1 |
2 |
3 |
Bias compensation for photon density estimates |
4 |
5 |
For background see: |
6 |
R. Schregle, "Bias Compensation for Photon Maps", |
7 |
Computer Graphics Forum, v22:n4, pp. 729-742, Dec. 2003. |
8 |
9 |
Roland Schregle (roland.schregle@{hslu.ch, gmail.com}) |
10 |
(c) Fraunhofer Institute for Solar Energy Systems, |
11 |
Lucerne University of Applied Sciences & Arts |
12 |
13 |
14 |
$Id: pmapbias.c,v 4.5 2015/01/29 13:12:35 taschreg Exp taschreg $ |
15 |
16 |
17 |
18 |
19 |
#include "pmapbias.h" |
20 |
#include "pmap.h" |
21 |
#include "pmaprand.h" |
22 |
23 |
24 |
25 |
void squeuePartition (PhotonSQNode* squeue, unsigned lo, |
26 |
unsigned mid, unsigned hi) |
27 |
/* REVERSE Partition squeue such that all photons in |
28 |
squeue-hi+1..squeue-mid are farther than the median at squeue-mid+1, |
29 |
and those in squeue-mid+2..squeue-lo+1 are closer than the median. |
30 |
This means that squeue points to the END of the queue, and the (1-based) |
31 |
indices are offsets relative to it. This convoluted scheme is adopted |
32 |
since the queue is initially a maxheap, so reverse sorting is expected |
33 |
to be faster. */ |
34 |
35 |
unsigned l, h, p; |
36 |
PhotonSQNode *lp, *hp, *pp; |
37 |
float pivot, dist; |
38 |
Photon* photon; |
39 |
40 |
while (hi > lo) { |
41 |
/* Grab pivot node in middle as an educated guess, since our |
42 |
queue is sorta sorted. */ |
43 |
l = lo; |
44 |
h = hi; |
45 |
p = mid; |
46 |
lp = squeue - lo + 1; |
47 |
hp = squeue - hi + 1; |
48 |
pp = squeue - p + 1; |
49 |
pivot = pp -> dist; |
50 |
51 |
/* l & h converge, swapping elements out of order with respect to |
52 |
pivot node. */ |
53 |
while (l < h) { |
54 |
while (lp -> dist <= pivot && l <= h && l < hi) |
55 |
++l, --lp; |
56 |
while (hp -> dist >= pivot && h >= l && h > lo) |
57 |
--h, ++hp; |
58 |
59 |
if (l < h) { |
60 |
/* Swap */ |
61 |
photon = lp -> photon; |
62 |
dist = lp -> dist; |
63 |
lp -> photon = hp -> photon; |
64 |
lp -> dist = hp -> dist; |
65 |
hp -> photon = photon; |
66 |
hp -> dist = dist; |
67 |
68 |
69 |
70 |
/* Swap convergence and pivot node */ |
71 |
if (p > h) { |
72 |
/* Need this otherwise shit happens! |
73 |
Since lp -> dist > hp -> dist, we swap either l or p depending |
74 |
on whether we're above or below p */ |
75 |
h = l; |
76 |
hp = lp; |
77 |
78 |
79 |
80 |
81 |
hp -> photon = pp -> photon; |
82 |
hp -> dist = pivot; |
83 |
pp -> photon = photon; |
84 |
pp -> dist = dist; |
85 |
if (h >= mid) |
86 |
hi = h - 1; |
87 |
if (h <= mid) |
88 |
lo = h + 1; |
89 |
90 |
91 |
/* Once lo & hi have converged, we have found the median! */ |
92 |
93 |
94 |
95 |
96 |
void biasComp (PhotonMap* pmap, COLOR irrad) |
97 |
/* Photon density estimate with bias compensation -- czech dis shit out! */ |
98 |
99 |
unsigned i, numLo, numHi, numMid; |
100 |
PhotonSQNode *sq; |
101 |
PhotonBCNode *hist; |
102 |
float r, totalWeight = 0; |
103 |
PhotonSQNode *squeueEnd; |
104 |
PhotonBCNode *histEnd; |
105 |
COLOR fluxLo, fluxMid, irradVar, irradAvg, p, d; |
106 |
107 |
if (!pmap -> biasCompHist) { |
108 |
/* Allocate bias compensation history */ |
109 |
numHi = pmap -> maxGather - pmap -> minGather; |
110 |
for (i = pmap -> minGather + 1; numHi > 1; numHi >>= 1, ++i); |
111 |
pmap -> biasCompHist = (PhotonBCNode*)malloc(i * sizeof(PhotonBCNode)); |
112 |
if (!pmap -> biasCompHist) |
113 |
error(USER, "can't allocate bias compensation history"); |
114 |
115 |
116 |
numLo = min(pmap -> minGather, pmap -> squeueEnd - 1); |
