root/radiance/ray/src/rt/pmap.c
Revision: 2.4
Committed: Thu Apr 23 20:02:04 2015 UTC (10 years, 2 months ago) by rschregle
Changes since 2.3: +6 -4 lines
Check for stale photon map skipped if octree name not initialised
1 /*
2 ==================================================================
3 Photon map main module
4
5 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
6 (c) Fraunhofer Institute for Solar Energy Systems,
7 (c) Lucerne University of Applied Sciences and Arts,
8 supported by the Swiss National Science Foundation (SNSF, #147053)
9 ==================================================================
10
11 $Id: pmap.c,v 2.3 2015/04/22 20:28:16 rschregle Exp $
12 */
13
14
15
16 #include "pmap.h"
17 #include "pmapmat.h"
18 #include "pmapsrc.h"
19 #include "pmaprand.h"
20 #include "pmapio.h"
21 #include "pmapbias.h"
22 #include "pmapdiag.h"
23 #include "otypes.h"
24 #include <time.h>
25 #include <sys/stat.h>
26
27
28
29 extern char *octname;
30
31 static char PmapRevision [] = "$Revision: 2.3 $";
32
33
34
35 /* Photon map lookup functions per type */
36 void (*pmapLookup [NUM_PMAP_TYPES])(PhotonMap*, RAY*, COLOR) = {
37 photonDensity, photonPreCompDensity, photonDensity, volumePhotonDensity,
38 photonDensity, NULL
39 };
40
41
42
43 void colorNorm (COLOR c)
44 /* Normalise colour channels to average of 1 */
45 {
46 const float avg = colorAvg(c);
47
48 if (!avg)
49 return;
50
51 c [0] /= avg;
52 c [1] /= avg;
53 c [2] /= avg;
54 }
55
56
57
58 void loadPmaps (PhotonMap **pmaps, const PhotonMapParams *parm)
59 {
60 unsigned t;
61 struct stat octstat, pmstat;
62 PhotonMap *pm;
63 PhotonMapType type;
64
65 for (t = 0; t < NUM_PMAP_TYPES; t++)
66 if (setPmapParam(&pm, parm + t)) {
67 /* Check if photon map newer than octree */
68 if (pm -> fileName && octname &&
69 !stat(pm -> fileName, &pmstat) && !stat(octname, &octstat) &&
70 octstat.st_mtime > pmstat.st_mtime) {
71 sprintf(errmsg, "photon map in file %s may be stale",
72 pm -> fileName);
73 error(USER, errmsg);
74 }
75
76 /* Load photon map from file and get its type */
77 if ((type = loadPhotonMap(pm, pm -> fileName)) == PMAP_TYPE_NONE)
78 error(USER, "failed loading photon map");
79
80 /* Assign to appropriate photon map type (deleting previously
81 * loaded photon map of same type if necessary) */
82 if (pmaps [type]) {
83 deletePhotons(pmaps [type]);
84 free(pmaps [type]);
85 }
86 pmaps [type] = pm;
87
88 /* Check for invalid density estimate bandwidth */
89 if (pm -> maxGather > pm -> heapSize) {
90 error(WARNING, "adjusting density estimate bandwidth");
91 pm -> minGather = pm -> maxGather = pm -> heapSize;
92 }
93 }
94 }
95
96
97
98 void savePmaps (const PhotonMap **pmaps, int argc, char **argv)
99 {
100 unsigned t;
101
102 for (t = 0; t < NUM_PMAP_TYPES; t++) {
103 if (pmaps [t])
104 savePhotonMap(pmaps [t], pmaps [t] -> fileName, t, argc, argv);
105 }
106 }
107
108
109
110 void cleanUpPmaps (PhotonMap **pmaps)
111 {
112 unsigned t;
113
114 for (t = 0; t < NUM_PMAP_TYPES; t++) {
115 if (pmaps [t]) {
116 deletePhotons(pmaps [t]);
117 free(pmaps [t]);
118 }
119 }
120 }
121
122
123
124 static int photonParticipate (RAY *ray)
125 /* Trace photon through participating medium. Returns 1 if passed through,
126 or 0 if absorbed and $*%&ed. Analogon to rayparticipate(). */
127 {
128 int i;
