--- ray/src/rt/pmapbias.c 2015/05/08 13:20:23 2.2 +++ ray/src/rt/pmapbias.c 2016/05/17 17:39:47 2.5 @@ -1,3 +1,7 @@ +#ifndef lint +static const char RCSid[] = "$Id: pmapbias.c,v 2.5 2016/05/17 17:39:47 rschregle Exp $"; +#endif + /* ================================================================== Bias compensation for photon density estimates @@ -10,7 +14,7 @@ (c) Fraunhofer Institute for Solar Energy Systems ================================================================== - $Id: pmapbias.c,v 2.2 2015/05/08 13:20:23 rschregle Exp $ + $Id: pmapbias.c,v 2.5 2016/05/17 17:39:47 rschregle Exp $ */ @@ -21,7 +25,7 @@ -void squeuePartition (PhotonSQNode* squeue, unsigned lo, +void squeuePartition (PhotonSearchQueueNode* squeue, unsigned lo, unsigned mid, unsigned hi) /* REVERSE Partition squeue such that all photons in squeue-hi+1..squeue-mid are farther than the median at squeue-mid+1, @@ -31,10 +35,9 @@ void squeuePartition (PhotonSQNode* squeue, unsigned l since the queue is initially a maxheap, so reverse sorting is expected to be faster. */ { - unsigned l, h, p; - PhotonSQNode *lp, *hp, *pp; - float pivot, dist; - Photon* photon; + unsigned l, h, p; + PhotonSearchQueueNode *lp, *hp, *pp, tmp; + float pivot; while (hi > lo) { /* Grab pivot node in middle as an educated guess, since our @@ -45,44 +48,47 @@ void squeuePartition (PhotonSQNode* squeue, unsigned l lp = squeue - lo + 1; hp = squeue - hi + 1; pp = squeue - p + 1; - pivot = pp -> dist; + pivot = pp -> dist2; /* l & h converge, swapping elements out of order with respect to pivot node. */ while (l < h) { - while (lp -> dist <= pivot && l <= h && l < hi) + while (lp -> dist2 <= pivot && l <= h && l < hi) ++l, --lp; - while (hp -> dist >= pivot && h >= l && h > lo) + + while (hp -> dist2 >= pivot && h >= l && h > lo) --h, ++hp; if (l < h) { /* Swap */ - photon = lp -> photon; - dist = lp -> dist; - lp -> photon = hp -> photon; - lp -> dist = hp -> dist; - hp -> photon = photon; - hp -> dist = dist; + tmp.idx = lp -> idx; + tmp.dist2 = lp -> dist2; + lp -> idx = hp -> idx; + lp -> dist2 = hp -> dist2; + hp -> idx = tmp.idx; + hp -> dist2 = tmp.dist2; } } /* Swap convergence and pivot node */ if (p > h) { /* Need this otherwise shit happens! - Since lp -> dist > hp -> dist, we swap either l or p depending + Since lp -> dist2 > hp -> dist2, we swap either l or p depending on whether we're above or below p */ h = l; hp = lp; } - photon = hp -> photon; - dist = hp -> dist; - hp -> photon = pp -> photon; - hp -> dist = pivot; - pp -> photon = photon; - pp -> dist = dist; + tmp.idx = hp -> idx; + tmp.dist2 = hp -> dist2; + hp -> idx = pp -> idx; + hp -> dist2 = pivot; + pp -> idx = tmp.idx; + pp -> dist2 = tmp.dist2; + if (h >= mid) hi = h - 1; + if (h <= mid) lo = h + 1; } @@ -95,42 +101,43 @@ void squeuePartition (PhotonSQNode* squeue, unsigned l void biasComp (PhotonMap* pmap, COLOR irrad) /* Photon density estimate with bias compensation -- czech dis shit out! */ { - unsigned i, numLo, numHi, numMid; - PhotonSQNode *sq; - PhotonBCNode *hist; - float r, totalWeight = 0; - PhotonSQNode *squeueEnd; - PhotonBCNode *histEnd; - COLOR fluxLo, fluxMid, irradVar, irradAvg, p, d; + unsigned i, numLo, numHi, numMid; + float r, totalWeight = 0; + COLOR fluxLo, fluxMid, irradVar, irradAvg, p, d; + Photon *photon; + PhotonSearchQueueNode *sqn, *sqEnd; + PhotonBiasCompNode *hist, *histEnd; if (!pmap -> biasCompHist) { /* Allocate bias compensation history */ - numHi = pmap -> maxGather - pmap -> minGather; - for (i = pmap -> minGather + 1; numHi > 1; numHi >>= 1, ++i); - pmap -> biasCompHist = (PhotonBCNode*)malloc(i * sizeof(PhotonBCNode)); + numHi = pmap -> maxGather - pmap -> minGather; + for (i = pmap -> minGather + 1; numHi > 1; numHi >>= 1, ++i); + pmap -> biasCompHist = calloc(i, sizeof(PhotonBiasCompNode)); + if (!pmap -> biasCompHist) error(USER, "can't allocate bias compensation history"); } - numLo = min(pmap -> minGather, pmap -> squeueEnd - 1); - numHi = min(pmap -> maxGather, pmap -> squeueEnd - 1); - sq = squeueEnd = pmap -> squeue + pmap -> squeueEnd - 1; + numLo = min(pmap -> minGather, pmap -> squeue.tail - 1); + numHi = min(pmap -> maxGather, pmap -> squeue.tail - 1); + sqn = sqEnd = pmap -> squeue.node + pmap -> squeue.tail - 1; histEnd = pmap -> biasCompHist; setcolor(fluxLo, 0, 0, 0); /* Partition to get numLo closest photons starting from END of queue */ - squeuePartition(squeueEnd, 1, numLo + 1, numHi); + squeuePartition(sqEnd, 1, numLo + 1, numHi); /* Get irradiance estimates (ignoring 1 / PI) using 1..numLo photons and chuck in history. Queue is traversed BACKWARDS. */ - for (i = 1; i <= numLo; i++, sq--) { - /* Make sure furthest two photons are consecutive wrt distance */ - squeuePartition(squeueEnd, i, i + 1, numLo + 1); - getPhotonFlux(sq -> photon, irrad); + for (i = 1; i <= numLo; i++, sqn--) { + /* Make sure furthest two photons are consecutive w.r.t. distance */ + squeuePartition(sqEnd, i, i + 1, numLo + 1); + photon = getNearestPhoton(&pmap -> squeue, sqn -> idx); + getPhotonFlux(photon, irrad); addcolor(fluxLo, irrad); /* Average radius between furthest two photons to improve accuracy */ - r = 0.25 * (sq -> dist + (sq - 1) -> dist + - 2 * sqrt(sq -> dist * (sq - 1) -> dist)); + r = 0.25 * (sqn -> dist2 + (sqn - 1) -> dist2 + + 2 * sqrt(sqn -> dist2 * (sqn - 1) -> dist2)); /* Add irradiance and weight to history. Weights should increase monotonically based on number of photons used for the estimate. */ histEnd -> irrad [0] = fluxLo [0] / r; @@ -161,21 +168,22 @@ void biasComp (PhotonMap* pmap, COLOR irrad) numMid = (numLo + numHi) >> 1; /* Split interval to get numMid closest photons starting from the END of the queue */ - squeuePartition(squeueEnd, numLo, numMid, numHi); + squeuePartition(sqEnd, numLo, numMid, numHi); /* Make sure furthest two photons are consecutive wrt distance */ - squeuePartition(squeueEnd, numMid, numMid + 1, numHi); + squeuePartition(sqEnd, numMid, numMid + 1, numHi); copycolor(fluxMid, fluxLo); - sq = squeueEnd - numLo; + sqn = sqEnd - numLo; /* Get irradiance for numMid photons (ignoring 1 / PI) */ - for (i = numLo; i < numMid; i++, sq--) { - getPhotonFlux(sq -> photon, irrad); + for (i = numLo; i < numMid; i++, sqn--) { + photon = getNearestPhoton(&pmap -> squeue, sqn -> idx); + getPhotonFlux(photon, irrad); addcolor(fluxMid, irrad); } /* Average radius between furthest two photons to improve accuracy */ - r = 0.25 * (sq -> dist + (sq + 1) -> dist + - 2 * sqrt(sq -> dist * (sq + 1) -> dist)); + r = 0.25 * (sqn -> dist2 + (sqn + 1) -> dist2 + + 2 * sqrt(sqn -> dist2 * (sqn + 1) -> dist2)); /* Get deviation from current average, and probability that it's due to noise from gaussian distribution based on current variance. Since @@ -206,17 +214,18 @@ void biasComp (PhotonMap* pmap, COLOR irrad) irradVar [i] = irradVar [i] / totalWeight - r * r; } - /* Need more photons -- recurse on [numMid, numHi] */ + /* Need more photons --> recurse on [numMid, numHi] */ numLo = numMid; copycolor(fluxLo, fluxMid); } else - /* Deviation is probably bias -- need fewer photons, + /* Deviation is probably bias --> need fewer photons, so recurse on [numLo, numMid] */ numHi = numMid; } --histEnd; + for (i = 0; i <= 2; i++) { /* Estimated relative error */ d [i] = histEnd -> irrad [i] / irradAvg [i] - 1; @@ -232,14 +241,17 @@ void biasComp (PhotonMap* pmap, COLOR irrad) /* Update statistix */ r = colorAvg(d); + pmap -> rmsError += r * r; + if (r < pmap -> minError) pmap -> minError = r; + if (r > pmap -> maxError) pmap -> maxError = r; - pmap -> rmsError += r * r; if (numHi < pmap -> minGathered) pmap -> minGathered = numHi; + if (numHi > pmap -> maxGathered) pmap -> maxGathered = numHi; @@ -249,6 +261,8 @@ void biasComp (PhotonMap* pmap, COLOR irrad) +/* Volume bias compensation disabled (probably redundant) */ +#if 0 void volumeBiasComp (PhotonMap* pmap, const RAY* ray, COLOR irrad) /* Photon volume density estimate with bias compensation -- czech dis shit out! */ @@ -421,4 +435,4 @@ void volumeBiasComp (PhotonMap* pmap, const RAY* ray, pmap -> totalGathered += numMid; ++pmap -> numDensity; } - \ No newline at end of file +#endif
