitted flux per light source */
185 srcDistribTarget; /* Target photon count per source */
186 PhotonContribCnt *photonCnt; /* Photon emission counter array */
187 unsigned photonCntSize = sizeof(PhotonContribCnt) *
188 PHOTONCNT_NUMEMIT(nsources);
189 FILE **primaryHeap = NULL;
190 char **primaryHeapFname = NULL;
191 PhotonPrimaryIdx *primaryOfs = NULL;
192
193 if (!pm)
194 error(USER, "no photon map defined in distribPhotonContrib");
195
196 if (!nsources)
197 error(USER, "no light sources in distribPhotonContrib");
198
199 if (nsources > MAXMODLIST)
200 error(USER, "too many light sources in distribPhotonContrib");
201
202 /* Allocate photon flux per light source; this differs for every
203 * source as all sources contribute the same number of distributed
204 * photons (srcDistribTarget), hence the number of photons emitted per
205 * source does not correlate with its emitted flux. The resulting flux
206 * per photon is therefore adjusted individually for each source. */
207 if (!(srcFlux = calloc(nsources, sizeof(double))))
208 error(SYSTEM, "can't allocate source flux in distribPhotonContrib");
209
210 /* ===================================================================
211 * INITIALISATION - Set up emission and scattering funcs
212 * =================================================================== */
213 emap.samples = NULL;
214 emap.src = NULL;
215 emap.maxPartitions = MAXSPART;
216 emap.partitions = (unsigned char*)malloc(emap.maxPartitions >> 1);
217 if (!emap.partitions)
218 error(USER, "can't allocate source partitions in distribPhotonContrib");
219
220 /* Initialise contrib photon map */
221 initPhotonMap(pm, PMAP_TYPE_CONTRIB);
222 initPhotonHeap(pm);
223 initPhotonEmissionFuncs();
224 initPhotonScatterFuncs();
225
226 /* Per-subprocess / per-source target counts */
227 pm -> distribTarget /= numProc;
228 srcDistribTarget = nsources ? (double)pm -> distribTarget / nsources : 0;
229
230 if (!pm -> distribTarget)
231 error(INTERNAL, "no photons to distribute in distribPhotonContrib");
232
233 /* Get photon ports if specified */
234 if (ambincl == 1)
235 getPhotonPorts();
236
237 /* Get photon sensor modifiers */
238 getPhotonSensors(photonSensorList);
239
240 #if NIX
241 /* Set up shared mem for photon counters (zeroed by ftruncate) */
242 strcpy(shmFname, PMAP_TMPFNAME);
243 shmFile = mkstemp(shmFname);
244
245 if (shmFile < 0 || ftruncate(shmFile, photonCntSize) < 0)
246 error(SYSTEM, "failed shared mem init in distribPhotonContrib");
247
248 photonCnt = mmap(NULL, photonCntSize, PROT_READ | PROT_WRITE,
249 MAP_SHARED, shmFile, 0);
250
251 if (photonCnt == MAP_FAILED)
252 error(SYSTEM, "failed shared mem mapping in distribPhotonContrib");
253 #else
254 /* Allocate photon counters statically on Windoze */
255 if (!(photonCnt = malloc(photonCntSize)))
256 error(SYSTEM, "failed trivial malloc in distribPhotonContrib");
257
258 for (srcIdx = 0; srcIdx < PHOTONCNT_NUMEMIT(nsources); srcIdx++)
259 photonCnt [srcIdx] = 0;
260 #endif /* NIX */
261
262 if (verbose) {
263 sprintf(errmsg, "\nIntegrating flux from %d sources", nsources);
264
265 if (photonPorts) {
266 sprintf(errmsg2, " via %d ports", numPhotonPorts);
267 strcat(errmsg, errmsg2);
268 }
269
270 strcat(errmsg, "\n");
271 eputs(errmsg);
272 }
273
274 /* =============================================================
275 * FLUX INTEGRATION - Get total flux emitted from sources/ports
276 * ============================================================= */
277 for (srcIdx = 0; srcIdx < nsources; srcIdx++) {
278 unsigned portCnt = 0;