129 RREAL cosTheta, cosPhi, du, dv;
130 const float cext = colorAvg(ray -> cext),
131 albedo = colorAvg(ray -> albedo);
132 FVECT u, v;
133 COLOR cvext;
134
135 /* Mean free distance until interaction with medium */
136 ray -> rmax = -log(pmapRandom(mediumState)) / cext;
137
138 while (!localhit(ray, &thescene)) {
139 setcolor(cvext, exp(-ray -> rmax * ray -> cext [0]),
140 exp(-ray -> rmax * ray -> cext [1]),
141 exp(-ray -> rmax * ray -> cext [2]));
142
143 /* Modify ray color and normalise */
144 multcolor(ray -> rcol, cvext);
145 colorNorm(ray -> rcol);
146 VCOPY(ray -> rorg, ray -> rop);
147
148 if (albedo > FTINY)
149 /* Add to volume photon map */
150 if (ray -> rlvl > 0) addPhoton(volumePmap, ray);
151
152 /* Absorbed? */
153 if (pmapRandom(rouletteState) > albedo) return 0;
154
155 /* Colour bleeding without attenuation (?) */
156 multcolor(ray -> rcol, ray -> albedo);
157 scalecolor(ray -> rcol, 1 / albedo);
158
159 /* Scatter photon */
160 cosTheta = ray -> gecc <= FTINY ? 2 * pmapRandom(scatterState) - 1
161 : 1 / (2 * ray -> gecc) *
162 (1 + ray -> gecc * ray -> gecc -
163 (1 - ray -> gecc * ray -> gecc) /
164 (1 - ray -> gecc + 2 * ray -> gecc *
165 pmapRandom(scatterState)));
166
167 cosPhi = cos(2 * PI * pmapRandom(scatterState));
168 du = dv = sqrt(1 - cosTheta * cosTheta); /* sin(theta) */
169 du *= cosPhi;
170 dv *= sqrt(1 - cosPhi * cosPhi); /* sin(phi) */
171
172 /* Get axes u & v perpendicular to photon direction */
173 i = 0;
174 do {
175 v [0] = v [1] = v [2] = 0;
176 v [i++] = 1;
177 fcross(u, v, ray -> rdir);
178 } while (normalize(u) < FTINY);
179 fcross(v, ray -> rdir, u);
180
181 for (i = 0; i < 3; i++)
182 ray -> rdir [i] = du * u [i] + dv * v [i] +
183 cosTheta * ray -> rdir [i];
184 ray -> rlvl++;
185 ray -> rmax = -log(pmapRandom(mediumState)) / cext;
186 }
187
188 setcolor(cvext, exp(-ray -> rot * ray -> cext [0]),
189 exp(-ray -> rot * ray -> cext [1]),
190 exp(-ray -> rot * ray -> cext [2]));
191
192 /* Modify ray color and normalise */
193 multcolor(ray -> rcol, cvext);
194 colorNorm(ray -> rcol);
195
196 /* Passed through medium */
197 return 1;
198 }
199
200
201
202 void tracePhoton (RAY *ray)
203 /* Follow photon as it bounces around... */
204 {
205 long mod;
206 OBJREC* mat;
207
208 if (ray -> rlvl > photonMaxBounce) {
209 error(WARNING, "runaway photon!");
210 return;
211 }
212
213 if (colorAvg(ray -> cext) > FTINY && !photonParticipate(ray))
214 return;
215
216 if (localhit(ray, &thescene)) {
217 mod = ray -> ro -> omod;
218
219 if ((ray -> clipset && inset(ray -> clipset, mod)) || mod == OVOID) {
220 /* Transfer ray if modifier is VOID or clipped within antimatta */
221 RAY tray;
222 photonRay(ray, &tray, PMAP_XFER, NULL);
223 tracePhoton(&tray);
224 }
225 else {
226 /* Scatter for modifier material */
227 mat = objptr(mod);
228 photonScatter [mat -> otype] (mat, ray);
229 }
230 }
231 }
232
233
234
235 static void preComputeGlobal (PhotonMap *pmap)
236 /* Precompute irradiance from global photons for final gathering using
237 the first finalGather * pmap -> heapSize photons in the heap. Returns
238 new heap with precomputed photons. */
239 {
240 unsigned long i, nuHeapSize;
241 unsigned j;
242 Photon *nuHeap, *p;
243 COLOR irrad;
244 RAY ray;
245 float nuMinPos [3], nuMaxPos [3];
246
