root/radiance/ray/src/rt/pmap.h
Revision: 2.3
Committed: Fri May 8 13:20:22 2015 UTC (10 years ago) by rschregle
1 /*
2 ==================================================================
3 Photon map main header
4
5 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
6 (c) Fraunhofer Institute for Solar Energy Systems,
7 (c) Lucerne University of Applied Sciences and Arts,
8 supported by the Swiss National Science Foundation (SNSF, #147053)
9 ==================================================================
10
11 $Id: pmap.h,v 2.2 2015/04/21 19:16:51 greg Exp $
12 */
13
14
15 #ifndef PMAP_H
16 #define PMAP_H
17
18 #include "pmapparm.h"
19 #include "pmapdata.h"
20
21
22 #ifndef min
23 #define min(a, b) ((a) < (b) ? (a) : (b))
24 #endif
25
26 #ifndef max
27 #define max(a, b) ((a) > (b) ? (a) : (b))
28 #endif
29
30 #define sqr(a) ((a) * (a))
31
32 /* Average over colour channels */
33 #define colorAvg(col) ((col [0] + col [1] + col [2]) / 3)
34
35 /* Macros to test for enabled photon maps */
36 #define photonMapping (globalPmap || preCompPmap || \
37 causticPmap ||contribPmap)
38 #define causticPhotonMapping (causticPmap)
39 #define directPhotonMapping (directPmap)
40 #define volumePhotonMapping (volumePmap)
41 #define contribPhotonMapping (contribPmap && contribPmap -> srcContrib)
42
43
44
45 extern void (*pmapLookup [])(PhotonMap*, RAY*, COLOR);
46 /* Photon map lookup functions per type */
47
48 void loadPmaps (PhotonMap **pmaps, const PhotonMapParams *params);
49 /* Load photon and set their respective parameters, checking timestamps
50 * relative to octree for possible staleness */
51
52 void savePmaps (const PhotonMap **pmaps, int argc, char **argv);
53 /* Save all defined photon maps with specified command line */
54
55 void cleanUpPmaps (PhotonMap **pmaps);
56 /* Trash all photon maps after processing is complete */
57
58 void distribPhotons (PhotonMap **pmaps);
59 /* Emit photons from light sources and build photon maps for non-NULL
60 * entries in photon map array */
61
62 void tracePhoton (RAY*);
63 /* Follow photon as it bounces around the scene. Analogon to
64 * raytrace(). */
65
66 void photonDensity (PhotonMap*, RAY*, COLOR irrad);
67 /* Perform surface density estimate from incoming photon flux at
68 ray's intersection point. Returns irradiance from found photons. */
69
70 void photonPreCompDensity (PhotonMap *pmap, RAY *r, COLOR irrad);
71 /* Returns precomputed photon density estimate at ray -> rop. */
72
73 void volumePhotonDensity (PhotonMap*, RAY*, COLOR);
74 /* Perform volume density estimate from incoming photon flux at
75 ray's intersection point. Returns irradiance. */
76
77 void colorNorm (COLOR);
78 /* Normalise colour channels to average of 1 */
79
80 #endif