279 srcFlux [srcIdx] = 0;
280 emap.src = source + srcIdx;
281
282 do { /* Need at least one iteration if no ports! */
283 emap.port = emap.src -> sflags & SDISTANT ? photonPorts + portCnt
284 : NULL;
285 photonPartition [emap.src -> so -> otype] (&emap);
286
287 if (verbose) {
288 sprintf(errmsg, "\tIntegrating flux from source %s ",
289 source [srcIdx].so -> oname);
290
291 if (emap.port) {
292 sprintf(errmsg2, "via port %s ",
293 photonPorts [portCnt].so -> oname);
294 strcat(errmsg, errmsg2);
295 }
296
297 sprintf(errmsg2, "(%lu partitions)\n", emap.numPartitions);
298 strcat(errmsg, errmsg2);
299 eputs(errmsg);
300 #if NIX
301 fflush(stderr);
302 #endif
303 }
304
305 for (emap.partitionCnt = 0; emap.partitionCnt < emap.numPartitions;
306 emap.partitionCnt++) {
307 initPhotonEmission(&emap, pdfSamples);
308 srcFlux [srcIdx] += colorAvg(emap.partFlux);
309 }
310
311 portCnt++;
312 } while (portCnt < numPhotonPorts);
313
314 if (srcFlux [srcIdx] < FTINY) {
315 sprintf(errmsg, "source %s has zero emission",
316 source [srcIdx].so -> oname);
317 error(WARNING, errmsg);
318 }
319 }
320
321 /* Allocate & init per-subprocess primary heap files */
322 primaryHeap = calloc(numProc, sizeof(FILE*));
323 primaryHeapFname = calloc(numProc, sizeof(char*));
324 primaryOfs = calloc(numProc, sizeof(PhotonPrimaryIdx));
325 if (!primaryHeap || !primaryHeapFname || !primaryOfs)
326 error(SYSTEM, "failed primary heap allocation in "
327 "distribPhotonContrib");
328
329 for (proc = 0; proc < numProc; proc++) {
330 primaryHeapFname [proc] = malloc(PMAP_TMPFNLEN);
331 if (!primaryHeapFname [proc])
332 error(SYSTEM, "failed primary heap file allocation in "
333 "distribPhotonContrib");
334
335 mktemp(strcpy(primaryHeapFname [proc], PMAP_TMPFNAME));
336 if (!(primaryHeap [proc] = fopen(primaryHeapFname [proc], "w+b")))
337 error(SYSTEM, "failed opening primary heap file in "
338 "distribPhotonContrib");
339 }
340
341 /* Record start time for progress reports */
342 repStartTime = time(NULL);
343
344 if (verbose) {
345 sprintf(errmsg, "\nPhoton distribution @ %d procs\n", numProc);
346 eputs(errmsg);
347 }
348
349 /* MAIN LOOP */
350 for (proc = 0; proc < numProc; proc++) {
351 #if NIX
352 if (!(pid = fork())) {
353 /* SUBPROCESS ENTERS HERE; opened and mmapped files inherited */
354 #else
355 if (1) {
356 /* No subprocess under Windoze */
357 #endif
358 /* Local photon counters for this subprocess */
359 unsigned long lastNumPhotons = 0, localNumEmitted = 0;
360 double photonFluxSum = 0; /* Accum. photon flux */
361
362 /* Seed RNGs from PID for decorellated photon distribution */
363 pmapSeed(randSeed + proc, partState);
364 pmapSeed(randSeed + (proc + 1) % numProc, emitState);
365 pmapSeed(randSeed + (proc + 2) % numProc, cntState);
366 pmapSeed(randSeed + (proc + 3) % numProc, mediumState);
367 pmapSeed(randSeed + (proc + 4) % numProc, scatterState);
368 pmapSeed(randSeed + (proc + 5) % numProc, rouletteState);
369
370 #ifdef PMAP_SIGUSR
371 double partNumEmit;
372 unsigned long partEmitCnt;
373 double srcPhotonFlux, avgPhotonFlux;
374 unsigned portCnt, passCnt, prePassCnt;
375 float srcPreDistrib;
376 double srcNumEmit; /* # to emit from source */
377 unsigned long srcNumDistrib; /* # stored */
378
379 void sigUsrDiags()
380 /* Loop diags via SIGUSR1 */
381 {
382 sprintf(errmsg,
383 "********************* Proc %d Diags *********************\n"
384 "srcIdx = %d (%s)\nportCnt = %d (%s)\npassCnt = %d\n"
385 "srcFlux = %f\nsrcPhotonFlux = %f\navgPhotonFlux = %f\n"
386 "partNumEmit = %f\npartEmitCnt = %lu\n\n",