117 |
numHi = min(pmap -> maxGather, pmap -> squeueEnd - 1); |
118 |
sq = squeueEnd = pmap -> squeue + pmap -> squeueEnd - 1; |
119 |
histEnd = pmap -> biasCompHist; |
120 |
setcolor(fluxLo, 0, 0, 0); |
121 |
122 |
/* Partition to get numLo closest photons starting from END of queue */ |
123 |
squeuePartition(squeueEnd, 1, numLo + 1, numHi); |
124 |
125 |
/* Get irradiance estimates (ignoring 1 / PI) using 1..numLo photons |
126 |
and chuck in history. Queue is traversed BACKWARDS. */ |
127 |
for (i = 1; i <= numLo; i++, sq--) { |
128 |
/* Make sure furthest two photons are consecutive wrt distance */ |
129 |
squeuePartition(squeueEnd, i, i + 1, numLo + 1); |
130 |
getPhotonFlux(sq -> photon, irrad); |
131 |
addcolor(fluxLo, irrad); |
132 |
/* Average radius between furthest two photons to improve accuracy */ |
133 |
r = 0.25 * (sq -> dist + (sq - 1) -> dist + |
134 |
2 * sqrt(sq -> dist * (sq - 1) -> dist)); |
135 |
/* Add irradiance and weight to history. Weights should increase |
136 |
monotonically based on number of photons used for the estimate. */ |
137 |
histEnd -> irrad [0] = fluxLo [0] / r; |
138 |
histEnd -> irrad [1] = fluxLo [1] / r; |
139 |
histEnd -> irrad [2] = fluxLo [2] / r; |
140 |
totalWeight += histEnd++ -> weight = BIASCOMP_WGT((float)i); |
141 |
142 |
143 |
/* Compute expected value (average) and variance of irradiance based on |
144 |
history for numLo photons. */ |
145 |
setcolor(irradAvg, 0, 0, 0); |
146 |
setcolor(irradVar, 0, 0, 0); |
147 |
148 |
for (hist = pmap -> biasCompHist; hist < histEnd; ++hist) |
149 |
for (i = 0; i <= 2; ++i) { |
150 |
irradAvg [i] += r = hist -> weight * hist -> irrad [i]; |
151 |
irradVar [i] += r * hist -> irrad [i]; |
152 |
153 |
154 |
155 |
r = irradAvg [i] /= totalWeight; |
156 |
irradVar [i] = irradVar [i] / totalWeight - r * r; |
157 |
158 |
159 |
/* Do binary search within interval [numLo, numHi]. numLo is towards |
160 |
the END of the queue. */ |
161 |
while (numHi - numLo > 1) { |
162 |
numMid = (numLo + numHi) >> 1; |
163 |
/* Split interval to get numMid closest photons starting from the |
164 |
END of the queue */ |
165 |
squeuePartition(squeueEnd, numLo, numMid, numHi); |
166 |
167 |
squeuePartition(squeueEnd, numMid, numMid + 1, numHi); |
168 |
copycolor(fluxMid, fluxLo); |
169 |
sq = squeueEnd - numLo; |
170 |
171 |
/* Get irradiance for numMid photons (ignoring 1 / PI) */ |
172 |
for (i = numLo; i < numMid; i++, sq--) { |
173 |
174 |
addcolor(fluxMid, irrad); |
175 |
176 |
177 |
178 |
r = 0.25 * (sq -> dist + (sq + 1) -> dist + |
179 |
2 * sqrt(sq -> dist * (sq + 1) -> dist)); |
180 |
181 |
/* Get deviation from current average, and probability that it's due |
182 |
to noise from gaussian distribution based on current variance. Since |
183 |
we are doing this for each colour channel we can also detect |
184 |
chromatic bias. */ |
185 |
186 |
d [i] = irradAvg [i] - (irrad [i] = fluxMid [i] / r); |
187 |
p [i] = exp(-0.5 * d [i] * d [i] / irradVar [i]); |
188 |
189 |
190 |
if (pmapRandom(pmap -> randState) < colorAvg(p)) { |
191 |
/* Deviation is probably noise, so add mid irradiance to history */ |
192 |
copycolor(histEnd -> irrad, irrad); |
193 |
totalWeight += histEnd++ -> weight = BIASCOMP_WGT((float)numMid); |
194 |
195 |
196 |
197 |
/* Update average and variance */ |
198 |
199 |
for (i = 0; i <= 2; i++) { |
200 |
r = hist -> irrad [i]; |
201 |
irradAvg [i] += hist -> weight * r; |
202 |
irradVar [i] += hist -> weight * r * r; |