247 repComplete = nuHeapSize = finalGather * pmap -> heapSize;
248
249 if (photonRepTime) {
250 sprintf(errmsg,
251 "Precomputing irradiance for %ld global photons...\n",
252 nuHeapSize);
253 eputs(errmsg);
254 fflush(stderr);
255 }
256
257 p = nuHeap = (Photon*)malloc(nuHeapSize * sizeof(Photon));
258 if (!nuHeap)
259 error(USER, "can't allocate photon heap");
260
261 for (j = 0; j <= 2; j++) {
262 nuMinPos [j] = FHUGE;
263 nuMaxPos [j] = -FHUGE;
264 }
265
266 /* Record start time, baby */
267 repStartTime = time(NULL);
268 #ifdef SIGCONT
269 signal(SIGCONT, pmapPreCompReport);
270 #endif
271 repProgress = 0;
272 memcpy(nuHeap, pmap -> heap, nuHeapSize * sizeof(Photon));
273
274 for (i = 0, p = nuHeap; i < nuHeapSize; i++, p++) {
275 ray.ro = NULL;
276 VCOPY(ray.rop, p -> pos);
277
278 /* Update min and max positions & set ray normal */
279 for (j = 0; j < 3; j++) {
280 if (p -> pos [j] < nuMinPos [j]) nuMinPos [j] = p -> pos [j];
281 if (p -> pos [j] > nuMaxPos [j]) nuMaxPos [j] = p -> pos [j];
282 ray.ron [j] = p -> norm [j] / 127.0;
283 }
284
285 photonDensity(pmap, &ray, irrad);
286 setPhotonFlux(p, irrad);
287 repProgress++;
288
289 if (photonRepTime > 0 && time(NULL) >= repLastTime + photonRepTime)
290 pmapPreCompReport();
291 #ifdef SIGCONT
292 else signal(SIGCONT, pmapPreCompReport);
293 #endif
294 }
295
296 #ifdef SIGCONT
297 signal(SIGCONT, SIG_DFL);
298 #endif
299
300 /* Replace & rebuild heap */
301 free(pmap -> heap);
302 pmap -> heap = nuHeap;
303 pmap -> heapSize = pmap -> heapEnd = nuHeapSize;
304 VCOPY(pmap -> minPos, nuMinPos);
305 VCOPY(pmap -> maxPos, nuMaxPos);
306
307 if (photonRepTime) {
308 eputs("Rebuilding global photon heap...\n");
309 fflush(stderr);
310 }
311
312 balancePhotons(pmap, NULL);
313 }
314
315
316
317 void distribPhotons (PhotonMap **pmaps)
318 {
319 EmissionMap emap;
320 char errmsg2 [128];
321 unsigned t, srcIdx, passCnt = 0, prePassCnt = 0;
322 double totalFlux = 0;
323 PhotonMap *pm;
324
325 for (t = 0; t < NUM_PMAP_TYPES && !photonMaps [t]; t++);
326 if (t >= NUM_PMAP_TYPES)
327 error(USER, "no photon maps defined");
328
329 if (!nsources)
330 error(USER, "no light sources");
331
332 /* ===================================================================
333 * INITIALISATION - Set up emission and scattering funcs
334 * =================================================================== */
335 emap.samples = NULL;
336 emap.maxPartitions = MAXSPART;
337 emap.partitions = (unsigned char*)malloc(emap.maxPartitions >> 1);
338 if (!emap.partitions)
339 error(INTERNAL, "can't allocate source partitions");
340
341 /* Initialise all defined photon maps */
342 for (t = 0; t < NUM_PMAP_TYPES; t++)
343 initPhotonMap(photonMaps [t], t);
344
345 initPhotonEmissionFuncs();
346 initPhotonScatterFuncs();
347
348 /* Get photon ports if specified */
349 if (ambincl == 1)
350 getPhotonPorts();
351
352 /* Get photon sensor modifiers */
353 getPhotonSensors(photonSensorList);
354
355 /* Seed RNGs for photon distribution */
356 pmapSeed(randSeed, partState);
357 pmapSeed(randSeed, emitState);
358 pmapSeed(randSeed, cntState);
359 pmapSeed(randSeed, mediumState);
360 pmapSeed(randSeed, scatterState);
361 pmapSeed(randSeed, rouletteState);
362
363 if (photonRepTime)
364 eputs("\n");
365
366 /* ===================================================================