387 proc, srcIdx, findmaterial(source [srcIdx].so) -> oname,
388 portCnt, photonPorts [portCnt].so -> oname,
389 passCnt, srcFlux [srcIdx], srcPhotonFlux, avgPhotonFlux,
390 partNumEmit, partEmitCnt);
391 eputs(errmsg);
392 fflush(stderr);
393 }
394 #endif
395
396 #if PMAP_SIGUSR
397 signal(SIGUSR1, sigUsrDiags);
398 #endif
399
400 /* Output child process PID after random delay to prevent corrupted
401 * console output due to race condition */
402 usleep(1e6 * pmapRandom(rouletteState));
403 fprintf(stderr, "Proc %d: PID = %d\n", proc, getpid());
404 /* Allow time for debugger to attach to child process */
405 sleep(10);
406
407 /* =============================================================
408 * 2-PASS PHOTON DISTRIBUTION
409 * Pass 1 (pre): emit fraction of target photon count
410 * Pass 2 (main): based on outcome of pass 1, estimate remaining
411 * number of photons to emit to approximate target
412 * count
413 * ============================================================= */
414 for (srcIdx = 0; srcIdx < nsources; srcIdx++) {
415 #ifndef PMAP_SIGUSR
416 unsigned portCnt, passCnt = 0, prePassCnt = 0;
417 float srcPreDistrib = preDistrib;
418 double srcNumEmit = 0; /* # to emit from source */
419 unsigned long srcNumDistrib = pm -> numPhotons; /* # stored */
420 #else
421 passCnt = prePassCnt = 0;
422 srcPreDistrib = preDistrib;
423 srcNumEmit = 0; /* # to emit from source */
424 srcNumDistrib = pm -> numPhotons; /* # stored */
425 #endif
426
427 if (srcFlux [srcIdx] < FTINY)
428 continue;
429
430 while (passCnt < 2) {
431 if (!passCnt) {
432 /* INIT PASS 1 */
433 if (++prePassCnt > maxPreDistrib) {
434 /* Warn if no photons contributed after sufficient
435 * iterations; only output from subprocess 0 to reduce
436 * console clutter */
437 if (!proc) {
438 sprintf(errmsg,
439 "source %s: too many prepasses, skipped",
440 source [srcIdx].so -> oname);
441 error(WARNING, errmsg);
442 }
443
444 break;
445 }
446
447 /* Num to emit is fraction of target count */
448 srcNumEmit = srcPreDistrib * srcDistribTarget;
449 }
450 else {
451 /* INIT PASS 2 */
452 #ifndef PMAP_SIGUSR
453 double srcPhotonFlux, avgPhotonFlux;
454 #endif
455
456 /* Based on the outcome of the predistribution we can now
457 * figure out how many more photons we have to emit from
458 * the current source to meet the target count,
459 * srcDistribTarget. This value is clamped to 0 in case
460 * the target has already been exceeded in pass 1.
461 * srcNumEmit and srcNumDistrib is the number of photons
462 * emitted and distributed (stored) from the current
463 * source in pass 1, respectively. */
464 srcNumDistrib = pm -> numPhotons - srcNumDistrib;
465 srcNumEmit *= srcNumDistrib
466 ? max(srcDistribTarget/srcNumDistrib, 1) - 1
467 : 0;
468
469 if (!srcNumEmit)
470 /* No photons left to distribute in main pass */
471 break;
472
473 srcPhotonFlux = srcFlux [srcIdx] / srcNumEmit;
474 avgPhotonFlux = photonFluxSum / (srcIdx + 1);
475
476 if (avgPhotonFlux > FTINY &&
477 srcPhotonFlux / avgPhotonFlux < FTINY) {
478 /* Skip source if its photon flux is grossly below the
479 * running average, indicating negligible contributions
480 * at the expense of excessive distribution time; only
481 * output from subproc 0 to reduce console clutter */
482 if (!proc) {
483 sprintf(errmsg,
484 "source %s: itsy bitsy photon flux, skipped",
485 source [srcIdx].so -> oname);
486 error(WARNING, errmsg);
487 }
488
489 srcNumEmit = 0; /* Or just break??? */
490 }
491
492 /* Update sum of photon flux per light source */
493 photonFluxSum += srcPhotonFlux;
494 }
495
496 portCnt = 0;
