root/radiance/ray/src/rt/pmap.h
Tue Sep 17 16:36:04 2024 UTC (9 months ago) by greg
Changes since 2.9: +9 -2 lines
chore: Added extern "C" to headers to avoid C++ name mangling
Wed Jan 24 19:39:05 2018 UTC (7 years, 4 months ago) by rschregle
CVS Tags: rad5R2, rad5R3, rad5R4
Changes since 2.8: +6 -5 lines
Hack to render contrib pmap as regular global pmap with rpict/rtrace/rvu
Mon Aug 14 21:12:10 2017 UTC (7 years, 10 months ago) by rschregle
Changes since 2.7: +13 -5 lines
Updated photon map code for Windows; no multproc or ooC for now
Tue May 17 17:39:47 2016 UTC (9 years, 1 month ago) by rschregle
Changes since 2.6: +6 -4 lines
Tue Sep 1 16:27:52 2015 UTC (9 years, 9 months ago) by greg
Changes since 2.5: +1 -2 lines
Tue Aug 18 18:45:55 2015 UTC (9 years, 10 months ago) by greg
Tue May 26 15:58:34 2015 UTC (10 years, 1 month ago) by greg
Changes since 2.3: +5 -5 lines
More macro-management
Fri May 8 13:20:22 2015 UTC (10 years, 1 month ago) by rschregle
Tue Apr 21 19:16:51 2015 UTC (10 years, 2 months ago) by greg
Changes since 2.1: +9 -4 lines
Diff to previous 2.1
Fixes for Windows and photon map
Tue Feb 24 19:39:26 2015 UTC (10 years, 4 months ago) by greg