367 * FLUX INTEGRATION - Get total photon flux from light sources
368 * =================================================================== */
369 for (srcIdx = 0; srcIdx < nsources; srcIdx++) {
370 unsigned portCnt = 0;
371 emap.src = source + srcIdx;
372
373 do {
374 emap.port = emap.src -> sflags & SDISTANT ? photonPorts + portCnt
375 : NULL;
376 photonPartition [emap.src -> so -> otype] (&emap);
377
378 if (photonRepTime) {
379 sprintf(errmsg, "Integrating flux from source %s ",
380 source [srcIdx].so -> oname);
381
382 if (emap.port) {
383 sprintf(errmsg2, "via port %s ",
384 photonPorts [portCnt].so -> oname);
385 strcat(errmsg, errmsg2);
386 }
387
388 sprintf(errmsg2, "(%lu partitions)...\n", emap.numPartitions);
389 strcat(errmsg, errmsg2);
390 eputs(errmsg);
391 fflush(stderr);
392 }
393
394 for (emap.partitionCnt = 0; emap.partitionCnt < emap.numPartitions;
395 emap.partitionCnt++) {
396 initPhotonEmission(&emap, pdfSamples);
397 totalFlux += colorAvg(emap.partFlux);
398 }
399
400 portCnt++;
401 } while (portCnt < numPhotonPorts);
402 }
403
404 if (totalFlux < FTINY)
405 error(USER, "zero flux from light sources");
406
407 /* Record start time and enable progress report signal handler */
408 repStartTime = time(NULL);
409 #ifdef SIGCONT
410 signal(SIGCONT, pmapDistribReport);
411 #endif
412 repProgress = prePassCnt = 0;
413
414 if (photonRepTime)
415 eputs("\n");
416
417 /* ===================================================================
418 * 2-PASS PHOTON DISTRIBUTION
419 * Pass 1 (pre): emit fraction of target photon count
420 * Pass 2 (main): based on outcome of pass 1, estimate remaining number
421 * of photons to emit to approximate target count
422 * =================================================================== */
423 do {
424 double numEmit;
425
426 if (!passCnt) {
427 /* INIT PASS 1 */
428 /* Skip if no photons contributed after sufficient iterations; make
429 * it clear to user which photon maps are missing so (s)he can
430 * check the scene geometry and materials */
431 if (++prePassCnt > maxPreDistrib) {
432 sprintf(errmsg, "too many prepasses");
433
434 for (t = 0; t < NUM_PMAP_TYPES; t++)
435 if (photonMaps [t] && !photonMaps [t] -> heapEnd) {
436 sprintf(errmsg2, ", no %s photons stored", pmapName [t]);
437 strcat(errmsg, errmsg2);
438 }
439
440 error(USER, errmsg);
441 break;
442 }
443
444 /* Num to emit is fraction of minimum target count */
445 numEmit = FHUGE;
446
447 for (t = 0; t < NUM_PMAP_TYPES; t++)
448 if (photonMaps [t])
449 numEmit = min(photonMaps [t] -> distribTarget, numEmit);
450
451 numEmit *= preDistrib;
452 }
453
454 else {
455 /* INIT PASS 2 */
456 /* Based on the outcome of the predistribution we can now estimate
457 * how many more photons we have to emit for each photon map to
458 * meet its respective target count. This value is clamped to 0 in
459 * case the target has already been exceeded in the pass 1. Note
460 * repProgress is the number of photons emitted thus far, while
461 * heapEnd is the number of photons stored in each photon map. */
462 double maxDistribRatio = 0;
463
464 /* Set the distribution ratio for each map; this indicates how many
465 * photons of each respective type are stored per emitted photon,
466 * and is used as probability for storing a photon by addPhoton().