497 do { /* Need at least one iteration if no ports! */
498 emap.src = source + srcIdx;
499 emap.port = emap.src -> sflags & SDISTANT
500 ? photonPorts + portCnt : NULL;
501 photonPartition [emap.src -> so -> otype] (&emap);
502
503 if (verbose && !proc) {
504 /* Output from subproc 0 only to avoid race condition
505 * on console I/O */
506 if (!passCnt)
507 sprintf(errmsg, "\tPREPASS %d on source %s ",
508 prePassCnt, source [srcIdx].so -> oname);
509 else
510 sprintf(errmsg, "\tMAIN PASS on source %s ",
511 source [srcIdx].so -> oname);
512
513 if (emap.port) {
514 sprintf(errmsg2, "via port %s ",
515 photonPorts [portCnt].so -> oname);
516 strcat(errmsg, errmsg2);
517 }
518
519 sprintf(errmsg2, "(%lu partitions)\n",
520 emap.numPartitions);
521 strcat(errmsg, errmsg2);
522 eputs(errmsg);
523 #if NIX
524 fflush(stderr);
525 #endif
526 }
527
528 for (emap.partitionCnt = 0; emap.partitionCnt < emap.numPartitions;
529 emap.partitionCnt++) {
530 #ifndef PMAP_SIGUSR
531 double partNumEmit;
532 unsigned long partEmitCnt;
533 #endif
534
535 /* Get photon origin within current source partishunn
536 * and build emission map */
537 photonOrigin [emap.src -> so -> otype] (&emap);
538 initPhotonEmission(&emap, pdfSamples);
539
540 /* Number of photons to emit from ziss partishunn;
541 * scale according to its normalised contribushunn to
542 * the emitted source flux */
543 partNumEmit = srcNumEmit * colorAvg(emap.partFlux) /
544 srcFlux [srcIdx];
545 partEmitCnt = (unsigned long)partNumEmit;
546
547 /* Probabilistically account for fractional photons */
548 if (pmapRandom(cntState) < partNumEmit - partEmitCnt)
549 partEmitCnt++;
550
551 /* Update local and shared global emission counter */
552 photonCnt [PHOTONCNT_NUMEMIT(srcIdx)] += partEmitCnt;
553 localNumEmitted += partEmitCnt;
554
555 /* Integer counter avoids FP rounding errors during
556 * iteration */
557 while (partEmitCnt--) {
558 RAY photonRay;
559
560 /* Emit photon according to PDF (if any), allocate
561 * associated primary ray, and trace through scene
562 * until absorbed/leaked; emitPhoton() sets the
563 * emitting light source index in photonRay */
564 emitPhoton(&emap, &photonRay);
565 #if 1
566 if (emap.port)
567 /* !!! PHOTON PORT REJECTION SAMPLING HACK: set
568 * !!! photon port as fake hit object for
569 * !!! primary ray to check for intersection in
570 * !!! tracePhoton() */
571 photonRay.ro = emap.port -> so;
572 #endif
573 newPhotonPrimary(pm, &photonRay, primaryHeap[proc]);
574 /* Set subprocess index in photonRay for post-
575 * distrib primary index linearisation; this is
576 * propagated with the primary index in photonRay
577 * and set for photon hits by newPhoton() */
578 PMAP_SETRAYPROC(&photonRay, proc);
579 tracePhoton(&photonRay);
580 }
581
582 /* Update shared global photon count */
583 photonCnt [PHOTONCNT_NUMPHOT] += pm -> numPhotons -
584 lastNumPhotons;
585 lastNumPhotons = pm -> numPhotons;
586 #if !NIX
587 /* Synchronous progress report on Windoze */
588 if (!proc && photonRepTime > 0 &&
589 time(NULL) >= repLastTime + photonRepTime) {
590 unsigned s;
591 repComplete = pm -> distribTarget * numProc;
592 repProgress = photonCnt [PHOTONCNT_NUMPHOT];
593
594 for (repEmitted = 0, s = 0; s < nsources; s++)
595 repEmitted += photonCnt [PHOTONCNT_NUMEMIT(s)];
596
597 pmapDistribReport();
598 }
599 #endif
600 }
601
602 portCnt++;
603 } while (portCnt < numPhotonPorts);
604
605 if (pm -> numPhotons == srcNumDistrib) {
606 /* Double predistrib factor in case no photons were stored
607 * for this source and redo pass 1 */
608 srcPreDistrib *= 2;