203 |
204 |
205 |
206 |
207 |
208 |
209 |
210 |
/* Need more photons -- recurse on [numMid, numHi] */ |
211 |
numLo = numMid; |
212 |
copycolor(fluxLo, fluxMid); |
213 |
214 |
else |
215 |
/* Deviation is probably bias -- need fewer photons, |
216 |
so recurse on [numLo, numMid] */ |
217 |
numHi = numMid; |
218 |
219 |
220 |
--histEnd; |
221 |
222 |
/* Estimated relative error */ |
223 |
d [i] = histEnd -> irrad [i] / irradAvg [i] - 1; |
224 |
225 |
#ifdef BIASCOMP_BWIDTH |
226 |
/* Return bandwidth instead of irradiance */ |
227 |
irrad [i] = numHi / PI; |
228 |
#else |
229 |
/* 1 / PI required as ambient normalisation factor */ |
230 |
irrad [i] = histEnd -> irrad [i] / (PI * PI); |
231 |
#endif |
232 |
233 |
234 |
/* Update statistix */ |
235 |
r = colorAvg(d); |
236 |
if (r < pmap -> minError) |
237 |
pmap -> minError = r; |
238 |
if (r > pmap -> maxError) |
239 |
pmap -> maxError = r; |
240 |
pmap -> rmsError += r * r; |
241 |
242 |
if (numHi < pmap -> minGathered) |
243 |
pmap -> minGathered = numHi; |
244 |
if (numHi > pmap -> maxGathered) |
245 |
pmap -> maxGathered = numHi; |
246 |
247 |
pmap -> totalGathered += numHi; |
248 |
++pmap -> numDensity; |
249 |
250 |
251 |
252 |
253 |
void volumeBiasComp (PhotonMap* pmap, const RAY* ray, COLOR irrad) |
254 |
/* Photon volume density estimate with bias compensation -- czech dis |
255 |
shit out! */ |
256 |
257 |
unsigned i, numLo, numHi, numMid = 0; |
258 |
PhotonSQNode *sq; |
259 |
260 |
const float gecc2 = ray -> gecc * ray -> gecc; |
261 |
262 |
263 |
264 |
265 |
266 |
267 |
268 |
269 |
270 |
271 |
272 |
273 |
274 |
275 |
276 |
277 |
278 |
279 |
280 |
281 |
squeuePartition(squeueEnd, 1, numLo, numHi); |
282 |
283 |
/* Get irradiance estimates (ignoring constants) using 1..numLo photons |
284 |
285 |
286 |
287 |
squeuePartition(squeueEnd, i, i + 1, numHi); |
288 |
289 |
/* Compute phase function for inscattering from photon */ |
290 |
if (gecc2 <= FTINY) |
291 |
r = 1; |
292 |
else { |
293 |
r = DOT(ray -> rdir, sq -> photon -> norm) / 127; |
294 |
r = 1 + gecc2 - 2 * ray -> gecc * r; |
295 |
r = (1 - gecc2) / (r * sqrt(r)); |
296 |
297 |
298 |
299 |
scalecolor(irrad, r); |
300 |
301 |
302 |
303 |
304 |
r *= sqrt(r); |
305 |
306 |
307 |
308 |
309 |
310 |
311 |
312 |
313 |
314 |
315 |
316 |
317 |
318 |
319 |
320 |
321 |
322 |
323 |
324 |
325 |
326 |
327 |
328 |
329 |
330 |
331 |
332 |
333 |
334 |
335 |
336 |
337 |
338 |
339 |
340 |
341 |
/* Get irradiance for numMid photons (ignoring constants) */ |
342 |
343 |
344 |
345 |
r = 1; |
346 |
else { |
347 |
348 |
349 |
350 |
351 |
352 |
353 |
354 |
355 |
356 |
357 |
358 |
359 |
360 |
r *= sqrt(r); |
361 |
362 |
363 |
364 |
365 |
366 |
367 |
368 |
369 |
370 |
371 |
372 |
373 |
374 |
375 |
376 |
377 |
378 |
379 |
380 |
381 |
382 |
383 |
384 |
385 |
386 |
387 |
388 |
389 |
390 |
391 |
numLo = numMid; |
392 |
393 |
394 |
else |
395 |
396 |
397 |
numHi = numMid; |
398 |
399 |
400 |
--histEnd; |
401 |
402 |
403 |
404 |
/* Divide by 4 / 3 * PI for search volume (r^3 already accounted |
405 |
for) and phase function normalization factor 1 / (4 * PI) */ |
406 |
irrad [i] = histEnd -> irrad [i] * 3 / (16 * PI * PI); |
407 |
408 |
409 |
410 |
r = colorAvg(d); |
411 |
412 |
413 |
414 |
415 |
416 |
417 |
if (numMid < pmap -> minGathered) |
418 |
pmap -> minGathered = numMid; |
419 |
if (numMid > pmap -> maxGathered) |
420 |
pmap -> maxGathered = numMid; |
421 |
422 |
pmap -> totalGathered += numMid; |
423 |
424 |
425 |