467 * Since this biases the photon density, addPhoton() promotes the
468 * flux of stored photons to compensate. */
469 for (t = 0; t < NUM_PMAP_TYPES; t++)
470 if ((pm = photonMaps [t])) {
471 pm -> distribRatio = (double)pm -> distribTarget /
472 pm -> heapEnd - 1;
473
474 /* Check if photon map "overflowed", i.e. exceeded its target
475 * count in the prepass; correcting the photon flux via the
476 * distribution ratio is no longer possible, as no more
477 * photons of this type will be stored, so notify the user
478 * rather than deliver incorrect results.
479 * In future we should handle this more intelligently by
480 * using the photonFlux in each photon map to individually
481 * correct the flux after distribution. */
482 if (pm -> distribRatio <= FTINY) {
483 sprintf(errmsg,
484 "%s photon map overflow in prepass, reduce -apD",
485 pmapName [t]);
486 error(INTERNAL, errmsg);
487 }
488
489 maxDistribRatio = max(pm -> distribRatio, maxDistribRatio);
490 }
491
492 /* Normalise distribution ratios and calculate number of photons to
493 * emit in main pass */
494 for (t = 0; t < NUM_PMAP_TYPES; t++)
495 if ((pm = photonMaps [t]))
496 pm -> distribRatio /= maxDistribRatio;
497
498 if ((numEmit = repProgress * maxDistribRatio) < FTINY)
499 /* No photons left to distribute in main pass */
500 break;
501 }
502
503 /* Set completion count for progress report */
504 repComplete = numEmit + repProgress;
505
506 /* PHOTON DISTRIBUTION LOOP */
507 for (srcIdx = 0; srcIdx < nsources; srcIdx++) {
508 unsigned portCnt = 0;
509 emap.src = source + srcIdx;
510
511 do {
512 emap.port = emap.src -> sflags & SDISTANT ? photonPorts + portCnt
513 : NULL;
514 photonPartition [emap.src -> so -> otype] (&emap);
515
516 if (photonRepTime) {
517 if (!passCnt)
518 sprintf(errmsg, "PREPASS %d on source %s ",
519 prePassCnt, source [srcIdx].so -> oname);
520 else
521 sprintf(errmsg, "MAIN PASS on source %s ",
522 source [srcIdx].so -> oname);
523
524 if (emap.port) {
525 sprintf(errmsg2, "via port %s ",
526 photonPorts [portCnt].so -> oname);
527 strcat(errmsg, errmsg2);
528 }
529
530 sprintf(errmsg2, "(%lu partitions)...\n", emap.numPartitions);
531 strcat(errmsg, errmsg2);
532 eputs(errmsg);
533 fflush(stderr);
534 }
535
536 for (emap.partitionCnt = 0; emap.partitionCnt < emap.numPartitions;
537 emap.partitionCnt++) {
538 double partNumEmit;
539 unsigned long partEmitCnt;
540
541 /* Get photon origin within current source partishunn and
542 * build emission map */
543 photonOrigin [emap.src -> so -> otype] (&emap);
544 initPhotonEmission(&emap, pdfSamples);
545
546 /* Number of photons to emit from ziss partishunn --
547 * proportional to flux; photon ray weight and scalar flux
548 * are uniform (the latter only varying in RGB). */
549 partNumEmit = numEmit * colorAvg(emap.partFlux) / totalFlux;