609 }
610 else {
611 /* Now do pass 2 */
612 passCnt++;
613 }
614 }
615 }
616
617 /* Flush heap buffa one final time to prevent data corruption */
618 flushPhotonHeap(pm);
619 /* Flush final photon primary to primary heap file */
620 newPhotonPrimary(pm, NULL, primaryHeap [proc]);
621 /* Heap files closed automatically on exit
622 fclose(pm -> heap);
623 fclose(primaryHeap [proc]); */
624
625 #ifdef DEBUG_PMAP
626 sprintf(errmsg, "Proc %d total %ld photons\n", proc,
627 pm -> numPhotons);
628 eputs(errmsg);
629 fflush(stderr);
630 #endif
631
632 #ifdef PMAP_SIGUSR
633 signal(SIGUSR1, SIG_DFL);
634 #endif
635
636 #if NIX
637 /* Terminate subprocess */
638 exit(0);
639 #endif
640 }
641 else if (pid < 0)
642 error(SYSTEM, "failed to fork subprocess in distribPhotonContrib");
643 }
644
645 #if NIX
646 /* PARENT PROCESS CONTINUES HERE */
647 #ifdef SIGCONT
648 /* Enable progress report signal handler */
649 signal(SIGCONT, pmapDistribReport);
650 #endif
651 /* Wait for subprocesses to complete while reporting progress */
652 proc = numProc;
653 while (proc) {
654 while (waitpid(-1, &stat, WNOHANG) > 0) {
655 /* Subprocess exited; check status */
656 if (!WIFEXITED(stat) || WEXITSTATUS(stat))
657 error(USER, "failed photon distribution");
658
659 --proc;
660 }
661
662 /* Nod off for a bit and update progress */
663 sleep(1);
664
665 /* Asynchronous progress report from shared subprocess counters */
666 repComplete = pm -> distribTarget * numProc;
667 repProgress = photonCnt [PHOTONCNT_NUMPHOT];
668
669 for (repEmitted = 0, srcIdx = 0; srcIdx < nsources; srcIdx++)
670 repEmitted += photonCnt [PHOTONCNT_NUMEMIT(srcIdx)];
671
672 /* Get global photon count from shmem updated by subprocs */
673 pm -> numPhotons = photonCnt [PHOTONCNT_NUMPHOT];
674
675 if (photonRepTime > 0 && time(NULL) >= repLastTime + photonRepTime)
676 pmapDistribReport();
677 #ifdef SIGCONT
678 else signal(SIGCONT, pmapDistribReport);
679 #endif
680 }
681 #endif /* NIX */
682
683 /* ================================================================
684 * POST-DISTRIBUTION - Set photon flux and build kd-tree, etc.
685 * ================================================================ */
686 #ifdef SIGCONT
687 /* Reset signal handler */
688 signal(SIGCONT, SIG_DFL);
689 #endif
690 free(emap.samples);
691
692 if (!pm -> numPhotons)
693 error(USER, "empty contribution photon map");
694
695 /* Load per-subprocess primary rays into pm -> primary array */
696 /* Dumb compilers apparently need the char** cast */
697 pm -> numPrimary = buildPrimaries(pm, primaryHeap,
698 (char**)primaryHeapFname,
699 primaryOfs, numProc);
700 if (!pm -> numPrimary)
701 error(INTERNAL, "no primary rays in contribution photon map");
702
703 /* Set photon flux per source */
704 for (srcIdx = 0; srcIdx < nsources; srcIdx++)
705 srcFlux [srcIdx] /= photonCnt [PHOTONCNT_NUMEMIT(srcIdx)];
706 #if NIX
707 /* Photon counters no longer needed, unmap shared memory */
708 munmap(photonCnt, sizeof(*photonCnt));
709 close(shmFile);
710 unlink(shmFname);
711 #else
712 free(photonCnt);
713 #endif
714
715 if (verbose) {
716 eputs("\nBuilding contribution photon map...\n");
717 #if NIX
718 fflush(stderr);
719 #endif
720 }
721
722 /* Build underlying data structure; heap is destroyed */
723 buildPhotonMap(pm, srcFlux, primaryOfs, numProc);
724
725 /* Free per-subprocess primary heap files */
726 for (proc = 0; proc < numProc; proc++)
727 free(primaryHeapFname [proc]);
728
729 free(primaryHeapFname);
730 free(primaryHeap);
731 free(primaryOfs);
732
733 if (verbose)
734 eputs("\n");
735 }
