root/radiance/ray/src/rt/pmapamb.c
Tue May 17 17:39:47 2016 UTC (9 years ago) by rschregle
CVS Tags: HEAD, rad5R1, rad5R2, rad5R3, rad5R4
Changes since 2.7: +4 -2 lines
Tue Sep 1 16:27:52 2015 UTC (9 years, 8 months ago) by greg
Changes since 2.6: +1 -2 lines
Tue Aug 18 18:45:55 2015 UTC (9 years, 9 months ago) by greg
Wed Jul 29 18:54:20 2015 UTC (9 years, 10 months ago) by rschregle
Fixed bug with handling of -am rendering option, removed redundant code
Wed May 27 17:05:13 2015 UTC (10 years ago) by greg
Changes since 2.3: +4 -4 lines
Simplified logic and fixed comment
Wed May 27 16:23:41 2015 UTC (10 years ago) by greg
Added back caustic map contributions to ambient
Fri May 8 13:20:23 2015 UTC (10 years ago) by rschregle
Diff to previous 2.1
Tue Feb 24 19:39:26 2015 UTC (10 years, 3 months ago) by greg