550 partEmitCnt = (unsigned long)partNumEmit;
551
552 /* Probabilistically account for fractional photons */
553 if (pmapRandom(cntState) < partNumEmit - partEmitCnt)
554 partEmitCnt++;
555
556 /* Integer counter avoids FP rounding errors */
557 while (partEmitCnt--) {
558 RAY photonRay;
559
560 /* Emit photon based on PDF and trace through scene until
561 * absorbed/leaked */
562 emitPhoton(&emap, &photonRay);
563 tracePhoton(&photonRay);
564
565 /* Record progress */
566 repProgress++;
567
568 if (photonRepTime > 0 &&
569 time(NULL) >= repLastTime + photonRepTime)
570 pmapDistribReport();
571 #ifdef SIGCONT
572 else signal(SIGCONT, pmapDistribReport);
573 #endif
574 }
575 }
576
577 portCnt++;
578 } while (portCnt < numPhotonPorts);
579 }
580
581 for (t = 0; t < NUM_PMAP_TYPES; t++)
582 if (photonMaps [t] && !photonMaps [t] -> heapEnd) {
583 /* Double preDistrib in case a photon map is empty and redo
584 * pass 1 --> possibility of infinite loop for pathological
585 * scenes (e.g. absorbing materials) */
586 preDistrib *= 2;
587 break;
588 }
589
590 if (t >= NUM_PMAP_TYPES) {
591 /* No empty photon maps found; now do pass 2 */
592 passCnt++;
593 if (photonRepTime)
594 eputs("\n");
595 }
596 } while (passCnt < 2);
597
598 /* ===================================================================
599 * POST-DISTRIBUTION - Set photon flux and build kd-tree, etc.
600 * =================================================================== */
601 #ifdef SIGCONT
602 signal(SIGCONT, SIG_DFL);
603 #endif
604 free(emap.samples);
605
606 /* Set photon flux (repProgress is total num emitted) */
607 totalFlux /= repProgress;
608
609 for (t = 0; t < NUM_PMAP_TYPES; t++)
610 if (photonMaps [t]) {
611 if (photonRepTime) {
612 sprintf(errmsg, "\nBuilding %s photon map...\n", pmapName [t]);
613 eputs(errmsg);
614 fflush(stderr);
615 }
616
617 balancePhotons(photonMaps [t], &totalFlux);
618 }
619
620 /* Precompute photon irradiance if necessary */
621 if (preCompPmap)
622 preComputeGlobal(preCompPmap);
623 }
624
625
626
627 void photonDensity (PhotonMap *pmap, RAY *ray, COLOR irrad)
628 /* Photon density estimate. Returns irradiance at ray -> rop. */
629 {
630 unsigned i;
631 PhotonSQNode *sq;
632 float r;
633 COLOR flux;
634
635 setcolor(irrad, 0, 0, 0);
636
637 if (!pmap -> maxGather)
638 return;
639
640 /* Ignore sources */
641 if (ray -> ro)
642 if (islight(objptr(ray -> ro -> omod) -> otype))
643 return;
644
645 pmap -> squeueEnd = 0;
646 findPhotons(pmap, ray);
647
648 /* Need at least 2 photons */
649 if (pmap -> squeueEnd < 2) {
650 #ifdef PMAP_NONEFOUND
651 sprintf(errmsg, "no photons found on %s at (%.3f, %.3f, %.3f)",
652 ray -> ro ? ray -> ro -> oname : "<null>",
653 ray -> rop [0], ray -> rop [1], ray -> rop [2]);
654 error(WARNING, errmsg);
655 #endif
656
657 return;
658 }
659
660 if (pmap -> minGather == pmap -> maxGather) {
661 /* No bias compensation. Just do a plain vanilla estimate */
662 sq = pmap -> squeue + 1;
663
664 /* Average radius between furthest two photons to improve accuracy */
665 r = max(sq -> dist, (sq + 1) -> dist);
666 r = 0.25 * (pmap -> maxDist + r + 2 * sqrt(pmap -> maxDist * r));
667
668 /* Skip the extra photon */
669 for (i = 1 ; i < pmap -> squeueEnd; i++, sq++) {
670 getPhotonFlux(sq -> photon, flux);
671 #ifdef PMAP_EPANECHNIKOV
672 /* Apply Epanechnikov kernel to photon flux (dists are squared) */
673 scalecolor(flux, 2 * (1 - sq -> dist / r));
674 #endif
675 addcolor(irrad, flux);
676 }
677
678 /* Divide by search area PI * r^2, 1 / PI required as ambient
679 normalisation factor */
680 scalecolor(irrad, 1 / (PI * PI * r));
681
682 return;
683 }
684 else
685 /* Apply bias compensation to density estimate */
686 biasComp(pmap, irrad);
687 }
688
689
690
691 void photonPreCompDensity (PhotonMap *pmap, RAY *r, COLOR irrad)
692 /* Returns precomputed photon density estimate at ray -> rop. */
693 {
694 Photon *p;
695
696 setcolor(irrad, 0, 0, 0);
697
698 /* Ignore sources */
699 if (r -> ro && islight(objptr(r -> ro -> omod) -> otype))
700 return;
701
702 if ((p = find1Photon(preCompPmap, r)))
703 getPhotonFlux(p, irrad);
704 }
705
706
707
708 void volumePhotonDensity (PhotonMap *pmap, RAY *ray, COLOR irrad)
709 /* Photon volume density estimate. Returns irradiance at ray -> rop. */
710 {
711 unsigned i;
712 PhotonSQNode *sq;
713 float gecc2, r, ph;
714 COLOR flux;
715
716 setcolor(irrad, 0, 0, 0);
717
718 if (!pmap -> maxGather)
719 return;
720
721 pmap -> squeueEnd = 0;
722 findPhotons(pmap, ray);
723
724 /* Need at least 2 photons */
725 if (pmap -> squeueEnd < 2)
726 return;
727
728 if (pmap -> minGather == pmap -> maxGather) {
729 /* No bias compensation. Just do a plain vanilla estimate */
730 gecc2 = ray -> gecc * ray -> gecc;
731 sq = pmap -> squeue + 1;
732
733 /* Average radius between furthest two photons to improve accuracy */
734 r = max(sq -> dist, (sq + 1) -> dist);
735 r = 0.25 * (pmap -> maxDist + r + 2 * sqrt(pmap -> maxDist * r));
736
737 /* Skip the extra photon */
738 for (i = 1 ; i < pmap -> squeueEnd; i++, sq++) {
739 /* Compute phase function for inscattering from photon */
740 if (gecc2 <= FTINY)
741 ph = 1;
742 else {
743 ph = DOT(ray -> rdir, sq -> photon -> norm) / 127;
744 ph = 1 + gecc2 - 2 * ray -> gecc * ph;
745 ph = (1 - gecc2) / (ph * sqrt(ph));
746 }
747
748 getPhotonFlux(sq -> photon, flux);
749 scalecolor(flux, ph);
750 addcolor(irrad, flux);
751 }
752
753 /* Divide by search volume 4 / 3 * PI * r^3 and phase function
754 normalization factor 1 / (4 * PI) */
755 scalecolor(irrad, 3 / (16 * PI * PI * r * sqrt(r)));
756
757 return;
758 }
759
760 else
761 /* Apply bias compensation to density estimate */
762 volumeBiasComp(pmap, ray, irrad);
763 }
